Hey y'all, figured I'd post up here before I go digging around in the car and trying to replace something that doesn't need replaced.
My car is running fine and doesn't appear to have any outward issues, but I've got a check engine light on and after driving it for about 10-20 miles the transmission position indicator lights all go solid and the cruise control won't work. Pulled the below scan and it's got me all kinds of confused. Wondering if the ECU has decided to take a dump on me or what's going on. Any one run into something like this before? Not sure what else to post description wise because it is running just fine. Any and all advice would be appreciated before I try digging into this to figure out what's up.
The only modification to the car was the addition of some HID headlights several years ago. Other than that it is all stock.
Thanks in advance.
Thanks in advance.
VIN: WVWCU73C17E147814 License Plate: PHILS
Mileage: 354520km-220288mi Repair Order: 11-6-19
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
65 72 76
VIN: WVWCU73C17E147814 Mileage: 354520km-220288miles
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 AD HW: 03H 906 032 AB
Component: P 3.6-FSI-LEV2 G00 0559
Revision: 5GH02--- Serial number: VWZCZ000000000
Coding: 0000075
Shop #: WSC 05311 000 00000
VCID: 64C77FA4A7BF5B6F1D-8030
001072 - Catalyst System; Bank 2
P0430 - 002 - Efficiency Below Threshold - Intermittent
Fault Frequency: 23
Mileage: 343092 km
Date: 2019.07.24
Time: 06:56:31
RPM: 2088 /min
Load: 56.8 %
Speed: 104.0 km/h
Temperature: 86.0°C
Temperature: 46.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.462 V
001056 - Catalyst System; Bank 1
P0420 - 002 - Efficiency Below Threshold - Intermittent
Mileage: 350752 km
Date: 2019.10.07
Time: 07:05:55
RPM: 2103 /min
Load: 38.8 %
Speed: 103.0 km/h
Temperature: 84.0°C
Temperature: -40.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - MIL ON
Fault Status: 11100100
Mileage: 354390 km
Temperature: 60.0°C
Voltage: 11.557 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - MIL ON
Fault Status: 11100010
Mileage: 354390 km
RPM: 155 /min
Load: 100.0 %
Temperature: 60.0°C
Voltage: 9.779 V
P0100 - 002 - Supply Voltage - MIL ON
Mileage: 354390 km
RPM: 240 /min
Load: 65.5 %
Temperature: 60.0°C
Voltage: 10.033 V
012555 - Low Pressure Fuel regulation
P310B - 004 - Fuel Pressure Outside Specification - Intermittent
Mileage: 354398 km
Date: 2019.11.04
Time: 04:16:21
RPM: 2104 /min
Load: 37.2 %
Speed: 104.0 km/h
Temperature: 84.0°C
Voltage: 14.224 V
Part No SW: 09G 927 750 FR HW: 09G 927 750 FR
Component: AQ 250 6F 0932
Revision: 00H38000 Serial number:
Coding: 0000072
VCID: 0603452C71C3C97FA3-8052
013 - Check DTC Memory
Fault Status: 00101101
Reset counter: 201
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 A HW: 3C0 614 109 A
Component: ESP 440 C4 H018 0001
Revision: H018 Serial number: 0668287678
Coding: 0046541
VCID: 1C370744DF4F23AF65-8048
Fault Status: 01101101
Reset counter: 75
Mileage: 354390 km
Date: 2019.11.03
Time: 19:46:15
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 67DD68A85689307738-8032
Fault Frequency: 238
Reset counter: 118
Mileage: 347924 km
Date: 2019.09.08
Time: 06:45:21
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006446544
Coding: ED849F1340041A00550000640F00000000195D45000001
Shop #: WSC 05311 123 12345
VCID: 6CD717844F6F132F55-8038
Subsystem 1 - Part No: 3C1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 151206 022 0601
Coding: 00046997
Shop #: WSC 05311
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 141206 020 0105
Coding: 00208933
Shop #: WSC 05311
Fault Status: 00111010
Reset counter: 111
Mileage: 354116 km
Date: 2019.11.01
Time: 16:05:00
Voltage: 13.80 V
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 78
Mileage: 338004 km
Date: 2019.05.20
Time: 18:50:00
Voltage: 11.75 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0031411
VCID: 2E53DD8CB9F3A13F3B-807A
Reset counter: 248
Mileage: 349692 km
Date: 2019.09.24
Time: 17:36:44
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 18 AIRBAG VW8R 031 2522
Revision: 12031000 Serial number: 003B2PQW8P03
Coding: 0012600
VCID: 3169C6F0A8CDBEC726-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003EAUB
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME153B205B9ÿ†63
Subsystem 5 - Serial number: B205B9ÿ†6342MSME15514611$ÿ†63
Subsystem 6 - Serial number: 14611$ÿ†6351HTS62AD0TJE6Gÿ†63
Subsystem 7 - Serial number: 0TJE6Gÿ†6361HTS6GIE4M527Cÿ†63
Subsystem 8 - Serial number: 4M527Cÿ†63727TS67SDA27D2+ÿ†63
Subsystem 9 - Serial number: A27D2+ÿ†63827TS67SDAAL43Dÿ
Subsystem 10 - Serial number: AAL43Dÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 K HW: 3C0 953 549 K
Component: J0527 0015
Revision: 00006000 Serial number: 3C5953507AE
Coding: 0002211
VCID: 3467CFE457DF8BEF4D-8060
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0007000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 07434 444 54071
VCID: 23453CB8E2311C57A4-8076
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06C06012C
Coding: 3FFD1F04D31002
VCID: 214936B0F82D0E47B6-8074
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TQ6LP04
VCID: 6DD11A8074751A2742-8038
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
VCID: 73E50CF81251CCD794-8026
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
VCID: 2D51DA80B4F5DA2702-8078
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1131
Revision: 31008001 Serial number: 00000065869210
Coding: 0001463
VCID: 3C77E7C47F8F43AF85-8068
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.136 H07 1806
Shop #: WSC 02069 000 90108
Component: KSG PQ46 RDK 051 0219
Coding: 1B910F8001864E767402141FF08A8F0E085800
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1131
Revision: 31008001 Serial number: 00000039569206
Coding: 0001462
VCID: 3D71EAC064954AA7B2-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 E HW: 3C0 907 801 E
Component: EPB VC8HC003 013 0003
Revision: 013
Coding: 0000013
VCID: 24473FA4E73F1B6FDD-8070
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 017 0023
Revision: 00017000 Serial number: VWZ5Z7F2121070
Coding: 0040402
Shop #: WSC 05314 000 00000
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1118
Revision: 12006001 Serial number: 00000001040309
Coding: 0001168
VCID: 3E73EDCC699351BFAB-806A
Component: RDK 0440
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1118
Revision: 12005001 Serial number: 00000000973918
Coding: 0001168
VCID: 3F8D90C86E9958B7A0-806A
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 B HW: 3C0 919 283 B
Component: Parkhilfe 8-Kan 004 0011
Revision: 00004000 Serial number: 82930634800135
Coding: 0001114
Shop #: WSC 05311 000 08193
VCID: 285F2B949B17FF0FF1-807C
End-------------------------(Elapsed Time: 02:30)--------------------------
