Hi This is my first time posting so bear with me. The original problem is my battery goes flat within 2 days. I have measured the battery current draw when the car is off and locked. After 2-3 minutes the current decreases from 2A to 1A then momentarily goes to .07A and then back up to 2A again and repeats this cycle over and over. I have recently replaced the passenger door lock actuator. When I ran a new scan I noticed a lot of malfunctions and reference to a convertible top( the car is a sedan). I'm thinking I need to get these faults cleared so the car actually go to sleep and stays asleep and thus will solve my battery drain problem. I'm looking for help on how to resolve these malfunctions. I'm also wondering how my car thinks its a convertible and could that be the reason for many of the malfunctions?
Thanks for all your help!
Kevin
Kevin
Wednesday,06,November,2019,16:11:31:14386
VCDS Version: 19.6.2.0
VIN: 3VWDT71K06M019877 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 26 36 42 44 46 47 52 56
62 65 72 77 7D
VIN: 3VWDT71K06M019877 Mileage: 393410km-244453miles
26-Auto Roof -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Not registered 0011
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F4158729
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64C7F4B6A7638D6F23-8030
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000605271085
VCID: 51A92D62C8D108C778-8004
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73E587EA128D1AD7AA-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BJ HW: 1K0 907 044 BJ
Component: ClimatronicPQ35 090 0909
Revision: 00090016 Serial number: 00000000000000
VCID: 70EF88E6639B21CF57-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000415162
Coding: 94018E034004150007140000001400000029770B5C0000
Shop #: WSC 00066 123 12345
VCID: 377D73FA4675B6F756-8062
Component: Wischer 230102 020 0501
Coding: 00038805
Shop #: WSC 00066
01335 - Drivers Seat/Mirror Position Control Module (J543)
Reset counter: 214
Voltage: 12.25 V
00830 - Convertible Top Control Module (J256)
Reset counter: 178
Mileage: 393199 km
Voltage: 12.20 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7F2030889
VCID: 2A5B5A8E85C71B1FD9-807E
Reset counter: 171
Mileage: 393199 km
Time: 19:00:25
Part No SW: 1K0 909 605 Q HW: 1K0 909 605 Q
Component: 6A AIRBAG VW8R 033 7900
Revision: 04033000 Serial number: 0038LD09CSJR
Coding: 0013889
VCID: 3A7B6ACE7567AB9FA9-806E
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 633 SME
Subsystem 3 - Serial number: 6342MSME0D3E10306
Subsystem 4 - Serial number: 6351HSME0A1E4948H
Subsystem 5 - Serial number: 6361HSME0A13653EA
Subsystem 6 - Serial number: 63727SME0A30080C-
Subsystem 7 - Serial number: 63827SME0A380437$
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Part No SW: 1K0 953 549 AS HW: 1K0 953 549 AS
Component: J0527 035 0070
Coding: 0012021
VCID: 0305D72A422D2A57BA-8056
Component: E0221 002 0010
Part No SW: 1K0 920 973 DX HW: 1K0 920 973 DX
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4158729
Coding: 0023207
Shop #: WSC 02615 444 84571
VCID: 0603CE3E711F1F7F9D-8052
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065272086
Coding: 3FFF23E20F001002
VCID: 2C575C968F33052F2B-8078
Reset counter: 171
Mileage: 393199 km
Time: 19:00:24
Reset counter: 171
Mileage: 393199 km
Time: 19:00:28
Reset counter: 171
Mileage: 393199 km
Time: 19:00:28
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1293324T219H01
Coding: 0000003
VCID: 397975C27061A087A0-806C
Component: IMMO 3HL 1610
Address 26: Auto Roof
Part No SW: 3C0 959 760 B HW: 3C0 959 760 B
Component: Sitzverstellung 0701
Revision: 00003000 Serial number: 00000000000000
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1127
Revision: 31008001 Serial number: 00000532869214
Coding: 0001463
Shop #: WSC 12336 024 394758
VCID: 3C776CD67F5395AFBB-8068
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 01101100
Fault Frequency: 16
Reset counter: 178
Mileage: 393226 km
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346744F657035DEF73-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CD HW: 1K0 959 433 CD
Component: KSG PQ35 RDK 051 0215
Revision: 00051000 Serial number: 00000000000000
Coding: 1B900F880186483F2904058FB0888F0488DC00
VCID: 74E784F617831DEFB3-8020
Reset counter: 171
Mileage: 393199 km
Time: 19:00:25
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000004867
00877 - Treble Speaker Rear Right (R16)
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1125
Revision: 11006001 Serial number: 00000052468706
Coding: 0001462
VCID: 3D7161D264499CA78C-8068
00110 - Right Mirror Turn Signal Lamp (L132)
Fault Frequency: 16
Reset counter: 178
Mileage: 393208 km
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio ZSW 017 0019
Revision: 00017000 Serial number: VWZ5Z7F6042131
Coding: 0010010
VCID: 2447B4B6E7E3CD6FE3-8070
Fault Status: 01110000
Reset counter: 171
Mileage: 393199 km
Time: 19:00:23
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12004001 Serial number: 00000000263917
Coding: 0001168
VCID: 3E7366DE694F87BF95-806A
Component: RDK 0420
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12004001 Serial number: 00000000259382
Coding: 0001168
VCID: 3F8D1BDA6E458EB79E-806A
Address 77: Telephone
Component: PTC-Element 0404
VCID: 2D515192B4290C273C-8078
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:37)--------------------------
