Hi.
I hope it is okay I start a new thread as I now have more problems after retrofitting the last parts.
I can't figure out and load the autoscan right.
I've retrofitted..:
Blind spot
PLA 3.0
Area view
TPMS
A5 camera
LED High front
AID
I think I've got the Blind spot coded but don't know until next week when I get the CP removed
But I can't figure out why I have "Local databus" error in A5 camera
Camera gets calibrated Friday.
When I drive forward and get close to something the p-sensor turns on but they do not appear on the screen.
I need to turn off the p-sensor on the button and turn it on again for it to appear on the screen.
Every time I start the car it makes the sign assist error in the cluster. I hope it will be resolved Friday when calibrated.
It shows the sign in the cluster but only the same as in the navi and it does not read the right boards I pass by
I've retrofitted..:
Blind spot
PLA 3.0
Area view
TPMS
A5 camera
LED High front
AID
Wednesday,06,November,2019,16:43:38:52337
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
Workshop Code: 970 22339 012345
VIN: WVWZZZ3CZGExxxxxx License Plate:
Mileage: 89856km-55833mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
65 69 6C 6D A5 BB BC CF
VIN: WVWZZZ3CZGExxxxxx Mileage: 89856km-55833miles
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 FN HW: 04L 907 309 M
Component: R4 2.0l TDI H23 2011
Revision: B4H23---
Coding: 011D003A047405083000
Shop #: WSC 22339 970 00001
ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
VCID: 7BB621D8F2291197F2-802E
Part No SW: 0D9 300 041 J HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4906
Revision: 06253104 Serial number: TFK01602241041
Shop #: WSC 05311 115 00061
ROD: EV_TCMDQ250021.rod
VCID: 1F0E35480671ADB7BE-804A
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61046000000938
Coding: 0FEC6A8F34220B74077D060841C549F0562CD0E0608292F11862F078C209
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 7AB824DCFD13289FE9-802E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0401603713
Coding: 000F0F0F03
Shop #: WSC 05311 115 00236
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 393AFBD0B895E387A0-806C
Part No SW: 5G0 907 044 BH HW: 5G0 907 044 BH
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 12020104204101011015500000101802
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 6E90188CB15B743F45-803A
Air quality sensor:
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0163
Revision: -------- Serial number: 8658160416012I
Coding: 00071D46C2C102FF53C44004001457081C80000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 034659388AD96957BA-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160326 042 0607
Serial number: 160408192827
Subsystem 2 - Part No SW: 8UD 955 559 B HW: 8UD 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 90070925
Coding: 00006E
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 20 01 2016 10000219
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417618081
Coding: 0A71265A51
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50ECA6740B2F42CF77-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 3200670B51FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3424CAE49FF71EEF73-8060
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STP7HZFH4
Coding: 88CCC000008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F4ED5C8E6310DB7DE-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 204 16
Serial number: 3576U000000426303A1.
Subsystem 2 - Part No SW: ----------- HW: 454 000 204 16
Serial number: 3586U000000A5B5D4A1P
Subsystem 3 - Part No SW: ----------- HW: 454 802 503 16
Serial number: 3516RE6FDFF090000000
Subsystem 4 - Part No SW: ----------- HW: 454 802 503 16
Serial number: 3526RB1E4FF09000000Q
Subsystem 5 - Part No SW: ----------- HW: 454 802 803 16
Serial number: 3556VB451470A0000006
Part No SW: 3Q0 953 521 DJ HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160303501287
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 791 A HW: 3G0 920 791 A
Component: KOMBI 412 1460
Coding: 07A509986F8C000C01887F0F3001000000000000
VCID: 271E2DA85E216577C6-8072
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
Shop #: WSC 00015 115 00001
VCID: 383CFED4839FFA8F5F-806C
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001374380
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 10041610801934
Coding: 0B0300345F017300FB0002581C0F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 79BA3BD0F8152387E0-802C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000731660016146
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 0448649703
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H55 0033
Serial number: 0226931
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000073540012
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA03F0A0656BC758-8024
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
VCID: 373EFDE88E81F5F756-8062
267010 - Databus
[FAULT_SLAVE]
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
Control Module temperature: 31 °C
Voltage terminal 30: Measured value not available
Vehicle speed: 0.00 km/h
Terminal 15 status: Measured value not available
Voltage terminal 15: 11.60 V
U1101 00 [009] - Active
[Component protection is active]
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
Voltage terminal 15: 11.70 V
Component: TSG FS 020 0041
Serial number: 040416ED414997
Coding: 001F0B20DC00020000001000
VCID: 43C69938CA59A957FA-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000735503
Coding: 01010011005000
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
VCID: 3D32EFC0ACBDDFA78C-8068
Component: TSG BFS 020 0041
Serial number: 060416ED60262A
Coding: 001F0120DC00020000001000
VCID: 42C89C3CD543A05FF1-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 039A00001F210200
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FCE95C8A6B1CDB79E-806A
Subsystem 1 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 0001
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 0001
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 X003
Coding: E02400
Part No SW: 3G0 035 043 J HW: 3G0 035 043
Component: MU-H-N-EU H50 0343
Serial number: A683D0GB030629
Coding: 02840201FF00000051110001000808031F0106E441200000DF
VCID: 230639B82A1989579A-8076
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL00H4C
Subsystem 2 - Part No SW: V03 959 806 FM HW: -----------
Component: ECE 2019/2020 --- 0177
Compact Disc Database:
Component: Gracenote2 --- 1012
U1111 00 [008] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 28
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:20
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 01
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000199487
ROD: EV_RDKBERU30_006_VW48.rod
8398082 - Tire Pressure Sensor(s)
C111A 31 [009] - No Signal
Reset counter: 201
Mileage: 88074 km
Date: 2019.10.19
Time: 03:02:17
Vehicle speed: 58 km/h
Outside air temperature: 9.5 °C
Reception level antenna 1: 620 mV
Offset level antenna 1: 270 mV
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0400569602
Coding: 0100000202000000
VCID: 3B36E1D8B2A9D197B2-806E
Part No SW: 5Q0 907 556 HW: 5Q0 907 556
Component: Areaview 2 H11 0329
Serial number: C854706JG000690
Coding: 01840201E70F200000204814
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
VCID: 76A030ECC90B4CFF8D-8022
9616786 - Surroundings Camera Front
B127C F0 [009] - Calibration Failed
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
9616787 - Surroundings Camera Rear
B127D F0 [009] - Calibration Failed
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
10489856 - No Basic Setting
B2010 00 [009] - -
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
9616994 - Front Surroundings Camera
B127C 54 [009] - Missing Calibration / Basic Setting
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
9617993 - Rear Surroundings Camera
B127D 54 [009] - Missing Calibration / Basic Setting
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30613377500000
Coding: 0280
ASAM Dataset: EV_DeckLidCONTIAU736 001012
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 04091815P12091
Coding: 0004080200000401002423478040A10094000E200020
VCID: 3C34E2C4B7A7D6AFBB-8068
0660 - No Basic Setting
B2010 00 [009] - -
[Initial_calibration_missing]
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
Control Module temperature: 28 °C
Outside air temperature: 2.5 °C
System run time: 224.9 s
Voltage terminal 15: 11.6 V
mid: 00 1E
Status of camera: System malfunction
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1122597 - Local Data Bus
U1169 00 [009] - Missing Message
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
System run time: 225.3 s
mid: 01 43
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Component: TSG HFS 020 0041
Serial number: 090316EC817976
Coding: 000E01200100020000001000
VCID: 45C28720C46D9767D4-8010
Component: TSG HBFS 020 0041
Serial number: 090316EC817797
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 B HW: 3Q0 907 590
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
Reset counter: 243
Mileage: 89856 km
Date: 2019.11.06
Time: 16:39:18
Control Module temperature: 29 °C
End----(Elapsed Time: 02:31, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
