New ECM for '12 Passat SE gasser
jettajim
C?ID=14954
Hi,
I know that I cannot install a new ECM in this car with my vagcom because you need a code that only the 'fatherland' has. Can only the dealer get this code or can I go to an independent mechanic to have this done?
Thanks,
Jim
Keithuk
Stoke on Trent, England
C?ID=122432
Welcome to the forum Jim.
You need to post a full AutoScan inside CODE tags whether there are any error code or not [CODE] Full AutoScan [/CODE] as it shows more info on the system.
In principle, if the independent mechanic has jumped through all the flaming hoops needed to get on-line with the fatherland, it's possible.
Why? How will that help here? ;)
Jef
HQ
Yes, an independent mechanics can do this if they have invested a metric butt load for the factory VAS scan tool and registered with the 'fatherland'. My friend's repair shop has done this, but I doubt he will get a good return on the investment, not like he is doing ECM swapping and key adaptations every day...
Which is irrelevant to the question at hand on a 2012 car. :)
jettajim
C?ID=14954
Yes, I have been scanning this car and posted one of them a while ago. I was told that it's probably a vacuum leak. I used my vagcom just a few weeks ago and did the method as posted here for fuel trim values to maybe help me. I still couldn't find a leak. I cleared the codes and the car ran like new for a few days. Now, this AM, the car was shuttering (rough idle) with flickering lights etc. I did a restart 6 times and it didn't help.
The car has 60kmiles and the CEL has been on for the past 20kmiles. The dealer said he fixed it but didn't. I'll scan the car tonight and post the results.
So far, I have:
--cleaned the MAP
--new PCV
--checked the bolts on the top end (hoping that one was lose causing a leak)
--changed the plugs(only done for routine maintenance)
--new battery (factory battery died in <3 years!)
I'm interested in seeing the codes tonight because the car has never shuttered like it did this AM.
I should never have sold my '01 Jetta TDI. That car was bullet proof and never saw a mechanic besides me!!
I'll post the scan as soon as I can.
Thanks,
Jim
jettajim
C?ID=14954
Attached is my scan from a few minutes ago. Nothing new as I have seen these all before on previous scans for this car. Any insights? I started the car this evening and it started and idled fine. Should I do a TBA?
Thanks,
Jim
Tuesday,13,January,2015,20:30:08:06624
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: 1VWBH7A32CC034086   License Plate: PASSAT
Mileage: 93560km-58135mi   Repair Order: 01.13.2015
Chassis Type: A3 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 46 4F 52 56 62 72 77
VIN: 1VWBH7A32CC034086   Mileage: 93560km-58135miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DD    HW: 07K 907 309 A
   Component: 2,5l R5/4V       01 5685
   Revision: T6H02---    Serial number:
   Coding: 0000075
   Shop #: WSC 08408 001 1048576
   VCID: 73EF76E312ACC8B9629-8026
012408 - Throttle Control
               P3078 - 000 - Airflow at Idle too Low
                    Mileage: 93086 km
                    Date: 2015.01.06
                    Time: 07:21:13
                    RPM: 1240 /min
                    Load: 15.3 %
                    Speed: 63.0 km/h
                    Temperature: 87.0°C
                    Temperature: 5.0°C
                    Absolute Pres.: 1020.0 mbar
000262 - Manifold / Barometric Pressure Sensor (G71) / (F96)
               P0106 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 93100 km
                    Date: 2015.01.06
                    Time: 07:40:14
                    RPM: 1368 /min
                    Load: 36.8 %
                    Speed: 14.0 km/h
                    Temperature: 86.0°C
                    Temperature: 17.0°C
   Part No SW: 09G 927 750 LH    HW: 09G 927 750 LH
   Component: AQ 250 6F           2043
   Revision: 00H97000    Serial number:
   Coding: 0000840
   Shop #: WSC 09003 957 00200
   VCID: 020123275D16F13179F-8057
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 22
                    Reset counter: 201
                    Mileage: 46733 km
                    Date: 2013.07.01
                    Time: 14:57:17
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Coding: C54BC0F5492508FEA30B03EC921F1061A60000
   VCID: 79F344CBF0C0B2E9285-802C
                    Reset counter: 130
                    Mileage: 93100 km
                    Date: 2015.01.06
                    Time: 07:40:14
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 50690
                    Count: 768
   Part No SW: 561 907 044 D    HW: 561 907 044 D
   Component: Climatronic   H01 0102
   Revision: 00001001
   Coding: 0010001002
   ROD: EV_ACClimaBHBVW411.rod
   VCID: 1835614FE38A4BE1B7B-804D
   Part No SW: 5K0 937 085 P    HW: 5K0 937 085 P
   Component: BCM PQ35 B+   011 0048
   Revision: BH011001
   Coding: 6F200EB8802B08D4088A0001360004480271008641A00D60648040000C70
   VCID: 4085E92FD39A23212FB-8015
   Component: RLS 111111 05  54  0403
   Coding: 22300A
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM00L4VW
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   VCID: 6FE77A93B684EC59861-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100008AGS0V
   Coding: 30324D
   Serial number: 3572MSME22307460ZZZH
   Serial number: 3582MSME3D4E1164ZZZ/
   Serial number: 3516KSME25534515ZZZJ
   Serial number: 3526KSME66671115ZZZN
   Serial number: 3556LSME570A5411ZZZR
   Serial number: 3566LSME502A5411ZZZN
   Part No SW: 1K5 953 501 Q    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20110917101307
   Coding: 098A140000
   VCID: 397384CBB84072E9685-806C
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 B    HW: 561 920 970 B
   Component: KOMBI         H07 0507
   Coding: 231C01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 1933644B188052E9885-804C
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 21101101291151
   Coding: 461000
   VCID: 387581CF8B4A6BE197B-806D
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1829227R0G9M05
   Coding: 0000002
   VCID: 63CF06A3A24C5839129-8036
   Component: IMMO          H07 0507
   VCID: 6AD16B878D660971D1F-803F
   Revision: 13110009    Serial number: 0003479621
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BBF3E43523C60F95A9-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Component: EZE_2         H40 1620
   Coding: 00000008
   VCID: 6FE77A93BE84EC59861-803A
   Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0004
   Revision: 15110009    Serial number: 0003575889
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CBD3D5F573267C1533-8009
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L1120765
   Coding: 0500040004000B
   Shop #: WSC 25053 444 999999
   VCID: 63CF06A3624C5839129-8036
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661082186
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
   VCID: 275752B35EF4F4190E1-8072
End-------------------------(Elapsed Time: 02:52)--------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
A TBA can't hurt, but I doubt it will fix the problem.
What values are you seeing for the Manifold Pressure, the Barometric Pressure, and the Airflow under various conditions?
jettajim
C?ID=14954
I'll check tonight--thanks! What groups do I look at?
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Just for a record ,
VAS online is not only option for this, It can be done other way by transferring or adding immo data , but of course it need good skills and good and very expensive tool :).
Also USED ECU can be install as well.
Jetta 97
C?ID=81680
So far, I have:
--cleaned the MAP
--new PCV
Thanks,
Jim
I do not think you have ECU problem, it looks like you TB has lot of carbon on it and getting stuck time to time.
I suggest to clean TB , reset codes and see. Be care full when you clean TB , do not apply liquid direct on it.
jettajim
C?ID=14954
Thanks Jetta, 97. I now don't think it's the ECM either.
I will next clean the TB. Can this be done with it on the car?
Note: my wife drove it to work yesterday and when she got home, I did a TBA. But first, when she drove inside the garage, the car was very loud--as if the exhaust pipe was missing! She also said the car almost stalled a few times at red lights. I cleared the codes and cycled the engine twice before doing the TBA. After the TBA, the vagcom said the TBA was OK. I restarted the car and dang, it was even louder. So it sits until this weekend. She's driving our '93 Dodge Cummins:)
There must be a massive leak that should be easy to find. I replaced the PCV disk but that wasn't the issue. I wonder if the N80 is it?
Uwe, I can't get the values you asked for because the car idles so rough and loud that I don't want to drive it.
Thanks again!
Yep, sounds like you should focus on finding the source of the noise first. Fixing whatever is causing that may fix other issues as well.
Now as for cleaning the TB, my personal opinion is that it cannot be done properly with it on the car.
jettajim
C?ID=14954
OK, I finally fixed the problem. Jetta 97, you were correct. I removed the TB and cleaned it with carb cleaner last weekend. It had some oil/carbon built-up but not much. It's been 13+ years since I messed with a gasser and forgot that this part has to be so clean. I cleared the codes and ran it for the week and it was normal. Got it inspected today and it passed.
The loud noise was the aftermarket (Dorman) PCV. When I started to diagnose this problem months ago, someone said it may be the PCV. I bought the part from Amazon for $18 and installed it last November. This wasn't the fix. The rubber on the aftermarket piece was VERY thin and it tore in one spot. I put the original back on and all is good. If you take the original off carefully in the first place, it can be re-used. The aftermarket not only has cheap, thin rubber, the plastic is cheap. Some of the tabs broke when removing it no matter how careful I was. It sucks that you have to buy the entire valve cover just for this $20 piece!!! But I'll tell you something, as soon as the PCV goes, it goes and the car doesn't! I was lucky because the car was in my garage.
This car just turned 3 years old and has 60k miles. It's been our workhorse for long distance vacations, school activities etc and has not had one problem except for this--but it was an easy fix. Oh yeah, the cruise has been out for a while. After doing some research, it sounds like it is the stock--maybe a bad connection. Any ideas?
Thanks for all of the help!
Jim
It's possible the ECU may have refused to engage cruise due to some of the other faults you had. Before you make yourself crazy, get the ECU free of faults and then verify that cruise is still inop. If so, check MVB 066 and 067 for the status of the various switches and such. Hover your cursor over the data fields to see what they mean.
jettajim
C?ID=14954
Uwe,
I checked those fields and did as you suggested but I can't figure out what the nomenclature represents. I logged what I was doing. The values did change in switch positions II of Group 66 with setting the cruise on/off and decreasing/increasing the set speed.
Switch positions I in both Groups changed when the brake pedal was depressed.
In Group 67, Shut-Off Crit. (rev.) and Shut-Off Crit. (irrev.) had values of 255 each throughout the test. Not sure what this means.
The ignition was on but engine off.
Also, when I did an Auto Scan at the beginning, it said 9-Cent Conv had a malfunction. There was no fault code. What does this mean?
Thanks,
Jim
OK, for Group 066, VCDS should show you the following when you hover your cursor over field 2:
xxxxxxx? = Brake Light Switch
xxxxxx?x = Brake Pedal Switch
xxxxx?xx = Clutch Pedal Switch
xxxx?xxx = CCS (Cruise Control System) enabled
xxx?xxxx = ACC (Adaptive Cruise Control) available
xx?xxxxx = Main Switch engaged
??xxxxxx = CCS Status
The position of the question mark indicates which bit(s) correspond to the thing being desribed.
Ditto for field 4:
x0xxxxx? = CCS ON (CAN)
x0xxxx?x = SET (CCS ON)
x0xxx?xx = Deceleration (-)
x0xx?xxx = Acceleration (+)
x0x?xxxx = SET
x0?xxxxx = RESUME/RESET
?0xxxxxx = CCS ON (Hardware Pin)
If the problem is due to any of the switches in the stalk (or elsewhere) you should be able to identify it.
Did you save the scan? I rarely like to speculate on what something means without seeing the actual data. ;)
NostraJackAss
Your ecu needs a firmware update.
The cruise may also be disabled, because the faults are circulating from Trans and ABS on CAN......
Make sure to do a broadcast or access the controllers directly erasing the DTC's if they exist.
Check that the TV in blocks is ADP-ok...... for both main ADP, and Kick-down ADP.
Leaks can come from any location which cause false air.
If sporadic be sure to suspect the N80, LDP , and Booster circuit.........( since mechanically switched or altered )in addition to know VC issues.
I have found that re-routing the VC vent to the lower air box cover, is a much better place to send crank-case gases.
This way you can see when oil pools here, and it is filtered out one last time to the combustion chamber, verse taking a CAT down.
You may find that due to running super slick synthetic oils...... that this increases the vapor/PSI in block.
A solution is to run conventional SAE oil with more frequent oil changes.
Please post a new auto-scan after broadcast of DTC's
