Polo 2017 bsi coding and key remote
Frikki
South Africa
C?ID=357723
hi there all members. customer changed bsi unit due to damaged in car accident with secondhand unit. old unit is dead because pc board is damaged. could someone please help me or advise how to programm unit. i also need to programm the key remote. no windows or central locking is working. many thanks for advise. keep well.
Tuesday,05,November,2019,12:01:47:62451
VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4508.4
VIN: AAVZZZ6RZHU064729   License Plate:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 55 5F 69
VIN: AAVZZZ6RZHU064729   Mileage: 48112km-29895miles
55-Headlight Range -- Status: Cannot be reached 0100
69-Trailer -- Status: Cannot be reached 0100
Address 01: Engine (J623-CJZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 LH    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H24 3855
   Revision: R4H24---
   Coding: 01110012232410010000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12TFS01104E906027LH 001001
   ROD: EV_ECM12TFS01104E906027BB.rod
   VCID: 75B615A7054E099FBDB-8020
   CAN Converter 01:
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Fault Frequency: 9
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:00:14
                    Engine speed: 867.50 /min
                    Normed load value: 28.6 %
                    Coolant temperature: 54 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 11.614 V
                    Mass flow through throttle valve: 8.0 kg/h
                    Median injection timing: 1.098 ms
                    Engine operating condition: Idling
          U0428 00 [047] - -
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:00:13
                    Engine speed: 899.50 /min
                    Normed load value: 32.5 %
                    Voltage terminal 30: 11.756 V
                    selected gear-Bits 0-7: 0
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:00:13
                    Normed load value: 32.9 %
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08505756170124
   Coding: 23DD2885492933C4091B006B005AC41492CC90000005C9098000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3E24CA8B70F88AC7AC1-806A
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:06:06
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [137] - -
          [Scl_LWI_SensorNotCalibrated]
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:06:06
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 G    HW: 6C0 820 045 G
   Component: AC Manuell    H03 0204
   Serial number:  1701161B-1748
   Coding: 200100010000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 23121BFFFB5AC72FA3F-8076
262914 - Refrigerant Pressure
          B10AB F0 [013] - Too Low
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:00:19
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [012] -  -
                    Reset counter: 84
                    Mileage: 47057 km
                    Date: 2019.07.06
                    Time: 15:36:27
                    Voltage terminal 30: 12.6 V
                    Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 001098150496
   Coding: 03120A5040530A7B4B844080A12F07800000580053010000000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_MQBA0.rod
   VCID: 2F3AE7CFA792734F377-807A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 802 DK    HW: 6R0 959 802 DK  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU012011770126223
   Coding: 1000A0
   Subsystem 2 - Part No SW: 6R0 959 801 DH    HW: 6R0 959 801 DH  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU020011770202567
   Coding: 0000A0
   Subsystem 3 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1700939P3
   Subsystem 4 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU016011770167311
   Coding: 1000A0
   Subsystem 5 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU030011770301365
   Coding: 0000A0
11 Faults Found:
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [009] - Open or Short to Plus
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:40
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:40
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:34
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [009] - Voltage Supply Open or Short to Plus
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:34
529173 - Databus
          [Anhaenger_01 Datenbus fehlende Botschaft]
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:32
540693 - Databus
          [LWR_AFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:31
558100 - Databus
          [Airbag_02 Datenbus empfangener Fehlerwert]
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:32
722436 - No Communications with Moveable Sunroof Control Module
          U0207 00 [009] - -
          [Steuergerät für Schiebedach->kein Signal/ Kommunikation]
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:31
787462 - Relay for Headlight Washer System
          B1262 15 [008] - Open or Short to Plus
                    Reset counter: 63
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:05:57
934148 - No Communications with Rain/Light Sensor
          U10F6 00 [009] - -
          [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                    Reset counter: 23
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:31
          U1101 00 [009] - Active
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:31
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00Q 002 0380
   Revision: --------    Serial number: 003TH00G5JSV
   Coding: 88C0C000000000005C0000CA008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A2CC69B6CD0A6E7909-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 820 906 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00C7211AA8361EQ
   Subsystem 2 - Part No SW: -----------    HW: 410 822 101 17
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H002629E1E13227F
   Subsystem 3 - Part No SW: -----------    HW: 442 150 112 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A002C29E291A05BH
   Subsystem 4 - Part No SW: -----------    HW: 442 150 112 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A001229E0845272/
8 Faults Found:
          B1000 1B [137] - Resistance Too High
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:49
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:49
          B1006 1B [137] - Resistance Too High
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:49
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:50
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:49
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:49
9447189 - Seat Occupied Sensor; Passenger's Side
          B1027 15 [137] - Open or Short to Plus
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:49
          U1101 00 [137] - Active
          [ATP Wrong IKA]
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:47
   Part No SW: 6C0 920 740 E    HW: 6C0 920 740 E
   Component: KOMBI         202 2310
   Coding: 272409002080000801082A001000000000000000
   VCID: 241018E3FE54C017DA5-8070
8 Faults Found:
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:53
16776962 - Databus
          [Airbag_01 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 22:54:01
16776964 - Databus
          [BCM_01 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 22:54:01
16776965 - Databus
          [BEM_02 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 22:54:01
16776968 - Databus
          [ESP_24 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 22:54:01
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 22:54:01
16776978 - Databus
          [LH_EPS_01 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 22:54:01
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 22:54:01
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001098150496
   Coding: 01010038300A560071000000000000000001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 659645E7B5EEF91F0DB-8030
10 Faults Found:
0769 - Analog Measuring Input
          C1155 31 [008] - No Signal
                    Reset counter: 62
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: OFF
1282 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 22
                    Mileage: 36692 km
                    Date: 2017.10.14
                    Time: 00:14:45
                    Supply voltage: Terminal 30: 8.4 V
                    Terminal 15: On
131604 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:58
                    Supply voltage: Terminal 30: 12.6 V
                    Terminal 15: OFF
131655 - No Communication with Towing System Control Module (J345)
          U1003 00 [009] - -
          [Timeout Knoten 0x47 / 69 - Steuergerät für Anhängererkennung]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:00:16
                    Terminal 15: On
131668 - Headlight Range Control Module
          U101E 00 [009] - No Communication
          [Timeout Knoten 0x54 / 55 - Steuergerät für Leuchtweitenregelung]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:00:16
                    Terminal 15: On
197169 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
          [MFL (LIN#2) Timeout]
                    Fault Frequency: 20
                    Reset counter: 22
                    Terminal 15: OFF
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 9
                    Mileage: 30934 km
                    Date: 2017.05.12
                    Time: 13:00:01
                    Supply voltage: Terminal 30: 14.1 V
                    Terminal 15: On
8782087 - Multi-Function Switches in Steering Wheel; Right
          B114C 96 [009] - Component internal failure
                    Reset counter: 22
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: On
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:00:17
                    Supply voltage: Terminal 30: 14.5 V
                    Terminal 15: On
15360768 - Component Protection
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:53
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AJ    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  323 3242
   Serial number: CH1K0176
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 71BE21B7712625BF613-8024
1094656 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:24
1073664 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [DEM_LEFT_ENDSTOP_NOT_KNOWN]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:24
1073920 - Steering End Stops Not Learned
          [DEM_RIGHT_ENDSTOP_NOT_KNOWN]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:08:24
Address 55: Headlight Range
   Part No SW: 3Q0 035 819 B    HW: 3Q0 035 819 B
   Component: MU-S--ER      H30 0361
   Serial number: VWZAZ2T1070906
   Coding: 02620000BE00000051110001000918001F0100C60120010001
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 3038E4B3BAAC6CB72ED-8064
   Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
   Component: ABTm_Std2  H53 1031
   Serial number: VWZ8Z9SKU01X4F
15 Faults Found:
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:53
                    Voltage terminal 30: 12.2 V
0518 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:59
                    Voltage terminal 30: 11.8 V
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
                    Reset counter: 22
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:59
0526 - Connection to Front Left Loudspeakers
          B1109 F0 [008] - Short Circuit Between Poles
                    Reset counter: 87
                    Mileage: 48094 km
                    Date: 2019.07.20
                    Time: 13:06:20
                    Voltage terminal 30: 12.3 V
6697 - Databus
          [Airbag: no communication]
                    Reset counter: 62
                    Network diagnosis-Status: Not available
6715 - Databus
          [BEM: no communication]
                    Reset counter: 62
6700 - Databus
          [Dimming: no communication]
                    Reset counter: 62
6702 - Databus
          [ESP: no communication]
                    Reset counter: 62
6704 - Databus
          [Gateway: no communication]
                    Reset counter: 62
6705 - Databus
          [Terminal_status: no communication]
                    Reset counter: 62
6708 - Databus
          [Engine: no communication]
                    Reset counter: 62
6713 - Databus
          [System information: no communication]
                    Reset counter: 62
6718 - Databus
          [BCM: no communication]
                    Reset counter: 62
6691 - Local Data Bus
          U10BA 00 [008] - No Communication
          [Sub-Bus keine Kommunikation]
                    Reset counter: 88
                    Voltage terminal 30: 12.5 V
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 62
                    Mileage: 48112 km
                    Date: 2019.07.20
                    Time: 00:01:09
                    Voltage terminal 30: 11.7 V
                    Interface for external media: status-Status: Open circuit
Address 69: Trailer
End----------(Elapsed Time: 01:32, VBatt start/end: 12.0V/12.1V)-----------
myounus
Northwest UK
C?ID=321059
BSI unit??? Are you referring to Module 09 Cent Elec, i.e. BCM J519? If so, it will have component protection. Unless you have a backup of the old one the only way to swap it would be by using ODIS or taking the car to a dealer with ODIS, as they will be able to download the coding and adaptations as they pair the BCM to the car.
Frikki
South Africa
C?ID=357723
Thanks. Is it maybe possible to use another exact same car with same bcm part number long coding. Or is it impossible. Many thanks.
myounus
Northwest UK
C?ID=321059
Yes but it will still need component protection removing. There is no way around it I'm afraid.
Frikki
South Africa
C?ID=357723
Thanks my friend. Lastly. So with component protection causes things not to function in vehicle. Or what exactly is happening with cp. Thanks
myounus
Northwest UK
C?ID=321059
Component protection is an anti-theft system that locks/reduces some functions of the module or in some causes prevents other functions from working. Think of it like a padlock, once it is removed the lock is open :)
VW have a database of all blacklisted VIN numbers from stolen vehicles, therefore if you try to change the
VIN of a stolen part onto your car it will fail. It has been designed to stop the trade of stolen parts.
Frikki
South Africa
C?ID=357723
Thanks dear friend. Make sense. Keep well.
myounus
Northwest UK
C?ID=321059
Are you sure that was the only design objective? ;)
VW could never have an ulterior motive, such as making billions in CP removal and trying to enforce ODIS only coding, removal of CP, SVM, parameterisation and elimination of all 3rd party competitors. CP makes perfect sense to prevent theft of a BCM, which is a mega high value theft item traded on the black market - must have gold in it! Really easy to steal too, once you've spent ages removing the glove box dash panels.
What makes even less sense is adding in the gateway which is a real pain to get to, let alone remove it!
