Hi, been using VCDS for a few years but never got round to needing to code things, however I've just fitted a towbar and dedicated vehicle electrics to a 2014 T5.1. Successful installation and all lights work, the trailer shows on the 'Radio' screen when connected and sensors are inhibited so pretty happy. However! When I use a trailer light board to test the 'Bulb Out' sensing, I don't get any indication on the MFD that I have removed a bulb. Without the trailer the 'Bulb Out' sensing works as it should.
The dedicated electrics kit was purchased from P.F.Jones in UK, and the kit is made by ConWys of Switzerland. All the reviews say that this is a perfectly good dedicated wiring kit.
I have included an Auto Scan. In particular, I added module 69 (Trailer)to the Gateway, and adapted the coding in 10(Park/Steer Assist) to show 'trailer hitch installed'.
I have received some help from Ross Tech support which suggested I change the coding of module 69, however, when I go to try and access module 69 it requires a Security Access code before it will allow access to coding. When I hover over the security access box I don't get any 'pop up' as I would expect. Is this because Ross Tech does not have any suggestions? I have tried 12345 but that didn't work either.
Please could someone suggest how I find a security code to use to get into the trailer coding so I can try the coding Ross Tech have suggested.
Any other ideas about how to make the 'Bulb out' system work on the trailer would be appreciated.
Regards and Thanks. New to the Forum. Martin.
Monday,04,November,2019,17:18:49:27292
VCDS Version: 19.6.2.0 (x64)
VIN: WV1ZZZ7HZFH045096 License Plate: HJ64KUT
Mileage: 111130km-69052mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 56 69
VIN: WV1ZZZ7HZFH045096 Mileage: 111130km-69052miles
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GH HW: 03L 907 309 M
Component: R4 2,0L EDC H45 8437
Revision: 26H45--- Serial number: 00000000000000
Coding: 01194012232400080000
Shop #: WSC 00534 210 00000
ASAM Dataset: EV_ECM20TDI01103L906019GH 003006
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: 77FDEB59CEA7D8F796-8022
4807 - EGR System
P0401 00 [096] - Insufficient Flow
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A80A9A24A2917AA96410
Shop #: WSC 02737 790 49152
VCID: 3A7B326DB535059FA9-806E
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 21081404650212
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3FE7DE19DE9BFD5-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BG HW: 7E5 907 047 BG
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 75E1E151D4ABAAE784-8020
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 P HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0424
Revision: BO034001 Serial number: 0673 251140050
Coding: A0A4303A0A613431922848106C2B8C540080632F60840000320000000800
Shop #: WSC 02739 790 12345
VCID: 41894581D8E35647E8-8014
Subsystem 1 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU005091442485173
Coding: 1000B1
Subsystem 2 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU010091442537027
Coding: 0000A1
Subsystem 3 - Part No: 7E1 951 172
Subsystem 5 - Part No: 7E1 951 172
Subsystem 6 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0023
Serial number: 70000000000000799490
Coding: E20000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261420400910
Coding: 118004
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 3B753769B20F3C97B2-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00SDTWE
Shop #: WSC 02734 790 50316
VCID: 35612151942BEAE744-8060
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H03 0805
Coding: 160A00
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BO034001
Coding: 042300
VCID: 70EFD045A3C98FCF57-8024
Component: IMMO H03 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADBC22D8D15751F19-803E
Part No SW: 3C8 035 279 R HW: 3C8 035 279 R
Component: RNS315-EU H80 0500
Serial number: VWZAZ2P0470904
Coding: 000002110200140000039002
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A7B326DBD35059FA9-806E
Component: EUR_W_V6 0062
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 306F10456349CFCF17-8064
End-------------------------(Elapsed Time: 02:37)--------------------------
