2014 Bentley Continental GT ACC Calibration
USImotors
Knoxville, TN
C?ID=380250
Good Morning everyone,
I am currently working on a 2014 Bentley, and the customer hit a bump in the road, knocking the ACC (adaptive cruise control) radar out of its holder. I have corrected the mechanical issue, and now have to calibrate it. I have found the process to calibrate it through VCDS, but I need the security access code to enter the system. Does any one know of the code I can use to proceed? I do understand that these radars are very sensitive, and could possibly be damaged due to the hit, but I want to first attempt calibration, before deeming the radar inoperable. I have included a full autoscan, in which there is a code for misalignment of the radar. Thanks in advance!
Chassis Type: ZA-BY62 (6N0)
Scan: 01 02 03 05 06 07 08 09 13 15 16 17 19 23 26 2E 34 36 37 38
          46 47 53 56 65 68 6C 71 76 77
VIN: SCBGT3ZA9EC088140   Mileage: 49330km-30652miles
38-Roof Electronics -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (------CMMC)       Labels: None
   Part No SW: 4W0 906 560 A    HW: 079 907 309
   Component: 4.0l V8TFSI / H57 0001
   Revision: NFH57---    Serial number: VWX3Z0M7006167
   Coding: 252A00126566000E0001
   Shop #: WSC 00083 790 00189
   ASAM Dataset: EV_ECM40TFS0114W0906560A 001003
   ROD: EV_ECM40TFS0114W0906560A.rod
   VCID: 362036C68952F9FF73-8062
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Mileage: 49331 km
                    Date: 2019.11.01
                    Time: 14:27:05
                    Engine speed: 650.50 /min
                    Normed load value: 7.1 %
                    Coolant temperature: 99 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 13.970 V
                    Engine status: COENG_RUNNING
                    Engine oil temperature: 92.9 °C
                    Engine operating condition-Channel 87: Idling
                    Relative load value: 19.41 %
                    Current system status: SYC_DRIVE
                    Time since ignition off: 9421 s
                    Engine torque: 71.3 Nm
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 3W0 927 158 A    HW: 0CU 927 760 A
   Component: OBL 40TFSIUSA H16 0001
   Revision: --H16---    Serial number:
   Coding: 000002
   ASAM Dataset: EV_TCMAL450211 002010
   ROD: EV_TCMAL450211_BY62.rod
   VCID: 3B3627F2B27024978C-806E
Address 03: ABS Brakes        Labels: None
   VCID: 55E2914AB814D2E79A-8000
No Faults Found
   Part No SW: 3D0 909 137 G    HW: 3D0 909 137 G
   Component: 7B Kessy            6850
   Revision: 00H24072    Serial number: VWX3Z0M7006167
   Coding: 0405741
   VCID: 2B1617B28E10B4171C-807E
   Part No SW: 4W0 959 760     HW: 4W0 959 760
   Component: MEM-BFS       H04 0600
   Revision: AA000000    Serial number: 00000060018275
   Coding: D01A1B2485A70000090001010101000000212727000000
   Shop #: WSC 00083 790 00242
   VCID: 7F4E13E2EAE8F8B7E0-802A
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0100
   Revision: ABH15001    Serial number: VWZ6Z7N0146006
   VCID: 6386BF92A6403C57E4-8036
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W7 907 040 D
   Component: Climatronic BY625   3030
   Coding: 0001101
   VCID: 393A3DFA744C16879E-806C
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
   Component: J519                7700
   Revision: -4007---    Serial number: --------------
   Coding: 40820000AB2A11800508030000000000
   VCID: 383C38FE4F460F8F61-806C
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4W0 907 567     HW: 4W0 907 567
   Component: AC201  NAR BY685   00931
   Revision: 00041000    Serial number: 00000000588539
   Coding: 0020685
   Shop #: WSC 00083 790 00206
   VCID: 7DB2E9EA20E4EAA7F2-8028
00234 - Sensor for Automatic Distance Regulation Misadjusted
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 156
                    Mileage: 49331 km
                    Date: 2019.11.07
                    Time: 10:03:16
                    Count: 117
Address 15: Airbags        Labels: None
   Part No SW: 3W3 959 655     HW: 3W3 959 655
   Component: 31 Airbag 9.43  H04 0050
   Revision: 93H04005    Serial number: 003FV000DTNS
   Coding: 0013105
   VCID: 04449C0E430E9B6FBD-8050
   Subsystem 1 - Part No: 3W7 959 339 C
   Component: BF-Gewichtsens. H03 0101
   Subsystem 2 - Serial number: 021EY
   Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40F258816Sÿ†63
   Subsystem 5 - Serial number: 58816Sÿ†6342DRB40F245323Iÿ†63
   Subsystem 6 - Serial number: 45323Iÿ†63528RB406E809D4Yÿ†63
   Subsystem 7 - Serial number: 809D4Yÿ†63628RB406E802B1Nÿ†63
   Subsystem 8 - Serial number: 802B1Nÿ†63747RB406D698EEAÿ†63
   Subsystem 9 - Serial number: 698EEAÿ†63847RB406EE7304Wÿ
   Subsystem 10 - Serial number: E7304Wÿ
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 L
   Component: J527                3601
   Coding: 0000242
   VCID: 48DC483E3FA67F0F11-801C
Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
   Part No SW: 3W0 920 851 L    HW: 3W0 920 851 L
   Component: J285 KOMBI-INST.    3925
   Revision: KPH10V02
   Coding: 0042214
   Shop #: WSC 11685 002 1048576
   VCID: 3FCE53E26E6838B7A0-806A
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3W0 920 851 L
   Component: J533  GW-K-CAN TP20 3925
   Coding: DFF3FFAEEB0D5700
   VCID: 70ACC0DE63B697CF69-8024
Address 23: Brake Booster        Labels: None
   Part No: 3W0 907 563 B
   Component: BREMSBOOSTER    007 0430
   Revision: 00007000    Serial number: 00000000026572
   VCID: 3A3822F6714A1D9F97-806E
Address 26: Auto Roof        Labels: 3W7-959-255.clb
   Part No: 3W7 959 255 B
   Component: J256  VSG BY615     1717
   Revision: 00017000    Serial number: 00000007500009
   Shop #: WSC 00083 790 00205
   VCID: 46C0460635B2697FE3-8012
   Revision: A1001003    Serial number: 7664802678
   Coding: 030100
   Shop #: WSC 00083 790 00191
   VCID: 2B1617B24A10B4171C-807E
Address 34: Level Control        Labels: 3Wx-907-553-34.clb
   Part No: 3W7 907 553 E
   Component: LUFTFDR.-CDC- 3C3V0 7606
   Coding: 0005521
   VCID: 43C65F1206805C57C4-8016
   Component: MEM-FS        H04 0600
   Revision: AA000000    Serial number: 00000060034108
   Coding: D01A1B2485A70000090001010101010000212727000000
   Shop #: WSC 00083 790 00236
01882 - Lumbar Support Fore / Aft Adjustment Button (E336); Forward
                    Fault Status: 00100011
                    Reset counter: 162
                    Mileage: 46319 km
                    Date: 2019.04.27
                    Time: 10:25:10
01881 - Lumbar Support Height Adjustment Button (E335); Down
                    Reset counter: 162
                    Mileage: 46319 km
                    Date: 2019.04.27
                    Time: 10:25:10
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 3W0 035 017 L    HW: 3W0 035 017 L
   Component: RNS-MID       H15 0520
   Revision: AB001001    Serial number: VWZ6Z7N0146006
   Coding: 04010002000000044000
   VCID: 362036C68152F9FF73-8062
   Subsystem 1 - Part No: 3W0 919 859 BE
   Component: NAR V3.1  7921
                    Fault Status: 00100111
                    Reset counter: 196
                    Mileage: 47758 km
                    Date: 2019.09.12
                    Time: 09:36:39
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 G
   Component: Dachmodul           0803
   Coding: 0006077
   Shop #: WSC 00083 790 00214
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 P
   Component: GS HSG              8136
   Coding: 0000040
   Shop #: WSC 00083 790 00211
   VCID: 3D3229EA65642AA7B2-4B1E
   Subsystem 1 - Part No: 3W7 959 701 B
   Component: Tuersteuergeraet FS 1108
   Subsystem 2 - Part No: 3W7 959 702 B
   Component: Tuersteuergeraet BF 1108
   Subsystem 3 - Part No: 3W7 959 703 E
   Component: Tuersteuergeraet HL 0804
   Subsystem 4 - Part No: 3W7 959 704 E
   Component: Tuersteuergeraet HR 0804
   Subsystem 5 - Part No: 3W3 909 610
   Component: 25 HDSG             1811
   Subsystem 6 - Part No: 7L0 907 719 A
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
Address 47: Sound System        Labels: None
   Part No SW: 3W7 035 465 A    HW: 3W7 035 465 A
   Component: DSP 8 Channel       0050
   Revision: 00H07001    Serial number: 75811000513805
   VCID: 393A3DFA704C16879E-806C
Address 53: Parking Brake
Address 56: Radio (J0506)       Labels: None
                    Reset counter: 196
                    Mileage: 47758 km
                    Date: 2019.09.12
                    Time: 09:36:39
Address 65: Tire Pressure        Labels: None
   Part No SW: 3W7 907 273 C    HW: 3W7 907 273 C
   Component: J0502 RDK           0006
   Revision: 0004 006    Serial number: 00000900003205
   Coding: 0000604185BB63B8EE43BB0076FF0065FF004B6E4B6E4B6E4B6E4B6E
   Shop #: WSC 00083 790 00209
   VCID: 40CC501E1796474FD9-8014
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W1 955 023 L
   Component: Wischermodul       ª0401
   Shop #: WSC 00000 725 65552
   VCID: 3FCE53E26A6838B7A0-806A
   Part No SW: 3W3 907 441 C    HW: 3W3 907 441 C
   Revision: 00H12000    Serial number: 525 PA8J350357
   Coding: 2020002
Address 71: Battery Charger (J367)       Labels:* None
   Part No SW: 3W3 915 181 A    HW: 3W3 915 181 A
   Component: EMM Batt Man  H04 0570
   Serial number: 0000000001
   Coding: 1E0100
   Shop #: WSC 61486 000 1048576
   ASAM Dataset: EV_BatteChargVaria1 002019
   ROD: EV_BatteChargVaria1_002.rod
   VCID: 373E3BC28E5800F768-8062
   Part No SW: 3W0 919 283 G    HW: 3W0 919 283 E
   Component: J446  ST Parkhilfe  0111
   Revision: 11H02001    Serial number: 58131313600283
   Coding: 0300056
   VCID: 41CA551A1C9C4E47D6-8014
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3D0 035 730 B    HW: 3D0 035 730 B
   Component: Telefon       012 0825
   Revision: --------    Serial number: 35909603569306
   Coding: 020105000100010000000000
   ASAM Dataset: EV_UHVPremi A02705
   ROD: EV_UHVPremi_A02.rod
   VCID: 1B76C77212B044976C-804E
End----------(Elapsed Time: 02:21, VBatt start/end: 14.6V/14.6V)-----------
myounus
Northwest UK
C?ID=321059
You need to have the calibration board and equipment to properly calibrate. My advice is to take the car to a VW dealer or a third party garage who does ADAS calibration.
DrPeter
16.4905° S, 151.7375° W
Based on some research, there does not appear to be any Security Access code needed for the Adaptation Channel that is used to relearn the ADR(Automatic Distance Regulation) Sensor.
You mentioned you "found the process to calibrate it through VCDS", could you elaborate on this a bit more? Is this a procedure or a "test plan"? Tell us more....
And yes, I agree with myounus "You need to have the calibration board and equipment to properly calibrate" - due to the fact that if the adjustment is off, you have 2 1/2 tons of vehicle that could be incorrectly calibrated, traveling at highway speeds!
Thanks,
drpeter
