hello wizards need your help.
i have a skoda yeti attaching the scan file.
the abs shows many errors i replaced the faulty sensors now only one error is present and that is
01130 - ABS Operation
Fault Status: 01101000
Reset counter: 226
Mileage: 126756 km
please help
other fault code which returns after erasing is
629 - ECM Power Relay Load Circuit
P068A 00 [040] - Opens Too Early
Engine speed: 0.00 /min
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Unlearning counter according OBD: 33
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
please help
Reset counter: 226
Mileage: 126756 km
please help
please help
Monday,04,November,2019,15:12:35:02918
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: TMBMDM5L9AA700725 License Plate: JIJU YETI
Mileage: 127440km-79187mi Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 56 62 72
VIN: TMBMDM5L9AA700725 Mileage: 127440km-79187miles
56-Radio -- Status: Malfunction 1110
Address 01: Engine (J623-CLCB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 EK HW: 03L 906 018 BR
Component: R4 2.0l TDI H22 9977
Revision: 42H22--- Serial number:
Coding: 00190012040700080000
Shop #: WSC 22033 663 00000
ASAM Dataset: EV_ECM20TDI01103L906018EK 003010
ROD: EV_ECM20TDI01103L906018EK.rod
VCID: 77BEFC0CCEC622F796-8022
4629 - ECM Power Relay Load Circuit
4278 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
[Invalid Data Received FromAnti-Lock Brake System Control Module]
Readiness: 0 1 0 0 0
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 933F400E092201FAC91202E6901E808A310000
Shop #: WSC 73430 790 00999
VCID: 76A0F108C1CC5BFF8D-8022
03840 - RPM Sensor Front Right: Incorrect Signal
Reset counter: 8
Mileage: 126966 km
Count: 3
Count: 2
Count: 4096
Count: 55
Count: 42497
Count: 966
Count: 65532
Fault Status: 00100011
Reset counter: 10
Mileage: 127179 km
Date: 2014.03.26
Time: 20:27:41
Count: 7
Count: 4608
Count: 51
Count: 47616
Count: 64516
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Fault Status: 00101100
Fault Frequency: 8
Reset counter: 11
Mileage: 126833 km
Date: 2014.03.04
Time: 18:25:57
Count: 7
Count: 32768
Count: 4608
Count: 40
Count: 46338
Count: 56818
Count: 65026
Fault Frequency: 13
Reset counter: 226
Mileage: 126881 km
Date: 2014.03.19
Time: 13:45:36
Count: 7
Count: 32770
Count: 12800
Count: 56
Count: 47360
Count: 54528
Count: 65534
Reset counter: 226
Mileage: 126756 km
Date: 2014.03.02
Time: 17:52:07
Count: 2
Count: 2
Count: 12800
Count: 124
Count: 47360
Count: 57344
Count: 65277
Part No SW: 3T0 907 044 BD HW: 3T0 907 044 BD
Component: Climatronic H16 0402
Revision: 00005001
Coding: 0000001002
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 75A2F604D4CA50E784-8020
13701904 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Bremsensteuergerät - bitte Fehlerspeicher auslesen]
Reset counter: 11
Mileage: 126883 km
Date: 2019.10.27
Time: 22:04:38
Part No SW: 1K0 937 086 H HW: 1K0 937 086 H
Component: BCM PQ35 M 103 0615
Revision: 00103 AD
Coding: 46800AB8E81308C040080080150081E4436800FF527D8160508140000040
Shop #: WSC 73430 790 00075
VCID: 352236049C4A10E744-8060
Subsystem 1 - Part No: 5L2 955 119 A Labels: 1KX-955-119.CLB
Component: SK356 26 0604
Coding: 00D7B7
Component: RLS 221010 05 54 0403
Coding: 0730ED
Address 10: Park/Steer Assist (J446) Labels:| 1Z0-919-475-V2.clb
Part No SW: 1Z0 919 475 E HW: 7N0 919 475
Component: PARKHILFE 8K H06 0005
Revision: --H06--- Serial number: 28241031003721
Coding: 108006
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_EPHVA18SKxxx0000 001001
ROD: EV_EPHVA18SKxxx0000_001.rod
VCID: 43C658DCCA9EBE57FA-8016
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6R0007P+
Coding: 0000544A
Shop #: WSC 33361 790 00000
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 32280D18652407DF61-8066
Serial number: 3572MSME7201563DZZZU
Serial number: 3582MSME7C230258ZZZX
Serial number: 3512QSME0C147B01ZZZR
Serial number: 3522QSME10577A4DZZZ$
12850432 - Implausible Data Received from ABS Control Module
U0415 00 [008] - -
[Communication with Vehicle Dynamics Control Module Implausible]
Reset counter: 11
Mileage: 126883 km
Date: 2019.10.27
Time: 22:04:33
Part No SW: 5K0 953 521 BM HW: 5K0 953 569 D
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101118201777
Coding: 1082040000
Shop #: WSC 22000 663 135624
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 78BCFF30C3D82D8F9F-802C
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 800000
Part No SW: 5L0 920 840 HX HW: 5L0 920 840 HX
Component: KOMBI H22 0422
Coding: 120B00
ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
VCID: 085C8FF0B3385D0FEF-805C
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 101110F2000209
Coding: 356303
VCID: 302C0710632835CF17-8064
Fault Status: 00101011
Reset counter: 10
Mileage: 126763 km
Date: 2014.03.03
Time: 15:00:54
01304 - Radio
Fault Frequency: 80
Reset counter: 226
Mileage: 126756 km
Date: 2014.03.02
Time: 17:52:31
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 44C45BC00790B96FC3-8010
00625 - Vehicle Speed Signal
Fault Status: 01110001
Fault Frequency: 57
Reset counter: 48
Mileage: 3618101 km
Time Indication: 4
Time: 0.00 s
Raw, Form. N/A: 000 000 000
Component: IMMO H22 0422
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A98D5788D748F1F19-803E
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 E HW: 7N0 959 793 A
Component: TSG FA H04 0400
Revision: Serial number: 0000110558402
Coding: 011502208401231004
VCID: 44C45BC0C790B96FC3-8010
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 312A0214A8223CC718-8064
Fault Status: 00101101
Fault Frequency: 48
Reset counter: 11
Mileage: 127447 km
Date: 2014.03.27
Time: 14:52:36
Voltage: 12.25 V
DD
Temperature: 36.0°C
Reset counter: 11
Mileage: 127326 km
Date: 2014.03.27
Time: 10:50:59
Voltage: 13.38 V
DU
Temperature: 66.0°C
RPM: 845 /min
Speed: 2.0 km/h
Speed: 2.0 km/h
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 E HW: 7N0 959 792 A
Component: TSG BF H04 0400
Revision: Serial number: 0000011730178
Coding: 011500208001231004
VCID: 43C658DCC29EBE57FA-8016
02111 - Motor for Window Regulator
Fault Status: 00100101
Reset counter: 4
Mileage: 126834 km
Date: 2014.03.04
Time: 21:47:24
Address 56: Radio
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-795.clb
Part No SW: 7N0 959 795 D HW: 7N0 959 795
Component: TSG HL H03 0400
Revision: Serial number: 0000011686650
Coding: 010000200001531004
VCID: 45C246C4CCAA8067D4-8010
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-795.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000011686677
End----(Elapsed Time: 01:13, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Address 19: DTCs cleared
