Folding Mirrors With Keyfob Audi Q3
judge360
C?ID=77581
Hi everyone, I have a gentleman who would like his mirrors to fold in when he locks his car with the keyfob. Car is an Audi Q3 2015. How would I go about doing this? I have never done anything like this with VCDS before so any help would be greatly appreciated. Thanks
Not all cars have the hardware required to implement this. Please post an Auto-Scan so people can see how this one is equipped.
judge360
C?ID=77581
I will have to wait until I can get the car back before I can post a scan. The mirrors fold in from the inside of the car so I believe the module should support them folding in with the keyfob.
nirvananils
C?ID=289109
As Iam right there are Gen3 Door ECU inside, so there´s no possibility with VCDS
judge360
C?ID=77581
Hi everyone, here is the autoscan of the audi q3. Thanks
Friday,08,November,2019,10:42:20:63801
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8U4FR018253   License Plate:
Mileage: 70860km-44030mi   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8U4FR018253   Mileage: 70860km-44030miles
55-Headlight Range -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CUVC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 BF    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 2911
   Revision: 8AH20---
   Coding: 01190032043701080000
   Shop #: WSC 27915 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016BF 004002
   ROD: EV_ECM20TDI01104L906016BF_004.rod
   VCID: 6ED812D6B16E3C3F45-803A
9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
          P2209 00 [096] - Implausible Signal
                    Mileage: 70605 km
                    Date: 2019.11.05
                    Time: 09:27:43
                    Engine speed: 1927.00 /min
                    Normed load value: 68.6 %
                    Vehicle speed: 29 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 13.240 V
                    Unlearning counter according OBD: 28
                    NOx sens.dwnstrm.SCR cat conv: NOx conc.: 0 ppm
                    NOx sensor before SCR cat conv: NOx concentration: 17 ppm
                    NOx sens. dwnstrm. of SCR cat.: target heat. temp reached-Bits 0-7: 0
                    NOx sensor after SCR catalytic converter: supply voltage: 0 mV
                    NOx sensor before SCR catalytic converter: supply voltage: 12640 mV
                    Extern.temp.sens.1 bank 1: raw value: 7.5 °C
                    Mean injection quantity: 14.21 mg/stroke
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CA    HW: 5N0 614 109 CA
   Component: ESC-EBC460iV1 H08 0004
   Serial number: A00QH6F
   Coding: 21F124A1C921E3742079840524C693C704355700508B4884
   Shop #: WSC 00049 770 00152
   ASAM Dataset: EV_Brake1ESCEPBTRW 003039
   ROD: EV_Brake1ESCEPBTRW_003.rod
   VCID: 6CDC18DE8772CE2F6B-8038
0763 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 230
                    Mileage: 54067 km
                    Date: 2019.03.22
                    Time: 17:09:55
                    Additional_Codes: 1E FF 00 0D 6E 7F 00 48 02
                    DTC: 00 02 FB
                    Additional2: 00 03 01 08 05 22 A7 00 A7 00
   Part No SW: 8U0 820 043 F    HW: 8U0 820 043 F
   Component: E87  Klimavoll      0210
   Revision: 00H05000    Serial number: 8U0820043F
   VCID: 346CC0BE57C256EF73-8060
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
                    Fault Status: 00101010
                    Reset counter: 212
                    Mileage: 70582 km
                    Date: 2019.11.04
                    Time: 11:10:26
                    Voltage: 14.50 V
                    (no units): 255.0
                    Temperature: 9.0°C
                    Fault Status: 00100011
                    Reset counter: 212
                    Mileage: 53240 km
                    Date: 2019.03.10
                    Time: 15:28:19
                    Voltage: 14.40 V
                    Temperature: 17.5°C
                    (no units): 207.0
                    (no units): 152.0
                    Temperature: 4.5°C
   Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
   Component: BCM PQ35  M   113 0817
   Revision: AB113817
   Coding: 0E000A2CA805F1C0201849C80144094C43FF25AA006F912BE400878400C1
   Shop #: WSC 00049 770 00010
   VCID: 7CFC289EFF125EAFFB-8028
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 141203  H37 0090
   Serial number:         141215020408
   Coding: 0047F7
   Serial number: 23648554
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177 A
   Component: Sensor, DWA 0  005 0002
Address 10: Park/Steer Assist (J791)       Labels:* None
   Part No SW: 8U0 919 475 B    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0060
   Revision: --------    Serial number: 56231436300185
   Coding: 181208
   Shop #: WSC 00049 770 00116
   ASAM Dataset: EV_EPHVA2CAU3160000 003004
   ROD: EV_EPHVA2CAU3160000_003.rod
   VCID: 42809666D576E85FF1-8016
   Part No SW: 8U0 959 655 C    HW: 8U0 959 655 C
   Component: AirbagVW-AU10 H09 0900
   Serial number: 003PAR0A8UL5
   Coding: 30523232333030303030554A305238553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 47968772FE54CD7726-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME536A7B34ZZZ2
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME160D0B34ZZZQ
   Serial number: 3516KSME16347834ZZZP
   Serial number: 3526KSME5E100B34ZZZS
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME69566D32ZZZ9
   Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010018    Serial number: 20150121101381
   Coding: 1084204000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D7AE59AAC8897A78C-8068
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
   Serial number: 16 01 2015  F0047887
   Part No SW: 8U0 920 990 H    HW: 8U0 920 990 H
   Component: KOMBI_COLOUR  H02 0350
   Coding: 42CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
13639168 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 212
                    Mileage: 70582 km
                    Date: 2019.11.04
                    Time: 11:20:26
   Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0090
   Revision: 1P140041    Serial number: 4141P15124008A
   Coding: FBCF1A5A000108610353
   Shop #: WSC 28422 002 1048576
   VCID: 1122692AC89043C738-8044
   Component: J367-BDM  H07 0180
   Serial number: 32022931481491380295
   Serial number: 15015002935021200181
                    Reset counter: 212
                    Mileage: 70582 km
                    Date: 2019.11.04
                    Time: 11:20:26
                    Bin. Bits:    11111
                    Voltage: 13.30 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Part No SW: 8U0 857 511 B    HW: 8U0 857 511 B
   Component: FLA           H03 0012
   Revision: AA002001
   Coding: 02020A64747464545425363E00
   VCID: 3A70EE86B5A6A09FA9-806E
   Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
   Component: Haldex4Motion H52 7522
   Serial number: HA1-00023.12.14
   Coding: 0001
   VCID: 52A0A626051678DF41-8006
   Component: IMMO          H02 0350
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011806201C01000000
   VCID: 52A0A6260D1678DF41-8006
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 296    3501
   Revision: 00H22000
   VCID: 40849C6E137AFA4FE7-8014
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   Coding: 011806201E01000000
   VCID: 51A2A92A081003C778-8004
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Serial number: 150124-0002-068
   Coding: 11C7A4101000A500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 448C907ECF62E66FC3-8010
   Part No SW: 8U1 035 192 D    HW: 8U1 035 192 A
   Component: RMC Nav Plus  H61 0186
   Coding: 01010600024153470823020103010000000000
   VCID: 3668FAB681BE44FF4D-8062
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
   Component: DUBasic AU316  H42 0018
   Serial number: AUZ8ZDEM502QCB8
                    Reset counter: 225
                    Mileage: 70808 km
                    Date: 2019.11.07
                    Time: 13:32:01
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010006200001000000
   VCID: 4FA6AF521E2415376E-801A
   Component: TSG HR        H08 0415
End-------------------------(Elapsed Time: 03:16)--------------------------
judge360
C?ID=77581
Looking at the modules, is it possible to get the mirrors to fold in the locking the car with the keyfob? or is this not supported? Thanks
judge360
C?ID=77581
Customer is coming back sometime today to find out if it can be done, so if anyone knows that would be great. Thanks
nirvananils
C?ID=289109
As I said, in my opinion you have to use VCP to edit EEPROM in Door ECU. VCDS can´t do this job
judge360
C?ID=77581
My apologies I didnt quite understand what you said. Where do I get VCP and what is the cost? Thanks
ch1z64
C?ID=316572
Vcp software can be downloaded fron the net , but i think the cable is pricey for the benefit off using the keyfob
Gashhey
C?ID=350180
Automatically Fold Mirror Upon Locking with Remote or With HOLD for 4 seconds on Door Sensor : You MUST code BOTH door controllers or only ONE mirror will fold -
[42 - Door Elect. Driver] [Coding - 07] -> [Long Coding Helper] -> [Byte 4] [Bit 6 - Undocumented (1 = active) in Binary String] => Change Bit 6 to 1 Note : Bit 0 is at the far right of the binary string The old HEX value for this byte was prolly 1C; Binary Value [00011100] and the NEW HEX value should be typed in as 5C; Binary Value [01011100]
Esc or Exit Transfer Coding Do It!
[52 - Door Elect. Pass.] [Coding - 07] -> [Long Coding Helper] -> [Byte 4] [Bit 6 - Undocumented (1 = active) in Binary String] => Change Bit 6 to 1 Note : Bit 0 is at the far right of the binary string The old HEX value for this byte was prolly 1E; Binary Value [00011110] and the NEW HEX value should be typed in as 5E; Binary Value [01011110]
I’m almost certain this worked for me
Richard Hamilton
Maidenhead, UK
C?ID=271942
What Gashhey said. This worked for me too, on my 2015 RSQ3.
Of course, you have to have electrically folding mirrors in the first place. If it doesn't have the fold position on the control knob, then it doesn't.
andyhud
C?ID=32695
Yep, this is spot on
Module 42 and 52
Long Coding
Byte 4 / Bit 6
Its called "mirror_comfort_folding,active"
