Audi A4 b7 model stw
KajFinland
Finland
C?ID=383521 (NRRT)
Hey, I have couple issues after car got water inside, yes its watterproof, bottom, water stay inside and CCM was damaged. I bought new and install it but there is one strange problem, when i open left front door, in door panel in multimeter , open left door indicator”led” .
When I open right front door , shows same gauge that left door is open, rear doors work right eith right indicator.
Question.
Can I use ross- tech to change samething that right door open in ”door openpanel”.
South Molton, UK
Please post a full unedited VCDS Auto-Scan so we can see how this B7 A4 is equipped.
KajFinland
Finland
C?ID=383521 (NRRT)
Wednesday,06,November,2019,21:43:57:43728
VIN: WAUZZZ8E86A127192   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E86A127192   Mileage: 171410km-106509miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 8E0 910 401 E    HW: 8E0 907 401 AJ
   Component: 3.0L V6TDI  G000SG  0030
   Revision: --H01---    Serial number:
   Coding: 0011911
   Shop #: WSC 67849 150 85095
   VCID: 211FE2B64DC3470FE69-8074
8 Faults Found:
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 001 - Open Circuit
                    Fault Status: 01110001
                    Mileage: 171284 km
                    RPM: 756 /min
                    Torque: 27.3 Nm
                    Voltage: 12.16 V
                    Bin. Bits:        0
                    Bin. Bits:        0
                    Bin. Bits:        0
005658 - Glowplug for Cylinder 1 (Q10)
               P161A - 001 - Open Circuit
                    Mileage: 171299 km
                    RPM: 924 /min
                    Torque: 117.0 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 14.67 V
                    Duty Cycle: 24.5 %
                    Temperature: 1.8°C
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 001 - Open Circuit
                    Mileage: 171299 km
                    RPM: 924 /min
                    Torque: 117.0 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 14.67 V
                    Duty Cycle: 24.5 %
                    Temperature: 1.8°C
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 001 - Open Circuit
                    Mileage: 171299 km
                    RPM: 924 /min
                    Torque: 117.0 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 14.67 V
                    Duty Cycle: 24.5 %
                    Temperature: 1.8°C
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 001 - Open Circuit
                    Mileage: 171299 km
                    RPM: 924 /min
                    Torque: 117.0 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 14.67 V
                    Duty Cycle: 24.5 %
                    Temperature: 1.8°C
005662 - Glowplug for Cylinder 5 (Q15)
               P161E - 001 - Open Circuit
                    Mileage: 171299 km
                    RPM: 924 /min
                    Torque: 117.0 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 14.67 V
                    Duty Cycle: 24.5 %
                    Temperature: 1.8°C
005663 - Glowplug for Cylinder 6 (Q15)
               P161F - 001 - Open Circuit
                    Mileage: 171299 km
                    RPM: 924 /min
                    Torque: 117.0 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 14.67 V
                    Duty Cycle: 24.5 %
                    Temperature: 1.8°C
004120 - Intake Manifold Runner (Bank 2)
               P1018 - 001 - Lower limit not reached - Intermittent
                    Fault Status: 00100001
                    Mileage: 171376 km
                    Torque: 0.0 Nm
                    Voltage: 12.46 V
                    Duty Cycle: 20.5 %
                    Duty Cycle: 88.8 %
                    Duty Cycle: 20.5 %
   Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
   Component: ESP8 quattro    H05 0120
   Coding: 0004425
   Shop #: WSC 06325 000 00000
   VCID: 290FFA9635F38F4FBE9-807C
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: 6D87CE86C48B536F121-50D0
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0504
   Coding: 11021
   Shop #: WSC 65536
   VCID: 3B2330DECA7F0DDFDC5-4AA4
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M0084N8V
   Coding: 0033622
   VCID: 3B2330DECF6F0DDFDC5-806E
   Subsystem 1 - Serial number: 6332DRB40255D2A9T
   Subsystem 2 - Serial number: 6342DRB40255CE28W
   Subsystem 3 - Serial number: 6352ARB400A16453B
   Subsystem 4 - Serial number: 6362ARB400AF6690T
   Subsystem 5 - Serial number: 63729RB400BDF06D+
   Subsystem 6 - Serial number: 63829RB400BDF016U
01284 - Side Airbag; Drivers Side; Disabled
                    Fault Priority: 8
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 04042
   Shop #: WSC 06325
   VCID: 41DF4236A893670F869-4AA4
01301 - Control Module for Voice Recognition (J507)
   Part No SW: 8E0 920 931 P    HW: 8E0 920 931 P
   Component: KOMBI+WFS 4     H12 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0005001
   Shop #: WSC 75264 512 00000
   VCID: 353726E6E95BDBAF2A1-50F4
Address 18: Aux. Heat        Labels: 8E0-265-105.lbl
   Part No: 8E0 265 105 G
   Component: Standheizung Diesel 0316
   Coding: 00111
   Shop #: WSC 06325
   VCID: 270BFCAE26C7B93FA8D-513C
   Coding: 0005001
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 D    HW: 8E0 035 192 D
   Component: RNS-E HIGH EU   H70 0550
   Revision:      01S    Serial number: AUZBZ7E1121538
   Coding: 0301715
   VCID: 2517F6A659CBAB2F9A1-5160
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   VCID: 6B83C09EFA9F5D5F0C5-508A
   Part No: 8E0 959 433 CA
   Component: Komfortgerát T3B    3332
   Coding: 06911
   Shop #: WSC 06335
   VCID: 72BDDDFADDB58C97CF3-4AA4
   Subsystem 1 - Part No: 8E1959801H
   Component: Tõrsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 0205
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
   Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
   Coding: 0000019
   VCID: 2809FF922EF9B647A17-807C
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH03 0020
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0301715
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802020528
   Coding: 0010014
   VCID: 313F12F61D03F78F769-5184
                    Reset counter: 142
   Part No SW: 8P0 862 335 C    HW: 8P0 862 335 C
   Component: FSE_255x BT     H18 0160
   Revision: 00000001    Serial number: 00000000329378
   Coding: 0011811
   VCID: 363521EAF45DD0B723B-50D0
                    Reset counter: 23
                    Time Indication: 15
End----------(Elapsed Time: 04:58, VBatt start/end: 12.4V/12.4V)-----------
It looks like your CCM is coded for RHD. Try changing its coding from 06911 to 06783.
KajFinland
Finland
C?ID=383521 (NRRT)
Now have to say that I am so green rookie that I dont know where to change it , i have own rosstech so long period, 3 days , :)
myounus
Northwest UK
C?ID=321059
Coding: 06911
Open this module.
Change 06911 to 06783. Save it.
[Select]
[46-Cent. Conv]
[Coding]
It will look something like this:
The change will be done in the field labelled "Software Coding"
KajFinland
Finland
C?ID=383521 (NRRT)
Thanks it works now its right door open.
Hmm..... but not ready yet, is there somewhere in internet place where I can see with vincode, what all functions has been in my car when it was new ?
One thing is which I like to change next is automatic door lockong system, when I speed 20km/h all doors locks and that has not been there and I dont like that. We dont need that in forest Finland
Subtract 32 from the existing coding in the Central Convenience module. So if your coding is now 06783, change it to 06751.
Danners74
C?ID=273244
Refer to my thread on 3B Passat water leaks for the root cause of your problem.
