Hello, here is the Auto-Scan of my new car.
I had problem with activating Traffic sign recognition, everything went well but there are no signs appearing on the active info display.
Also, I had normal lane assist factory activated, but then I activated in adaptations option to select via menu ( that activates lane assist guidance)
but everything seems like before because it does not centre the vehicle in the middle of the road, but at least steering wheel is not vibrating.
Also, there is a sign of a car with a little sand-clock that seems to deactivate after some speed every time, but before coding, there wasn't any sign.
Managed to change the look of AID with tube variations in 17-Instruments Adaptation, does anyone know any other way to put bubbles in AID, it is not working like on VW Golf where you change Display Depiction option.
Cheers.
Wednesday,06,November,2019,09:19:10:60999
VIN: WVGZZZC1ZLY023566 License Plate: RI353H
Mileage: 1561km-969mi Repair Order:
Chassis Type: C1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 44 55 5F 75 A5 D6 D7
VIN: WVGZZZC1ZLY023566 Mileage: 1561km-969miles
Address 01: Engine (J623-DGTD) Labels: None
Part No SW: 04L 906 056 TT HW: 04L 907 445 F
Component: R4 1.6l TDI H01 6938
Revision: 22101001
Coding: 0125403243641D091000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI03004L906056TT 004001
ROD: EV_ECM16TDI03004L906056ML_VW27.rod
VCID: 127C417744E165E76F3-8046
Readiness: N/A
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 043 F HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1602
Revision: 00005008 Serial number: CU501908145268
ROD: EV_TCMDQ200021_VW27.rod
VCID: 3A2CC9D73CD17DA7C73-806E
Part No SW: 2Q0 614 517 AF HW: 2Q0 614 517 M
Component: ESC_high_vFGS H34 0342
Serial number: 08501677190806
Coding: 9205533E3D4349B0CA01BC1C12E011A649265146446A2448485452554548886592648A6222562412122A4AAAA269C64FFD9663F2BF
ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
ROD: EV_Brake1BOSCHESPMQBA0.rod
VCID: 72BC21F72421C5E7CF3-8026
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0524948027
Coding: 132C0C0723
ROD: EV_KessyHellaMQBAB_VW27.rod
VCID: 45D6AA2B452F025FBA1-8010
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 2G0 907 044 Q HW: 2G0 907 044 Q
Component: Climatronic H05 0701
Coding: 612010000802010001100800524401150100000000000000000000000000
ASAM Dataset: EV_ACClimaBHBMQBA0 004023
ROD: EV_ACClimaBHBMQBA0_VW27.rod
VCID: 323CE1F7E4A185E70F3-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q0 937 090 B HW: 2Q0 937 090
Component: BCM A0 Std+ H10 0934
Serial number: 01101923200214
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205_VW27.rod
VCID: 313EEEFBE1A7BEFF769-8064
Drivers Door Control Module:
Subsystem 1 - Part No SW: 2Q2 959 405 HW: 2Q2 959 163
Component: FHSG_DRV 002 0005
Serial number: 00000000000030763704
Coding: 0300F0
Subsystem 2 - Part No SW: 2Q2 959 406 HW: 2Q2 959 164
Component: FHSG_PSG 002 0005
Serial number: 00000000000030708932
Coding: 1900F0
Subsystem 3 - Part No SW: 5Q0 907 658 HW: 5Q0 907 658
Component: HS 003 0002
Serial number: S4Y19M07D12H17M08S15
Subsystem 4 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000033084771
Coding: 030000
Subsystem 5 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000033387805
Coding: 1B0000
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058319241
Coding: 0471155851
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 50F88B7F8A6DD7F7197-8004
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3204670208FF8748949C810580508700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D2B4334B1B3C6F945-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AM HW: 2Q0 959 655 AM
Component: VW22Airbag 012 0351
Revision: --------
Coding: 88CCC0C0000000005C5400CF000C40A80065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001020
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 0848631F32BDDF37817-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 654 980 945 HW: 654 980 945
Component: BeltPretRevFL 004 0051
Serial number: 278A-001603091900230
Coding: 303531
Belt Pretensioner right:
Subsystem 2 - Part No SW: 654 980 946 HW: 654 980 946
Component: BeltPretRevFR 004 0051
Serial number: 278A-001702091900017
Coding: 303531
Subsystem 3 - Part No SW: ----------- HW: 442 062 108 19
Serial number: 3577Y50C731F1E91C42D
Subsystem 4 - Part No SW: ----------- HW: 442 062 108 19
Serial number: 3587Y50C731F1E9200EB
Subsystem 5 - Part No SW: ----------- HW: 442 0B2 808 19
Serial number: 35177829D33B285452DP
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 808 19
Serial number: 35277829D328BA04D1BX
Subsystem 7 - Part No SW: ----------- HW: 442 132 308 19
Component: FrontSensor_D 290 118A
Serial number: 355AG11A130CACA1A2C
Part No SW: 2G0 920 790 B HW: 2G0 920 790 B
Component: KOMBI 502 4187
Coding: 04A410186D8800080188220B5000000800000404
ASAM Dataset: EV_DashBoardVDDMQBA0 001041
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 26140DA7D869E94793B-8072
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000030054
Coding: 030100044F0873002310025C180F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 70B82BFF2A2DF7F7397-8024
Component: 4-01-02-01-04
Subsystem 2 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440036204191684
Coding: 2C1D00
Subsystem 3 - Part No SW: 2Q0 915 181 HW: 2Q0 915 181
Component: J367-BDMBOSCH H02 2011
Serial number: 1016A20D
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000233117007
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 A HW: 2Q0 907 686 A
Component: HRE3_Kl15_Mst H05 0052
Serial number: 00000524520597
Coding: 50014500
ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
ROD: EV_HREntryHellaGen3Kl15_001_VW48.rod
VCID: 3828D3DF02DD6FB7317-806C
Address 44: Steering Assist (J792) Labels:* None
Part No SW: 2Q1 909 144 M HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 611 6041
Serial number: 01J7A0RJCB4K242
Coding: 010000010100000001010201010001000000010101
ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
ROD: EV_SteerAssisTRWG4LMQBA0.rod
VCID: 3C20CFCF36E54397D5F-8068
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 0688000001200003
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DEBE3B51072E7F869-8014
Part No SW: 2GM 035 840 HW: 2GM 035 840
Component: MU-S--ER 724 0873
Coding: 02120600BE0000004111000100080A001F0500F40120000002
Shop #: WSC 40072 001 1048576
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 7AAC09D77C51BDA7873-802E
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H61 8214
Serial number: VWZ6ZJW2420025
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: --------
Coding: 022106016A16140D0100040000354003804600
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: 3D26C2CB2DFF4A9FE21-8068
Part No SW: 3Q0 980 654 R HW: 3Q0 980 654 A
Component: MQB_B_MFK H11 0460
Serial number: 13081915K15231
Coding: 0002070600000401002200148156440084000E20000000
ROD: EV_MFKBoschMQBB_002_VW27.rod
VCID: 46D4AD2778290947B3B-8012
Part No SW: 992 941 571 AC HW: 992 941 571 A
Component: LED1L H08 9201
ROD: EV_LLPGen3LKEBODPO68X.rod
VCID: 639254B3EBDB5C6FB45-8036
Component: LED1R H08 9201
End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.1V)-----------
Cheers.
