2018 USA Tiguan R-Line LED lamps retrofit
obdserwis-pl
Poland
C?ID=364454
Hello
We have 2018 Tiguan from retrofitting to full LEDs (R Line packet). Wiring is done by another workshop.
Situation now is only low beams works. No other lights.
So do you have any suggestions?
I watched another threads connected with this problems, and not found any solution (eg. https://forums.ross-tech.com/showthread.php?20695)
My idea now is to copy some adaptations from 4B module, maybe from this car: https://forums.ross-tech.com/showthread.php?18164
Wednesday,30,October,2019,19:36:29:02777
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: OBDserwis.pl
VIN: 3VV3B7AX8JM174376   License Plate:
Mileage: 12326km-7659mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 29 2B 39 3C 42 44 4B 52
          5F 69 6C 75 CA D6 D7 D8 D9
VIN: 3VV3B7AX8JM174376   Mileage: 12326km-7659miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
3C-Lane Change -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Not registered 0011
D7-Light Ctrl Right 2 -- Status: Not registered 0011
D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100
D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000
   Coding: 012A00122424010F34000000000000000000000000000000
   Shop #: WSC 00066 790 00449
   ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: 3C343886B7617EAFBB-8068
17158 - Databus
17921 - Databus
          U1122 00 [032] - Implausible Message
   Part No SW: 09G 927 158 B    HW: 09G 927 158
   Component: AISIN AQ8     206 3380
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00444
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 322816BE6525B8DF61-8066
   Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
   Component: ESC           H25 0423
   Revision: 00000000    Serial number: 50958000000897
   Coding: 0BFA6BA454271B70C57A0207A2C949D0D62AD8A34045927010415058C282420B002764121A1C230A35351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 0248867E9505C85FB1-8056
8362 - Databus
          [FCAN: RCTA_01 is not received]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 03:08:40
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 44
                    Mileage: 12152 km
                    Date: 2019.10.04
                    Time: 10:22:18
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0477643063
   Coding: 132C0C0723
   VCID: 3E30328EA17D6CBF95-806A
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00156980
   Coding: 00020024200118001005000012111406
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4FEE7F4A16D7F5376E-801A
   Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
   Component: BCM PQ37BOSCH 034 0246
   Revision: --------    Serial number: C86401061804FY
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0C54A846A7418E2FCB-8058
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180427  034 0373
   Serial number: 18042222009110
   Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
   Component: G355_FeuchteS  H07 0002
   Serial number: 72160003
14 Faults Found:
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
566550 - Databus
          [LCM links - unplausibler Datensatz]
                    Fault Frequency: 18
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:23:53
566806 - Databus
          [LCM rechts - unplausibler Datensatz]
                    Fault Frequency: 18
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:23:53
568086 - Databus
          [LCM links - Blinker defekt]
                    Fault Frequency: 18
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:23:53
568342 - Databus
          [LCM rechts - Blinker defekt]
                    Fault Frequency: 18
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:23:53
7178 - Bulb for High Beam Headlamp Left
          B1219 15 [009] - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:29:26
7434 - Bulb for High Beam Headlamp Right
          B121A 15 [009] - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:29:27
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 21:00:25
8970 - Bulb for Right Fog Lamp
          B1220 15 [009] - Open or Short to Plus
                    Fault Frequency: 17
                    Reset counter: 245
                    Mileage: 10503 km
                    Date: 2019.08.21
                    Time: 15:53:33
13578 - Bulb for Left Tail Light 2
          B12C0 15 [008] - Open or Short to Plus
18954 - Left LED Module for DRL and Parking Lights
          B12EC F5 [009] - Control Circuit Open or Short to Plus
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:23:55
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 200
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:34:01
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:23:53
526615 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.07.15
                    Time: 10:23:53
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0021
   Serial number: 002004167478000
   Coding: 0231467A51
   Shop #: WSC 01487 111 28888
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   VCID: 3B363B9AB26F7997B2-FFFE
12 Faults Found:
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Fault Frequency: 108
                    Reset counter: 11
                    Mileage: 11911 km
                    Date: 2019.09.16
                    Time: 10:47:42
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [009] - Open Circuit
                    Fault Frequency: 102
                    Reset counter: 11
                    Mileage: 11926 km
                    Date: 2019.09.20
                    Time: 07:53:27
1112068 - Front Left Center Parking Aid Sensor
          B10F8 04 [009] - Internal System Fault
                    Reset counter: 10
                    Mileage: 12288 km
                    Date: 2019.10.06
                    Time: 08:31:18
1112324 - Front Right Center Parking Aid Sensor
          B10F9 04 [009] - Internal System Fault
                    Reset counter: 11
                    Mileage: 12326 km
                    Date: 2019.10.08
                    Time: 19:31:50
1079089 - Center Rear Left Parking Aid Sensor
          B1077 31 [009] - No Signal
                    Reset counter: 225
                    Mileage: 10963 km
                    Date: 2019.08.25
                    Time: 16:41:00
1079060 - Center Rear Left Parking Aid Sensor
          B1077 14 [009] - Open or Short to Ground
                    Reset counter: 179
                    Mileage: 8735 km
                    Date: 2019.07.21
                    Time: 12:46:01
1078788 - Rear Left Parking Aid Sensor
          B1076 04 [009] - Internal System Fault
                    Reset counter: 11
                    Mileage: 12273 km
                    Date: 2019.10.05
                    Time: 17:08:15
1078858 - Rear Left Parking Aid Sensor
          B1076 4A [009] - Incorrect component(s) installed
                    Reset counter: 11
                    Mileage: 12326 km
                    Date: 2019.10.08
                    Time: 19:31:32
1079572 - Rear Right Parking Aid Sensors
          B1079 14 [009] - Open or Short to Ground
                    Reset counter: 179
                    Mileage: 8735 km
                    Date: 2019.07.21
                    Time: 12:46:01
1079556 - Rear Right Parking Aid Sensors
          B1079 04 [009] - Internal System Fault
                    Reset counter: 10
                    Mileage: 12290 km
                    Date: 2019.10.06
                    Time: 09:27:18
1079626 - Rear Right Parking Aid Sensors
          B1079 4A [009] - Incorrect component(s) installed
1080852 - Side Rear Right Parking Aid Sensors
          B107E 14 [009] - Open or Short to Ground
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM093EBT
   Coding: 8CCCFC00000000005000001AC20800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 05429D62842BFF6794-8050
   Occupant Detection:
   Serial number: IBH0000000000099DALM
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 002 004 18
   Serial number: 3570000000086D2C5D2X
   Subsystem 3 - Part No SW: -----------    HW: 480 002 004 18
   Serial number: 35800000000FEB604D2
   Subsystem 4 - Part No SW: -----------    HW: 480 402 904 18
   Serial number: 3510001C929B6A831746
   Subsystem 5 - Part No SW: -----------    HW: 480 402 804 18
   Serial number: 3520001BB29D67852458
   Subsystem 6 - Part No SW: -----------    HW: 480 402 704 18
   Serial number: 3550001A529D6772C79H
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 704 18
   Component: FrontSensor_P  000 6149
   Serial number: 35600019F29D6761C50E
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 25021820240271
   Coding: 0410
   VCID: 075E976ABE27ED77E6-8052
   Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
   Component: KOMBI         380 0310
   Coding: 03A4091A2788000807882A0954000000A0000000
   Shop #: WSC 11618 000 00000
          U1014 00 [009] - -
                    Reset counter: 11
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:41:03
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_SWA_0x1A keine Kommunikation]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:41:06
16776982 - Databus
          [SWA_01 keine Kommunikation]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:41:03
   Component: GW MQB High   518 5323
   Serial number: 11051800840611
   Coding: 030100347F085900FA0002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 383C24968359528F5F-806C
   Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
   Serial number: 0811808223300796BH2B
   Coding: 280000
   Serial number: 1508325800
131662 - Lane change assistant control module
          U1045 00 [009] - No communication
          [Timeout Knoten 0x4E / 3C - Steuergerät für Spurwechselassistent]
                    Reset counter: 11
                    Mileage: 8046 km
                    Date: 2019.07.13
                    Time: 00:27:15
                    Supply voltage: Terminal 30: 11.1 V
                    Terminal 15: On
131736 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x98]
                    Reset counter: 11
                    Mileage: 8046 km
                    Date: 2019.07.13
                    Time: 00:27:15
                    Terminal 15: On
131737 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x99]
                    Reset counter: 11
                    Mileage: 8046 km
                    Date: 2019.07.13
                    Time: 00:27:15
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C25D62C4AB3F67D4-8010
0019 - Headlamp Type
          C119F 00 [008] - Implausible
                    Fault Frequency: 21
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 01:51:44
0033 - Supply voltage
          U1011 00 [009] - Voltage too Low
          [Supply voltage - lower limit exceeded]
                    Reset counter: 11
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 01:37:42
0036 - Terminal 15
          U1405 00 [009] - Implausible signal
          [Clamp 15 implausible signal]
                    Fault Frequency: 18
                    Reset counter: 247
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 01:36:14
   Serial number: 18000102415002
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 332613BA9A3FB1D76A-8066
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Fault Frequency: 21
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 01:51:44
                    Fault Frequency: 135
                    Reset counter: 11
                    Mileage: 11750 km
                    Date: 2019.09.05
                    Time: 14:57:14
0036 - Terminal 15
                    Fault Frequency: 18
                    Reset counter: 247
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 01:36:14
Address 3C: Lane Change
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 7038814702482
   Coding: 003013200000028000000000
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000428321
   Coding: 011000
   Revision: 00000000    Serial number: 0002382846
   Coding: 01000010004000
   Shop #: WSC 00066 790 00066
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40CC4C76DB891A4FE7-8014
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 22031810802606
   Coding: 000000070100094E07000900000000000000000000000000000000000000
   Shop #: WSC 00049 770 00107
   VCID: 72A8D6BEA5A5F8DFA1-8026
10 Faults Found:
13705478 - Databus
          [RLS_01 data bus missing message]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
13705473 - Databus
          U1121 00 [137] - Missing Message
          [Fahrwerk_01 data bus missing message]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
0035 - Databus for Front Lighting
          U12EB 00 [009] - Additional Installations Detected
          [CAN_AFS_multiple_plug_LCM_identified]
                    Reset counter: 11
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
0037 - Databus for Front Lighting
          [CAN_AFS_multiple_plug_LED_Leimo_identified]
                    Reset counter: 11
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
13705988 - Databus
          [FA_Hoehenwert_VL_00 received error value]
                    Fault Frequency: 71
                    Reset counter: 10
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
13705989 - Databus
          [FA_Hoehenwert_HL_00 received error value]
                    Fault Frequency: 71
                    Reset counter: 10
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
66678 - Databus
          [LCM_Datensatz_Fehler_L received error value]
                    Fault Frequency: 19
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:34:14
66679 - Databus
          [LCM_Datensatz_Fehler_R received error value]
                    Fault Frequency: 19
                    Reset counter: 32
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:34:14
66881 - Databus
          [LED_L_falsch_codiert received error value]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
66882 - Databus
          [LED_R_falsch_codiert received error value]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 02:31:56
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 8038815200283
   VCID: 44C44066CF91066FC3-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000420495
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0867
   Coding: 02730600BE00000051110001001808001F0100C40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E1002CE711D9C3F05-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV1151165
          B11CF 53 [009] - Deactivated
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 03:05:05
                    Voltage terminal 30: 11.9 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 104 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 03:04:28
                    Voltage terminal 30: 11.8 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0504818959
   Coding: 0100000202000000
   VCID: 42C8467ED585085FF1-8016
136203 - Supply Voltage
          P1757 00 [009] - Open Circuit
                    Fault Frequency: 211
                    Reset counter: 11
   Coding: 0123060120002017300040
   VCID: 393A2192B8534B87A0-806C
   Component: OCULowMQBUS   009 0570
   Coding: 02230602C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43C6437ACA9F0157FA-8016
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D323582AC7B77A78C-8068
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1660CA2EE98D44FF6D-8042
          C119F 00 [009] - Implausible
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 01:36:12
0785 - Bulb for Low-Beam Headlamp
          C1198 F0 [009] - Current Coding Electrical Malfunction
                    Reset counter: 11
                    Mileage: 11889 km
                    Date: 2019.09.15
                    Time: 11:00:53
0849 - Bulb for High-Beam Headlamp
          C1199 F0 [009] - Current Coding Electrical Malfunction
                    Reset counter: 11
                    Mileage: 11889 km
                    Date: 2019.09.15
                    Time: 11:00:53
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
                    Reset counter: 172
                    Mileage: 8046 km
                    Date: 2019.06.28
                    Time: 01:36:12
                    Reset counter: 11
                    Mileage: 11889 km
                    Date: 2019.09.15
                    Time: 11:00:53
                    Reset counter: 11
                    Mileage: 11889 km
                    Date: 2019.09.15
                    Time: 11:00:53
Address D8: LED HeadL. Pwr Left
Address D9: LED HeadL. Pwr Right
End----------(Elapsed Time: 02:49, VBatt start/end: 14.9V/14.9V)-----------
myounus
Northwest UK
C?ID=321059
Has the car got ACC (front distance sensor) and lane assist? What did it have prior to wiring the LED Headlights? Do you know what wiring has been done?
There are more errors here than only Headlights. Try clearing all faults are run another scan. I'd advise you to compare your settings with one from factory, assuming the wiring is correct? Do you have a backup scan prior to changes being made?
obdserwis-pl
Poland
C?ID=364454
Yes, ACC is present lane assist also, but now not works. Car came to me after another workshop. Don't know if wiring is correct.
Turn signals and high beams are priority for now.
This is first backup of coding I have. That is situation when car came to my workshop
OEMplusCC
C?ID=160054
The thread you watching is mine and I have not done the retrofit yet. But have pretty clear idea what I would do.
For the wiring, you need to repin or make an adapter from 10 pin to 14pin. I believe low beam is the only wire that stays at the same position pin 5 on both 10-pin and 14-pin connector. In theory low beam will always work even if you don't do anything simply because its the same. Rest is slightly different connection which all go to BCM J519.
Once you are 100% + sure your connection is correct then you can proceed to coding. If you don't have good wiring you will go crazy figuring out coding.
For the coding (again I have not done it yet). Is to add all modules into CAN cateway. Code 4B module based on the autoscan you posted. Then you need to go to J519 and match adaptations
myounus
Northwest UK
C?ID=321059
What lights has it got at the minute? Led? D6 and D7 need enabling in the gateway it would seem. What lights did it have before the install?
OEMplusCC
C?ID=160054
He mentioned this is a USA Tiguan which means the car must have standard halogen headlights with LED DRL. Which are also wired differently than halogen headlights in Europen Tiguans. In addition European LED headlights are wired differently than USA LED Headlights.
General note, one must be very careful and consider this when rewiring headlights. I hope that the shop that did the wiring realized that.
myounus
Northwest UK
C?ID=321059
Time to get the WD out and check!
obdserwis-pl
Poland
C?ID=364454
Don't really know, if my wiring is 100% OK. Customer said, that wiring is done correct from 10pin to 14pin socket.
Now I want to know, that my coding is OK.
What do you mean
Which autoscan and adaptations you are talking about? 2019 Tiguan SEL Premium?
OEMplusCC
C?ID=160054
vastechnics
C?ID=143747
There are some important things about these headlights. These are fully CANBUS controlled. That means: turn, DRL, high beams and parking lights are totally functioned by canbus. This needs to be connected by the 55 (xenonrange) or 4B (multifunctional module). Depending on this you need to get your wiring ok.
The wiring for 55 module is other that the 4B module. 29 39 D6 D7 no need to be coded in the gateway as the are subsystems recognized by the 55/4B module. This only need BF additional canbus (correct me if i'm wrong), I have not find this option in VCDS only ODIS.
If someone need some help with installation PM me. Done this enoug times.
