- Aug 10, 2016
- 3,759
- 4,174
- Netherlands, eastern part
- C?ID=284912
Let's imagine a bloke. This bloke is from the UK and let's call him a typical British name, for the sake of his privacy.
Since Will is his actual name, we'll use that.
Will owns a VW Polo and is familiar with VCDS. So far I like Will a lot, but things will take a drastic turn for the worse.
Somehow Will found my email address and linked this mail address to a deep love for the PQ25 platform. So far Will is right.
Let's see what Will wrote:
here is the autoscan, suspect a clone:
Full of intermittent codes but the ABS is my main issue. The fine promise of some queens currency makes my heart accelerate instantly so why not.
Reverse engineering ABS codes is something I really love to do anyway, the MK60EC1 and Bosch ESP units are good fun and RHD is one up one the difficulty scale.
Within a few seconds my mind decided to ask for more information. This is easy, ESP8.2.
Well, it looks like Will is a man that probably has the miracle of email on his phone so expect quick responses.
My dear lord, he starts to like me so much he's actually using his full name and I now have his phone number as well!
Given the urgence, I'm wondering why I haven't heard back from Will. Do you also think to guess where this is going?
Nope, the tread continues...
I don't suspect a classic VIN mismatch between ECU and ABS since I'm under the impression that this car actually started.
Futhermore I'm amused they changed the BCM and immo reader coil as well, why would you do that?
I'm going for the jackpot now since I just did another, almost identical, RHD Polo 6R. That went very well, so these must be the right codes.
I even gave him a free XDS diff and TPMS!
Yee ha, I'm so excited!
Still excited!
Back when I was still a doctor, I hated night shifts as well so I can relate...
However, come tomorrow:
Trying the Dutch straight approach:
Well, for me it's clear now...
I get it why you'd ask hobbyist people for help. I get it you don't want to pay top dollar for a dealer to do an SVM.
What I don't get is you're mailing me to help you out, I take some effort to do so and then as soon as it's done, you're ingoring me and take away my reward.
I'm 100 % sure the coding I gave him worked out. I'm guessing he simply doesn't want to pay me... such a shame.
This is exactly the reason I'll stop doing these e-mail requests and only post publicly on forums. I'm a bit cross with Will and people like him.
Will ***
17 Oct 2019, 18:25
to me
Hi Michel!
My name is will and i am in the UK, I have a 2010 6r polo 1.6tdi I am trying to re code the ABS after it lost its coding, been through all the old auto scans and it isnt there!
hope the auto scan i have posted below might be able to help you help me with an ABS code.
I will happily pay you some fine british pounds if it works!
I have attached my auto scan. car is a UK model. smallest disc and drum brake option
1.6tdi 75hp
I am losing my mind trying to sort it snd would reapply appreciate any help!
Thanks
Tuesday,08,October,2019,21:03:06:40315
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4441.4
Dealer/Shop Name: [redacted]
VIN: [redacted] License Plate: [redacted]
Mileage: 194130km-120626mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZAU015607 Mileage: 194130km-120626miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BC HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 8876
Revision: --H13--- Serial number:
Coding: 00114014000500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023BC 003007
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 688944E422FA0CF736D-803C
7332 - Mass Air Flow Sensor (G70)
P0103 00 [165] - Signal too High
Mileage: 193905 km
Date: 2019.10.07
Time: 23:51:41
Coolant temperature: 12 °C
Intake air temperature: 14 °C
Voltage terminal 30: 11.633 V
Engine speed: 0 /min
Battery voltage: 11.6 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
14359 - Exhaust Gas Temperature Sensor 4 Bank 1
P2470 00 [165] - Short to Ground
Mileage: 193905 km
Date: 2019.10.07
Time: 00:40:48
Engine speed: 983.25 /min
Normed load value: 22.0 %
Coolant temperature: 53 °C
Intake air temperature: 23 °C
Voltage terminal 30: 13.892 V
Exh.gas temp.sen 3-TEG_MES[1]: 11.41 °C
Sensor for engine block temperature: raw value-Coolant temperature: 12 °C
Exh.gas temp.sen 1-TEG_MES[0]: 19.98 °C
Exh.gas temp.sen 4-TEG_MES[2]: -175.02 °C
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Shop #: WSC 31414 790 31414
VCID: 4DC79570AD98C9DF25B-8018
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 23:34:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x1497
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Fault Status: 01100101
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 23:34:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B97
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 23:34:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x1A97
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
03306 - Coding Not Valid
Reset counter: 93
Mileage: 194137 km
Date: 2014.02.27
Time: 23:37:11
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x2597
Hex Value: 0x00FF
Hex Value: 0x7F80
Hex Value: 0x7E00
Hex Value: 0x0000
Address 08: Auto HVAC (J3ÿÿÿ) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0600
Revision: 00 10 24
VCID: 3039EC84DA2A84372ED-8064
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Mileage: 4069 km
Date: 2010.11.04
Time: 16:33:40
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H09 0029
Revision: BF009001 Serial number: 9955A267090629
Coding: 25B02BBF08E12400923000003D2B0CD00000410F600400002000
Shop #: WSC 00389 210 88335
VCID: 3C21C8B406627057825-8068
Subsystem 1 - Part No SW: 6R0 959 802 H HW: 6R0 959 802 H Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 005 0803
Serial number: KU0-KU025.09.0915949
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 K HW: 6R0 959 801 K Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 005 0803
Serial number: KU0-KU028.09.0910648
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100015273
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 005 0803
Serial number: KU0-KU015.09.0910328
Coding: 08BC32
Fault Status: 00101011
Reset counter: 93
Reset counter: 93
Mileage: 194136 km
Date: 2014.02.25
Time: 23:24:59
02660 - Radio Remote Control not Matched/Adapted
Fault Frequency: 7
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 00:01:46
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00B H09 0018
Revision: -------- Serial number: 003DW007DHSR
Coding: 003042
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 42DDB64C640606A7C89-8016
Serial number: 3572SRB400009BCC81BM
Serial number: 3582SRB400009BE52A6G
Serial number: 3516GRB402V9BR0F14IJ
Serial number: 3526GRB4021DJ2ND8JBD
Part No SW: 6R0 920 961 B HW: 6R0 920 961 B
Component: KOMBI H23 0110
Coding: 440A00
VCID: 3537DD9025C8A11F7DB-8060
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Reset counter: 93
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Airbag: keine Kommunikation]
Reset counter: 93
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0029
Coding: 002300
VCID: 70B92C841AAAC4376ED-8024
02078 - Media Player Position 3 (R120)
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 00:00:04
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H23 0110
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
Address 2E: Media Player 3
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10130
Shop #: WSC 31414
VCID: 2E05F2FCC95E92C73C1-807A
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 013 0049
Revision: 01000000 Serial number: VWZ1Z2I6829004
Coding: 0500040002
Shop #: WSC 77011 210 104168
VCID: 6B833BE8338C27EF5BF-803E
03272 - Control Module for Audio Interface
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 00:00:59
End----(Elapsed Time: 01:31, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
Michel ***
17 Oct 2019, 18:38
to Will
Do you have any idea why you lost the coding?
Did you replace the instrument cluster?
Will ***
Thu, 17 Oct, 18:47
to me
had to replace the ABS module as the pins had corroded off the front of it.
car has had a new ECU, body control module, cluster and keys before but that was a while ago
thanks
Michel ***
Thu, 17 Oct, 18:50
to Will
I see, so the ABS has worked with this ECU/cluster, correct?
Give this coding a try please:
230224e3436E00B7C42B24E2C2D800521700
Michel ***
Thu, 17 Oct, 18:53
to Will
PS, you put an ECU of a 90hp polo in it (CAYB engine code) so you’re running 90bhp right now ;-)
if your coding is rejected, try this coding as well please:
230228e3416E00B7C42B14E282D800521700
Will ***
Fri, 18 Oct, 00:22
to me
That’s great thanks for that! I’m pretty good with numbers but struggled working out all the binary inversion for the vin haha!
I’ll give it a try tomorrow. Yes I did know about the ECU!
Thanks again
William ***
T:079313153**
Michel ***
Sun, 20 Oct, 21:33 (13 days ago)
to Will
Update please
Will ***
Mon, 21 Oct, 10:20 (12 days ago)
to me
Hi buddy,
Only got round to trying these this morning and neither worked unfortunately! Still giving the errors 22. Appreciate your help so far though. Is there anything I need to do prior to the coding? Am doing the security login first.
I do also have vagtacho. Do I need to make sure the key codes are correct
Thanks again
Michel ***
Mon, 21 Oct, 10:21 (12 days ago)
to Will
Yes, please check the advanced ID of both the immobiliser and the engine to see if the VIN matches.
Will ***
21 Oct 2019, 10:47 (12 days ago)
to me
Ok, does the ABS module have the vin attached to it too? Because that wasn’t changed when the clocks, ecu, bcm and transponder ring etc was changed.
If so can I correct this in vcds or vag tacho?
Thanks
William ***
T:079313153**
Michel ***
Mon, 21 Oct, 11:01 (12 days ago)
to Will
you don’t need to change the VIN in the ABS, just read module 01 and 17
Michel Bekker ***
Mon, 21 Oct, 11:27 (12 days ago)
to Will
Try this as well:
230228E3416E00B7C42B14E282D800821300
230228E3416E00B7C42B14E282D800821700
Michel ***
Wed, 23 Oct, 16:07 (10 days ago)
to Will
Any news?
Still excited!
Michel ***
Thu, 24 Oct, 19:07 (9 days ago)
to Will
Any news?
Will ***
25 Oct 2019, 00:16 (9 days ago)
to me
Giving it a try tomorrow. Nightsift = booo
William ***
T:079313153**
Michel ***
Mon, 28 Oct, 14:00 (5 days ago)
to Will
And?
Michel ***
Tue, 29 Oct, 22:48 (4 days ago)
to Will
Any news? I did a lot of work to help you out and I’m not hearing anything back. That isn’t very nice.
Michel ****
Thu, 31 Oct, 22:19 (2 days ago)
to Will Hook <[redacted]>
I think it’s a bit of a shame that you’re ignoring me now.
