Lost cruise control after new key was coded P1647
Diagnose Specialisten
Denmark
C?ID=379879
Hello.
This is my first post. I'm from Denmark and work as an independant technician and problemsolver for auto workshops. I have worked with VCDS for 13 years. But now I have a problem I can't solve myself.
The car is a 2013 Golf 7 which after dealer coded new key lost function of the cruise control. Not long ago, a thread with exactly the same problem was created in this forum, but there are no solution yet as I see it.
I have genuine ODIS, and have tried to recode all the modules to their original coding with SWM. That mysteriously did not solve the problem. I have in collaboration with Niels, tried to experiment a bit with the coding in 01 and 19 but with no luck. The only thing that is not working by now is the cruise control. The customer insists that the problem was not there before the new key was coded. The dealer denies that it have anything to do with the new key they have added, but have offered to start a diagnostics session if he agrees to pay all the cost and the labour, which he of course knows will be expensive. So his regular workshop called me when they could not solve the problem themselves.
The codes I have tried:
01: 01190012232415082000
19: 030000042B086400EF000248080E00010001000000000000000000000000
No luck.
If I code 01 to have NO cruise control, the faultcode can be deleted.
The cruise control are NOT retrofitted.
There exsits no autoscan from before the key was coded.
Any suggestions?
All inputs will be appreciated!
Thanks, Jimmy
Wednesday,06,November,2019,09:21:34:29794
Dealer/Shop Name: Diagnose Specialisten ApS
VIN: WVWZZZAUZEW060422   License Plate: AJ27576
Mileage: 84885km-52745mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW060422   Mileage: 84885km-52745miles
Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 H    HW: 04E 907 309 A
   Component: R4 1.2l TFS   H08 9020
   Revision: WAH08---
   Coding: 01190012242415082000
   ASAM Dataset: EV_ECM12TFS01104E906016H 001009
   ROD: EV_ECM12TFS01104E906016H.rod
   VCID: 270BFB58AF6A521FA8D-8072
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [038] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 84885 km
                    Date: 2019.11.06
                    Time: 01:07:43
                    Engine speed: 0.00 /min
                    Coolant temperature: 55 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.015 V
                    Mass flow through throttle valve: 0.0 kg/h
                    Median injection timing: 0.000 ms
                    Engine operating condition: Idling
Readiness: 1110 0001
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 61763000000634
   Coding: 01FA6AA12426296C037B060241C52580562494C06082A4F300200068C002
   Shop #: WSC 50664 003 1048576
   VCID: 074B9BD84FAA721F88D-8052
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 00020004200100011005000000101000
   VCID: 6695B65C68E08B1753B-8032
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011318701694
   Coding: 00040846C24100D34BE44000001C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77ABEB183F4A029FF8D-8022
   Component: WWS    130630  042 0551
   Serial number:         130702062205
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 20425444
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R03YGK/
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4ACD62EC1C384F77573-801E
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169667B08071370922
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169668B08071350686
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 806 13
   Serial number: 35767000000C337DFC07
   Subsystem 4 - Part No SW: -----------    HW: 480 002 806 13
   Serial number: 358670000002E65DFC0A
   Subsystem 5 - Part No SW: -----------    HW: 480 402 106 13
   Serial number: 3516502C910CBDD6016K
   Subsystem 6 - Part No SW: -----------    HW: 480 402 906 13
   Serial number: 3526502C110CBDD370FP
   Subsystem 7 - Part No SW: -----------    HW: 480 402 706 13
   Serial number: 3556502A1106FA20F1FG
   Part No SW: 5Q0 953 507 AM    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 02071304220024
   Coding: 1604
   VCID: 015F85C0618E4C2FC69-8054
   Part No SW: 5G0 920 851     HW: 5G0 920 851
   Component: KOMBI         104 3380
   Coding: 07A402002300000800080800040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 6597B15095E6800F5A1-8030
   Part No SW: 5Q0 907 530 K    HW: 5Q0 907 530 D
   Component: GW MQB Low    123 1144
   Revision: --------    Serial number: 0000749523
   Coding: 030000342B086400EF00024C080E00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 392F2D2049DED4EFCE9-806C
   Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 2489810803
   Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
   Component: TSG FS        012 0006
   Serial number: 22061301100273
   Coding: 003003208000048000001000
   VCID: 3D2739305DF6E8CFE21-8068
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001956288
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 01
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
   Component: TSG BFS       012 0006
   Serial number: 23061302091512
   Coding: 003001208000048000801000
   VCID: 3C21343446ECE1C7D5F-8068
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001865671
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT1.clb
   Part No SW: 5G0 035 867     HW: 5G0 035 867
   Component: MU-E--ER      636 5675
   Serial number: 04061300010047
   Coding: 02730000FF0000004011000100000000000000040000010000
   ASAM Dataset: EV_MUEnt4CLGE 001025
   ROD: EV_MUEnt4CLGE_VW37.rod
   VCID: 698FBD6079FEA46F7E9-803C
End----------(Elapsed Time: 00:57, VBatt start/end: 12.3V/13.2V)-----------
nirvananils
C?ID=289109
You have to go to dealer to restore FEC codes in Car, actually VAG is a little bit stupid because some Blackbox are sold in china. A few months ago FEC restored automatically if you do guided functions. But actually you have to restore them manually after do this jobs.
golfi_vend
Tartu, Estonia
C?ID=195131
Because matching keys also creates new CP for Cluster and BCM. This is why this happens.
https://forums.ross-tech.com/showth...I-dealership-coded-extra-key-and-modules-lost
EDIT: I saw You had genuine ODIS.
For everything to work to spec I'd suggest doing following:
1) CP Basic setting. It will rewrite all CP-s. This is just in case to get fresh start.
2) Do Software Configuration. This option can be found in Special Options tab. Manually select module 19(Gateway). This will restore dataset. Seen issues with this after such jobs.
3) Restore FEC. This option is also in Specia Options tab. Restore them in 19 and 5F.
