Power steering calibration Not working, ESP error in ABS module
sas
Hello people, how are you?
This is my first post and english is not my native language, so i'm open to suggestions and corrections.
Let's start with my car: Its a Volkswagen Up! 2017 and had some (small) damage at the front of the car, replaced components like Bumper and steer-airbag.
The airbag sensor behind the front bumper generated a error code: P160900 (crash activation).
My buddy with VCDS and a HEX-V2 (+ experience) said he can clear the code.. and he did following whis tutorial
[https://www.youtube.com/watch?v=J3IYx--0TK0]
now the power steering works but the car has still this error (under this story)
0360 - Steering angle sensor not calibrated. AND the dashboard shows: ESP braking error (yellow car light goes on)
Ok this can't be that hard to do... so i went to the ABS module and followed the steps like this manual:
[http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1J)_Brake_Electronics_(MK60)#Basic_Setting]
Then VCDS gave a error that the calibrations was not possible to continue
Tried it again with ODIS Software but same story. tried a lot of times with 3 different people and both software but no luck.
But i don't give up! so i went to the interwebs and search.
Some may suggest that the steering angle sensor is broken. i thinks that's not the case because VCDS shows correct values when i rotate the steerwheel.
The airbag module still shows: IDE01555 Number of frontal crashes = 1.
(can this be the case? Someone said that might be the cause of the error but i want to know for sure (and why? Why does the airbag module cause you to not calibrate the steering wheel?)
Also VCDS shows the voltage to the powersteering is a bit low so i tried it with another battery connected but no luck either.
Maybe dissconenct the airbag module? or the ABS module? i'm hoping this could help calibrating the steeringwheel (but idk its a suggestion)
Does someone know a answer? :)
Saturday,02,November,2019,11:18:21:01206
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
Workshop Code: 000 54322 000000
VIN: WVWZZZAAZJD103832   License Plate:
Mileage: 54030km-33572mi   Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 09 15 17 19 25 44 5F 61 AD
VIN: WVWZZZAAZJD103832   Mileage: 54030km-33572miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYA)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 EN    HW: 04C 907 309 P
   Component: R3 1.0l MPI   H24 3171
   Revision: UNH24---
   Coding: 00110014020401000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM10MPI01104C906020EN 002002
   ROD: EV_ECM10MPI_VW12.rod
   VCID: 6B823684E305BB3F0C5-803E
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 L    HW: 1S0 614 517 L
   Component: EBC 460 ESP   H16 0023
   Serial number: A01I02O
   Coding: 12BF247129AD02F3480124F994AA40505FB100
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
   VCID: 3828D9C8E2D3C0A7317-806C
          B1168 54 [137] - Missing Calibration / Basic Setting
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 1S0 937 090 H    HW: 1S0 937 090 H
   Component: BCM PQ25 1MX4 H82 0752
   Revision: BW082001    Serial number: 5000 137170890
   Coding: 62B82B0000010000010007D02CEB8EC07940704C60432D602101000B0900
   VCID: 3828D9C8E253C0A7317-806C
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 110517 04  42  0106
   Coding: 0228DD
   Part No SW: 1S0 959 655 C    HW: 1S0 959 655 C
   Component: VW10Airbag02N H03 0007
   Revision: --------    Serial number: 003UB0021TE4
   Coding: 00000000000000000000000000000000324E
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 3E24CFD0C0F7FE97FBB-806A
   Serial number: 3497ARB405V4OAOEBHOO
   Serial number: 3507ARB404R4OIFUB8QJ
   Serial number: 3557BRB405N4AVKIGQ1C
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 870     HW: 1S0 920 870
   Component: KOMBI         H05 0010
   Revision: X0005001    Serial number: 00000000000000
   Coding: 114A010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 6E843F90D0174E172BB-803A
   Part No SW: 1S0 909 901     HW: 1S0 937 090 H
   Component: GW-K-CAN TP20 H82 0752
   Revision: BW082001
   Coding: 001201
   VCID: 70B821E8CAA358E7397-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 870
   Component: IMMO          H05 0010
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   VCID: 6A8C3380ECFFA237773-803E
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AN    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  313 3150
   Serial number: CH5T0279
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 03527E24EB95537FD45-8056
   Part No SW: 1S0 035 869 B    HW: 1S0 035 869 B
   Component: MU-E-D-EU     068 7288
   Serial number: 15051700021689
   Coding: 022100002800000041111101008002001F0002C40001010001
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 3536D0FCF5C13DCF2A1-8060
   Part No SW: 1S0 907 534     HW: 1S0 937 090 H
   Component: Batt.regelung H82 0752
   Coding: 032B7864
   Subsystem 1 - Part No SW: 1S0 915 181 C    HW: 1S0 915 181 C
   Component: J367-BDM  H08 0270
   Serial number: 64123621585861412708
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H08 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 2808098832735027A17-807C
End----(Elapsed Time: 00:45, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
AIB Wolfgang
Hello
if you're confident alignment is OK, go back to the garage
- open 44 steering assist
- advanced measurement values and check if steering angle is 0.0 degrees (or close to) with the steering wheel centered.
- open 03 abs, login with SA, basic settings, basic setting/zero calibration of steering angle
- see if it completes successfully
- if so, start engine and turn steering wheel from lock to lock a few cycles to learn end stops
- clear DTCs and see if they return
sas
Hello
Thanks for the fast reply,
Sadly I actually tried this already. The Zero calibration of steering angle completes NOT successfully. As what I described in the story. I've tried it with ODIS software as wel. Furthermore thank you for the reply I've you have more suggestions let me hear
sas
The problem was fixed by re-learning the steering angle sensor. Dont know how. a company in Den Haag called CarTronic did it for me
