Golf R mk7 2014 - missing Race Mode Driver Profile
Krimbo
London, UK
Hello
Recently retrofitted a Discover Pro Mib2 unit along with a brand new 2018 virtual cockpit dash. Had fuel guage error that was solved by changing out my old 5q0 gateway control module to a newer 3q0 gateway control module. However I have a missing driver profile error where by Race Mode is no longer available to select. I have Eco, Normal, Individual only.
Does anybody have any advice or is there somebody who could help me? I have read in another post that this can be and has been solved.
K
South Molton, UK
Isn't Race Mode a FeC that needs to be restored by someone with an ODIS/Fazit connection?
golfi_vend
Tartu, Estonia
C?ID=195131
Usual behaviour for this type of retrofit.
You need to find someone who can remove CP and load parameters to GW.
Krimbo
London, UK
Hi the person who did the retrofit spent quite a few hours attempting to re-parameterise is what he said to me. He had someone remotely connect using odis to try and sort but no joy. Wondered if anyone had any exact steps to solve by any chance..? I have been without race mode for nearly 3months and it's super sad lol.
Krimbo
London, UK
Also I was told CP deffo removed and parameters of Golf R loaded on to the new gateway. What was weird is that racemode worked before on my old gateway with the retrofit but then had fuel guage error which basically left me to guess when my fuel tank was empty. Since upgrading to a new gateway I got the race mode issue. I've currently got the car at VW for a dsg oil change and asked if they could look into but they said they haven't got the slightest idea where to start and wouldn't want to break anything already programmed.
South Molton, UK
Looks like you need to find a VW specialist who knows what they are doing ;)
Krimbo
London, UK
Can anyone recommend a specialist who has solved this race mode issue before then? Would really appreciate it
myounus
Northwest UK
C?ID=321059
djalix is in your neck of the woods. Google vagcarcoding and his details should come up. The driver profiles are FEC, i.e. Gateway. From memory this is caused by an incorrect dataset. Can you post a full autoscan so we can see.
Krimbo
London, UK
Djalix on this forum or is he the guy to ask for when contacting vagcarcoding website? I unfortunately don't have the car with me at the minute (it's at VW) so cannot pull a scan. Soon as I can I'll post it up. Cheers @myounus.
golfi_vend
Tartu, Estonia
C?ID=195131
Be sure to use legit interface.
Issue I've seen with this type of retrofit is that parameter set gets deleted with mib2.5 install from gw and sometimes FEC isn't active for driver modes.
I'm not aware if parameter for R and regular differ or just fec which tells which nr driver mode is active.
Krimbo
London, UK
Thanks @Golfi appreciate the input. Hopefully I can get to the bottom of this. Just need to get my car back from VW first then can pull some scans
DJAlix
London, United Kingdom
C?ID=238277
Evening guys and gals,
So the OP reached out and I have now had two interesting and indeed frustrating sessions with this vehicle, todays was 5 hours!
In the first session I completed the following:
- 3Q0907530L/C gateway in place. Re-coded correctly as additional modules were added to installation list which the vehicle does not have. Recoded vehicle also. Once error free I attempted to upload parameters with no luck. Replace Module and FES = Control module not valid.
- 5Q0907530T gateway in place, CP removed, parameter upload no go. Replace Module and FES = Control Module not valid.
- 3Q0907530L/C reinstalled, Drive Mode Issues remain, no errors on vehicle.
In the second session:
- 3Q0907530L/C installed, tested additional upload of parameter sets, no go.
- 5Q0907530T Gateway reinstalled and then flashed to AJ, CP Removed, parameter upload no go. Replace Module and FES = Control Module not valid.
- 5Q0907530T (now AJ) Gateway flashed to AM, CP Removed, parameter upload no go. Replace Module and FES = Control Module not valid.
- 5Q0907530T (now AM) Gateway flashed to Q, CP Removed, parameter upload no go. Replace Module and FES = Control Module not valid. Range Error Returned. Only available Q firmware was Audi so am guessing this was always going to fail but wanted to see the Range Error as its something I have not seen before and I have retrofit way too many AID to count / remember.
- 5Q0907530T (now Q) Gateway flashed to T, CP Removed, parameter upload no go. Replace Module and FES = Control Module not valid.
- 3Q0907530L/C installed in order to return vehicle to error free state, ECO, Normal and Individual Drive Modes.
Official parameterisation and FES is not possible with this vehicle / VIN. Tested all available manual parameter sets with interesting results as while able to always restore the basic drive modes of ECO, Normal and Individual whenever I managed to restore Race it would only be in conjunction with Individual and switching via the mode button was not possible. Also on ignition cycle any and all available drive modes would disappear. Disconnecting and reconnecting power to the Gateway would bring drive mode display back again but not allow switching. A further ignition cycle would then cause them to disappear again until re-uploading. Even a hard reset on the Gateway would not make them pop again.
Conclusion, unless anyone else can shed light on this, a used gateway from a golf R needs to be sourced and installed in to this vehicle with parameters intact or another golf R needs to host a gateway which can be parameterised / FES officially and then transferred over to the problem vehicle, example:
- Golf R with factory fitted T found.
- Replace factory T with another T module.
- Code, parameterise, FES etc.
- Remove and install in to problem vehicle.
Any ideas / thoughts would be welcome as I am not sure what else would be possible short of "spoofing" another R but this comes with its own set of complications...
myounus
Northwest UK
C?ID=321059
Alix can you post a scan of this car for completeness. Maybe it's not an R from factory??
DJAlix
C?ID=238277
Car is an R :)
Scan from first session, post recoding vehicle in order to correct incorrect coding / adaptations:
Wednesday,13,November,2019,19:49:34:27508
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
Dealer/Shop Name: VAG Car Coding Limited
VIN: WVWZZZAUZEW281704   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZEW281704   Mileage: 58908km-36603miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 091D00322466050B2004
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001006
   ROD: EV_ECM20TFS0205G0906259E.rod
   VCID: 302CF5776B4827CF17-8065
Readiness: 1110 0001
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4311
   Revision: 05852204    Serial number: TFK01401212258
   ROD: EV_TCMDQ250021.rod
   VCID: 240409272FB08B6FE3-8071
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6008400000014A
   Coding: 01FA93A15428296D037E070041C76980C92A94C0E08296F7F8425078C208
   Shop #: WSC 00046 000 00000
   VCID: 7CB41147F78013AFFB-8029
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120014200100011005004000101000
   VCID: 6680532F990CB97F3D-8033
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011402302594
   Coding: 03101A46C24122F30BA44080B10C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BB6125BF28E1497F2-802F
   Component: WWS    140119  042 0551
   Serial number:         140122202111
   Component: RLFS  024 0042
   Serial number: Y14M01D28H23M40S39S8
   Coding: 00A8DD
   Serial number: 000000000ZY140090BAC
   Serial number: 00000000000028702150
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO26267287
   Coding: 181901
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331401301971
   Coding: 0071051011
   VCID: 3E30DB4FA11CC1BF95-806B
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H05 0200
   Serial number: 20031903270019
   Coding: 001C1300FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3620C36F892C09FF4D-8063
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0355EE
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F4EE64BE69608B7DE-802B
   Belt Pretensioner left:
   Serial number: 34169677B20011471070
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B21011470419
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 201 14
   Serial number: 3576700000006D44CE0
   Subsystem 4 - Part No SW: -----------    HW: 480 000 901 14
   Serial number: 35867000000B2C6C7E07
   Subsystem 5 - Part No SW: -----------    HW: 480 402 501 14
   Serial number: 3516502B712AB1B193CF
   Subsystem 6 - Part No SW: -----------    HW: 480 402 501 14
   Serial number: 3526502BB12FAE23C23N
   Subsystem 7 - Part No SW: -----------    HW: 480 400 901 14
   Serial number: 3556502A113013E3603S
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 24011404221204
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 23AD4008AF80AE00018D7E011400000000000000
   Shop #: WSC 00046 123 12345
   VCID: 2A18E71F4D945D1FD9-807F
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007089302
   Coding: 030100042B085900FF00027E9C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: 383CCD578338FF8F5F-806D
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0038
   Serial number: 29130000553640094032
   Coding: 2DFFFF
   Serial number: 4427022403
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00020.12.13
   Coding: 0001
   VCID: 46C0B3AFF9CC997FDD-8013
   Serial number: 20011402091012
   Coding: 001F0220D001048000001000
   VCID: 40CCA5B7DBE8B74FE7-8015
   Serial number: 00000000000001664433
   Coding: 1D0000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5063
   Coding: 8103
   Shop #: WSC 65136 001 1048576
   VCID: 393AC853B832E687A0-806D
   Serial number: 19011402091397
   Coding: 001F0020DE01048000801000
   VCID: 3FCEA64BA616C8B79E-806B
   Serial number: 00000000000001652494
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 02AE01000B000200
   VCID: 3D32DC43AC1ADAA78C-8069
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5NA 035 020 A    HW: 5NA 035 020
   Component: MU-H-ND-EU    H54 1121
   Serial number: A845F0HB007430
   Coding: 02731001FF00000051110101008808001F0107E601208400FF
   VCID: 2F2EF60B767638370E-807B
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV2772538
   Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 131113201718
   VCID: 2D12EC037C7A4A273C-8079
End----------(Elapsed Time: 01:28, VBatt start/end: 12.7V/12.7V)-----------
downtime
Finland
C?ID=280813
Send me PM. I’ll give you some hints how you might solve this.
Online parameterization and FeC restore DOES NOT work for modules not in factory database for this VIN. I thought that would be quite clear for people now.
You need some other means:)
golfi_vend
Tartu, Estonia
C?ID=195131
Can I somehow join the chat?
FeC restore does work to some extent, but not parameters.
Krimbo
London, UK
Hi all, many thanks for the responses. Would much appreciate if we shared the knowledge of the fix given how long we have been after a solution. ......Owner of a golf R missing race mode :(
downtime
Finland
C?ID=280813
Yes with FeC true but for online coding and parameterization no go. I’ll send you PM :)
DJAlix
C?ID=238277
Thanks. Will fire over a message once home. Appreciate the time and assistance.
The "online actions" were mainly for completeness and for the owners peace of mind. The actual main point of the above works was to see if any of the available files from another "tool" could be applied to the gateway when flashed to different versions.
downtime
Finland
C?ID=280813
Djalix and golfi_vend I sent you both PM. Check if it makes any sense :)
