- Nov 23, 2014
- 154
- 45
- Los Angeles CA.
- C?ID=242342
hello, any help here.
why i can t start the Throttle adapt on J338
Monday,12,August,2019,14:37:51:23194
VCDS Version: 19.6.1.0 HEX-NET CB: 0.4508.4
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 11 31 13 15 16 17 19 36 37 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUGN74F37N029770 Mileage: 230180km-143027miles
0E-Media Player 1 -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F1 910 552 A HW: 4F1 907 552
Component: 5.2L V10/4V FSI ª0040
Revision: 59H09--- Serial number:
Coding: 01050009190F0260
Shop #: WSC 22163 444 999999
VCID: A2088D267D95EB5F11-80F6
005497 - Throttle Actuator (J338)
P1579 - 001 - Adaptation Not Started
Fault Status: 01100001
Mileage: 230189 km
Date: 2019.11.05
Time: 13:29:40
Temperature: 30.0°C
Temperature: 30.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.303 V
005445 - Throttle Valve Controller
P1545 - 008 - Malfunction
Fault Status: 01101000
Mileage: 230189 km
Date: 2019.11.05
Time: 13:29:40
Temperature: 30.0°C
Temperature: 30.0°C
Voltage: 11.303 V
000289 - Throttle Position Sensor (G69)
P0121 - 008 - Implausible Signal
Mileage: 230189 km
Date: 2019.11.05
Time: 13:30:14
RPM: 1120 /min
Load: 66.6 %
Temperature: 30.0°C
Temperature: 30.0°C
Voltage: 11.176 V
008454 - Throttle Valve Actuator Module (J338)
P2106 - 002 - Power Limited due to Malfunction
Fault Status: 01100010
Mileage: 230189 km
Temperature: 45.0°C
Temperature: 30.0°C
Voltage: 12.065 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4F2 910 156 M HW: 09E 927 156 C
Component: AG6 09E 5,2 FSI USA 0010
Revision: --H01--- Serial number: 0088250
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: AF2E74123E4756378E-80FA
006231 - Load Signal
P1857 - 001 - Error Message from ECU
Fault Frequency: 12
Mileage: 230186 km
Date: 2019.09.10
Time: 08:58:27
RPM: 1184 /min
RPM: 1152 /min
(no units): 30.0
(no units): 36.0
Temperature: 28.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 P HW: 4F0 614 517 P
Component: ESP 8.0 quattro H05 0070
Coding: 0020920
VCID: B12A726A287340C798-80E4
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Fault Frequency: 76
Reset counter: 43
Mileage: 230186 km
Date: 2019.09.10
Time: 08:58:27
Hex Value: 0x00C0
Hex Value: 0x6282
Hex Value: 0x0028
Hex Value: 0x0193
Hex Value: 0x00FF
013 - Check DTC Memory
Fault Status: 01101101
Fault Frequency: 89
Reset counter: 43
Mileage: 230186 km
Date: 2019.09.10
Time: 08:58:27
Hex Value: 0x00C0
Hex Value: 0x6282
Hex Value: 0x0025
Hex Value: 0x0193
Hex Value: 0x00FF
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 08:34:25
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0024
Hex Value: 0x0179
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0210
Revision: 27120501 Serial number: 10601000481540
Coding: 0000007
Shop #: WSC 45207 001 1048576
VCID: E386C822220FA2575A-80B6
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
Component: FBSAUDIC6 IDG H01 0053
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 17:11:18
Reset counter: 83
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 2750
Revision: 00000000 Serial number: 393FP067500047
Coding: 0010003
Shop #: WSC 02335 785 00200
Component: Bedienteil MMIC6H02 0060
Subsystem 2 - Serial number: 00000000467769
Subsystem 3 - Serial number: 0110.07.060000000100011423ÿ
Subsystem 4 - Serial number: 011423ÿ
01964 - Control Module for Seat & Steering Column Memory (J136)
Fault Frequency: 35
Reset counter: 43
Mileage: 230186 km
Date: 2019.09.16
Time: 15:20:13
01327 - Control Module for Parking Aid (J446)
Reset counter: 83
Mileage: 230187 km
Date: 2019.09.19
Time: 14:30:58
01319 - Control Module for Distance Control (J428)
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 08:35:44
Reset counter: 83
Time Indication: 15
00658 - Control Head
Mileage: 230189 km
Date: 2019.10.11
Time: 17:39:09
Bin. Bits: 001
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 HW: 4F1 820 043 AC
Component: KLIMABETAETIGUNGH20 0170
Revision: 00000030 Serial number: 00000030142620
Coding: 0524330
VCID: DBF6F0C21A7F9A9712-808E
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 43
Mileage: 230163 km
Date: 2019.09.05
Time: 17:07:31
Temperature: 45.0°C
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Coding: 0115123
VCID: B02C776E237949CF97-80E4
Subsystem 1 - Part No: 4F1 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
Fault Status: 01100101
Fault Frequency: 96
Reset counter: 43
Mileage: 230160 km
Date: 2019.09.05
Time: 11:10:00
01024 - Rain Sensor (G213)
Fault Status: 00101110
Reset counter: 83
Mileage: 230168 km
Date: 2019.09.06
Time: 14:29:00
Reset counter: 83
Mileage: 230188 km
Date: 2019.10.12
Time: 17:08:00
Reset counter: 83
Mileage: 230188 km
Date: 2019.10.12
Time: 17:09:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8151712
VCID: 9C74B3DE5FF1DDAFDB-80C8
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:59:43
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F1029876
VCID: A81C9F0E1BA9010F4F-80FC
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 17:12:03
Voltage: 8.40 V
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 17:11:52
Voltage: 8.40 V
Reset counter: 39
Mileage: 230163 km
Date: 2019.09.05
Time: 11:10:22
Address 11: Engine II Labels: Redir Fail!
Address 13: Auto Dist. Reg Labels: 4F0-910-561.lbl
Part No SW: 4F0 910 561 B HW: 4F0 907 561 A
Component: ABSTANDSREGELUNGH05 0060
Revision: -------- Serial number: 00000000000000
Coding: 0041118
Reset counter: 43
Mileage: 230186 km
Date: 2019.09.10
Time: 08:58:24
Temperature: 27.0°C
Voltage: 11.01 V
Bin. Bits: 01000
Hex Value: 0x2512
Hex Value: 0x0006
Lateral Accel.: 0.00 m/s^2
Fault Frequency: 85
Reset counter: 43
Mileage: 230186 km
Date: 2019.09.10
Time: 08:58:26
Temperature: 27.0°C
Voltage: 11.26 V
Bin. Bits: 01000
Hex Value: 0x2513
Hex Value: 0x0002
Speed: -3.6 km/h
Lateral Accel.: -0.12 m/s^2
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 K HW: 4F0 959 655 D
Component: 7G AIRBAG AUDI8RH29 0400
Revision: 01H29000 Serial number: 003BMD0007P
Coding: 0014151
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME0F401644
Subsystem 3 - Serial number: 6342CSME112D0E23+
Subsystem 4 - Serial number: 6352QSME1253253B9
Subsystem 5 - Serial number: 6362QSME1109055BA
Subsystem 6 - Serial number: 63734SME6F45427AB
Subsystem 7 - Serial number: 63834SME0E6C2C1DJ
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
014 - Defective - Intermittent - MIL ON
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026061890164
Coding: 0012151
Shop #: WSC 02323 785 00200
VCID: E680D136D13DD77FBD-80B2
Component: Lenkradmodul H07 0090
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:58:57
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:59:43
Part No SW: 4F0 910 930 C HW: 4F0 920 980 S
Component: KOMBIINSTR. M73 H18 0110
Revision: 00300000 Serial number: 5H658R576
Coding: 2257263
Shop #: WSC 09518 003 1048576
VCID: A3068822628FE2571A-80F6
Reset counter: 83
Mileage: 230188 km
Date: 2019.10.08
Time: 18:04:35
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06619805B
Coding: F5D5DEF7317A06
Shop #: WSC 02334 785 00200
VCID: EC94A31ECFD1ED2FEB-80B8
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: E18AC22A3813B04748-80B4
Reset counter: 83
Mileage: 230188 km
Date: 2019.10.12
Time: 17:12:49
Part No SW: 4E0 910 888 M HW: 4E0 919 887 D
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381FS067502729
Shop #: WSC 02324 785 00200
VCID: B83C4F4ECB09918FDF-80EC
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 17:13:40
Hex Value: 0x5DA2
Hex Value: 0x09C4
Hex Value: 0x0054
02927 - DVD Read Error
Reset counter: 83
Mileage: 230187 km
Date: 2019.09.19
Time: 14:31:17
Hex Value: 0x5D94
Hex Value: 0xE358
Hex Value: 0x0401
Hex Value: 0x0000
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0051947
Shop #: WSC 22161 444 101414
VCID: AC14631E0F512D2FAB-80F8
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:59:43
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01015925940000
Coding: 4618269
VCID: AE106916394D5F3F85-80FA
Fault Status: 01101100
Reset counter: 43
Mileage: 171496 km
Date: 2014.02.17
Time: 15:08:09
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 F HW: 4F0 035 223 F
Component: DSP-High C6 H09 0190
Revision: PROD_01 Serial number: 00000000006424
Coding: 0000026
VCID: A10A822A7893F04708-80F4
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:59:01
Voltage: 7.90 V
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000030228
Coding: 0012014
VCID: DEF0F9D6096D8FBF75-808A
Fault Status: 00110010
Reset counter: 83
Mileage: 230188 km
Date: 2019.10.14
Time: 17:58:00
Voltage: 7.600 V
Temperature: 31.0°C
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0051947
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:59:43
Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
Component: EPB CB4C0060 H04 0060
Revision: --H04---
Coding: 0008022
VCID: 9F0E84D24EE7C6B73E-80CA
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000016
VCID: A91A9A0A00A3380750-80FC
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
01537 - Vehicle Level Sensor; Supply Voltage
007 - Short to Ground - MIL ON
Fault Status: 11100111
Fault Frequency: 101
Reset counter: 43
Mileage: 230168 km
Date: 2019.09.05
Time: 11:10:23
Part No SW: 4E0 910 541 M HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 394GX067662452
Coding: 0000002
VCID: AA18650605A5331F59-80FE
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 17:08:17
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000069735
Shop #: WSC 22163 444 84528
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2607031170
Coding: 344630393135313035442056413032363037303331313730
Shop #: WSC 00000 512 00290
02272 - Quiescent Current Stage 1
Fault Frequency: 63
Mileage: 230186 km
Date: 2019.09.16
Time: 14:39:52
02273 - Quiescent Current Stage 2
Fault Frequency: 58
Mileage: 230186 km
Date: 2019.09.16
Time: 14:46:19
02276 - Quiescent Current Stage 5
Fault Frequency: 58
Mileage: 230186 km
Date: 2019.09.16
Time: 14:46:29
02274 - Quiescent Current Stage 3
Fault Frequency: 56
Mileage: 230186 km
Date: 2019.09.16
Time: 14:46:39
02277 - Quiescent Current Stage 6
Fault Frequency: 56
Mileage: 230186 km
Date: 2019.09.16
Time: 14:46:49
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0051754
Shop #: WSC 02327 785 00200
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:59:43
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900025644
Coding: 0062725
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication - Intermittent - MIL ON
Fault Status: 10100100
Reset counter: 63
Mileage: 229926 km
Date: 2006.03.19
Time: 12:16:07
(no units): 0.0
Voltage: 11.70 V
(no units): 33.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
02214 - Tire Pressure Warning
Fault Frequency: 182
Reset counter: 0
Mileage: 229858 km
Date: 2006.03.15
Time: 12:24:05
(no units): 0.0
Temperature: 21.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606220389
Shop #: WSC 12336 024 394758
VCID: B4247B7ED76175EFF3-80E0
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.12
Time: 17:12:05
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4F0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6620NW
Coding: 1000204
VCID: DDF2FEDA046B94A76C-8088
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.11
Time: 17:39:05
Reverse OFF
Count: 3
Reset counter: 83
Term 15 Off
Reverse OFF
Count: 3
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0051754
Reset counter: 83
Mileage: 230189 km
Date: 2019.10.14
Time: 17:59:43
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220619204261
Coding: 0021306
VCID: A71E9C3216B70E7746-80F2
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007562688
Coding: 0010900
Shop #: WSC 49145 001 1048576
Reset counter: 83
End----(Elapsed Time: 02:48, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
