Hello guys, I was trying to deactive the start/stop system on an Audi A1 2015, but I coulnd´t.
I´ve tryied with 09-cent elect > byte 26 > bit 7 but it continues working after that coding.
Also I´ve found a adaptation channel related with the start stop in engine module, but it also didn´t work.
Autoscan attached.
Autoscan attached.
Wednesday,30,October,2019,10:30:26:26375
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
Workshop Code: 123 12345 000001
VIN: WAURYA8X4HB084151 License Plate: CODING A1
Mileage: 16880km-10488mi Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 5F 62 72
VIN: WAURYA8X4HB084151 Mileage: 16880km-10488miles
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 AL HW: 04E 907 309 AC
Component: R4 1.4l TFS H26 2118
Revision: R7H26---
Coding: 00250012240401080000
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_ECM14TFS01104E906027AL 001006
ROD: EV_ECM14TFS01104E906027AL.rod
VCID: 6E90D86CB1F0023F45-803A
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 041 K HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 052 2605
Revision: 00005026 Serial number: CU501703077095
Shop #: WSC 00046 000 00000
VCID: 312A0310A84E5DC718-8064
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 S HW: 6R0 907 379 BA
Component: ESP9.0i H04 0006
Serial number: 08511994170319
Coding: 31DF488B8D2B33C41115106E00528C12B1CC8808000AE3090700
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 3FCE5528A61ABBB79E-806A
Address 08: Auto HVAC (J255) Labels:* Redir Fail!
Part No SW: 8XA 820 043 HW: 8XA 820 043
Component: Klima 1 Zone H01 0010
Serial number: 00000000455748
Coding: 6403280890
ASAM Dataset: EV_AirCondiFrontAU210 007002
ROD: EV_AirCondiFrontAU210_007.rod
VCID: 02489CDC9568165FB1-8056
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AF HW: 8X0 907 063 AF
Component: BCM PQ35 M 113 0821
Revision: AB113821
Coding: 06000A2CB805F3C0201841E00104094C43FF630A20EF5922E400878700C1
VCID: 004C96D49364044FA7-8054
Subsystem 1 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62721791
Coding: 02005D
Subsystem 2 - Part No: 8X0 951 177 A
Component: Sensor, DWA 0 005 0002
Subsystem 3 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8XA 959 655 A HW: 8XA 959 655 A
Component: Airbag10.41 H08 0011
Revision: -------- Serial number: 003NZ004LD2F
Coding: 30323236303330323439554A304C38584153
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
VCID: 59FA9BB0587E758780-800C
Serial number: 3554VRB400U59FV2JGOQ
Serial number: 3575HRB40514D4QC60N1
Serial number: 3585HRB4061422T4B82K
Rear Impact Crash Sensor:
Serial number: 3515ZRB400A599U2P8R1
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 AE HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: FF010018 Serial number: 20170317100709
Coding: 1894004000
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7F4E1528E69A7BB7DE-802A
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 14 02 2017 B0031610
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8XA 920 930 D HW: 8XA 920 930 D
Component: KOMBI_MEDIUM H05 0530
Coding: 11CE01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
VCID: 4CD472E4E7AC102F0B-8018
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0090
Revision: 1P170044 Serial number: 4441P1731008F0
Coding: FBCF7057000100010253
VCID: 116AA390C80E7DC738-8044
Subsystem 1 - Part No SW: 8K0 915 181 N HW: 8K0 915 181 N
Component: J367-BDM H08 0270
Serial number: 64073A30043131329254
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Serial number: 16122900000000000A38
Component: IMMO H05 0530
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 F HW: 8X0 959 793 F
Component: TSG FA H11 0415
Coding: 011802204100000000
VCID: 50EC6694038434CF77-8004
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AM HW: 6R1 909 144 E
Component: EPS_TRW_ALow 313 3142
Serial number: CH3N1150
Coding: 800700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 F HW: 8X0 959 792 F
Component: TSG BF H11 0415
VCID: 4FEE65E81EBA2B376E-801A
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 E HW: 8X0 907 357 B
Serial number: 170315-0002-031
Coding: 11B3941010022500
ROD: EV_HeadlRegulBasic.rod
VCID: 44C45AC4CFFCD86FC3-8010
Part No SW: 8XA 035 182 F HW: 8XA 035 182 A
Component: RMC Cnct Plus H62 0186
Coding: 01000400004051470023000102010000010000
VCID: 4AD874FCE5D80E1F39-801E
Subsystem 1 - Part No SW: 8X0 919 603 B HW: 8X0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9462C-0H3119915
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H08 0415
Coding: 010002200000000000
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H08 0415
End----------(Elapsed Time: 01:08, VBatt start/end: 12.4V/12.3V)-----------
