2001 MK4 Jetta 1.8T. Manual trans. California vehicle, not a rust bucket. 125K miles. Immobilizer initiated.
Vehicle condition: extensive service and upkeep, 4K miles ago.
New windshield 4 weeks ago. Car wash today (2nd or 3rd wash).
This was abrupt, never had these symptoms.
1/2 hour after car wash, vehicle went into immobilization mode while attempting to start from warm condition. Two avail factory keys, neither solve problem.
While key is in switch and turned on [car is dead cold at this point]: fans are running full speed, tach and speedo are pegged, immobilization yellow light is on or flashing.
The mileage changed to KM and odometer significantly reduced.
STEPS: Like a dummy I should have grabbed my VCDS and scanned it first. Instead I disconnected the battery terminals (both) and shorted them together for 15 minutes. No change.
Ran a scan (while the fans are humming away....). Posted scan below.
From the scan results I think I have too many intermittents. I need to check grounds. I need to check the oil level sensor wiring.
I'd like to check the ignition key coil via VCDS without digging around the wiring, but can't seem to find how to do that.
(the radio and door lock faults were existing...never mind the man behind the curtain)
Do you think I'm on the right track? Thank you in advance.
Eric
Eric
Saturday,02,November,2019,19:16:52:23523
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
76
Mileage: 69940km-43458miles (this is not correct, actual mileage is 125,010. Went wonky during immobilization).
Address 01: Engine Labels: 06A-906-032-AWW.lbl
Part No: 06A 906 032 DL
Component: 1.8L R4/5VT G 0006
Coding: 07500
Shop #: WSC 22110
VCID: 6B83C6759A904E6F0C5-5184
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00066 000 00000
VCID: 2B0306755F108E6F4C5-5184
Part No: 6Q0 909 605 F
Component: 04 AIRBAG VW6 0202 0004
Coding: 12340
Shop #: WSC 00066
VCID: 3A2D3331A54A27E7C73-4B3C
Address 17: Instruments Labels: None
Part No: 1j0 920 905 j
Component: A4-KOMBIINSTR. VDO V53
Coding: 10432
Shop #: WSC 00098
VCID: 6E85CF61A982BB472BB-5184
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VwZ7Z0A3253560
IMMO-IDENTNR: VwZ7Z0A3253560
00-00 - -
01128 - Immobilizer Pickup Coil (D2)
35-10 - - - Intermittent
01176 - Key
65-10 - Unauthorized - Intermittent
01177 - Engine Control Unit
Address 19: CAN Gateway Labels: None
Part No: 6n0 909 901
Coding: 04102
Shop #: WSC 08258
VCID: 1079B199D376CDB7597-5184
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 065597C1A1329307F3B-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002B
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002r
01358 - Internal Central Locking Switch; Driver Side (E150)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1JM 035 157 A
Component: Radio DE2 0005
Coding: 02043
Shop #: WSC 22503
VCID: 3E253F21B9620BC7FBB-51F2
00856 - Radio Antenna
36-10 - Open Circuit - Intermittent
End----(Elapsed Time: 05:12, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
