2013 Audi Allroad (A4 B8) persistent CEL
rickmac
C?ID=344391
Greetings,
I've been struggling with a CEL. In the last 6 months I had the Allroad serviced at a dealership; at which time I had to replace the timing chain and had all 4 injectors done. This was in response to a series of fault codes that ended catastrophically. The Allroad was disabled in my driveway and I had to have it towed for service; wouldn't start.
Since that repair I have been trying to track down gremlins that presented similarly to the catastrophic event. Getting a rough idle in the morning and sometimes after the car has warmed up in stop and go traffic. I was seeing too rich / too lean codes, misfires, etc. Over the last 6 months I have replaced the upstream 02 sensor, replaced spark plugs, replaced coil packs, replaced pcv, replaced MAF sensor and visually verified the air filter resulting in a couple of weeks on/off running smoothly while the CEL is on. I think - hey, lets clear that and check everything again causing the car to relearn the right mixture (I'm assuming) and then the rough idle returns. I thought I had narrowed everything down to a bad catalytic converter, and then last night happened. I'm stumped and the last time I saw these errors I had to replace the timing chain and injectors. So I'm hoping to avoid another expensive visit to the dealer; that clearly never fixed the root cause in the first place. Thoughts?
Thursday,31,October,2019,17:03:01:05213
VIN: WA1VFAFL0DA0XXXXX   License Plate:
Mileage: 218940km-136043mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
          62 6C 6D 72
VIN: WA1VFAFL0DA0XXXXX   Mileage: 218940km-136043miles
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0008
   Revision: ECH09---
   Coding: 722A0013242600062000
   Shop #: WSC 61325 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
   ROD: EV_ECM20TFS0118K5907115F.rod
   VCID: 353722E965C0337F2A1-8060
13 Faults Found:
5580 - Oil Pressure Switch
          P164B 00 [167] - Malfunction
                    Mileage: 218947 km
                    Date: 2019.10.31
                    Time: 16:53:39
                    Engine speed: 2707.00 /min
                    Normed load value: 26.7 %
                    Vehicle speed: 52 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.324 V
                    Median injection timing: 0.916 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
5646 - Leak in Air Intake System
          P2279 00 [096] - -
                    Mileage: 218866 km
                    Date: 2019.10.30
                    Time: 16:15:27
                    Engine speed: 797.50 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 81 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 13.853 V
                    Median injection timing: 0.807 ms
                    Engine operating condition: Idling
                    Driver-side belt buckle status-Bits 0-7: 233
                    Engine torque: 29.6 Nm
4113 - Camshaft Position Sensor (G40)
          P0341 00 [174] - Implausible Signal
                    Fault Frequency: 19
                    Mileage: 218936 km
                    Date: 2019.10.31
                    Time: 16:30:34
                    Engine speed: 1463.50 /min
                    Normed load value: 23.9 %
                    Vehicle speed: 9 km/h
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.465 V
                    Median injection timing: 1.004 ms
2822 - Bank 1; System Too Rich off Idle
          P2178 00 [175] - -
                    Mileage: 218865 km
                    Date: 2019.10.30
                    Time: 13:11:23
                    Engine speed: 1664.00 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 91 °C
                    Intake air temperature: 32 °C
                    Median injection timing: 0.847 ms
4010 - Idle Control System
          P0506 00 [175] - RPM Lower than Expected
                    Mileage: 218889 km
                    Date: 2019.10.31
                    Time: 06:41:53
                    Engine speed: 780.00 /min
                    Normed load value: 62.4 %
                    Coolant temperature: 15 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 13.640 V
                    Median injection timing: 3.620 ms
4601 - Cold Start Idle Air Control System
          P050A 00 [237] - Malfunction
                    Mileage: 218889 km
                    Date: 2019.10.31
                    Time: 06:41:12
                    Engine speed: 896.00 /min
                    Normed load value: 68.2 %
                    Coolant temperature: 7 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 12.745 V
                    Median injection timing: 3.410 ms
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [172] - -
                    Mileage: 218839 km
                    Date: 2019.10.30
                    Time: 08:59:34
                    Engine speed: 799.50 /min
                    Normed load value: 11.0 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 63 °C
                    Voltage terminal 30: 14.536 V
                    Median injection timing: 0.552 ms
                    Driver-side belt buckle status-Bits 0-7: 129
                    Engine torque: 24.1 Nm
10591 - Cylinder 1
          P0301 00 [172] - Misfire Detected
                    Mileage: 218839 km
                    Date: 2019.10.30
                    Time: 09:00:32
                    Engine speed: 704.50 /min
                    Median injection timing: 4.463 ms
10593 - Cylinder 3
          P0303 00 [172] - Misfire Detected
                    Mileage: 218839 km
                    Date: 2019.10.30
                    Time: 09:00:32
10594 - Cylinder 4
          P0304 00 [172] - Misfire Detected
                    Mileage: 218839 km
                    Date: 2019.10.30
                    Time: 09:00:32
10592 - Cylinder 2
          P0302 00 [172] - Misfire Detected
                    Mileage: 218866 km
                    Date: 2019.10.30
                    Time: 16:39:01
                    Median injection timing: 0.536 ms
                    Driver-side belt buckle status-Bits 0-7: 118
                    Engine torque: 23.2 Nm
4106 - Bank 1; System too Rich at Idle
          P2188 00 [175] - -
                    Mileage: 218932 km
                    Date: 2019.10.31
                    Time: 16:10:50
                    Engine speed: 842.50 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 14.442 V
                    Median injection timing: 0.509 ms
                    A/C compressor: load current: act. value: -575.50 A
4201 - Fuel Level too Low
          P1250 00 [032] - -
Readiness: 0000 0101
   Part No SW: 8K1 927 158     HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1002
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 74B1DFED2E3A6A77DDF-8020
   Part No SW: 8K9 907 379 M    HW: 8K9 907 379 M
   Component: ESP8 quattro  H09 0100
   Coding: 0E1D18
   Shop #: WSC 06335 000 00000
   VCID: 4CC1670D16CA52B765F-8018
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H11 0621
   Coding: 0D824000000000000000
   VCID: 04518F2D7E1A5AF7EDF-8050
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0512000038266011
   Serial number: 2312000114720010
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01070620121806
   Coding: 6480208000
   VCID: 392F2ED94958D71FCE9-806C
                    Fault Status: 00101101
                    Reset counter: 207
                    Mileage: 218866 km
                    Date: 2019.10.30
                    Time: 16:17:49
                    Temperature: 15.0°C
                    RPM: 800 /min
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000431027402
   Coding: 26000091863CAFE00700480300003D0D0F9C4708A2090221000008004000010200020030000000
   Shop #: WSC 06335 123 12345
   VCID: 7AADF1D50CDE1C07873-802E
   Component: WWS 030612  H07 0070
   Serial number: SWF12060035560
   Coding: 00FD11
   Serial number: 20329176
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002605120343
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1Y0002
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 14280236000000000001
   Part No SW: 8K0 959 655 M    HW: 8K0 959 655 M
   Component: AirbagVW-AU10 H46 0610
   Serial number: 003KEDA01DWK
   Coding: 303844354A32303030304A55304C384B3053
   Shop #: WSC 07924 002 1048576
   VCID: 47CB58210F2CB1EF48D-8012
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200008T0G
   Serial number: 6334MSME6E761444J
   Serial number: 6344MSME70010514Z
   Serial number: 6352QSME4118105C9
   Serial number: 6362QSME07184856H
   Serial number: 63732SME66153448-
   Serial number: 63832SME17181150O
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120614000900
   Coding: 000037
   VCID: 4FFB7001E7DC69AF00D-801A
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 D    HW: 8K0 920 982 D
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBI34G46D
   Coding: 8BB629020B01D705020000
   VCID: 353722E96540337F2A1-8060
   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 1Z090025    Serial number: 2541Z12509012E
   Coding: 80C303FF00
   VCID: 46D5552508A6A8E7B3B-8012
   Serial number: 6732957401
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000030150295
   Coding: 00581B00000000000000
   VCID: 3B2334D14364E50FDC5-806E
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H16 0040
   Serial number: 0177660840
   Coding: 010211
   Shop #: WSC 06334 000 00000
   VCID: 3E253DC550F6F027FBB-806A
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H16 0040
   Serial number: 0177657689
   Coding: 010211
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000032090403
   Coding: 011C13205E00410001
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0021598393
   Coding: 100000000001
   Shop #: WSC 63374 000 1048576
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311FED6EBA2A771DF-8060
   Revision: 00002001    Serial number: 0177694537
   Coding: 0126023A20BA709580B0023200000000
   Shop #: WSC 06334 123 12345
   Component: GTO BF  H01 0080
   Serial number: 00000000000000523024
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
02764 - Access/Start Authorization Switch (E408)
                    Reset counter: 208
                    Mileage: 218889 km
                    Date: 2019.10.31
                    Time: 06:41:48
   Revision: 00005001    Serial number: 94813003158901
   VCID: 2D070A898D107BBF521-8078
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000032126870
   VCID: 4EC56D05E0D660A70BB-801A
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 10000000039228
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 38292BDD72D2CE17317-806C
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156FU0C7603251
   Coding: 020007010000000001
   VCID: 211FE6B9C1C8AFDFE69-8074
                    Reset counter: 207
                    Mileage: 218866 km
                    Date: 2019.10.30
                    Time: 15:41:24
                    Bin. Bits: 00000000 00101100
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0552
   Revision: --------    Serial number: 204FT0C7505273
   Coding: 010200050006E1EF55028F4E00000403140000000000000000
   VCID: 363525E57846386723B-8062
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130FG0CS189870
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001174897
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
                    Fault Frequency: 15
                    Reset counter: 207
                    Mileage: 218866 km
                    Date: 2019.10.30
                    Time: 15:41:24
                    Bin. Bits: 10111110 10000010
                    Bin. Bits: 00000100 10011111
                    Bin. Bits: 00000000 00000000
                    Fault Frequency: 8
                    Reset counter: 207
                    Mileage: 218866 km
                    Date: 2019.10.30
                    Time: 15:41:44
                    Bin. Bits: 00011110 00010000
                    Bin. Bits: 00000000 00011010
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000032030548
   Coding: 010C13204000210001
   Revision: --H07---    Serial number: 525PA8-J2591A8
   Coding: 1000007
   VCID: 38292BDD7E52CE17317-806C
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C2137CD466AE237D5F-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000032030332
End----------(Elapsed Time: 02:14, VBatt start/end: 14.4V/14.5V)-----------
Jef
HQ
All the parts that you've installed.... are they from the Audi dealer or are they parts NOT from the Audi dealer?
Start with something simple, fuel rail pressure testing. With the engine up to operating temp (+80C coolant) and at idle, connect to the ECM and go into Advance Measuring Values:
IDE00589-ENG167462 - Fuel pressure
I'm guessing it will be something like 3000 to 4000 kPa. Note what it is at idle. Exit out of the ECM, shut engine off, turn ignition back on but do not start engine. Now go back and check the fuel pressure. What we'd like to see is about a +2000 kPa increase in 2 minutes from the time you shut the engine off. So if at idle it was around 3700 kPa, 2 minutes after the engine was shut off it would be around 5700 kPa. Do this test a few different times and see if the rate at which the fuel rail pressure ramps up is consistent.
rickmac
C?ID=344391
Thanks Jef.
Before I started the car up to let it get warm for the test I noted the fuel pressure was 11580 kPa rel with a high fuel pressure specified value of 7.8080 MPa and a Low fuel pressure specified value of 600.0 kPa.
Let it warm up and took a few logs. At idle the fuel pressure read between 3880 and 3910 consistently.
The first time I shut it down I observed it climb back up to 8270 before I started the car. I wasn't paying close attention to the timing. When I attempted to restart the car it wouldn't immediately start and idled a bit rough at first. Sort of took a little coaxing (I assume to let off some of the excess pressure?) Once it leveled out (eg back to the 3880-3910 range it .
Second time I observed it climb back up to 4790 in 2 minutes.
Third time I observed it climb back up to 4560 in 2 minutes.
First
Marker,TIME,Loc. IDE00025,TIME,Loc. IDE00201,TIME,Loc. IDE00202,TIME,Loc. IDE00347,TIME,Loc. IDE00589,TIME,Loc. IDE00604,TIME,Loc. IDE01644,TIME,Loc. IDE01869,TIME,Loc. IDE02118,TIME,Loc. IDE06393,,,,,
,STAMP,Coolant temperature,STAMP,High fuel pressure: specified value,STAMP,Low fuel pressure: specified value,STAMP,Air mass: actual value:,STAMP,Fuel pressure,STAMP,Short term adaptation of mixture formation bank 1,STAMP,Oxygen sensor voltage bank 1 after catalytic converter,STAMP,Long-term fuel trim bank 1 at idle,STAMP,Oxygen sensor bank 1 sensor 1: voltage,STAMP,Oil level: dynamic average value,,,,,
,, °C,, MPa,, kPa,, g/s,, kPa rel,, %,, V,, %,, V,, mm,,,,,
,0.43,81,0.55,3.9680,0.67,600.0,0.74,0.00,0.86,4890,0.96,0.0,1.06,0.519,0.05,-6.52,0.20,1.494,0.30,46.976,,,,,
,1.52,81,1.61,3.9680,1.74,600.0,1.83,0.00,1.96,4920,2.05,0.0,2.19,0.514,1.18,-6.52,1.30,1.494,1.43,46.976,,,,,
,2.68,81,2.80,3.9680,2.92,600.0,3.02,0.00,3.11,4950,3.24,0.0,3.34,0.504,2.30,-6.52,2.44,1.494,2.55,46.976,,,,,
,3.80,81,3.92,3.9680,3.99,600.0,4.12,0.00,4.21,4970,4.30,0.0,4.44,0.499,3.46,-6.52,3.56,1.494,3.68,46.976,,,,,
,4.94,81,5.05,3.9680,5.18,600.0,5.30,0.00,5.42,4990,5.49,0.0,5.61,0.494,4.55,-6.52,4.69,1.494,4.80,46.976,,,,,
,6.05,81,6.18,3.9680,6.30,600.0,6.42,0.00,6.49,5010,6.58,0.0,6.71,0.489,5.74,-6.52,5.84,1.494,5.96,46.976,,,,,
,7.18,81,7.30,3.9680,7.42,600.0,7.49,0.00,7.58,5050,7.68,0.0,7.80,0.484,6.80,-6.52,6.94,1.494,7.05,46.976,,,,,
,8.24,81,8.33,3.9680,8.46,600.0,8.55,0.00,8.68,5080,8.80,0.0,8.93,0.484,7.93,-6.52,8.00,1.494,8.11,46.976,,,,,
,9.30,81,9.43,3.9680,9.55,600.0,9.67,0.00,9.74,5100,9.83,0.0,9.96,0.479,8.99,-6.52,9.09,1.494,9.21,46.976,,,,,
,10.43,81,10.55,3.9680,10.67,600.0,10.74,0.00,10.87,5120,10.96,0.0,11.06,0.475,10.05,-6.52,10.19,1.494,10.30,46.976,,,,,
,11.49,81,11.58,3.9680,11.71,600.0,11.80,0.00,11.93,5140,12.05,0.0,12.17,0.475,11.18,-6.52,11.30,1.494,11.42,46.976,,,,,
,12.59,81,12.68,3.9680,12.80,600.0,12.92,0.00,12.99,5170,13.08,0.0,13.21,0.475,12.24,-6.52,12.37,1.494,12.46,46.976,,,,,
,13.67,81,13.74,3.9680,13.87,600.0,13.96,0.00,14.05,5180,14.18,0.0,14.30,0.475,13.30,-6.52,13.43,1.494,13.55,46.976,,,,,
,14.74,81,14.83,3.9680,14.96,600.0,15.05,0.00,15.18,5220,15.30,0.0,15.42,0.470,14.42,-6.52,14.52,1.494,14.61,46.976,,,,,
,15.83,81,15.96,3.9680,16.05,600.0,16.18,0.00,16.30,5240,16.41,0.0,16.50,0.470,15.52,-6.52,15.62,1.494,15.74,46.976,,,,,
,16.94,81,17.05,3.9680,17.18,600.0,17.30,0.00,17.42,5270,17.49,0.0,17.62,0.465,16.62,-6.52,16.71,1.494,16.80,46.976,,,,,
,18.05,81,18.17,3.9680,18.24,600.0,18.33,0.00,18.46,5290,18.55,0.0,18.69,0.465,17.71,-6.52,17.81,1.494,17.93,46.976,,,,,
,19.18,81,19.30,3.9680,19.42,600.0,19.49,0.00,19.62,5320,19.71,0.0,19.81,0.465,18.80,-6.52,18.94,1.494,19.05,46.976,,,,,
,20.24,81,20.33,3.9680,20.46,600.0,20.55,0.00,20.68,5340,20.80,0.0,20.92,0.465,19.93,-6.52,20.05,1.494,20.17,46.976,,,,,
,21.33,81,21.46,3.9680,21.55,600.0,21.68,0.00,21.80,5360,21.93,0.0,21.99,0.465,21.02,-6.52,21.12,1.494,21.24,46.976,,,,,
,22.43,81,22.55,3.9680,22.67,600.0,22.74,0.00,22.83,5400,22.96,0.0,23.06,0.465,22.08,-6.52,22.21,1.494,22.30,46.976,,,,,
,23.49,81,23.58,3.9680,23.71,600.0,23.80,0.00,23.93,5420,24.05,0.0,24.18,0.465,23.18,-6.52,23.30,1.494,23.42,46.976,,,,,
,24.58,81,24.71,3.9680,24.80,600.0,24.93,0.00,25.05,5440,25.17,0.0,25.24,0.465,24.27,-6.52,24.37,1.494,24.49,46.976,,,,,
,25.68,81,25.80,3.9680,25.92,600.0,25.99,0.00,26.12,5470,26.21,0.0,26.31,0.465,25.37,-6.52,25.46,1.494,25.55,46.976,,,,,
,26.77,81,26.87,3.9680,26.96,600.0,27.05,0.00,27.18,5500,27.30,0.0,27.42,0.460,26.43,-6.52,26.55,1.494,26.67,46.976,,,,,
,27.80,81,27.93,3.9680,28.05,600.0,28.17,0.00,28.24,5510,28.37,0.0,28.47,0.465,27.49,-6.52,27.61,1.494,27.71,46.976,,,,,
,28.93,81,29.05,3.9680,29.17,600.0,29.24,0.00,29.36,5540,29.46,0.0,29.56,0.460,28.58,-6.52,28.71,1.494,28.80,46.976,,,,,
,29.99,81,30.12,3.9680,30.21,600.0,30.30,0.00,30.43,5570,30.55,0.0,30.67,0.460,29.68,-6.52,29.80,1.494,29.92,46.976,,,,,
,31.09,81,31.18,3.9680,31.30,600.0,31.42,0.00,31.49,5590,31.62,0.0,31.71,0.460,30.77,-6.52,30.87,1.494,30.96,46.976,,,,,
,32.18,81,32.30,3.9680,32.42,600.0,32.49,0.00,32.58,5600,32.71,0.0,32.81,0.460,31.80,-6.52,31.94,1.494,32.05,46.976,,,,,
,33.27,81,33.36,3.9680,33.49,600.0,33.58,0.00,33.71,5640,33.80,0.0,33.94,0.460,32.93,-6.52,33.05,1.494,33.17,46.976,,,,,
,34.43,81,34.55,3.9680,34.67,600.0,34.74,0.00,34.87,5670,34.96,0.0,35.06,0.460,34.05,-6.52,34.19,1.494,34.30,46.976,,,,,
,35.49,81,35.58,3.9680,35.71,600.0,35.80,0.00,35.93,5690,36.05,0.0,36.17,0.460,35.18,-6.52,35.30,1.494,35.42,46.976,,,,,
,36.55,81,36.68,3.9680,36.80,600.0,36.92,0.00,36.99,5710,37.08,0.0,37.21,0.460,36.24,-6.52,36.34,1.494,36.46,46.976,,,,,
,37.68,81,37.80,3.9680,37.92,600.0,37.99,0.00,38.08,5730,38.21,0.0,38.31,0.460,37.30,-6.52,37.44,1.494,37.55,46.976,,,,,
,38.74,81,38.83,3.9680,38.96,600.0,39.05,0.00,39.18,5760,39.30,0.0,39.42,0.460,38.43,-6.52,38.55,1.494,38.67,46.976,,,,,
,39.83,81,39.96,3.9680,40.05,600.0,40.18,0.00,40.30,5780,40.42,0.0,40.49,0.460,39.49,-6.52,39.61,1.494,39.74,46.976,,,,,
,40.93,81,41.05,3.9680,41.17,600.0,41.24,0.00,41.36,5800,41.46,0.0,41.56,0.460,40.62,-6.52,40.71,1.494,40.80,46.976,,,,,
,41.99,81,42.12,3.9680,42.21,600.0,42.34,0.00,42.43,5820,42.55,0.0,42.67,0.460,41.68,-6.52,41.80,1.494,41.92,46.976,,,,,
,43.08,81,43.21,3.9680,43.30,600.0,43.43,0.00,43.55,5840,43.67,0.0,43.75,0.460,42.77,-6.52,42.86,1.494,42.99,46.976,,,,,
,44.21,81,44.30,3.9680,44.43,600.0,44.55,0.00,44.67,5870,44.74,0.0,44.87,0.460,43.86,-6.52,43.99,1.494,44.08,46.976,,,,,
,45.30,81,45.42,3.9680,45.49,600.0,45.61,0.00,45.71,5900,45.80,0.0,45.94,0.460,44.96,-6.52,45.08,1.494,45.18,46.976,,,,,
,46.43,81,46.55,3.9680,46.68,600.0,46.74,0.00,46.87,5920,46.96,0.0,47.06,0.460,46.05,-6.52,46.19,1.494,46.30,46.976,,,,,
,47.49,81,47.58,3.9680,47.71,600.0,47.80,0.00,47.92,5940,48.02,0.0,48.17,0.460,47.18,-6.52,47.30,1.494,47.42,46.976,,,,,
,48.55,81,48.68,3.9680,48.80,600.0,48.92,0.00,48.99,5970,49.08,0.0,49.21,0.460,48.24,-6.52,48.34,1.494,48.46,46.976,,,,,
,49.68,81,49.80,3.9680,49.92,600.0,49.99,0.00,50.12,5990,50.21,0.0,50.31,0.460,49.30,-6.52,49.44,1.494,49.55,46.976,,,,,
,50.77,81,50.87,3.9680,50.96,600.0,51.09,0.00,51.18,6010,51.30,0.0,51.42,0.460,50.43,-6.52,50.55,1.494,50.67,46.976,,,,,
,51.84,81,51.93,3.9680,52.05,600.0,52.17,0.00,52.24,6040,52.37,0.0,52.46,0.460,51.52,-6.52,51.62,1.494,51.71,46.976,,,,,
,52.93,81,53.05,3.9680,53.17,600.0,53.24,0.00,53.33,6060,53.46,0.0,53.56,0.460,52.55,-6.52,52.69,1.494,52.80,46.976,,,,,
,53.99,81,54.08,3.9680,54.21,600.0,54.30,0.00,54.43,6090,54.55,0.0,54.67,0.460,53.68,-6.52,53.80,1.494,53.92,46.976,,,,,
,55.05,81,55.18,3.9680,55.30,600.0,55.42,0.00,55.49,6110,55.58,0.0,55.71,0.460,54.77,-6.52,54.87,1.494,54.96,46.976,,,,,
,56.18,81,56.30,3.9680,56.42,600.0,56.49,0.00,56.58,6130,56.71,0.0,56.81,0.460,55.80,-6.52,55.94,1.494,56.05,46.976,,,,,
,57.24,81,57.33,3.9680,57.46,600.0,57.55,0.00,57.68,6150,57.80,0.0,57.92,0.460,56.93,-6.52,57.05,1.494,57.17,46.976,,,,,
,58.30,81,58.43,3.9680,58.55,600.0,58.67,0.00,58.74,6180,58.86,0.0,58.96,0.460,57.99,-6.52,58.09,1.494,58.21,46.976,,,,,
,59.44,81,59.55,3.9680,59.67,600.0,59.74,0.00,59.83,6200,59.96,0.0,60.06,0.460,59.05,-6.52,59.19,1.494,59.30,46.976,,,,,
,60.49,81,60.62,3.9680,60.71,600.0,60.80,0.00,60.93,6220,61.05,0.0,61.17,0.460,60.18,-6.52,60.30,1.494,60.42,46.976,,,,,
,61.58,81,61.71,3.9680,61.80,600.0,61.93,0.00,62.05,6250,62.17,0.0,62.24,0.460,61.27,-6.52,61.37,1.494,61.49,46.976,,,,,
,62.68,81,62.80,3.9680,62.92,600.0,62.99,0.00,63.08,6270,63.21,0.0,63.31,0.460,62.33,-6.52,62.46,1.494,62.55,46.976,,,,,
,63.74,81,63.87,3.9680,63.96,600.0,64.05,0.00,64.19,6300,64.30,0.0,64.44,0.460,63.43,-6.52,63.55,1.494,63.67,46.976,,,,,
,64.93,81,65.05,3.9680,65.17,600.0,65.27,0.00,65.36,6310,65.49,0.0,65.59,0.460,64.55,-6.52,64.69,1.494,64.80,46.976,,,,,
,66.05,81,66.17,3.9680,66.24,600.0,66.37,0.00,66.46,6340,66.55,0.0,66.69,0.460,65.71,-6.52,65.81,1.494,65.93,46.976,,,,,
,67.18,81,67.30,3.9680,67.42,600.0,67.49,0.00,67.62,6370,67.71,0.0,67.81,0.460,66.80,-6.52,66.94,1.494,67.05,46.976,,,,,
,68.24,81,68.36,3.9680,68.46,600.0,68.55,0.00,68.68,6390,68.80,0.0,68.92,0.460,67.93,-6.52,68.05,1.494,68.17,46.976,,,,,
,69.30,81,69.43,3.9680,69.55,600.0,69.67,0.00,69.74,6410,69.87,0.0,69.96,0.460,68.99,-6.52,69.12,1.494,69.21,46.976,,,,,
,70.43,81,70.55,3.9680,70.67,600.0,70.74,0.00,70.83,6430,70.96,0.0,71.06,0.460,70.05,-6.52,70.20,1.494,70.30,46.976,,,,,
,71.52,81,71.61,3.9680,71.71,600.0,71.80,0.00,71.93,6450,72.05,0.0,72.17,0.460,71.18,-6.52,71.30,1.494,71.42,46.976,,,,,
,72.55,81,72.68,3.9680,72.80,600.0,72.92,0.00,72.99,6470,73.12,0.0,73.21,0.460,72.24,-6.52,72.37,1.494,72.46,46.976,,,,,
,73.68,81,73.80,3.9680,73.92,600.0,73.99,0.00,74.08,6500,74.21,0.0,74.31,0.460,73.34,-6.52,73.44,1.494,73.55,46.976,,,,,
,74.74,81,74.87,3.9680,74.96,600.0,75.05,0.00,75.18,6520,75.30,0.0,75.42,0.460,74.43,-6.52,74.55,1.494,74.67,46.976,,,,,
,75.83,81,75.96,3.9680,76.05,600.0,76.18,0.00,76.30,6550,76.42,0.0,76.50,0.460,75.52,-6.52,75.62,1.494,75.74,46.976,,,,,
,76.96,81,77.05,3.9680,77.18,600.0,77.30,0.00,77.43,6560,77.49,0.0,77.62,0.460,76.61,-6.52,76.74,1.494,76.83,46.976,,,,,
,78.05,81,78.17,3.9680,78.24,600.0,78.37,0.00,78.46,6600,78.55,0.0,78.69,0.460,77.71,-6.52,77.81,1.494,77.93,46.976,,,,,
,79.18,81,79.30,3.9680,79.43,600.0,79.49,0.00,79.58,6620,79.71,0.0,79.81,0.460,78.80,-6.52,78.94,1.494,79.05,46.976,,,,,
,80.24,81,80.33,3.9680,80.46,600.0,80.55,0.00,80.68,6640,80.80,0.0,80.92,0.460,79.93,-6.52,80.05,1.494,80.17,46.976,,,,,
,81.34,81,81.43,3.9680,81.55,600.0,81.67,0.00,81.74,6660,81.87,0.0,81.96,0.460,80.99,-6.52,81.11,1.494,81.21,46.976,,,,,
,82.43,81,82.55,3.9680,82.67,600.0,82.74,0.00,82.83,6680,82.96,0.0,83.06,0.460,82.09,-6.52,82.19,1.494,82.30,46.976,,,,,
,83.52,81,83.61,3.9680,83.74,600.0,83.83,0.00,83.96,6700,84.05,0.0,84.19,0.460,83.18,-6.52,83.30,1.494,83.42,46.976,,,,,
,84.68,81,84.80,3.9680,84.92,600.0,84.99,0.00,85.12,6730,85.21,0.0,85.31,0.460,84.30,-6.52,84.44,1.494,84.55,46.976,,,,,
,85.74,81,85.87,3.9680,85.96,600.0,86.05,0.00,86.18,6750,86.30,0.0,86.42,0.460,85.43,-6.52,85.55,1.494,85.67,46.976,,,,,
,86.80,81,86.93,3.9680,87.05,600.0,87.18,0.00,87.24,6780,87.37,0.0,87.46,0.460,86.49,-6.52,86.59,1.494,86.71,46.976,,,,,
,87.93,81,88.05,3.9680,88.17,600.0,88.24,0.00,88.37,6790,88.46,0.0,88.56,0.460,87.55,-6.52,87.69,1.494,87.80,46.976,,,,,
,89.02,81,89.11,3.9680,89.24,600.0,89.33,0.00,89.46,6820,89.55,0.0,89.69,0.460,88.68,-6.52,88.80,1.494,88.92,46.976,,,,,
,90.18,81,90.30,3.9680,90.42,600.0,90.49,0.00,90.62,6840,90.71,0.0,90.81,0.460,89.80,-6.52,89.94,1.494,90.05,46.976,,,,,
,91.27,81,91.37,3.9680,91.46,600.0,91.55,0.00,91.68,6860,91.80,0.0,91.92,0.460,90.93,-6.52,91.05,1.494,91.17,46.976,,,,,
,92.34,81,92.43,3.9680,92.55,600.0,92.67,0.00,92.74,6890,92.87,0.0,92.96,0.460,91.99,-6.52,92.12,1.494,92.21,46.976,,,,,
,93.42,81,93.49,3.9680,93.58,600.0,93.71,0.00,93.80,6910,93.93,0.0,94.05,0.460,93.09,-6.52,93.18,1.494,93.30,46.976,,,,,
,94.49,81,94.58,3.9680,94.71,600.0,94.80,0.00,94.93,6920,95.05,0.0,95.17,0.455,94.17,-6.52,94.25,1.494,94.36,46.976,,,,,
,95.55,81,95.68,3.9680,95.80,600.0,95.92,0.00,95.99,6950,96.12,0.0,96.21,0.455,95.24,-6.52,95.34,1.494,95.46,46.976,,,,,
,96.68,81,96.80,3.9680,96.92,600.0,96.99,0.00,97.08,6970,97.21,0.0,97.31,0.460,96.30,-6.52,96.44,1.494,96.55,46.976,,,,,
,97.77,81,97.87,3.9680,97.96,600.0,98.05,0.00,98.18,6990,98.30,0.0,98.42,0.460,97.43,-6.52,97.55,1.494,97.67,46.976,,,,,
,98.83,81,98.96,3.9680,99.05,600.0,99.18,0.00,99.30,7020,99.42,0.0,99.49,0.460,98.49,-6.52,98.61,1.494,98.74,46.976,,,,,
,99.96,81,100.05,3.9680,100.18,600.0,100.30,0.00,100.42,7040,100.49,0.0,100.62,0.460,99.62,-6.52,99.72,1.494,99.83,46.976,,,,,
,101.05,81,101.17,3.9680,101.24,600.0,101.36,0.00,101.46,7060,101.58,0.0,101.69,0.455,100.71,-6.52,100.81,1.494,100.93,46.976,,,,,
,102.18,81,102.30,3.9680,102.42,600.0,102.49,0.00,102.61,7080,102.71,0.0,102.81,0.460,101.80,-6.52,101.94,1.494,102.05,46.976,,,,,
,103.27,81,103.36,3.9680,103.49,600.0,103.58,0.00,103.71,7110,103.80,0.0,103.94,0.460,102.93,-6.52,103.05,1.494,103.17,46.976,,,,,
,104.43,81,104.55,3.9680,104.67,600.0,104.74,0.00,104.87,7140,104.96,0.0,105.06,0.460,104.05,-6.52,104.19,1.494,104.30,46.976,,,,,
,105.49,81,105.61,3.9680,105.71,600.0,105.80,0.00,105.93,7160,106.05,0.0,106.17,0.460,105.18,-6.52,105.30,1.494,105.42,46.976,,,,,
,106.58,81,106.71,3.9680,106.80,600.0,106.93,0.00,107.05,7170,107.17,0.0,107.25,0.460,106.24,-6.52,106.36,1.494,106.49,46.976,,,,,
,107.68,81,107.80,3.9680,107.92,600.0,107.99,0.00,108.12,7200,108.21,0.0,108.31,0.460,107.37,-6.52,107.46,1.494,107.59,46.976,,,,,
,108.77,81,108.86,3.9680,108.99,600.0,109.08,0.00,109.21,7230,109.30,0.0,109.44,0.460,108.43,-6.52,108.55,1.494,108.67,46.976,,,,,
,109.93,81,110.05,3.9680,110.17,600.0,110.24,0.00,110.37,7260,110.46,0.0,110.56,0.455,109.55,-6.52,109.69,1.494,109.80,46.976,,,,,
,110.99,81,111.12,3.9680,111.21,600.0,111.30,0.00,111.43,7270,111.55,0.0,111.67,0.460,110.68,-6.52,110.80,1.494,110.92,46.976,,,,,
,112.08,81,112.18,3.9680,112.30,600.0,112.42,0.00,112.49,7280,112.58,0.0,112.71,0.460,111.77,-6.52,111.86,1.494,111.96,46.976,,,,,
,113.18,81,113.30,3.9680,113.42,600.0,113.49,0.00,113.62,7300,113.71,0.0,113.84,0.460,112.80,-6.52,112.94,1.494,113.05,46.976,,,,,
,114.30,81,114.42,3.9680,114.49,600.0,114.62,0.00,114.71,7330,114.84,0.0,114.94,0.460,113.93,-6.52,114.05,1.494,114.18,46.976,,,,,
,115.43,81,115.55,3.9680,115.67,600.0,115.74,0.00,115.87,7360,115.96,0.0,116.08,0.460,115.05,-6.52,115.19,1.494,115.30,46.976,,,,,
,116.49,81,116.62,3.9680,116.71,600.0,116.83,0.00,116.93,7380,117.05,0.0,117.17,0.460,116.18,-6.52,116.30,1.494,116.42,46.976,,,,,
,117.58,81,117.68,3.9680,117.80,600.0,117.92,0.00,117.99,7400,118.12,0.0,118.21,0.460,117.24,-6.52,117.36,1.494,117.49,46.976,,,,,
,118.68,81,118.80,3.9680,118.92,600.0,118.99,0.00,119.12,7430,119.21,0.0,119.31,0.460,118.30,-6.52,118.44,1.494,118.55,46.976,,,,,
,119.74,81,119.87,3.9680,119.96,600.0,120.05,0.00,120.18,7440,120.30,0.0,120.42,0.460,119.43,-6.52,119.55,1.494,119.67,46.976,,,,,
,120.80,81,120.93,3.9680,121.05,600.0,121.17,0.00,121.24,7470,121.37,0.0,121.46,0.460,120.49,-6.52,120.59,1.494,120.71,46.976,,,,,
,121.93,81,122.05,3.9680,122.17,600.0,122.24,0.00,122.36,7490,122.46,0.0,122.56,0.460,121.55,-6.52,121.69,1.494,121.80,46.976,,,,,
,122.99,81,123.12,3.9680,123.21,600.0,123.30,0.00,123.43,7510,123.55,0.0,123.67,0.455,122.68,-6.52,122.80,1.494,122.92,46.976,,,,,
,124.05,81,124.18,3.9680,124.30,600.0,124.42,0.00,124.49,7530,124.58,0.0,124.71,0.460,123.74,-6.52,123.84,1.494,123.96,46.976,,,,,
,125.18,81,125.30,3.9680,125.42,600.0,125.49,0.00,125.58,7540,125.71,0.0,125.81,0.460,124.80,-6.52,124.94,1.494,125.05,46.976,,,,,
,126.24,81,126.33,3.9680,126.46,600.0,126.55,0.00,126.68,7570,126.80,0.0,126.92,0.460,125.93,-6.52,126.03,1.494,126.17,46.976,,,,,
,127.33,81,127.43,3.9680,127.55,600.0,127.67,0.00,127.74,7590,127.86,0.0,127.97,0.460,126.99,-6.52,127.12,1.494,127.21,46.976,,,,,
,128.43,81,128.55,3.9680,128.67,600.0,128.74,0.00,128.86,7610,128.96,0.0,129.06,0.455,128.08,-6.52,128.21,1.494,128.30,46.976,,,,,
,129.55,81,129.67,3.9680,129.74,600.0,129.87,0.00,129.96,7640,130.09,0.0,130.19,0.460,129.19,-6.52,129.31,1.494,129.43,46.976,,,,,
,130.68,81,130.80,3.9680,130.92,600.0,130.99,0.00,131.12,7650,131.21,0.0,131.31,0.460,130.30,-6.52,130.44,1.494,130.55,46.976,,,,,
,131.74,81,131.83,3.9680,131.96,600.0,132.05,0.00,132.18,7670,132.30,0.0,132.42,0.460,131.43,-6.52,131.55,1.494,131.67,46.976,,,,,
,132.84,81,132.93,3.9680,133.05,600.0,133.17,0.00,133.24,7700,133.37,0.0,133.46,0.460,132.49,-6.52,132.61,1.494,132.71,46.976,,,,,
,133.93,81,134.05,3.9680,134.17,600.0,134.24,0.00,134.33,7720,134.46,0.0,134.56,0.455,133.55,-6.52,133.69,1.494,133.80,46.976,,,,,
,134.99,81,135.12,3.9680,135.21,600.0,135.30,0.00,135.43,7740,135.55,0.0,135.67,0.460,134.68,-6.52,134.80,1.494,134.92,46.976,,,,,
,136.05,81,136.17,3.9680,136.27,600.0,136.42,0.00,136.49,7760,136.62,0.0,136.71,0.460,135.74,-6.52,135.87,1.494,135.96,46.976,,,,,
,137.18,81,137.30,3.9680,137.42,600.0,137.49,0.00,137.62,7770,137.71,0.0,137.83,0.460,136.80,-6.52,136.94,1.494,137.05,46.976,,,,,
,138.24,81,138.37,3.9680,138.46,600.0,138.55,0.00,138.68,7800,138.80,0.0,138.92,0.460,137.93,-6.52,138.05,1.494,138.17,46.976,,,,,
,139.34,81,139.43,3.9680,139.55,600.0,139.67,0.00,139.74,7820,139.87,0.0,139.97,0.460,138.99,-6.52,139.11,1.494,139.21,46.976,,,,,
,140.43,81,140.55,3.9680,140.67,600.0,140.74,0.00,140.87,7840,140.96,0.0,141.06,0.460,140.08,-6.52,140.21,1.494,140.34,46.976,,,,,
,141.49,81,141.62,3.9680,141.71,600.0,141.80,0.00,141.93,7870,142.05,0.0,142.17,0.460,141.18,-6.52,141.30,1.494,141.42,46.976,,,,,
,142.55,81,142.68,3.9680,142.80,600.0,142.92,0.00,142.99,7890,143.12,0.0,143.22,0.460,142.24,-6.52,142.36,1.494,142.46,46.976,,,,,
,143.68,81,143.80,3.9680,143.92,600.0,143.99,0.00,144.12,7900,144.21,0.0,144.31,0.460,143.34,-6.52,143.44,1.494,143.55,46.976,,,,,
,144.74,81,144.86,3.9680,144.96,600.0,145.05,0.00,145.18,7920,145.30,0.0,145.42,0.460,144.43,-6.52,144.55,1.494,144.67,46.976,,,,,
,145.80,81,145.93,3.9680,146.05,600.0,146.17,0.00,146.24,7950,146.36,0.0,146.46,0.460,145.49,-6.52,145.59,1.494,145.71,46.976,,,,,
,146.93,81,147.05,3.9680,147.17,600.0,147.24,0.00,147.33,7960,147.46,0.0,147.56,0.460,146.55,-6.52,146.69,1.494,146.80,46.976,,,,,
,147.99,81,148.08,3.9680,148.21,600.0,148.30,0.00,148.43,7990,148.55,0.0,148.67,0.460,147.68,-6.52,147.80,1.494,147.92,46.976,,,,,
,149.08,81,149.18,3.9680,149.30,600.0,149.42,0.00,149.49,8020,149.58,0.0,149.71,0.460,148.74,-6.52,148.87,1.494,148.96,46.976,,,,,
,150.18,81,150.30,3.9680,150.42,600.0,150.49,0.00,150.62,8030,150.71,0.0,150.81,0.460,149.80,-6.52,149.94,1.494,150.05,46.976,,,,,
,151.27,81,151.36,3.9680,151.46,600.0,151.59,0.00,151.68,8050,151.80,0.0,151.92,0.455,150.93,-6.52,151.05,1.494,151.17,46.976,,,,,
,152.30,81,152.43,3.9680,152.55,600.0,152.67,0.00,152.74,8070,152.87,0.0,152.96,0.460,151.99,-6.52,152.12,1.494,152.21,46.976,,,,,
,153.43,81,153.55,3.9680,153.67,600.0,153.74,0.00,153.87,8090,153.96,0.0,154.06,0.460,153.05,-6.52,153.20,1.494,153.30,46.976,,,,,
,154.49,81,154.62,3.9680,154.71,600.0,154.83,0.00,154.93,8120,155.05,0.0,155.17,0.460,154.18,-6.52,154.30,1.494,154.43,46.976,,,,,
,155.58,81,155.71,3.9680,155.80,600.0,155.93,0.00,156.05,8130,156.17,0.0,156.25,0.460,155.24,-6.52,155.36,1.494,155.49,46.976,,,,,
,156.68,81,156.80,3.9680,156.92,600.0,156.99,0.00,157.12,8150,157.21,0.0,157.34,0.460,156.37,-6.52,156.46,1.494,156.55,46.976,,,,,
,157.74,81,157.87,3.9680,157.96,600.0,158.05,0.00,158.18,8170,158.30,0.0,158.42,0.460,157.43,-6.52,157.55,1.494,157.67,46.976,,,,,
,158.80,81,158.93,3.9680,159.05,600.0,159.17,0.00,159.24,8190,159.33,0.0,159.46,0.460,158.49,-6.52,158.59,1.494,158.71,46.976,,,,,
,159.93,81,160.05,3.9680,160.17,600.0,160.24,0.00,160.33,8220,160.46,0.0,160.56,0.460,159.55,-6.52,159.69,1.494,159.80,46.976,,,,,
,160.99,81,161.12,3.9680,161.21,600.0,161.30,0.00,161.43,8240,161.55,0.0,161.68,0.460,160.68,-6.52,160.80,1.494,160.92,46.976,,,,,
,162.05,81,162.18,3.9680,162.30,600.0,162.42,0.00,162.49,8260,162.62,0.0,162.71,0.460,161.74,-6.52,161.87,1.494,161.96,46.976,,,,,
,163.18,81,163.30,3.9680,163.42,600.0,163.49,0.00,163.58,8270,163.71,0.0,163.81,0.460,162.80,-6.52,162.94,1.494,163.05,46.976,,,,,
Friday,01,November,2019,14:31:01:05213-VCID:353722E965C0337F2A1-8060,VCDS Version: Release 19.6.2 (x64),Data version: 20190930 DS308.0
8K5 907 115 F,ADVMB,2.0l R4/4V TF H09 0008,
,,G004,F0,G038,F0,G039,F0,G043,F0,G094,F0,G102,F0,G162,F0,G180,F0,G252,F0,G504,F0,G000,F0,G000,F0,
Second & Third:
Friday,01,November,2019,14:47:16:05213-VCID:353722E965C0337F2A1-8060,VCDS Version: Release 19.6.2 (x64),Data version: 20190930 DS308.0
,,G004,F0,G094,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,G000,F0,
Marker,TIME,Loc. IDE00025,TIME,Loc. IDE00589,,,,,,,,,,,,,,,,,,,,,
,STAMP,Coolant temperature,STAMP,Fuel pressure,,,,,,,,,,,,,,,,,,,,,
,, °C,, kPa rel,,,,,,,,,,,,,,,,,,,,,
,0.13,80,0.02,3900,,,,,,,,,,,,,,,,,,,,,
,0.35,81,0.24,3900,,,,,,,,,,,,,,,,,,,,,
,0.55,81,0.46,3910,,,,,,,,,,,,,,,,,,,,,
,0.77,81,0.67,3900,,,,,,,,,,,,,,,,,,,,,
,0.99,81,0.88,3880,,,,,,,,,,,,,,,,,,,,,
,1.21,81,1.10,3890,,,,,,,,,,,,,,,,,,,,,
,1.41,81,1.32,3880,,,,,,,,,,,,,,,,,,,,,
,1.63,81,1.52,3880,,,,,,,,,,,,,,,,,,,,,
,1.85,81,1.74,3880,,,,,,,,,,,,,,,,,,,,,
,2.06,81,1.96,3900,,,,,,,,,,,,,,,,,,,,,
,2.27,81,2.16,3890,,,,,,,,,,,,,,,,,,,,,
,2.49,81,2.38,3900,,,,,,,,,,,,,,,,,,,,,
,2.71,81,2.60,3900,,,,,,,,,,,,,,,,,,,,,
,2.91,81,2.82,3890,,,,,,,,,,,,,,,,,,,,,
,3.13,81,3.02,3900,,,,,,,,,,,,,,,,,,,,,
,3.35,81,3.24,3900,,,,,,,,,,,,,,,,,,,,,
,3.55,81,3.46,3900,,,,,,,,,,,,,,,,,,,,,
,3.77,81,3.66,3910,,,,,,,,,,,,,,,,,,,,,
,3.99,81,3.88,3900,,,,,,,,,,,,,,,,,,,,,
,4.21,81,4.10,3920,,,,,,,,,,,,,,,,,,,,,
,4.41,81,4.30,3910,,,,,,,,,,,,,,,,,,,,,
,4.63,81,4.52,3860,,,,,,,,,,,,,,,,,,,,,
,4.85,81,4.74,3880,,,,,,,,,,,,,,,,,,,,,
,5.05,81,4.96,3900,,,,,,,,,,,,,,,,,,,,,
,5.27,81,5.17,3910,,,,,,,,,,,,,,,,,,,,,
,5.49,81,5.38,3900,,,,,,,,,,,,,,,,,,,,,
Friday,01,November,2019,14:48:20:05213-VCID:353722E965C0337F2A1-8060,VCDS Version: Release 19.6.2 (x64),Data version: 20190930 DS308.0
,0.01,81,0.11,4210,,,,,,,,,,,,,,,,,,,,,
,0.22,81,0.33,4210,,,,,,,,,,,,,,,,,,,,,
,0.42,81,0.53,4210,,,,,,,,,,,,,,,,,,,,,
,0.64,81,0.75,4220,,,,,,,,,,,,,,,,,,,,,
,0.86,81,0.95,4210,,,,,,,,,,,,,,,,,,,,,
,1.06,81,1.18,4220,,,,,,,,,,,,,,,,,,,,,
,1.28,81,1.39,4210,,,,,,,,,,,,,,,,,,,,,
,1.50,81,1.61,4220,,,,,,,,,,,,,,,,,,,,,
,1.70,81,1.81,4220,,,,,,,,,,,,,,,,,,,,,
,1.92,81,2.03,4220,,,,,,,,,,,,,,,,,,,,,
,2.14,81,2.25,4220,,,,,,,,,,,,,,,,,,,,,
,2.36,81,2.47,4230,,,,,,,,,,,,,,,,,,,,,
,2.58,81,2.68,4230,,,,,,,,,,,,,,,,,,,,,
,2.78,81,2.89,4230,,,,,,,,,,,,,,,,,,,,,
,3.00,81,3.11,4230,,,,,,,,,,,,,,,,,,,,,
,3.22,81,3.33,4230,,,,,,,,,,,,,,,,,,,,,
,3.43,81,3.53,4230,,,,,,,,,,,,,,,,,,,,,
,3.64,81,3.75,4230,,,,,,,,,,,,,,,,,,,,,
,3.86,81,3.97,4230,,,,,,,,,,,,,,,,,,,,,
,4.06,81,4.18,4240,,,,,,,,,,,,,,,,,,,,,
,4.28,81,4.39,4230,,,,,,,,,,,,,,,,,,,,,
,4.50,81,4.61,4230,,,,,,,,,,,,,,,,,,,,,
,4.72,81,4.81,4240,,,,,,,,,,,,,,,,,,,,,
,4.92,81,5.03,4240,,,,,,,,,,,,,,,,,,,,,
,5.14,81,5.25,4240,,,,,,,,,,,,,,,,,,,,,
,5.36,81,5.47,4250,,,,,,,,,,,,,,,,,,,,,
,5.58,81,5.68,4250,,,,,,,,,,,,,,,,,,,,,
,5.78,81,5.89,4250,,,,,,,,,,,,,,,,,,,,,
,6.00,81,6.11,4250,,,,,,,,,,,,,,,,,,,,,
,6.20,81,6.31,4250,,,,,,,,,,,,,,,,,,,,,
,6.43,81,6.53,4260,,,,,,,,,,,,,,,,,,,,,
,6.64,81,6.75,4250,,,,,,,,,,,,,,,,,,,,,
,6.86,81,6.95,4250,,,,,,,,,,,,,,,,,,,,,
,7.06,81,7.18,4260,,,,,,,,,,,,,,,,,,,,,
,7.28,81,7.39,4260,,,,,,,,,,,,,,,,,,,,,
,7.50,81,7.61,4260,,,,,,,,,,,,,,,,,,,,,
,7.72,81,7.81,4260,,,,,,,,,,,,,,,,,,,,,
,7.93,81,8.03,4260,,,,,,,,,,,,,,,,,,,,,
,8.14,81,8.25,4260,,,,,,,,,,,,,,,,,,,,,
,8.36,81,8.47,4260,,,,,,,,,,,,,,,,,,,,,
,8.56,81,8.67,4260,,,,,,,,,,,,,,,,,,,,,
,8.78,81,8.89,4260,,,,,,,,,,,,,,,,,,,,,
,9.00,81,9.11,4260,,,,,,,,,,,,,,,,,,,,,
,9.20,81,9.31,4270,,,,,,,,,,,,,,,,,,,,,
,9.43,81,9.53,4270,,,,,,,,,,,,,,,,,,,,,
,9.64,81,9.75,4270,,,,,,,,,,,,,,,,,,,,,
,9.86,81,9.95,4280,,,,,,,,,,,,,,,,,,,,,
,10.06,81,10.18,4280,,,,,,,,,,,,,,,,,,,,,
,10.28,81,10.39,4280,,,,,,,,,,,,,,,,,,,,,
,10.50,81,10.61,4280,,,,,,,,,,,,,,,,,,,,,
,10.72,81,10.81,4280,,,,,,,,,,,,,,,,,,,,,
,10.92,81,11.03,4280,,,,,,,,,,,,,,,,,,,,,
,11.14,81,11.25,4280,,,,,,,,,,,,,,,,,,,,,
,11.36,81,11.47,4280,,,,,,,,,,,,,,,,,,,,,
,11.56,81,11.67,4280,,,,,,,,,,,,,,,,,,,,,
,11.78,81,11.89,4280,,,,,,,,,,,,,,,,,,,,,
,12.00,81,12.11,4290,,,,,,,,,,,,,,,,,,,,,
,12.22,81,12.33,4280,,,,,,,,,,,,,,,,,,,,,
,12.44,81,12.55,4280,,,,,,,,,,,,,,,,,,,,,
,12.66,81,12.75,4290,,,,,,,,,,,,,,,,,,,,,
,12.86,81,12.97,4290,,,,,,,,,,,,,,,,,,,,,
,13.08,81,13.19,4290,,,,,,,,,,,,,,,,,,,,,
,13.30,81,13.39,4290,,,,,,,,,,,,,,,,,,,,,
,13.50,81,13.61,4300,,,,,,,,,,,,,,,,,,,,,
,13.72,81,13.81,4300,,,,,,,,,,,,,,,,,,,,,
,13.93,81,14.03,4300,,,,,,,,,,,,,,,,,,,,,
,14.14,81,14.25,4310,,,,,,,,,,,,,,,,,,,,,
,14.36,81,14.47,4300,,,,,,,,,,,,,,,,,,,,,
,14.56,81,14.68,4310,,,,,,,,,,,,,,,,,,,,,
,14.78,81,14.89,4300,,,,,,,,,,,,,,,,,,,,,
,15.00,81,15.11,4310,,,,,,,,,,,,,,,,,,,,,
,15.22,81,15.32,4310,,,,,,,,,,,,,,,,,,,,,
,15.43,81,15.53,4310,,,,,,,,,,,,,,,,,,,,,
,15.64,81,15.75,4310,,,,,,,,,,,,,,,,,,,,,
,15.86,81,15.95,4310,,,,,,,,,,,,,,,,,,,,,
,16.06,81,16.18,4310,,,,,,,,,,,,,,,,,,,,,
,16.28,81,16.39,4310,,,,,,,,,,,,,,,,,,,,,
,16.50,81,16.61,4310,,,,,,,,,,,,,,,,,,,,,
,16.72,81,16.83,4310,,,,,,,,,,,,,,,,,,,,,
,16.94,81,17.05,4310,,,,,,,,,,,,,,,,,,,,,
,17.14,81,17.25,4310,,,,,,,,,,,,,,,,,,,,,
,17.36,81,17.47,4310,,,,,,,,,,,,,,,,,,,,,
,17.56,81,17.67,4310,,,,,,,,,,,,,,,,,,,,,
,17.78,81,17.89,4310,,,,,,,,,,,,,,,,,,,,,
,18.00,81,18.11,4310,,,,,,,,,,,,,,,,,,,,,
,18.22,81,18.33,4310,,,,,,,,,,,,,,,,,,,,,
,18.43,81,18.53,4320,,,,,,,,,,,,,,,,,,,,,
,18.64,81,18.75,4320,,,,,,,,,,,,,,,,,,,,,
,18.86,81,18.97,4330,,,,,,,,,,,,,,,,,,,,,
,19.08,81,19.18,4320,,,,,,,,,,,,,,,,,,,,,
,19.28,81,19.39,4320,,,,,,,,,,,,,,,,,,,,,
,19.50,81,19.61,4320,,,,,,,,,,,,,,,,,,,,,
,19.72,81,19.83,4320,,,,,,,,,,,,,,,,,,,,,
,19.92,81,20.03,4330,,,,,,,,,,,,,,,,,,,,,
,20.14,81,20.25,4330,,,,,,,,,,,,,,,,,,,,,
,20.36,81,20.47,4320,,,,,,,,,,,,,,,,,,,,,
,20.56,81,20.68,4330,,,,,,,,,,,,,,,,,,,,,
,20.78,81,20.89,4330,,,,,,,,,,,,,,,,,,,,,
,21.00,81,21.11,4330,,,,,,,,,,,,,,,,,,,,,
,21.22,81,21.33,4330,,,,,,,,,,,,,,,,,,,,,
,21.43,81,21.53,4330,,,,,,,,,,,,,,,,,,,,,
,21.64,81,21.75,4340,,,,,,,,,,,,,,,,,,,,,
,21.86,81,21.97,4340,,,,,,,,,,,,,,,,,,,,,
,22.06,81,22.18,4340,,,,,,,,,,,,,,,,,,,,,
,22.28,81,22.39,4340,,,,,,,,,,,,,,,,,,,,,
,22.50,81,22.61,4340,,,,,,,,,,,,,,,,,,,,,
,22.70,81,22.81,4350,,,,,,,,,,,,,,,,,,,,,
,22.92,81,23.03,4350,,,,,,,,,,,,,,,,,,,,,
,23.14,81,23.25,4350,,,,,,,,,,,,,,,,,,,,,
,23.36,81,23.47,4350,,,,,,,,,,,,,,,,,,,,,
,23.58,81,23.67,4350,,,,,,,,,,,,,,,,,,,,,
,23.78,81,23.89,4350,,,,,,,,,,,,,,,,,,,,,
,24.00,81,24.11,4350,,,,,,,,,,,,,,,,,,,,,
,24.20,81,24.31,4350,,,,,,,,,,,,,,,,,,,,,
,24.42,81,24.53,4350,,,,,,,,,,,,,,,,,,,,,
,24.64,81,24.75,4350,,,,,,,,,,,,,,,,,,,,,
,24.86,81,24.97,4350,,,,,,,,,,,,,,,,,,,,,
,25.08,81,25.18,4350,,,,,,,,,,,,,,,,,,,,,
,25.28,81,25.39,4350,,,,,,,,,,,,,,,,,,,,,
,25.50,81,25.61,4360,,,,,,,,,,,,,,,,,,,,,
,25.72,81,25.81,4360,,,,,,,,,,,,,,,,,,,,,
,25.93,81,26.03,4360,,,,,,,,,,,,,,,,,,,,,
,26.14,81,26.25,4360,,,,,,,,,,,,,,,,,,,,,
,26.36,81,26.47,4370,,,,,,,,,,,,,,,,,,,,,
,26.58,81,26.68,4370,,,,,,,,,,,,,,,,,,,,,
,26.78,81,26.89,4380,,,,,,,,,,,,,,,,,,,,,
,27.00,81,27.11,4370,,,,,,,,,,,,,,,,,,,,,
,27.22,81,27.33,4370,,,,,,,,,,,,,,,,,,,,,
,27.43,81,27.53,4370,,,,,,,,,,,,,,,,,,,,,
,27.64,81,27.75,4370,,,,,,,,,,,,,,,,,,,,,
,27.86,81,27.97,4380,,,,,,,,,,,,,,,,,,,,,
,28.08,81,28.17,4380,,,,,,,,,,,,,,,,,,,,,
,28.28,81,28.39,4380,,,,,,,,,,,,,,,,,,,,,
,28.50,81,28.61,4380,,,,,,,,,,,,,,,,,,,,,
,28.72,81,28.81,4380,,,,,,,,,,,,,,,,,,,,,
,28.92,81,29.03,4380,,,,,,,,,,,,,,,,,,,,,
,29.14,81,29.25,4380,,,,,,,,,,,,,,,,,,,,,
,29.36,81,29.47,4380,,,,,,,,,,,,,,,,,,,,,
,29.58,81,29.67,4380,,,,,,,,,,,,,,,,,,,,,
,29.78,81,29.89,4390,,,,,,,,,,,,,,,,,,,,,
,30.00,81,30.11,4380,,,,,,,,,,,,,,,,,,,,,
,30.22,81,30.31,4380,,,,,,,,,,,,,,,,,,,,,
,30.42,81,30.53,4390,,,,,,,,,,,,,,,,,,,,,
,30.64,81,30.75,4390,,,,,,,,,,,,,,,,,,,,,
,30.86,81,30.95,4400,,,,,,,,,,,,,,,,,,,,,
,31.06,81,31.18,4400,,,,,,,,,,,,,,,,,,,,,
,31.28,81,31.39,4390,,,,,,,,,,,,,,,,,,,,,
,31.50,81,31.61,4400,,,,,,,,,,,,,,,,,,,,,
,31.72,81,31.81,4400,,,,,,,,,,,,,,,,,,,,,
,31.92,81,32.03,4400,,,,,,,,,,,,,,,,,,,,,
,32.14,81,32.25,4400,,,,,,,,,,,,,,,,,,,,,
,32.36,81,32.45,4400,,,,,,,,,,,,,,,,,,,,,
,32.56,81,32.67,4400,,,,,,,,,,,,,,,,,,,,,
,32.78,81,32.89,4400,,,,,,,,,,,,,,,,,,,,,
,33.00,81,33.11,4400,,,,,,,,,,,,,,,,,,,,,
,33.22,81,33.31,4400,,,,,,,,,,,,,,,,,,,,,
,33.42,81,33.53,4400,,,,,,,,,,,,,,,,,,,,,
,33.64,81,33.75,4400,,,,,,,,,,,,,,,,,,,,,
,33.86,81,33.97,4400,,,,,,,,,,,,,,,,,,,,,
,34.08,81,34.17,4410,,,,,,,,,,,,,,,,,,,,,
,34.28,81,34.39,4410,,,,,,,,,,,,,,,,,,,,,
,34.50,81,34.59,4410,,,,,,,,,,,,,,,,,,,,,
,34.70,81,34.81,4410,,,,,,,,,,,,,,,,,,,,,
,34.93,81,35.03,4410,,,,,,,,,,,,,,,,,,,,,
,35.14,81,35.25,4420,,,,,,,,,,,,,,,,,,,,,
,35.36,81,35.47,4420,,,,,,,,,,,,,,,,,,,,,
,35.58,81,35.67,4420,,,,,,,,,,,,,,,,,,,,,
,35.78,81,35.89,4420,,,,,,,,,,,,,,,,,,,,,
,36.00,81,36.11,4420,,,,,,,,,,,,,,,,,,,,,
,36.22,81,36.33,4430,,,,,,,,,,,,,,,,,,,,,
,36.43,81,36.53,4420,,,,,,,,,,,,,,,,,,,,,
,36.64,81,36.75,4430,,,,,,,,,,,,,,,,,,,,,
,36.86,81,36.97,4430,,,,,,,,,,,,,,,,,,,,,
,37.06,81,37.17,4430,,,,,,,,,,,,,,,,,,,,,
,37.28,81,37.39,4430,,,,,,,,,,,,,,,,,,,,,
,37.50,81,37.61,4430,,,,,,,,,,,,,,,,,,,,,
,37.72,81,37.81,4430,,,,,,,,,,,,,,,,,,,,,
,37.92,81,38.03,4430,,,,,,,,,,,,,,,,,,,,,
,38.14,81,38.25,4430,,,,,,,,,,,,,,,,,,,,,
,38.36,81,38.47,4430,,,,,,,,,,,,,,,,,,,,,
,38.56,81,38.67,4430,,,,,,,,,,,,,,,,,,,,,
,38.78,81,38.89,4430,,,,,,,,,,,,,,,,,,,,,
,39.00,81,39.11,4430,,,,,,,,,,,,,,,,,,,,,
,39.22,81,39.33,4430,,,,,,,,,,,,,,,,,,,,,
,39.44,81,39.55,4430,,,,,,,,,,,,,,,,,,,,,
,39.64,81,39.75,4440,,,,,,,,,,,,,,,,,,,,,
,39.86,81,39.97,4440,,,,,,,,,,,,,,,,,,,,,
,40.08,81,40.18,4430,,,,,,,,,,,,,,,,,,,,,
,40.28,81,40.39,4430,,,,,,,,,,,,,,,,,,,,,
,40.50,81,40.61,4440,,,,,,,,,,,,,,,,,,,,,
,40.72,81,40.83,4440,,,,,,,,,,,,,,,,,,,,,
,40.94,81,41.05,4440,,,,,,,,,,,,,,,,,,,,,
,41.14,81,41.25,4450,,,,,,,,,,,,,,,,,,,,,
,41.36,81,41.47,4450,,,,,,,,,,,,,,,,,,,,,
,41.56,81,41.67,4450,,,,,,,,,,,,,,,,,,,,,
,41.78,81,41.89,4450,,,,,,,,,,,,,,,,,,,,,
,42.00,81,42.11,4450,,,,,,,,,,,,,,,,,,,,,
,42.20,81,42.31,4450,,,,,,,,,,,,,,,,,,,,,
,42.43,81,42.53,4450,,,,,,,,,,,,,,,,,,,,,
,42.64,81,42.75,4450,,,,,,,,,,,,,,,,,,,,,
,42.86,81,42.97,4450,,,,,,,,,,,,,,,,,,,,,
,43.06,81,43.17,4450,,,,,,,,,,,,,,,,,,,,,
,43.28,81,43.39,4450,,,,,,,,,,,,,,,,,,,,,
,43.50,81,43.61,4450,,,,,,,,,,,,,,,,,,,,,
,43.72,81,43.81,4450,,,,,,,,,,,,,,,,,,,,,
,43.93,81,44.03,4450,,,,,,,,,,,,,,,,,,,,,
,44.14,81,44.25,4450,,,,,,,,,,,,,,,,,,,,,
,44.36,81,44.47,4460,,,,,,,,,,,,,,,,,,,,,
,44.56,81,44.67,4460,,,,,,,,,,,,,,,,,,,,,
,44.78,81,44.89,4470,,,,,,,,,,,,,,,,,,,,,
,45.00,81,45.11,4460,,,,,,,,,,,,,,,,,,,,,
,45.22,81,45.33,4470,,,,,,,,,,,,,,,,,,,,,
,45.43,81,45.53,4470,,,,,,,,,,,,,,,,,,,,,
,45.64,81,45.75,4470,,,,,,,,,,,,,,,,,,,,,
,45.86,81,45.97,4470,,,,,,,,,,,,,,,,,,,,,
,46.08,81,46.17,4480,,,,,,,,,,,,,,,,,,,,,
,46.28,81,46.39,4480,,,,,,,,,,,,,,,,,,,,,
,46.50,81,46.61,4480,,,,,,,,,,,,,,,,,,,,,
,46.72,81,46.81,4480,,,,,,,,,,,,,,,,,,,,,
,46.93,81,47.03,4480,,,,,,,,,,,,,,,,,,,,,
,47.14,81,47.25,4480,,,,,,,,,,,,,,,,,,,,,
,47.36,81,47.47,4480,,,,,,,,,,,,,,,,,,,,,
,47.57,81,47.67,4480,,,,,,,,,,,,,,,,,,,,,
,47.78,81,47.89,4490,,,,,,,,,,,,,,,,,,,,,
,48.00,81,48.11,4490,,,,,,,,,,,,,,,,,,,,,
,48.22,81,48.33,4490,,,,,,,,,,,,,,,,,,,,,
,48.44,81,48.55,4490,,,,,,,,,,,,,,,,,,,,,
,48.64,81,48.75,4490,,,,,,,,,,,,,,,,,,,,,
,48.86,81,48.97,4490,,,,,,,,,,,,,,,,,,,,,
,49.08,81,49.17,4490,,,,,,,,,,,,,,,,,,,,,
,49.28,81,49.39,4500,,,,,,,,,,,,,,,,,,,,,
,49.50,81,49.61,4500,,,,,,,,,,,,,,,,,,,,,
,49.71,81,49.81,4500,,,,,,,,,,,,,,,,,,,,,
,49.92,81,50.03,4500,,,,,,,,,,,,,,,,,,,,,
,50.14,81,50.25,4500,,,,,,,,,,,,,,,,,,,,,
,50.36,81,50.47,4500,,,,,,,,,,,,,,,,,,,,,
,50.56,81,50.68,4500,,,,,,,,,,,,,,,,,,,,,
,50.78,81,50.89,4500,,,,,,,,,,,,,,,,,,,,,
,51.00,81,51.11,4500,,,,,,,,,,,,,,,,,,,,,
,51.22,81,51.33,4500,,,,,,,,,,,,,,,,,,,,,
,51.42,81,51.53,4500,,,,,,,,,,,,,,,,,,,,,
,51.64,81,51.75,4500,,,,,,,,,,,,,,,,,,,,,
,51.86,81,51.97,4510,,,,,,,,,,,,,,,,,,,,,
,52.08,81,52.19,4510,,,,,,,,,,,,,,,,,,,,,
,52.30,81,52.41,4520,,,,,,,,,,,,,,,,,,,,,
,52.50,81,52.61,4520,,,,,,,,,,,,,,,,,,,,,
,52.72,81,52.83,4510,,,,,,,,,,,,,,,,,,,,,
,52.94,81,53.05,4520,,,,,,,,,,,,,,,,,,,,,
,53.14,81,53.25,4520,,,,,,,,,,,,,,,,,,,,,
,53.36,81,53.47,4520,,,,,,,,,,,,,,,,,,,,,
,53.58,81,53.69,4520,,,,,,,,,,,,,,,,,,,,,
,53.80,81,53.89,4530,,,,,,,,,,,,,,,,,,,,,
,54.00,81,54.11,4520,,,,,,,,,,,,,,,,,,,,,
,54.22,81,54.33,4520,,,,,,,,,,,,,,,,,,,,,
,54.44,81,54.55,4530,,,,,,,,,,,,,,,,,,,,,
,54.64,81,54.75,4530,,,,,,,,,,,,,,,,,,,,,
,54.86,81,54.97,4530,,,,,,,,,,,,,,,,,,,,,
,55.08,81,55.18,4530,,,,,,,,,,,,,,,,,,,,,
,55.28,81,55.39,4530,,,,,,,,,,,,,,,,,,,,,
,55.50,81,55.61,4530,,,,,,,,,,,,,,,,,,,,,
,55.72,81,55.81,4530,,,,,,,,,,,,,,,,,,,,,
,55.92,81,56.03,4530,,,,,,,,,,,,,,,,,,,,,
,56.14,81,56.25,4530,,,,,,,,,,,,,,,,,,,,,
,56.36,81,56.47,4530,,,,,,,,,,,,,,,,,,,,,
,56.57,81,56.68,4530,,,,,,,,,,,,,,,,,,,,,
,56.78,81,56.89,4530,,,,,,,,,,,,,,,,,,,,,
,57.00,81,57.11,4530,,,,,,,,,,,,,,,,,,,,,
,57.22,81,57.32,4540,,,,,,,,,,,,,,,,,,,,,
,57.42,81,57.53,4530,,,,,,,,,,,,,,,,,,,,,
,57.64,81,57.75,4540,,,,,,,,,,,,,,,,,,,,,
,57.86,81,57.97,4540,,,,,,,,,,,,,,,,,,,,,
,58.08,81,58.18,4540,,,,,,,,,,,,,,,,,,,,,
,58.28,81,58.39,4550,,,,,,,,,,,,,,,,,,,,,
,58.50,81,58.61,4550,,,,,,,,,,,,,,,,,,,,,
,58.72,81,58.83,4550,,,,,,,,,,,,,,,,,,,,,
,58.93,81,59.03,4550,,,,,,,,,,,,,,,,,,,,,
,59.14,81,59.25,4550,,,,,,,,,,,,,,,,,,,,,
,59.36,81,59.47,4550,,,,,,,,,,,,,,,,,,,,,
,59.58,81,59.68,4550,,,,,,,,,,,,,,,,,,,,,
,59.78,81,59.89,4550,,,,,,,,,,,,,,,,,,,,,
,60.00,81,60.11,4550,,,,,,,,,,,,,,,,,,,,,
,60.22,81,60.33,4550,,,,,,,,,,,,,,,,,,,,,
,60.44,81,60.55,4550,,,,,,,,,,,,,,,,,,,,,
,60.64,81,60.75,4550,,,,,,,,,,,,,,,,,,,,,
,60.86,81,60.95,4550,,,,,,,,,,,,,,,,,,,,,
,61.06,81,61.17,4550,,,,,,,,,,,,,,,,,,,,,
,61.28,81,61.39,4550,,,,,,,,,,,,,,,,,,,,,
,61.50,81,61.61,4550,,,,,,,,,,,,,,,,,,,,,
,61.72,81,61.81,4550,,,,,,,,,,,,,,,,,,,,,
,61.92,81,62.03,4560,,,,,,,,,,,,,,,,,,,,,
,62.14,81,62.25,4560,,,,,,,,,,,,,,,,,,,,,
,62.36,81,62.45,4560,,,,,,,,,,,,,,,,,,,,,
,62.56,81,62.68,4560,,,,,,,,,,,,,,,,,,,,,
,62.78,81,62.89,4560,,,,,,,,,,,,,,,,,,,,,
,63.00,81,63.11,4570,,,,,,,,,,,,,,,,,,,,,
,63.22,81,63.31,4570,,,,,,,,,,,,,,,,,,,,,
,63.42,81,63.53,4570,,,,,,,,,,,,,,,,,,,,,
,63.64,81,63.75,4570,,,,,,,,,,,,,,,,,,,,,
,63.86,81,63.97,4570,,,,,,,,,,,,,,,,,,,,,
,64.08,81,64.17,4570,,,,,,,,,,,,,,,,,,,,,
,64.28,81,64.39,4570,,,,,,,,,,,,,,,,,,,,,
,64.50,81,64.61,4570,,,,,,,,,,,,,,,,,,,,,
,64.72,81,64.83,4580,,,,,,,,,,,,,,,,,,,,,
,64.94,81,65.05,4570,,,,,,,,,,,,,,,,,,,,,
,65.14,81,65.25,4580,,,,,,,,,,,,,,,,,,,,,
,65.36,81,65.47,4580,,,,,,,,,,,,,,,,,,,,,
,65.57,81,65.67,4580,,,,,,,,,,,,,,,,,,,,,
,65.78,81,65.89,4580,,,,,,,,,,,,,,,,,,,,,
,66.00,81,66.11,4590,,,,,,,,,,,,,,,,,,,,,
,66.22,81,66.33,4580,,,,,,,,,,,,,,,,,,,,,
,66.44,81,66.55,4590,,,,,,,,,,,,,,,,,,,,,
,66.64,81,66.75,4590,,,,,,,,,,,,,,,,,,,,,
,66.86,81,66.97,4590,,,,,,,,,,,,,,,,,,,,,
,67.08,81,67.19,4600,,,,,,,,,,,,,,,,,,,,,
,67.30,81,67.41,4600,,,,,,,,,,,,,,,,,,,,,
,67.50,81,67.61,4600,,,,,,,,,,,,,,,,,,,,,
,67.72,81,67.83,4600,,,,,,,,,,,,,,,,,,,,,
,67.94,81,68.05,4600,,,,,,,,,,,,,,,,,,,,,
,68.14,81,68.25,4600,,,,,,,,,,,,,,,,,,,,,
,68.36,81,68.47,4600,,,,,,,,,,,,,,,,,,,,,
,68.58,81,68.69,4600,,,,,,,,,,,,,,,,,,,,,
,68.80,81,68.91,4600,,,,,,,,,,,,,,,,,,,,,
,69.00,81,69.11,4600,,,,,,,,,,,,,,,,,,,,,
,69.22,81,69.31,4600,,,,,,,,,,,,,,,,,,,,,
,69.42,81,69.53,4600,,,,,,,,,,,,,,,,,,,,,
,69.64,81,69.75,4600,,,,,,,,,,,,,,,,,,,,,
,69.86,81,69.97,4600,,,,,,,,,,,,,,,,,,,,,
,70.08,81,70.19,4610,,,,,,,,,,,,,,,,,,,,,
,70.30,81,70.39,4600,,,,,,,,,,,,,,,,,,,,,
,70.50,81,70.61,4610,,,,,,,,,,,,,,,,,,,,,
,70.72,81,70.83,4620,,,,,,,,,,,,,,,,,,,,,
,70.92,81,71.03,4620,,,,,,,,,,,,,,,,,,,,,
,71.14,81,71.25,4620,,,,,,,,,,,,,,,,,,,,,
,71.36,81,71.47,4620,,,,,,,,,,,,,,,,,,,,,
,71.56,81,71.67,4620,,,,,,,,,,,,,,,,,,,,,
,71.78,81,71.89,4620,,,,,,,,,,,,,,,,,,,,,
,72.00,81,72.11,4620,,,,,,,,,,,,,,,,,,,,,
,72.22,81,72.31,4620,,,,,,,,,,,,,,,,,,,,,
,72.42,81,72.53,4620,,,,,,,,,,,,,,,,,,,,,
,72.64,81,72.75,4620,,,,,,,,,,,,,,,,,,,,,
,72.86,81,72.95,4630,,,,,,,,,,,,,,,,,,,,,
,73.06,81,73.17,4630,,,,,,,,,,,,,,,,,,,,,
,73.28,81,73.39,4630,,,,,,,,,,,,,,,,,,,,,
,73.50,81,73.61,4640,,,,,,,,,,,,,,,,,,,,,
,73.72,81,73.83,4630,,,,,,,,,,,,,,,,,,,,,
,73.92,81,74.03,4630,,,,,,,,,,,,,,,,,,,,,
,74.14,81,74.25,4630,,,,,,,,,,,,,,,,,,,,,
,74.36,81,74.45,4630,,,,,,,,,,,,,,,,,,,,,
,74.56,81,74.67,4640,,,,,,,,,,,,,,,,,,,,,
,74.78,81,74.89,4630,,,,,,,,,,,,,,,,,,,,,
,75.00,81,75.11,4640,,,,,,,,,,,,,,,,,,,,,
,75.22,81,75.33,4640,,,,,,,,,,,,,,,,,,,,,
,75.43,81,75.53,4650,,,,,,,,,,,,,,,,,,,,,
,75.64,81,75.75,4650,,,,,,,,,,,,,,,,,,,,,
,75.86,81,75.97,4650,,,,,,,,,,,,,,,,,,,,,
,76.06,81,76.17,4650,,,,,,,,,,,,,,,,,,,,,
,76.28,81,76.39,4650,,,,,,,,,,,,,,,,,,,,,
,76.50,81,76.61,4650,,,,,,,,,,,,,,,,,,,,,
,76.72,81,76.83,4650,,,,,,,,,,,,,,,,,,,,,
,76.94,81,77.05,4650,,,,,,,,,,,,,,,,,,,,,
,77.14,81,77.25,4650,,,,,,,,,,,,,,,,,,,,,
,77.36,81,77.47,4650,,,,,,,,,,,,,,,,,,,,,
,77.58,81,77.69,4650,,,,,,,,,,,,,,,,,,,,,
,77.79,81,77.89,4650,,,,,,,,,,,,,,,,,,,,,
,78.00,81,78.11,4650,,,,,,,,,,,,,,,,,,,,,
,78.22,81,78.33,4650,,,,,,,,,,,,,,,,,,,,,
,78.44,81,78.55,4650,,,,,,,,,,,,,,,,,,,,,
,78.64,81,78.75,4650,,,,,,,,,,,,,,,,,,,,,
,78.86,81,78.97,4650,,,,,,,,,,,,,,,,,,,,,
,79.08,81,79.19,4650,,,,,,,,,,,,,,,,,,,,,
,79.30,81,79.41,4650,,,,,,,,,,,,,,,,,,,,,
,79.50,81,79.61,4650,,,,,,,,,,,,,,,,,,,,,
,79.72,81,79.83,4650,,,,,,,,,,,,,,,,,,,,,
,79.94,81,80.05,4650,,,,,,,,,,,,,,,,,,,,,
,80.14,81,80.25,4650,,,,,,,,,,,,,,,,,,,,,
,80.36,81,80.47,4660,,,,,,,,,,,,,,,,,,,,,
,80.58,81,80.67,4660,,,,,,,,,,,,,,,,,,,,,
,80.78,81,80.89,4670,,,,,,,,,,,,,,,,,,,,,
,81.00,81,81.11,4660,,,,,,,,,,,,,,,,,,,,,
,81.22,81,81.32,4670,,,,,,,,,,,,,,,,,,,,,
,81.43,81,81.53,4670,,,,,,,,,,,,,,,,,,,,,
,81.64,81,81.75,4670,,,,,,,,,,,,,,,,,,,,,
,81.86,81,81.97,4670,,,,,,,,,,,,,,,,,,,,,
,82.08,81,82.17,4670,,,,,,,,,,,,,,,,,,,,,
,82.28,81,82.39,4670,,,,,,,,,,,,,,,,,,,,,
,82.50,81,82.61,4670,,,,,,,,,,,,,,,,,,,,,
,82.72,81,82.83,4680,,,,,,,,,,,,,,,,,,,,,
,82.94,81,83.05,4670,,,,,,,,,,,,,,,,,,,,,
,83.14,81,83.25,4670,,,,,,,,,,,,,,,,,,,,,
,83.36,81,83.47,4680,,,,,,,,,,,,,,,,,,,,,
,83.58,81,83.69,4680,,,,,,,,,,,,,,,,,,,,,
,83.79,81,83.89,4680,,,,,,,,,,,,,,,,,,,,,
,84.00,81,84.11,4670,,,,,,,,,,,,,,,,,,,,,
,84.22,81,84.33,4670,,,,,,,,,,,,,,,,,,,,,
,84.42,81,84.53,4680,,,,,,,,,,,,,,,,,,,,,
,84.64,81,84.75,4680,,,,,,,,,,,,,,,,,,,,,
,84.86,81,84.97,4690,,,,,,,,,,,,,,,,,,,,,
,85.06,81,85.18,4690,,,,,,,,,,,,,,,,,,,,,
,85.28,81,85.39,4690,,,,,,,,,,,,,,,,,,,,,
,85.50,81,85.61,4690,,,,,,,,,,,,,,,,,,,,,
,85.72,81,85.81,4700,,,,,,,,,,,,,,,,,,,,,
,85.92,81,86.03,4690,,,,,,,,,,,,,,,,,,,,,
,86.14,81,86.25,4690,,,,,,,,,,,,,,,,,,,,,
,86.36,81,86.45,4700,,,,,,,,,,,,,,,,,,,,,
,86.56,81,86.68,4690,,,,,,,,,,,,,,,,,,,,,
,86.78,81,86.89,4700,,,,,,,,,,,,,,,,,,,,,
,87.00,81,87.11,4700,,,,,,,,,,,,,,,,,,,,,
,87.22,81,87.32,4700,,,,,,,,,,,,,,,,,,,,,
,87.42,81,87.53,4700,,,,,,,,,,,,,,,,,,,,,
,87.64,81,87.75,4700,,,,,,,,,,,,,,,,,,,,,
,87.86,81,87.97,4710,,,,,,,,,,,,,,,,,,,,,
,88.08,81,88.19,4700,,,,,,,,,,,,,,,,,,,,,
,88.30,81,88.39,4700,,,,,,,,,,,,,,,,,,,,,
,88.50,81,88.61,4700,,,,,,,,,,,,,,,,,,,,,
,88.72,81,88.81,4700,,,,,,,,,,,,,,,,,,,,,
,88.93,81,89.03,4710,,,,,,,,,,,,,,,,,,,,,
,89.14,81,89.25,4720,,,,,,,,,,,,,,,,,,,,,
,89.36,81,89.47,4710,,,,,,,,,,,,,,,,,,,,,
,89.58,81,89.67,4720,,,,,,,,,,,,,,,,,,,,,
,89.78,81,89.89,4720,,,,,,,,,,,,,,,,,,,,,
,90.00,81,90.11,4720,,,,,,,,,,,,,,,,,,,,,
,90.22,81,90.33,4720,,,,,,,,,,,,,,,,,,,,,
,90.42,81,90.53,4720,,,,,,,,,,,,,,,,,,,,,
,90.64,81,90.75,4720,,,,,,,,,,,,,,,,,,,,,
,90.86,81,90.97,4720,,,,,,,,,,,,,,,,,,,,,
,91.08,81,91.17,4720,,,,,,,,,,,,,,,,,,,,,
,91.28,81,91.39,4720,,,,,,,,,,,,,,,,,,,,,
,91.50,81,91.61,4730,,,,,,,,,,,,,,,,,,,,,
,91.72,81,91.83,4730,,,,,,,,,,,,,,,,,,,,,
,91.94,81,92.05,4720,,,,,,,,,,,,,,,,,,,,,
,92.14,81,92.25,4730,,,,,,,,,,,,,,,,,,,,,
,92.36,81,92.47,4740,,,,,,,,,,,,,,,,,,,,,
,92.58,81,92.69,4730,,,,,,,,,,,,,,,,,,,,,
,92.80,81,92.89,4720,,,,,,,,,,,,,,,,,,,,,
,93.00,81,93.11,4740,,,,,,,,,,,,,,,,,,,,,
,93.22,81,93.33,4740,,,,,,,,,,,,,,,,,,,,,
,93.44,81,93.55,4740,,,,,,,,,,,,,,,,,,,,,
,93.64,81,93.75,4740,,,,,,,,,,,,,,,,,,,,,
,93.86,81,93.97,4740,,,,,,,,,,,,,,,,,,,,,
,94.08,81,94.19,4740,,,,,,,,,,,,,,,,,,,,,
,94.30,81,94.39,4740,,,,,,,,,,,,,,,,,,,,,
,94.50,81,94.61,4740,,,,,,,,,,,,,,,,,,,,,
,94.72,81,94.83,4740,,,,,,,,,,,,,,,,,,,,,
,94.94,81,95.05,4740,,,,,,,,,,,,,,,,,,,,,
,95.14,81,95.25,4740,,,,,,,,,,,,,,,,,,,,,
,95.36,81,95.47,4740,,,,,,,,,,,,,,,,,,,,,
,95.58,81,95.69,4750,,,,,,,,,,,,,,,,,,,,,
,95.80,81,95.91,4750,,,,,,,,,,,,,,,,,,,,,
,96.02,81,96.11,4760,,,,,,,,,,,,,,,,,,,,,
,96.22,81,96.33,4750,,,,,,,,,,,,,,,,,,,,,
,96.44,81,96.55,4760,,,,,,,,,,,,,,,,,,,,,
,96.64,81,96.75,4760,,,,,,,,,,,,,,,,,,,,,
,96.86,81,96.97,4770,,,,,,,,,,,,,,,,,,,,,
,97.08,81,97.19,4750,,,,,,,,,,,,,,,,,,,,,
,97.30,81,97.39,4760,,,,,,,,,,,,,,,,,,,,,
,97.50,81,97.61,4760,,,,,,,,,,,,,,,,,,,,,
,97.72,81,97.83,4770,,,,,,,,,,,,,,,,,,,,,
,97.94,81,98.05,4770,,,,,,,,,,,,,,,,,,,,,
,98.14,81,98.25,4770,,,,,,,,,,,,,,,,,,,,,
,98.36,81,98.47,4770,,,,,,,,,,,,,,,,,,,,,
,98.58,81,98.68,4770,,,,,,,,,,,,,,,,,,,,,
,98.78,81,98.89,4770,,,,,,,,,,,,,,,,,,,,,
,99.00,81,99.11,4770,,,,,,,,,,,,,,,,,,,,,
,99.22,81,99.33,4770,,,,,,,,,,,,,,,,,,,,,
,99.44,81,99.55,4770,,,,,,,,,,,,,,,,,,,,,
,99.64,81,99.75,4770,,,,,,,,,,,,,,,,,,,,,
,99.86,81,99.97,4770,,,,,,,,,,,,,,,,,,,,,
,100.06,81,100.17,4780,,,,,,,,,,,,,,,,,,,,,
,100.28,81,100.39,4770,,,,,,,,,,,,,,,,,,,,,
,100.50,81,100.61,4780,,,,,,,,,,,,,,,,,,,,,
,100.72,81,100.83,4770,,,,,,,,,,,,,,,,,,,,,
,100.92,81,101.03,4780,,,,,,,,,,,,,,,,,,,,,
,101.14,81,101.25,4780,,,,,,,,,,,,,,,,,,,,,
,101.36,81,101.47,4780,,,,,,,,,,,,,,,,,,,,,
,101.56,81,101.67,4790,,,,,,,,,,,,,,,,,,,,,
,101.78,81,101.89,4780,,,,,,,,,,,,,,,,,,,,,
,102.00,81,102.11,4790,,,,,,,,,,,,,,,,,,,,,
,102.22,81,102.31,4790,,,,,,,,,,,,,,,,,,,,,
,102.42,81,102.53,4780,,,,,,,,,,,,,,,,,,,,,
,102.64,81,102.75,4790,,,,,,,,,,,,,,,,,,,,,
,102.86,81,102.97,4790,,,,,,,,,,,,,,,,,,,,,
,103.08,81,103.18,4790,,,,,,,,,,,,,,,,,,,,,
,103.28,81,103.39,4790,,,,,,,,,,,,,,,,,,,,,
Friday,01,November,2019,14:51:51:05213-VCID:353722E965C0337F2A1-8060,VCDS Version: Release 19.6.2 (x64),Data version: 20190930 DS308.0
,0.13,80,0.02,5570,,,,,,,,,,,,,,,,,,,,,
,0.35,80,0.24,5580,,,,,,,,,,,,,,,,,,,,,
,0.57,80,0.46,5570,,,,,,,,,,,,,,,,,,,,,
,0.77,80,0.68,5580,,,,,,,,,,,,,,,,,,,,,
,0.99,80,0.88,5580,,,,,,,,,,,,,,,,,,,,,
,1.21,80,1.10,5580,,,,,,,,,,,,,,,,,,,,,
,1.43,80,1.32,5580,,,,,,,,,,,,,,,,,,,,,
,1.63,80,1.54,5580,,,,,,,,,,,,,,,,,,,,,
,1.85,80,1.74,5580,,,,,,,,,,,,,,,,,,,,,
,2.07,80,1.96,5590,,,,,,,,,,,,,,,,,,,,,
,2.27,80,2.18,5580,,,,,,,,,,,,,,,,,,,,,
,2.49,80,2.38,5590,,,,,,,,,,,,,,,,,,,,,
,2.71,80,2.60,5580,,,,,,,,,,,,,,,,,,,,,
,2.93,80,2.82,5590,,,,,,,,,,,,,,,,,,,,,
,3.13,80,3.02,6770,,,,,,,,,,,,,,,,,,,,,
,3.35,80,3.24,8890,,,,,,,,,,,,,,,,,,,,,
,3.57,80,3.46,8870,,,,,,,,,,,,,,,,,,,,,
,3.77,80,3.68,8620,,,,,,,,,,,,,,,,,,,,,
,3.99,80,3.88,8210,,,,,,,,,,,,,,,,,,,,,
,4.21,80,4.10,7930,,,,,,,,,,,,,,,,,,,,,
,4.43,80,4.32,7670,,,,,,,,,,,,,,,,,,,,,
,4.63,80,4.52,7210,,,,,,,,,,,,,,,,,,,,,
,4.85,80,4.74,6750,,,,,,,,,,,,,,,,,,,,,
,5.05,80,4.96,5910,,,,,,,,,,,,,,,,,,,,,
,5.27,80,5.16,4980,,,,,,,,,,,,,,,,,,,,,
,5.49,80,5.38,4230,,,,,,,,,,,,,,,,,,,,,
,5.71,80,5.60,3680,,,,,,,,,,,,,,,,,,,,,
,5.91,80,5.80,3580,,,,,,,,,,,,,,,,,,,,,
,6.13,80,6.02,3710,,,,,,,,,,,,,,,,,,,,,
,6.35,80,6.24,3890,,,,,,,,,,,,,,,,,,,,,
,6.55,80,6.46,3950,,,,,,,,,,,,,,,,,,,,,
,6.77,80,6.66,3980,,,,,,,,,,,,,,,,,,,,,
,6.99,80,6.88,3910,,,,,,,,,,,,,,,,,,,,,
,7.21,80,7.10,3860,,,,,,,,,,,,,,,,,,,,,
,7.41,80,7.30,3860,,,,,,,,,,,,,,,,,,,,,
,7.63,80,7.52,3850,,,,,,,,,,,,,,,,,,,,,
,7.85,80,7.74,3870,,,,,,,,,,,,,,,,,,,,,
,8.05,80,7.96,3880,,,,,,,,,,,,,,,,,,,,,
,8.27,80,8.16,3920,,,,,,,,,,,,,,,,,,,,,
,8.49,80,8.38,3890,,,,,,,,,,,,,,,,,,,,,
,8.71,80,8.60,3900,,,,,,,,,,,,,,,,,,,,,
,8.91,80,8.82,3890,,,,,,,,,,,,,,,,,,,,,
,9.13,80,9.02,3870,,,,,,,,,,,,,,,,,,,,,
,9.35,80,9.24,3880,,,,,,,,,,,,,,,,,,,,,
,9.57,80,9.46,3890,,,,,,,,,,,,,,,,,,,,,
,9.77,80,9.66,3880,,,,,,,,,,,,,,,,,,,,,
,9.99,80,9.88,3920,,,,,,,,,,,,,,,,,,,,,
,10.21,80,10.10,3930,,,,,,,,,,,,,,,,,,,,,
,10.41,80,10.32,3920,,,,,,,,,,,,,,,,,,,,,
,10.63,80,10.52,3920,,,,,,,,,,,,,,,,,,,,,
,10.85,80,10.74,3900,,,,,,,,,,,,,,,,,,,,,
,11.06,80,10.94,3890,,,,,,,,,,,,,,,,,,,,,
,11.27,80,11.16,3880,,,,,,,,,,,,,,,,,,,,,
,11.49,80,11.38,3920,,,,,,,,,,,,,,,,,,,,,
,11.71,80,11.60,3870,,,,,,,,,,,,,,,,,,,,,
,11.93,80,11.82,3920,,,,,,,,,,,,,,,,,,,,,
,12.13,80,12.02,3880,,,,,,,,,,,,,,,,,,,,,
,12.34,80,12.24,3890,,,,,,,,,,,,,,,,,,,,,
,12.55,80,12.44,3840,,,,,,,,,,,,,,,,,,,,,
,12.77,80,12.66,3850,,,,,,,,,,,,,,,,,,,,,
,12.99,80,12.88,3870,,,,,,,,,,,,,,,,,,,,,
,13.21,80,13.10,3880,,,,,,,,,,,,,,,,,,,,,
,13.41,79,13.31,3880,,,,,,,,,,,,,,,,,,,,,
,13.63,80,13.52,3910,,,,,,,,,,,,,,,,,,,,,
,13.85,80,13.74,3920,,,,,,,,,,,,,,,,,,,,,
,14.06,79,13.96,3900,,,,,,,,,,,,,,,,,,,,,
,14.27,79,14.16,3860,,,,,,,,,,,,,,,,,,,,,
,14.49,79,14.38,3890,,,,,,,,,,,,,,,,,,,,,
,14.71,79,14.60,3900,,,,,,,,,,,,,,,,,,,,,
,14.91,79,14.80,3890,,,,,,,,,,,,,,,,,,,,,
,15.13,79,15.02,3850,,,,,,,,,,,,,,,,,,,,,
,15.35,79,15.24,3870,,,,,,,,,,,,,,,,,,,,,
,15.56,79,15.46,3870,,,,,,,,,,,,,,,,,,,,,
,15.77,79,15.66,3910,,,,,,,,,,,,,,,,,,,,,
,15.99,79,15.88,3920,,,,,,,,,,,,,,,,,,,,,
,16.21,79,16.10,3900,,,,,,,,,,,,,,,,,,,,,
,16.43,79,16.32,3900,,,,,,,,,,,,,,,,,,,,,
,16.63,79,16.52,3890,,,,,,,,,,,,,,,,,,,,,
,16.85,79,16.74,3920,,,,,,,,,,,,,,,,,,,,,
,17.06,79,16.96,3920,,,,,,,,,,,,,,,,,,,,,
,17.27,79,17.16,3870,,,,,,,,,,,,,,,,,,,,,
,17.49,79,17.38,3880,,,,,,,,,,,,,,,,,,,,,
,17.71,79,17.60,3880,,,,,,,,,,,,,,,,,,,,,
,17.92,79,17.82,3900,,,,,,,,,,,,,,,,,,,,,
,18.13,79,18.02,3860,,,,,,,,,,,,,,,,,,,,,
,18.35,79,18.24,3880,,,,,,,,,,,,,,,,,,,,,
,18.55,79,18.46,3900,,,,,,,,,,,,,,,,,,,,,
,18.77,79,18.66,3900,,,,,,,,,,,,,,,,,,,,,
,18.99,79,18.88,3920,,,,,,,,,,,,,,,,,,,,,
,19.21,79,19.10,3900,,,,,,,,,,,,,,,,,,,,,
,19.41,79,19.30,3890,,,,,,,,,,,,,,,,,,,,,
,19.63,79,19.52,3880,,,,,,,,,,,,,,,,,,,,,
,19.85,79,19.74,3870,,,,,,,,,,,,,,,,,,,,,
,20.07,79,19.96,3870,,,,,,,,,,,,,,,,,,,,,
,20.27,79,20.16,3910,,,,,,,,,,,,,,,,,,,,,
,20.49,79,20.38,3890,,,,,,,,,,,,,,,,,,,,,
,20.71,79,20.60,3850,,,,,,,,,,,,,,,,,,,,,
,20.91,79,20.81,3840,,,,,,,,,,,,,,,,,,,,,
,21.13,79,21.02,3900,,,,,,,,,,,,,,,,,,,,,
,21.35,79,21.24,3930,,,,,,,,,,,,,,,,,,,,,
,21.57,79,21.46,3910,,,,,,,,,,,,,,,,,,,,,
,21.77,79,21.66,3930,,,,,,,,,,,,,,,,,,,,,
,21.99,79,21.88,3910,,,,,,,,,,,,,,,,,,,,,
,22.21,79,22.10,3900,,,,,,,,,,,,,,,,,,,,,
,22.41,79,22.31,3900,,,,,,,,,,,,,,,,,,,,,
,22.63,79,22.52,3900,,,,,,,,,,,,,,,,,,,,,
,22.85,79,22.74,3880,,,,,,,,,,,,,,,,,,,,,
,23.07,79,22.96,3870,,,,,,,,,,,,,,,,,,,,,
,23.27,79,23.18,3880,,,,,,,,,,,,,,,,,,,,,
,23.49,79,23.38,3900,,,,,,,,,,,,,,,,,,,,,
,23.71,79,23.60,3870,,,,,,,,,,,,,,,,,,,,,
,23.91,79,23.82,3890,,,,,,,,,,,,,,,,,,,,,
,24.13,79,24.02,3870,,,,,,,,,,,,,,,,,,,,,
,24.35,79,24.24,3880,,,,,,,,,,,,,,,,,,,,,
,24.56,79,24.44,3880,,,,,,,,,,,,,,,,,,,,,
,24.77,79,24.66,3870,,,,,,,,,,,,,,,,,,,,,
,24.99,79,24.88,3900,,,,,,,,,,,,,,,,,,,,,
,25.19,79,25.10,3900,,,,,,,,,,,,,,,,,,,,,
,25.41,79,25.30,3890,,,,,,,,,,,,,,,,,,,,,
,25.63,79,25.52,3880,,,,,,,,,,,,,,,,,,,,,
,25.85,79,25.74,3880,,,,,,,,,,,,,,,,,,,,,
,26.05,79,25.96,3870,,,,,,,,,,,,,,,,,,,,,
,26.27,79,26.16,3920,,,,,,,,,,,,,,,,,,,,,
,26.49,79,26.38,3890,,,,,,,,,,,,,,,,,,,,,
,26.71,79,26.60,3870,,,,,,,,,,,,,,,,,,,,,
,26.93,79,26.82,3850,,,,,,,,,,,,,,,,,,,,,
,27.13,79,27.04,3870,,,,,,,,,,,,,,,,,,,,,
,27.35,79,27.24,3870,,,,,,,,,,,,,,,,,,,,,
,27.57,79,27.46,3910,,,,,,,,,,,,,,,,,,,,,
,27.77,79,27.66,3870,,,,,,,,,,,,,,,,,,,,,
,27.99,79,27.88,3900,,,,,,,,,,,,,,,,,,,,,
,28.21,79,28.10,3900,,,,,,,,,,,,,,,,,,,,,
,28.43,79,28.32,3940,,,,,,,,,,,,,,,,,,,,,
,28.65,79,28.54,3940,,,,,,,,,,,,,,,,,,,,,
,28.85,79,28.74,3910,,,,,,,,,,,,,,,,,,,,,
,29.07,79,28.96,3860,,,,,,,,,,,,,,,,,,,,,
,29.27,79,29.17,3870,,,,,,,,,,,,,,,,,,,,,
,29.49,79,29.38,3880,,,,,,,,,,,,,,,,,,,,,
,29.71,79,29.60,3890,,,,,,,,,,,,,,,,,,,,,
,29.93,79,29.82,3880,,,,,,,,,,,,,,,,,,,,,
,30.13,79,30.04,3880,,,,,,,,,,,,,,,,,,,,,
,30.35,79,30.24,3890,,,,,,,,,,,,,,,,,,,,,
,30.57,79,30.46,3900,,,,,,,,,,,,,,,,,,,,,
,30.77,79,30.68,3900,,,,,,,,,,,,,,,,,,,,,
,30.99,79,30.88,3880,,,,,,,,,,,,,,,,,,,,,
,31.21,79,31.10,3890,,,,,,,,,,,,,,,,,,,,,
,31.43,79,31.32,3880,,,,,,,,,,,,,,,,,,,,,
,31.63,79,31.54,3900,,,,,,,,,,,,,,,,,,,,,
,31.85,79,31.74,3900,,,,,,,,,,,,,,,,,,,,,
,32.07,79,31.96,3910,,,,,,,,,,,,,,,,,,,,,
,32.30,79,32.18,3900,,,,,,,,,,,,,,,,,,,,,
,32.49,79,32.40,3910,,,,,,,,,,,,,,,,,,,,,
,32.71,79,32.60,3880,,,,,,,,,,,,,,,,,,,,,
,32.93,79,32.82,3880,,,,,,,,,,,,,,,,,,,,,
,33.13,79,33.02,3900,,,,,,,,,,,,,,,,,,,,,
,33.35,79,33.24,3890,,,,,,,,,,,,,,,,,,,,,
,33.57,79,33.46,3900,,,,,,,,,,,,,,,,,,,,,
,33.79,79,33.68,3890,,,,,,,,,,,,,,,,,,,,,
,33.99,79,33.88,3900,,,,,,,,,,,,,,,,,,,,,
,34.21,79,34.10,3860,,,,,,,,,,,,,,,,,,,,,
,34.43,79,34.32,3870,,,,,,,,,,,,,,,,,,,,,
,34.63,79,34.52,3910,,,,,,,,,,,,,,,,,,,,,
,34.85,79,34.74,3920,,,,,,,,,,,,,,,,,,,,,
,35.06,79,34.96,3920,,,,,,,,,,,,,,,,,,,,,
,35.27,79,35.16,3900,,,,,,,,,,,,,,,,,,,,,
,35.49,79,35.38,3900,,,,,,,,,,,,,,,,,,,,,
,35.71,79,35.60,3900,,,,,,,,,,,,,,,,,,,,,
,35.93,79,35.82,3900,,,,,,,,,,,,,,,,,,,,,
1,36.14,79,36.04,3850,,,,,,,,,,,,,,,,,,,,,
,36.35,79,36.24,3890,,,,,,,,,,,,,,,,,,,,,
,36.56,79,36.46,3940,,,,,,,,,,,,,,,,,,,,,
,36.77,79,36.66,3940,,,,,,,,,,,,,,,,,,,,,
,36.99,79,36.88,3940,,,,,,,,,,,,,,,,,,,,,
,37.21,80,37.10,3940,,,,,,,,,,,,,,,,,,,,,
,37.43,80,37.32,3940,,,,,,,,,,,,,,,,,,,,,
,37.63,79,37.52,3940,,,,,,,,,,,,,,,,,,,,,
,37.85,80,37.74,3940,,,,,,,,,,,,,,,,,,,,,
,38.05,80,37.96,3960,,,,,,,,,,,,,,,,,,,,,
,38.27,80,38.16,3940,,,,,,,,,,,,,,,,,,,,,
,38.49,80,38.38,3960,,,,,,,,,,,,,,,,,,,,,
,38.71,80,38.60,3960,,,,,,,,,,,,,,,,,,,,,
,38.91,80,38.80,3960,,,,,,,,,,,,,,,,,,,,,
,39.13,80,39.02,3960,,,,,,,,,,,,,,,,,,,,,
,39.35,80,39.24,3960,,,,,,,,,,,,,,,,,,,,,
,39.57,80,39.46,3960,,,,,,,,,,,,,,,,,,,,,
,39.79,80,39.68,3960,,,,,,,,,,,,,,,,,,,,,
,39.99,80,39.88,3960,,,,,,,,,,,,,,,,,,,,,
,40.21,80,40.10,3960,,,,,,,,,,,,,,,,,,,,,
,40.41,80,40.31,3960,,,,,,,,,,,,,,,,,,,,,
,40.63,80,40.52,3990,,,,,,,,,,,,,,,,,,,,,
,40.85,80,40.74,3990,,,,,,,,,,,,,,,,,,,,,
,41.07,80,40.96,3990,,,,,,,,,,,,,,,,,,,,,
,41.27,80,41.17,3990,,,,,,,,,,,,,,,,,,,,,
,41.49,80,41.38,3990,,,,,,,,,,,,,,,,,,,,,
,41.71,80,41.60,3990,,,,,,,,,,,,,,,,,,,,,
,41.93,80,41.82,3960,,,,,,,,,,,,,,,,,,,,,
,42.13,80,42.02,3990,,,,,,,,,,,,,,,,,,,,,
,42.35,80,42.24,4010,,,,,,,,,,,,,,,,,,,,,
,42.57,80,42.46,3990,,,,,,,,,,,,,,,,,,,,,
,42.77,80,42.68,3990,,,,,,,,,,,,,,,,,,,,,
,42.99,80,42.88,3990,,,,,,,,,,,,,,,,,,,,,
,43.21,80,43.10,3990,,,,,,,,,,,,,,,,,,,,,
,43.41,80,43.30,3990,,,,,,,,,,,,,,,,,,,,,
,43.63,80,43.52,3990,,,,,,,,,,,,,,,,,,,,,
,43.85,80,43.74,3990,,,,,,,,,,,,,,,,,,,,,
,44.07,80,43.96,3990,,,,,,,,,,,,,,,,,,,,,
,44.27,80,44.16,4010,,,,,,,,,,,,,,,,,,,,,
,44.49,80,44.38,3990,,,,,,,,,,,,,,,,,,,,,
,44.70,80,44.60,3990,,,,,,,,,,,,,,,,,,,,,
,44.91,80,44.81,4010,,,,,,,,,,,,,,,,,,,,,
,45.13,80,45.02,4010,,,,,,,,,,,,,,,,,,,,,
,45.35,80,45.24,4010,,,,,,,,,,,,,,,,,,,,,
,45.57,80,45.46,4010,,,,,,,,,,,,,,,,,,,,,
,45.77,80,45.66,4010,,,,,,,,,,,,,,,,,,,,,
,46.18,80,45.88,4010,,,,,,,,,,,,,,,,,,,,,
,46.39,80,46.29,4010,,,,,,,,,,,,,,,,,,,,,
,46.60,80,46.48,4010,,,,,,,,,,,,,,,,,,,,,
,46.82,80,46.71,4010,,,,,,,,,,,,,,,,,,,,,
,47.04,80,46.92,4010,,,,,,,,,,,,,,,,,,,,,
,47.26,80,47.15,4020,,,,,,,,,,,,,,,,,,,,,
,47.46,80,47.36,4010,,,,,,,,,,,,,,,,,,,,,
,47.67,80,47.57,4020,,,,,,,,,,,,,,,,,,,,,
2,47.89,80,47.79,4030,,,,,,,,,,,,,,,,,,,,,
,48.10,80,48.00,4020,,,,,,,,,,,,,,,,,,,,,
,48.31,80,48.21,4020,,,,,,,,,,,,,,,,,,,,,
,48.54,80,48.43,4020,,,,,,,,,,,,,,,,,,,,,
,48.75,80,48.65,4030,,,,,,,,,,,,,,,,,,,,,
,48.96,80,48.84,4030,,,,,,,,,,,,,,,,,,,,,
,49.17,80,49.07,4030,,,,,,,,,,,,,,,,,,,,,
,49.40,80,49.29,4030,,,,,,,,,,,,,,,,,,,,,
,49.59,80,49.50,4030,,,,,,,,,,,,,,,,,,,,,
,49.82,80,49.70,4040,,,,,,,,,,,,,,,,,,,,,
,50.04,80,49.93,4040,,,,,,,,,,,,,,,,,,,,,
,50.25,80,50.15,4040,,,,,,,,,,,,,,,,,,,,,
,50.46,80,50.35,4040,,,,,,,,,,,,,,,,,,,,,
,50.68,80,50.57,4030,,,,,,,,,,,,,,,,,,,,,
,50.89,80,50.79,4040,,,,,,,,,,,,,,,,,,,,,
,51.10,80,51.01,4040,,,,,,,,,,,,,,,,,,,,,
,51.32,80,51.20,4040,,,,,,,,,,,,,,,,,,,,,
,51.54,80,51.42,4040,,,,,,,,,,,,,,,,,,,,,
,51.75,80,51.65,4040,,,,,,,,,,,,,,,,,,,,,
,51.95,80,51.85,4050,,,,,,,,,,,,,,,,,,,,,
,52.18,80,52.06,4040,,,,,,,,,,,,,,,,,,,,,
,52.40,80,52.29,4040,,,,,,,,,,,,,,,,,,,,,
,52.60,80,52.50,4050,,,,,,,,,,,,,,,,,,,,,
,52.81,80,52.70,4050,,,,,,,,,,,,,,,,,,,,,
,53.04,80,52.92,4050,,,,,,,,,,,,,,,,,,,,,
,53.25,80,53.15,4050,,,,,,,,,,,,,,,,,,,,,
,53.45,80,53.35,4050,,,,,,,,,,,,,,,,,,,,,
,53.67,80,53.57,4050,,,,,,,,,,,,,,,,,,,,,
,53.89,80,53.79,4060,,,,,,,,,,,,,,,,,,,,,
,54.11,80,54.00,4060,,,,,,,,,,,,,,,,,,,,,
,54.32,80,54.21,4060,,,,,,,,,,,,,,,,,,,,,
,54.54,80,54.42,4060,,,,,,,,,,,,,,,,,,,,,
,54.73,80,54.64,4060,,,,,,,,,,,,,,,,,,,,,
,54.96,80,54.84,4060,,,,,,,,,,,,,,,,,,,,,
,55.18,80,55.06,4060,,,,,,,,,,,,,,,,,,,,,
,55.40,80,55.29,4060,,,,,,,,,,,,,,,,,,,,,
,55.60,80,55.51,4060,,,,,,,,,,,,,,,,,,,,,
,55.82,80,55.71,4060,,,,,,,,,,,,,,,,,,,,,
,56.04,80,55.93,4060,,,,,,,,,,,,,,,,,,,,,
,56.24,80,56.14,4060,,,,,,,,,,,,,,,,,,,,,
,56.45,80,56.34,4060,,,,,,,,,,,,,,,,,,,,,
,56.67,80,56.56,4060,,,,,,,,,,,,,,,,,,,,,
,56.89,80,56.79,4060,,,,,,,,,,,,,,,,,,,,,
,57.12,80,57.01,4070,,,,,,,,,,,,,,,,,,,,,
,57.32,80,57.22,4070,,,,,,,,,,,,,,,,,,,,,
,57.54,80,57.43,4070,,,,,,,,,,,,,,,,,,,,,
,57.75,80,57.65,4070,,,,,,,,,,,,,,,,,,,,,
,57.95,80,57.85,4070,,,,,,,,,,,,,,,,,,,,,
,58.18,80,58.07,4080,,,,,,,,,,,,,,,,,,,,,
,58.40,80,58.29,4080,,,,,,,,,,,,,,,,,,,,,
,58.61,80,58.50,4080,,,,,,,,,,,,,,,,,,,,,
,58.81,80,58.71,4080,,,,,,,,,,,,,,,,,,,,,
,59.04,80,58.93,4080,,,,,,,,,,,,,,,,,,,,,
,59.26,80,59.15,4090,,,,,,,,,,,,,,,,,,,,,
,59.45,80,59.36,4090,,,,,,,,,,,,,,,,,,,,,
,59.68,80,59.56,4090,,,,,,,,,,,,,,,,,,,,,
,59.89,80,59.79,4090,,,,,,,,,,,,,,,,,,,,,
,60.11,80,60.00,4090,,,,,,,,,,,,,,,,,,,,,
,60.31,80,60.21,4090,,,,,,,,,,,,,,,,,,,,,
,60.54,80,60.42,4090,,,,,,,,,,,,,,,,,,,,,
,60.73,80,60.64,4090,,,,,,,,,,,,,,,,,,,,,
,60.95,80,60.84,4100,,,,,,,,,,,,,,,,,,,,,
,61.17,80,61.06,4090,,,,,,,,,,,,,,,,,,,,,
,61.40,80,61.29,4110,,,,,,,,,,,,,,,,,,,,,
,61.59,80,61.50,4100,,,,,,,,,,,,,,,,,,,,,
,61.82,80,61.71,4100,,,,,,,,,,,,,,,,,,,,,
,62.04,80,61.92,4110,,,,,,,,,,,,,,,,,,,,,
,62.23,80,62.14,4110,,,,,,,,,,,,,,,,,,,,,
,62.45,80,62.35,4110,,,,,,,,,,,,,,,,,,,,,
,62.67,80,62.57,4110,,,,,,,,,,,,,,,,,,,,,
,62.90,80,62.79,4110,,,,,,,,,,,,,,,,,,,,,
,63.11,80,63.00,4110,,,,,,,,,,,,,,,,,,,,,
,63.32,80,63.21,4110,,,,,,,,,,,,,,,,,,,,,
,63.54,80,63.43,4110,,,,,,,,,,,,,,,,,,,,,
,63.74,80,63.65,4120,,,,,,,,,,,,,,,,,,,,,
,63.96,80,63.84,4110,,,,,,,,,,,,,,,,,,,,,
,64.17,80,64.06,4120,,,,,,,,,,,,,,,,,,,,,
,64.40,80,64.29,4110,,,,,,,,,,,,,,,,,,,,,
,64.61,80,64.51,4120,,,,,,,,,,,,,,,,,,,,,
,64.81,80,64.70,4120,,,,,,,,,,,,,,,,,,,,,
,65.04,80,64.92,4130,,,,,,,,,,,,,,,,,,,,,
,65.25,80,65.15,4130,,,,,,,,,,,,,,,,,,,,,
,65.45,80,65.34,4130,,,,,,,,,,,,,,,,,,,,,
,65.68,80,65.57,4130,,,,,,,,,,,,,,,,,,,,,
,65.89,80,65.79,4130,,,,,,,,,,,,,,,,,,,,,
,66.10,80,66.00,4130,,,,,,,,,,,,,,,,,,,,,
,66.31,80,66.21,4130,,,,,,,,,,,,,,,,,,,,,
,66.54,80,66.42,4140,,,,,,,,,,,,,,,,,,,,,
,66.75,80,66.65,4130,,,,,,,,,,,,,,,,,,,,,
,66.95,80,66.85,4130,,,,,,,,,,,,,,,,,,,,,
,67.17,80,67.07,4130,,,,,,,,,,,,,,,,,,,,,
,67.39,80,67.29,4130,,,,,,,,,,,,,,,,,,,,,
,67.59,80,67.50,4140,,,,,,,,,,,,,,,,,,,,,
,67.82,80,67.71,4140,,,,,,,,,,,,,,,,,,,,,
,68.04,80,67.92,4140,,,,,,,,,,,,,,,,,,,,,
,68.25,80,68.15,4140,,,,,,,,,,,,,,,,,,,,,
,68.45,80,68.35,4130,,,,,,,,,,,,,,,,,,,,,
,68.67,80,68.56,4140,,,,,,,,,,,,,,,,,,,,,
,68.90,80,68.79,4150,,,,,,,,,,,,,,,,,,,,,
,69.10,80,69.00,4150,,,,,,,,,,,,,,,,,,,,,
,69.31,80,69.21,4140,,,,,,,,,,,,,,,,,,,,,
,69.54,80,69.43,4150,,,,,,,,,,,,,,,,,,,,,
,69.75,80,69.65,4160,,,,,,,,,,,,,,,,,,,,,
,69.95,80,69.84,4150,,,,,,,,,,,,,,,,,,,,,
,70.17,80,70.07,4160,,,,,,,,,,,,,,,,,,,,,
,70.39,80,70.29,4150,,,,,,,,,,,,,,,,,,,,,
,70.61,80,70.51,4150,,,,,,,,,,,,,,,,,,,,,
,70.82,80,70.70,4160,,,,,,,,,,,,,,,,,,,,,
,71.04,80,70.93,4160,,,,,,,,,,,,,,,,,,,,,
,71.26,80,71.15,4160,,,,,,,,,,,,,,,,,,,,,
,71.46,80,71.36,4160,,,,,,,,,,,,,,,,,,,,,
,71.67,80,71.57,4160,,,,,,,,,,,,,,,,,,,,,
,71.89,80,71.79,4160,,,,,,,,,,,,,,,,,,,,,
,72.09,80,72.00,4160,,,,,,,,,,,,,,,,,,,,,
,72.32,80,72.21,4160,,,,,,,,,,,,,,,,,,,,,
,72.54,80,72.43,4160,,,,,,,,,,,,,,,,,,,,,
,72.75,80,72.65,4160,,,,,,,,,,,,,,,,,,,,,
,72.95,80,72.85,4160,,,,,,,,,,,,,,,,,,,,,
,73.17,80,73.06,4160,,,,,,,,,,,,,,,,,,,,,
,73.39,80,73.29,4160,,,,,,,,,,,,,,,,,,,,,
,73.61,80,73.51,4160,,,,,,,,,,,,,,,,,,,,,
,73.82,80,73.70,4170,,,,,,,,,,,,,,,,,,,,,
,74.04,80,73.93,4160,,,,,,,,,,,,,,,,,,,,,
,74.25,80,74.15,4160,,,,,,,,,,,,,,,,,,,,,
,74.47,80,74.36,4170,,,,,,,,,,,,,,,,,,,,,
,74.67,80,74.58,4180,,,,,,,,,,,,,,,,,,,,,
,74.89,80,74.79,4170,,,,,,,,,,,,,,,,,,,,,
,75.09,80,75.00,4180,,,,,,,,,,,,,,,,,,,,,
,75.31,80,75.20,4180,,,,,,,,,,,,,,,,,,,,,
,75.54,80,75.43,4170,,,,,,,,,,,,,,,,,,,,,
,75.73,80,75.64,4180,,,,,,,,,,,,,,,,,,,,,
,75.95,80,75.85,4180,,,,,,,,,,,,,,,,,,,,,
,76.17,80,76.06,4180,,,,,,,,,,,,,,,,,,,,,
,76.40,80,76.29,4180,,,,,,,,,,,,,,,,,,,,,
,76.60,80,76.50,4180,,,,,,,,,,,,,,,,,,,,,
,76.81,80,76.70,4180,,,,,,,,,,,,,,,,,,,,,
,77.04,80,76.93,4180,,,,,,,,,,,,,,,,,,,,,
,77.25,80,77.15,4180,,,,,,,,,,,,,,,,,,,,,
,77.45,80,77.35,4180,,,,,,,,,,,,,,,,,,,,,
,77.67,80,77.56,4180,,,,,,,,,,,,,,,,,,,,,
,77.89,80,77.79,4180,,,,,,,,,,,,,,,,,,,,,
,78.10,80,77.98,4180,,,,,,,,,,,,,,,,,,,,,
,78.31,80,78.21,4190,,,,,,,,,,,,,,,,,,,,,
,78.54,80,78.42,4190,,,,,,,,,,,,,,,,,,,,,
,78.75,80,78.65,4190,,,,,,,,,,,,,,,,,,,,,
,78.96,80,78.85,4190,,,,,,,,,,,,,,,,,,,,,
,79.17,80,79.06,4190,,,,,,,,,,,,,,,,,,,,,
,79.39,80,79.29,4180,,,,,,,,,,,,,,,,,,,,,
,79.61,80,79.50,4190,,,,,,,,,,,,,,,,,,,,,
,79.81,80,79.71,4190,,,,,,,,,,,,,,,,,,,,,
,80.04,80,79.93,4200,,,,,,,,,,,,,,,,,,,,,
,80.26,80,80.14,4200,,,,,,,,,,,,,,,,,,,,,
,80.47,80,80.36,4210,,,,,,,,,,,,,,,,,,,,,
,80.67,80,80.57,4200,,,,,,,,,,,,,,,,,,,,,
,80.90,80,80.79,4200,,,,,,,,,,,,,,,,,,,,,
,81.11,80,81.00,4200,,,,,,,,,,,,,,,,,,,,,
,81.33,80,81.22,4210,,,,,,,,,,,,,,,,,,,,,
,81.54,80,81.43,4210,,,,,,,,,,,,,,,,,,,,,
,81.76,80,81.65,4210,,,,,,,,,,,,,,,,,,,,,
,81.98,80,81.86,4210,,,,,,,,,,,,,,,,,,,,,
,82.17,80,82.08,4210,,,,,,,,,,,,,,,,,,,,,
,82.40,80,82.29,4210,,,,,,,,,,,,,,,,,,,,,
,82.62,80,82.50,4210,,,,,,,,,,,,,,,,,,,,,
,82.83,80,82.73,4210,,,,,,,,,,,,,,,,,,,,,
,83.04,80,82.92,4210,,,,,,,,,,,,,,,,,,,,,
,83.24,80,83.14,4210,,,,,,,,,,,,,,,,,,,,,
,83.46,80,83.35,4220,,,,,,,,,,,,,,,,,,,,,
,83.68,80,83.56,4220,,,,,,,,,,,,,,,,,,,,,
,83.89,80,83.79,4220,,,,,,,,,,,,,,,,,,,,,
,84.09,80,83.99,4220,,,,,,,,,,,,,,,,,,,,,
,84.32,80,84.20,4210,,,,,,,,,,,,,,,,,,,,,
,84.54,80,84.42,4220,,,,,,,,,,,,,,,,,,,,,
,84.75,80,84.65,4220,,,,,,,,,,,,,,,,,,,,,
,84.96,80,84.85,4220,,,,,,,,,,,,,,,,,,,,,
,85.17,80,85.07,4230,,,,,,,,,,,,,,,,,,,,,
,85.39,80,85.29,4220,,,,,,,,,,,,,,,,,,,,,
,85.61,80,85.51,4230,,,,,,,,,,,,,,,,,,,,,
,85.82,80,85.70,4230,,,,,,,,,,,,,,,,,,,,,
,86.04,80,85.92,4230,,,,,,,,,,,,,,,,,,,,,
,86.25,80,86.14,4240,,,,,,,,,,,,,,,,,,,,,
,86.46,80,86.34,4230,,,,,,,,,,,,,,,,,,,,,
,86.68,80,86.56,4230,,,,,,,,,,,,,,,,,,,,,
,86.90,80,86.79,4230,,,,,,,,,,,,,,,,,,,,,
,87.10,80,87.00,4230,,,,,,,,,,,,,,,,,,,,,
,87.31,80,87.20,4230,,,,,,,,,,,,,,,,,,,,,
,87.54,80,87.43,4230,,,,,,,,,,,,,,,,,,,,,
,87.75,80,87.64,4240,,,,,,,,,,,,,,,,,,,,,
,87.95,80,87.85,4240,,,,,,,,,,,,,,,,,,,,,
,88.18,80,88.06,4240,,,,,,,,,,,,,,,,,,,,,
,88.39,80,88.29,4240,,,,,,,,,,,,,,,,,,,,,
,88.60,80,88.50,4240,,,,,,,,,,,,,,,,,,,,,
,88.82,80,88.71,4250,,,,,,,,,,,,,,,,,,,,,
,89.04,80,88.93,4240,,,,,,,,,,,,,,,,,,,,,
,89.24,80,89.14,4260,,,,,,,,,,,,,,,,,,,,,
,89.46,80,89.34,4250,,,,,,,,,,,,,,,,,,,,,
,89.67,80,89.57,4260,,,,,,,,,,,,,,,,,,,,,
,89.90,80,89.79,4250,,,,,,,,,,,,,,,,,,,,,
,90.10,80,90.00,4260,,,,,,,,,,,,,,,,,,,,,
,90.32,80,90.20,4260,,,,,,,,,,,,,,,,,,,,,
,90.54,80,90.43,4260,,,,,,,,,,,,,,,,,,,,,
,90.74,80,90.64,4260,,,,,,,,,,,,,,,,,,,,,
,90.96,80,90.85,4250,,,,,,,,,,,,,,,,,,,,,
,91.17,80,91.06,4260,,,,,,,,,,,,,,,,,,,,,
,91.40,80,91.29,4260,,,,,,,,,,,,,,,,,,,,,
,91.61,80,91.50,4260,,,,,,,,,,,,,,,,,,,,,
,91.82,80,91.72,4260,,,,,,,,,,,,,,,,,,,,,
,92.04,80,91.92,4260,,,,,,,,,,,,,,,,,,,,,
,92.25,80,92.15,4260,,,,,,,,,,,,,,,,,,,,,
,92.46,80,92.34,4260,,,,,,,,,,,,,,,,,,,,,
,92.68,80,92.56,4270,,,,,,,,,,,,,,,,,,,,,
,92.90,80,92.79,4260,,,,,,,,,,,,,,,,,,,,,
,93.11,80,93.00,4260,,,,,,,,,,,,,,,,,,,,,
,93.32,80,93.21,4260,,,,,,,,,,,,,,,,,,,,,
,93.54,80,93.43,4260,,,,,,,,,,,,,,,,,,,,,
,93.73,80,93.64,4260,,,,,,,,,,,,,,,,,,,,,
,93.96,80,93.84,4270,,,,,,,,,,,,,,,,,,,,,
,94.17,80,94.06,4270,,,,,,,,,,,,,,,,,,,,,
,94.39,80,94.29,4270,,,,,,,,,,,,,,,,,,,,,
,94.59,80,94.50,4270,,,,,,,,,,,,,,,,,,,,,
,94.81,80,94.71,4280,,,,,,,,,,,,,,,,,,,,,
,95.04,80,94.92,4270,,,,,,,,,,,,,,,,,,,,,
,95.25,80,95.14,4280,,,,,,,,,,,,,,,,,,,,,
,95.46,80,95.35,4280,,,,,,,,,,,,,,,,,,,,,
,95.68,80,95.57,4280,,,,,,,,,,,,,,,,,,,,,
,95.89,80,95.79,4280,,,,,,,,,,,,,,,,,,,,,
,96.11,80,96.00,4280,,,,,,,,,,,,,,,,,,,,,
,96.31,80,96.21,4280,,,,,,,,,,,,,,,,,,,,,
,96.54,80,96.43,4280,,,,,,,,,,,,,,,,,,,,,
,96.74,80,96.64,4280,,,,,,,,,,,,,,,,,,,,,
,96.96,80,96.85,4280,,,,,,,,,,,,,,,,,,,,,
,97.17,80,97.06,4280,,,,,,,,,,,,,,,,,,,,,
,97.39,80,97.29,4280,,,,,,,,,,,,,,,,,,,,,
,97.60,80,97.50,4280,,,,,,,,,,,,,,,,,,,,,
,97.82,80,97.70,4280,,,,,,,,,,,,,,,,,,,,,
,98.04,80,97.92,4280,,,,,,,,,,,,,,,,,,,,,
,98.24,80,98.14,4280,,,,,,,,,,,,,,,,,,,,,
,98.46,80,98.34,4280,,,,,,,,,,,,,,,,,,,,,
,98.68,80,98.57,4290,,,,,,,,,,,,,,,,,,,,,
,98.90,80,98.79,4290,,,,,,,,,,,,,,,,,,,,,
,99.10,80,99.00,4290,,,,,,,,,,,,,,,,,,,,,
,99.32,80,99.21,4290,,,,,,,,,,,,,,,,,,,,,
,99.54,80,99.42,4290,,,,,,,,,,,,,,,,,,,,,
,99.74,80,99.64,4290,,,,,,,,,,,,,,,,,,,,,
,99.95,80,99.84,4290,,,,,,,,,,,,,,,,,,,,,
,100.17,80,100.07,4300,,,,,,,,,,,,,,,,,,,,,
,100.39,80,100.29,4300,,,,,,,,,,,,,,,,,,,,,
,100.59,80,100.50,4300,,,,,,,,,,,,,,,,,,,,,
,100.82,80,100.70,4300,,,,,,,,,,,,,,,,,,,,,
,101.04,80,100.92,4300,,,,,,,,,,,,,,,,,,,,,
,101.25,80,101.15,4310,,,,,,,,,,,,,,,,,,,,,
,101.45,80,101.35,4300,,,,,,,,,,,,,,,,,,,,,
,101.68,80,101.57,4310,,,,,,,,,,,,,,,,,,,,,
,101.89,80,101.79,4310,,,,,,,,,,,,,,,,,,,,,
,102.10,80,102.00,4300,,,,,,,,,,,,,,,,,,,,,
,102.31,80,102.21,4310,,,,,,,,,,,,,,,,,,,,,
,102.54,80,102.43,4310,,,,,,,,,,,,,,,,,,,,,
,102.75,80,102.64,4300,,,,,,,,,,,,,,,,,,,,,
,102.96,80,102.85,4310,,,,,,,,,,,,,,,,,,,,,
,103.18,80,103.07,4310,,,,,,,,,,,,,,,,,,,,,
,103.39,80,103.29,4310,,,,,,,,,,,,,,,,,,,,,
,103.60,80,103.48,4310,,,,,,,,,,,,,,,,,,,,,
,103.81,80,103.71,4310,,,,,,,,,,,,,,,,,,,,,
,104.04,80,103.93,4310,,,,,,,,,,,,,,,,,,,,,
,104.25,80,104.15,4310,,,,,,,,,,,,,,,,,,,,,
,104.45,80,104.34,4310,,,,,,,,,,,,,,,,,,,,,
,104.68,80,104.56,4310,,,,,,,,,,,,,,,,,,,,,
,104.89,80,104.79,4310,,,,,,,,,,,,,,,,,,,,,
,105.12,80,105.01,4310,,,,,,,,,,,,,,,,,,,,,
,105.31,80,105.22,4320,,,,,,,,,,,,,,,,,,,,,
,105.54,80,105.43,4310,,,,,,,,,,,,,,,,,,,,,
,105.76,80,105.64,4320,,,,,,,,,,,,,,,,,,,,,
,105.97,80,105.86,4320,,,,,,,,,,,,,,,,,,,,,
,106.17,80,106.07,4320,,,,,,,,,,,,,,,,,,,,,
,106.40,80,106.29,4330,,,,,,,,,,,,,,,,,,,,,
,106.61,80,106.50,4320,,,,,,,,,,,,,,,,,,,,,
,106.82,80,106.72,4330,,,,,,,,,,,,,,,,,,,,,
,107.04,80,106.92,4330,,,,,,,,,,,,,,,,,,,,,
,107.25,80,107.14,4330,,,,,,,,,,,,,,,,,,,,,
,107.45,80,107.35,4330,,,,,,,,,,,,,,,,,,,,,
,107.68,80,107.57,4330,,,,,,,,,,,,,,,,,,,,,
,107.89,80,107.79,4330,,,,,,,,,,,,,,,,,,,,,
,108.10,80,108.00,4330,,,,,,,,,,,,,,,,,,,,,
,108.32,80,108.21,4340,,,,,,,,,,,,,,,,,,,,,
,108.54,80,108.42,4330,,,,,,,,,,,,,,,,,,,,,
,108.75,80,108.65,4330,,,,,,,,,,,,,,,,,,,,,
,108.95,80,108.84,4330,,,,,,,,,,,,,,,,,,,,,
,109.18,80,109.07,4330,,,,,,,,,,,,,,,,,,,,,
,109.40,80,109.29,4330,,,,,,,,,,,,,,,,,,,,,
,109.62,80,109.51,4340,,,,,,,,,,,,,,,,,,,,,
,109.82,80,109.72,4330,,,,,,,,,,,,,,,,,,,,,
,110.04,80,109.92,4340,,,,,,,,,,,,,,,,,,,,,
,110.25,80,110.14,4340,,,,,,,,,,,,,,,,,,,,,
,110.45,80,110.34,4340,,,,,,,,,,,,,,,,,,,,,
,110.67,80,110.57,4350,,,,,,,,,,,,,,,,,,,,,
,110.89,80,110.79,4350,,,,,,,,,,,,,,,,,,,,,
,111.09,80,111.00,4350,,,,,,,,,,,,,,,,,,,,,
,111.32,80,111.21,4350,,,,,,,,,,,,,,,,,,,,,
,111.54,80,111.43,4350,,,,,,,,,,,,,,,,,,,,,
,111.74,80,111.64,4350,,,,,,,,,,,,,,,,,,,,,
,111.95,80,111.85,4350,,,,,,,,,,,,,,,,,,,,,
,112.17,80,112.07,4350,,,,,,,,,,,,,,,,,,,,,
,112.39,80,112.29,4350,,,,,,,,,,,,,,,,,,,,,
,112.59,80,112.48,4350,,,,,,,,,,,,,,,,,,,,,
,112.81,80,112.70,4360,,,,,,,,,,,,,,,,,,,,,
,113.04,80,112.93,4350,,,,,,,,,,,,,,,,,,,,,
,113.25,80,113.14,4350,,,,,,,,,,,,,,,,,,,,,
,113.46,80,113.34,4360,,,,,,,,,,,,,,,,,,,,,
,113.67,80,113.56,4350,,,,,,,,,,,,,,,,,,,,,
,113.89,80,113.79,4350,,,,,,,,,,,,,,,,,,,,,
,114.09,80,114.00,4350,,,,,,,,,,,,,,,,,,,,,
,114.31,80,114.20,4360,,,,,,,,,,,,,,,,,,,,,
,114.54,80,114.42,4360,,,,,,,,,,,,,,,,,,,,,
,114.73,80,114.64,4360,,,,,,,,,,,,,,,,,,,,,
,114.95,80,114.84,4360,,,,,,,,,,,,,,,,,,,,,
,115.17,80,115.06,4360,,,,,,,,,,,,,,,,,,,,,
,115.39,80,115.29,4370,,,,,,,,,,,,,,,,,,,,,
,115.61,80,115.50,4370,,,,,,,,,,,,,,,,,,,,,
,115.81,80,115.70,4370,,,,,,,,,,,,,,,,,,,,,
,116.04,80,115.92,4370,,,,,,,,,,,,,,,,,,,,,
,116.25,80,116.14,4370,,,,,,,,,,,,,,,,,,,,,
,116.45,80,116.35,4380,,,,,,,,,,,,,,,,,,,,,
,116.67,80,116.56,4370,,,,,,,,,,,,,,,,,,,,,
,116.89,80,116.79,4380,,,,,,,,,,,,,,,,,,,,,
,117.12,80,117.00,4380,,,,,,,,,,,,,,,,,,,,,
,117.31,80,117.22,4380,,,,,,,,,,,,,,,,,,,,,
,117.54,80,117.42,4380,,,,,,,,,,,,,,,,,,,,,
,117.73,80,117.63,4380,,,,,,,,,,,,,,,,,,,,,
,117.95,80,117.85,4380,,,,,,,,,,,,,,,,,,,,,
,118.17,80,118.06,4380,,,,,,,,,,,,,,,,,,,,,
,118.40,80,118.29,4380,,,,,,,,,,,,,,,,,,,,,
,118.59,80,118.48,4380,,,,,,,,,,,,,,,,,,,,,
,118.82,80,118.70,4380,,,,,,,,,,,,,,,,,,,,,
,119.04,80,118.92,4390,,,,,,,,,,,,,,,,,,,,,
,119.25,80,119.14,4380,,,,,,,,,,,,,,,,,,,,,
,119.47,80,119.36,4390,,,,,,,,,,,,,,,,,,,,,
,119.68,80,119.58,4380,,,,,,,,,,,,,,,,,,,,,
,119.89,80,119.79,4380,,,,,,,,,,,,,,,,,,,,,
,120.11,80,120.00,4380,,,,,,,,,,,,,,,,,,,,,
,120.31,80,120.20,4380,,,,,,,,,,,,,,,,,,,,,
,120.54,80,120.42,4380,,,,,,,,,,,,,,,,,,,,,
,120.75,80,120.64,4400,,,,,,,,,,,,,,,,,,,,,
,120.95,80,120.84,4390,,,,,,,,,,,,,,,,,,,,,
,121.17,80,121.06,4400,,,,,,,,,,,,,,,,,,,,,
,121.39,80,121.29,4400,,,,,,,,,,,,,,,,,,,,,
,121.59,80,121.50,4400,,,,,,,,,,,,,,,,,,,,,
,121.81,80,121.70,4400,,,,,,,,,,,,,,,,,,,,,
,122.04,80,121.92,4400,,,,,,,,,,,,,,,,,,,,,
,122.23,80,122.14,4400,,,,,,,,,,,,,,,,,,,,,
,122.45,80,122.34,4400,,,,,,,,,,,,,,,,,,,,,
,122.67,80,122.56,4400,,,,,,,,,,,,,,,,,,,,,
,122.89,80,122.79,4400,,,,,,,,,,,,,,,,,,,,,
,123.11,80,123.00,4400,,,,,,,,,,,,,,,,,,,,,
,123.31,80,123.20,4400,,,,,,,,,,,,,,,,,,,,,
,123.54,80,123.42,4400,,,,,,,,,,,,,,,,,,,,,
,123.75,80,123.64,4400,,,,,,,,,,,,,,,,,,,,,
,123.95,80,123.86,4400,,,,,,,,,,,,,,,,,,,,,
,124.17,80,124.06,4400,,,,,,,,,,,,,,,,,,,,,
,124.39,80,124.29,4400,,,,,,,,,,,,,,,,,,,,,
,124.61,80,124.50,4400,,,,,,,,,,,,,,,,,,,,,
,124.81,80,124.72,4400,,,,,,,,,,,,,,,,,,,,,
,125.04,80,124.92,4400,,,,,,,,,,,,,,,,,,,,,
,125.23,80,125.14,4400,,,,,,,,,,,,,,,,,,,,,
,125.45,80,125.35,4400,,,,,,,,,,,,,,,,,,,,,
,125.67,80,125.56,4400,,,,,,,,,,,,,,,,,,,,,
,125.89,80,125.79,4400,,,,,,,,,,,,,,,,,,,,,
,126.09,80,125.98,4410,,,,,,,,,,,,,,,,,,,,,
,126.31,80,126.20,4410,,,,,,,,,,,,,,,,,,,,,
,126.54,80,126.42,4410,,,,,,,,,,,,,,,,,,,,,
,126.73,80,126.64,4410,,,,,,,,,,,,,,,,,,,,,
,126.95,80,126.84,4410,,,,,,,,,,,,,,,,,,,,,
,127.17,80,127.06,4410,,,,,,,,,,,,,,,,,,,,,
,127.39,80,127.29,4420,,,,,,,,,,,,,,,,,,,,,
,127.59,80,127.50,4410,,,,,,,,,,,,,,,,,,,,,
,127.81,80,127.70,4410,,,,,,,,,,,,,,,,,,,,,
,128.04,80,127.92,4420,,,,,,,,,,,,,,,,,,,,,
,128.25,80,128.14,4420,,,,,,,,,,,,,,,,,,,,,
,128.45,80,128.35,4420,,,,,,,,,,,,,,,,,,,,,
,128.68,80,128.56,4420,,,,,,,,,,,,,,,,,,,,,
,128.89,80,128.79,4420,,,,,,,,,,,,,,,,,,,,,
,129.09,80,128.98,4430,,,,,,,,,,,,,,,,,,,,,
,129.31,80,129.20,4420,,,,,,,,,,,,,,,,,,,,,
,129.54,80,129.42,4430,,,,,,,,,,,,,,,,,,,,,
,129.75,80,129.64,4420,,,,,,,,,,,,,,,,,,,,,
,129.96,80,129.86,4420,,,,,,,,,,,,,,,,,,,,,
,130.17,80,130.06,4430,,,,,,,,,,,,,,,,,,,,,
,130.39,80,130.29,4430,,,,,,,,,,,,,,,,,,,,,
,130.59,80,130.48,4430,,,,,,,,,,,,,,,,,,,,,
,130.81,80,130.70,4430,,,,,,,,,,,,,,,,,,,,,
,131.04,80,130.92,4430,,,,,,,,,,,,,,,,,,,,,
,131.25,80,131.14,4430,,,,,,,,,,,,,,,,,,,,,
,131.45,80,131.34,4430,,,,,,,,,,,,,,,,,,,,,
,131.67,80,131.57,4430,,,,,,,,,,,,,,,,,,,,,
,131.89,80,131.79,4430,,,,,,,,,,,,,,,,,,,,,
,132.11,80,132.00,4440,,,,,,,,,,,,,,,,,,,,,
,132.31,80,132.20,4430,,,,,,,,,,,,,,,,,,,,,
,132.54,80,132.42,4430,,,,,,,,,,,,,,,,,,,,,
,132.75,80,132.64,4440,,,,,,,,,,,,,,,,,,,,,
,132.97,80,132.86,4450,,,,,,,,,,,,,,,,,,,,,
,133.17,80,133.06,4440,,,,,,,,,,,,,,,,,,,,,
,133.40,80,133.29,4440,,,,,,,,,,,,,,,,,,,,,
,133.61,80,133.50,4440,,,,,,,,,,,,,,,,,,,,,
,133.81,80,133.70,4440,,,,,,,,,,,,,,,,,,,,,
,134.04,80,133.92,4440,,,,,,,,,,,,,,,,,,,,,
,134.26,80,134.14,4450,,,,,,,,,,,,,,,,,,,,,
,134.46,80,134.36,4450,,,,,,,,,,,,,,,,,,,,,
,134.67,80,134.56,4450,,,,,,,,,,,,,,,,,,,,,
,134.89,80,134.79,4450,,,,,,,,,,,,,,,,,,,,,
,135.09,80,135.00,4450,,,,,,,,,,,,,,,,,,,,,
,135.31,80,135.21,4450,,,,,,,,,,,,,,,,,,,,,
,135.54,80,135.42,4450,,,,,,,,,,,,,,,,,,,,,
,135.75,80,135.64,4450,,,,,,,,,,,,,,,,,,,,,
,135.95,80,135.84,4450,,,,,,,,,,,,,,,,,,,,,
,136.17,80,136.06,4460,,,,,,,,,,,,,,,,,,,,,
,136.39,80,136.29,4450,,,,,,,,,,,,,,,,,,,,,
,136.61,80,136.50,4450,,,,,,,,,,,,,,,,,,,,,
,136.81,80,136.70,4450,,,,,,,,,,,,,,,,,,,,,
,137.04,80,136.93,4450,,,,,,,,,,,,,,,,,,,,,
,137.22,80,137.13,4460,,,,,,,,,,,,,,,,,,,,,
,137.42,80,137.31,4450,,,,,,,,,,,,,,,,,,,,,
,137.64,80,137.54,4450,,,,,,,,,,,,,,,,,,,,,
,137.84,80,137.75,4460,,,,,,,,,,,,,,,,,,,,,
,138.06,80,137.95,4460,,,,,,,,,,,,,,,,,,,,,
,138.29,80,138.17,4460,,,,,,,,,,,,,,,,,,,,,
,138.50,80,138.39,4470,,,,,,,,,,,,,,,,,,,,,
,138.70,80,138.61,4470,,,,,,,,,,,,,,,,,,,,,
,138.92,80,138.81,4470,,,,,,,,,,,,,,,,,,,,,
,139.14,80,139.04,4470,,,,,,,,,,,,,,,,,,,,,
,139.34,80,139.25,4470,,,,,,,,,,,,,,,,,,,,,
,139.56,80,139.45,4470,,,,,,,,,,,,,,,,,,,,,
,139.79,80,139.67,4470,,,,,,,,,,,,,,,,,,,,,
,140.00,80,139.89,4470,,,,,,,,,,,,,,,,,,,,,
,140.20,80,140.10,4470,,,,,,,,,,,,,,,,,,,,,
,140.42,80,140.31,4480,,,,,,,,,,,,,,,,,,,,,
,140.64,80,140.54,4480,,,,,,,,,,,,,,,,,,,,,
,140.84,80,140.73,4480,,,,,,,,,,,,,,,,,,,,,
,141.06,80,140.95,4480,,,,,,,,,,,,,,,,,,,,,
,141.29,80,141.17,4480,,,,,,,,,,,,,,,,,,,,,
,141.50,80,141.39,4480,,,,,,,,,,,,,,,,,,,,,
,141.70,80,141.61,4480,,,,,,,,,,,,,,,,,,,,,
,141.93,80,141.81,4480,,,,,,,,,,,,,,,,,,,,,
,142.14,80,142.04,4480,,,,,,,,,,,,,,,,,,,,,
,142.35,80,142.23,4480,,,,,,,,,,,,,,,,,,,,,
,142.56,80,142.45,4480,,,,,,,,,,,,,,,,,,,,,
,142.79,80,142.67,4490,,,,,,,,,,,,,,,,,,,,,
,143.00,80,142.89,4490,,,,,,,,,,,,,,,,,,,,,
,143.20,80,143.09,4480,,,,,,,,,,,,,,,,,,,,,
,143.42,80,143.31,4490,,,,,,,,,,,,,,,,,,,,,
,143.64,80,143.54,4490,,,,,,,,,,,,,,,,,,,,,
,143.84,80,143.73,4490,,,,,,,,,,,,,,,,,,,,,
,144.06,80,143.95,4500,,,,,,,,,,,,,,,,,,,,,
,144.29,80,144.17,4500,,,,,,,,,,,,,,,,,,,,,
,144.50,80,144.39,4490,,,,,,,,,,,,,,,,,,,,,
,144.70,80,144.59,4500,,,,,,,,,,,,,,,,,,,,,
,144.93,80,144.81,4500,,,,,,,,,,,,,,,,,,,,,
,145.14,80,145.04,4500,,,,,,,,,,,,,,,,,,,,,
,145.36,80,145.25,4500,,,,,,,,,,,,,,,,,,,,,
,145.56,80,145.45,4500,,,,,,,,,,,,,,,,,,,,,
,145.79,80,145.68,4500,,,,,,,,,,,,,,,,,,,,,
,146.00,80,145.89,4500,,,,,,,,,,,,,,,,,,,,,
,146.22,80,146.11,4500,,,,,,,,,,,,,,,,,,,,,
,146.42,80,146.31,4500,,,,,,,,,,,,,,,,,,,,,
,146.64,80,146.54,4500,,,,,,,,,,,,,,,,,,,,,
,146.86,80,146.76,4500,,,,,,,,,,,,,,,,,,,,,
,147.08,80,146.98,4500,,,,,,,,,,,,,,,,,,,,,
,147.29,80,147.17,4500,,,,,,,,,,,,,,,,,,,,,
,147.50,80,147.39,4500,,,,,,,,,,,,,,,,,,,,,
,147.70,80,147.59,4500,,,,,,,,,,,,,,,,,,,,,
,147.92,80,147.81,4500,,,,,,,,,,,,,,,,,,,,,
,148.14,80,148.04,4500,,,,,,,,,,,,,,,,,,,,,
,148.34,80,148.25,4500,,,,,,,,,,,,,,,,,,,,,
,148.56,80,148.45,4500,,,,,,,,,,,,,,,,,,,,,
,148.79,80,148.67,4510,,,,,,,,,,,,,,,,,,,,,
,149.00,80,148.89,4500,,,,,,,,,,,,,,,,,,,,,
,149.20,80,149.09,4520,,,,,,,,,,,,,,,,,,,,,
,149.42,80,149.31,4510,,,,,,,,,,,,,,,,,,,,,
,149.64,80,149.54,4520,,,,,,,,,,,,,,,,,,,,,
,149.84,80,149.73,4520,,,,,,,,,,,,,,,,,,,,,
,150.06,80,149.95,4520,,,,,,,,,,,,,,,,,,,,,
,150.29,80,150.17,4520,,,,,,,,,,,,,,,,,,,,,
,150.50,80,150.39,4520,,,,,,,,,,,,,,,,,,,,,
,150.70,80,150.59,4520,,,,,,,,,,,,,,,,,,,,,
,150.92,80,150.82,4520,,,,,,,,,,,,,,,,,,,,,
,151.13,80,151.04,4530,,,,,,,,,,,,,,,,,,,,,
,151.34,80,151.23,4520,,,,,,,,,,,,,,,,,,,,,
,151.56,80,151.45,4530,,,,,,,,,,,,,,,,,,,,,
,151.79,80,151.68,4530,,,,,,,,,,,,,,,,,,,,,
,151.98,80,151.89,4530,,,,,,,,,,,,,,,,,,,,,
,152.20,80,152.09,4520,,,,,,,,,,,,,,,,,,,,,
,152.42,80,152.31,4530,,,,,,,,,,,,,,,,,,,,,
,152.64,80,152.54,4530,,,,,,,,,,,,,,,,,,,,,
,152.84,80,152.75,4530,,,,,,,,,,,,,,,,,,,,,
,153.07,80,152.96,4530,,,,,,,,,,,,,,,,,,,,,
,153.29,80,153.17,4530,,,,,,,,,,,,,,,,,,,,,
,153.51,80,153.40,4530,,,,,,,,,,,,,,,,,,,,,
,153.70,80,153.61,4530,,,,,,,,,,,,,,,,,,,,,
,153.92,80,153.81,4530,,,,,,,,,,,,,,,,,,,,,
,154.14,80,154.04,4530,,,,,,,,,,,,,,,,,,,,,
,154.34,80,154.25,4540,,,,,,,,,,,,,,,,,,,,,
,154.56,80,154.45,4530,,,,,,,,,,,,,,,,,,,,,
,154.79,80,154.67,4530,,,,,,,,,,,,,,,,,,,,,
,154.98,80,154.90,4530,,,,,,,,,,,,,,,,,,,,,
,155.20,80,155.09,4530,,,,,,,,,,,,,,,,,,,,,
,155.42,80,155.31,4540,,,,,,,,,,,,,,,,,,,,,
,155.64,80,155.54,4530,,,,,,,,,,,,,,,,,,,,,
,155.84,80,155.73,4530,,,,,,,,,,,,,,,,,,,,,
,156.06,80,155.95,4540,,,,,,,,,,,,,,,,,,,,,
,156.29,80,156.17,4540,,,,,,,,,,,,,,,,,,,,,
,156.50,80,156.39,4540,,,,,,,,,,,,,,,,,,,,,
,156.70,80,156.60,4540,,,,,,,,,,,,,,,,,,,,,
,156.92,80,156.82,4550,,,,,,,,,,,,,,,,,,,,,
,157.15,80,157.04,4540,,,,,,,,,,,,,,,,,,,,,
,157.36,80,157.25,4540,,,,,,,,,,,,,,,,,,,,,
,157.57,80,157.45,4550,,,,,,,,,,,,,,,,,,,,,
,157.79,80,157.67,4550,,,,,,,,,,,,,,,,,,,,,
,158.00,80,157.90,4540,,,,,,,,,,,,,,,,,,,,,
,158.20,80,158.10,4540,,,,,,,,,,,,,,,,,,,,,
,158.42,80,158.31,4550,,,,,,,,,,,,,,,,,,,,,
,158.64,80,158.54,4550,,,,,,,,,,,,,,,,,,,,,
,158.86,80,158.75,4550,,,,,,,,,,,,,,,,,,,,,
,159.06,80,158.95,4550,,,,,,,,,,,,,,,,,,,,,
,159.29,80,159.17,4550,,,,,,,,,,,,,,,,,,,,,
,159.51,80,159.39,4550,,,,,,,,,,,,,,,,,,,,,
,159.70,80,159.61,4550,,,,,,,,,,,,,,,,,,,,,
,159.92,80,159.81,4550,,,,,,,,,,,,,,,,,,,,,
,160.14,80,160.04,4550,,,,,,,,,,,,,,,,,,,,,
,160.36,80,160.26,4550,,,,,,,,,,,,,,,,,,,,,
3,160.57,80,160.45,4560,,,,,,,,,,,,,,,,,,,,,
,160.79,80,160.67,4560,,,,,,,,,,,,,,,,,,,,,
,161.00,80,160.89,4560,,,,,,,,,,,,,,,,,,,,,
,161.20,80,161.11,4560,,,,,,,,,,,,,,,,,,,,,
,161.42,80,161.32,5740,,,,,,,,,,,,,,,,,,,,,
,161.64,80,161.54,7150,,,,,,,,,,,,,,,,,,,,,
,161.86,80,161.75,5880,,,,,,,,,,,,,,,,,,,,,
,162.08,80,161.97,5150,,,,,,,,,,,,,,,,,,,,,
,162.29,80,162.19,4510,,,,,,,,,,,,,,,,,,,,,
,162.50,80,162.39,3670,,,,,,,,,,,,,,,,,,,,,
,162.70,80,162.60,3590,,,,,,,,,,,,,,,,,,,,,
,162.92,80,162.81,3590,,,,,,,,,,,,,,,,,,,,,
,163.14,80,163.04,3810,,,,,,,,,,,,,,,,,,,,,
,163.34,80,163.23,3980,,,,,,,,,,,,,,,,,,,,,
,163.56,80,163.45,4020,,,,,,,,,,,,,,,,,,,,,
,163.79,80,163.67,3930,,,,,,,,,,,,,,,,,,,,,
,163.98,80,163.89,3860,,,,,,,,,,,,,,,,,,,,,
,164.20,80,164.10,3870,,,,,,,,,,,,,,,,,,,,,
,164.42,80,164.31,3870,,,,,,,,,,,,,,,,,,,,,
,164.64,80,164.54,3900,,,,,,,,,,,,,,,,,,,,,
,164.84,80,164.75,3880,,,,,,,,,,,,,,,,,,,,,
,165.06,80,164.95,3870,,,,,,,,,,,,,,,,,,,,,
,165.29,80,165.17,3890,,,,,,,,,,,,,,,,,,,,,
,165.50,80,165.39,3900,,,,,,,,,,,,,,,,,,,,,
,165.72,80,165.61,3910,,,,,,,,,,,,,,,,,,,,,
,165.92,80,165.81,3900,,,,,,,,,,,,,,,,,,,,,
,166.15,80,166.04,3860,,,,,,,,,,,,,,,,,,,,,
,166.34,80,166.25,3900,,,,,,,,,,,,,,,,,,,,,
,166.56,80,166.46,3930,,,,,,,,,,,,,,,,,,,,,
,166.79,80,166.67,3940,,,,,,,,,,,,,,,,,,,,,
,166.98,80,166.90,3900,,,,,,,,,,,,,,,,,,,,,
,167.20,80,167.09,3890,,,,,,,,,,,,,,,,,,,,,
,167.43,80,167.31,3870,,,,,,,,,,,,,,,,,,,,,
,167.64,80,167.54,3860,,,,,,,,,,,,,,,,,,,,,
,167.84,80,167.75,3900,,,,,,,,,,,,,,,,,,,,,
,168.07,80,167.95,3930,,,,,,,,,,,,,,,,,,,,,
,168.29,80,168.17,3910,,,,,,,,,,,,,,,,,,,,,
,168.50,80,168.39,3900,,,,,,,,,,,,,,,,,,,,,
,168.70,80,168.59,3900,,,,,,,,,,,,,,,,,,,,,
,168.92,80,168.81,3910,,,,,,,,,,,,,,,,,,,,,
,169.14,80,169.04,3880,,,,,,,,,,,,,,,,,,,,,
,169.34,80,169.25,3890,,,,,,,,,,,,,,,,,,,,,
,169.57,80,169.45,3870,,,,,,,,,,,,,,,,,,,,,
,169.79,80,169.67,3880,,,,,,,,,,,,,,,,,,,,,
,170.00,80,169.89,3890,,,,,,,,,,,,,,,,,,,,,
,170.20,80,170.11,3860,,,,,,,,,,,,,,,,,,,,,
,170.42,80,170.31,3900,,,,,,,,,,,,,,,,,,,,,
,170.64,80,170.54,3910,,,,,,,,,,,,,,,,,,,,,
,170.86,80,170.75,3920,,,,,,,,,,,,,,,,,,,,,
,171.06,80,170.97,3930,,,,,,,,,,,,,,,,,,,,,
,171.29,80,171.17,3880,,,,,,,,,,,,,,,,,,,,,
,171.48,80,171.39,3880,,,,,,,,,,,,,,,,,,,,,
,171.70,80,171.59,3910,,,,,,,,,,,,,,,,,,,,,
,171.92,80,171.82,3900,,,,,,,,,,,,,,,,,,,,,
,172.14,80,172.04,3900,,,,,,,,,,,,,,,,,,,,,
,172.37,80,172.25,3890,,,,,,,,,,,,,,,,,,,,,
,172.58,80,172.47,3880,,,,,,,,,,,,,,,,,,,,,
,172.79,80,172.68,3900,,,,,,,,,,,,,,,,,,,,,
,173.00,80,172.89,3920,,,,,,,,,,,,,,,,,,,,,
,173.23,80,173.12,3910,,,,,,,,,,,,,,,,,,,,,
,173.42,80,173.33,3900,,,,,,,,,,,,,,,,,,,,,
,173.64,80,173.54,3900,,,,,,,,,,,,,,,,,,,,,
,173.86,80,173.75,3910,,,,,,,,,,,,,,,,,,,,,
,174.08,80,173.97,3920,,,,,,,,,,,,,,,,,,,,,
,174.29,80,174.17,3880,,,,,,,,,,,,,,,,,,,,,
,174.50,80,174.39,3880,,,,,,,,,,,,,,,,,,,,,
,174.71,80,174.61,3900,,,,,,,,,,,,,,,,,,,,,
,174.92,80,174.81,3900,,,,,,,,,,,,,,,,,,,,,
,175.14,80,175.04,3920,,,,,,,,,,,,,,,,,,,,,
,175.36,80,175.25,3900,,,,,,,,,,,,,,,,,,,,,
,175.56,80,175.47,3870,,,,,,,,,,,,,,,,,,,,,
,175.79,80,175.67,3880,,,,,,,,,,,,,,,,,,,,,
,176.00,80,175.89,3860,,,,,,,,,,,,,,,,,,,,,
,176.20,80,176.11,3880,,,,,,,,,,,,,,,,,,,,,
,176.42,80,176.31,3880,,,,,,,,,,,,,,,,,,,,,
,176.65,80,176.54,3860,,,,,,,,,,,,,,,,,,,,,
,176.85,80,176.75,3890,,,,,,,,,,,,,,,,,,,,,
,177.06,80,176.95,3890,,,,,,,,,,,,,,,,,,,,,
,177.29,80,177.17,3880,,,,,,,,,,,,,,,,,,,,,
,177.50,80,177.40,3910,,,,,,,,,,,,,,,,,,,,,
,177.70,80,177.60,3870,,,,,,,,,,,,,,,,,,,,,
,177.93,80,177.81,3880,,,,,,,,,,,,,,,,,,,,,
,178.14,80,178.04,3910,,,,,,,,,,,,,,,,,,,,,
,178.34,80,178.25,3930,,,,,,,,,,,,,,,,,,,,,
,178.56,80,178.46,3900,,,,,,,,,,,,,,,,,,,,,
,178.79,80,178.67,3890,,,,,,,,,,,,,,,,,,,,,
,179.00,80,178.90,3900,,,,,,,,,,,,,,,,,,,,,
,179.20,80,179.09,3870,,,,,,,,,,,,,,,,,,,,,
,179.42,80,179.31,3900,,,,,,,,,,,,,,,,,,,,,
,179.64,80,179.54,3920,,,,,,,,,,,,,,,,,,,,,
,179.85,80,179.75,3890,,,,,,,,,,,,,,,,,,,,,
,180.06,80,179.95,3900,,,,,,,,,,,,,,,,,,,,,
,180.29,80,180.17,3890,,,,,,,,,,,,,,,,,,,,,
,180.50,80,180.39,3890,,,,,,,,,,,,,,,,,,,,,
,180.70,80,180.61,3930,,,,,,,,,,,,,,,,,,,,,
,180.93,80,180.81,3900,,,,,,,,,,,,,,,,,,,,,
,181.15,80,181.04,3900,,,,,,,,,,,,,,,,,,,,,
,181.34,80,181.25,3880,,,,,,,,,,,,,,,,,,,,,
,181.56,80,181.45,3870,,,,,,,,,,,,,,,,,,,,,
,181.79,80,181.67,3920,,,,,,,,,,,,,,,,,,,,,
,182.00,80,181.89,3880,,,,,,,,,,,,,,,,,,,,,
,182.20,80,182.09,3900,,,,,,,,,,,,,,,,,,,,,
,182.43,80,182.31,3930,,,,,,,,,,,,,,,,,,,,,
,182.64,80,182.54,3920,,,,,,,,,,,,,,,,,,,,,
,182.86,80,182.75,3900,,,,,,,,,,,,,,,,,,,,,
,183.06,80,182.95,3900,,,,,,,,,,,,,,,,,,,,,
,183.29,80,183.17,3900,,,,,,,,,,,,,,,,,,,,,
,183.50,80,183.39,3910,,,,,,,,,,,,,,,,,,,,,
,183.70,80,183.59,3890,,,,,,,,,,,,,,,,,,,,,
,183.92,80,183.82,3880,,,,,,,,,,,,,,,,,,,,,
,184.14,80,184.04,3880,,,,,,,,,,,,,,,,,,,,,
,184.34,80,184.23,3910,,,,,,,,,,,,,,,,,,,,,
,184.56,80,184.45,3930,,,,,,,,,,,,,,,,,,,,,
,184.79,80,184.67,3920,,,,,,,,,,,,,,,,,,,,,
,185.00,80,184.90,3910,,,,,,,,,,,,,,,,,,,,,
,185.22,80,185.11,3900,,,,,,,,,,,,,,,,,,,,,
,185.42,80,185.31,3890,,,,,,,,,,,,,,,,,,,,,
,185.64,80,185.54,3880,,,,,,,,,,,,,,,,,,,,,
,185.84,80,185.75,3880,,,,,,,,,,,,,,,,,,,,,
,186.06,80,185.95,3880,,,,,,,,,,,,,,,,,,,,,
,186.29,80,186.17,3890,,,,,,,,,,,,,,,,,,,,,
,186.50,80,186.39,3870,,,,,,,,,,,,,,,,,,,,,
,186.72,80,186.61,3870,,,,,,,,,,,,,,,,,,,,,
,186.92,80,186.81,3890,,,,,,,,,,,,,,,,,,,,,
,187.14,80,187.04,3900,,,,,,,,,,,,,,,,,,,,,
,187.36,80,187.25,3900,,,,,,,,,,,,,,,,,,,,,
,187.56,80,187.45,3900,,,,,,,,,,,,,,,,,,,,,
,187.79,80,187.67,3880,,,,,,,,,,,,,,,,,,,,,
,188.00,80,187.89,3900,,,,,,,,,,,,,,,,,,,,,
,188.20,80,188.11,3900,,,,,,,,,,,,,,,,,,,,,
,188.42,80,188.31,3880,,,,,,,,,,,,,,,,,,,,,
,188.64,80,188.54,3880,,,,,,,,,,,,,,,,,,,,,
,188.86,80,188.75,3880,,,,,,,,,,,,,,,,,,,,,
,189.06,80,188.97,3890,,,,,,,,,,,,,,,,,,,,,
,189.29,80,189.17,3910,,,,,,,,,,,,,,,,,,,,,
,189.50,80,189.39,3910,,,,,,,,,,,,,,,,,,,,,
,189.72,80,189.61,3900,,,,,,,,,,,,,,,,,,,,,
,189.92,80,189.82,3880,,,,,,,,,,,,,,,,,,,,,
,190.14,80,190.04,3890,,,,,,,,,,,,,,,,,,,,,
,190.34,80,190.23,3900,,,,,,,,,,,,,,,,,,,,,
4,190.57,80,190.46,3870,,,,,,,,,,,,,,,,,,,,,
,190.79,80,190.68,3920,,,,,,,,,,,,,,,,,,,,,
,191.00,80,190.90,3920,,,,,,,,,,,,,,,,,,,,,
,191.21,80,191.09,3920,,,,,,,,,,,,,,,,,,,,,
,191.42,80,191.31,3940,,,,,,,,,,,,,,,,,,,,,
,191.64,80,191.54,3940,,,,,,,,,,,,,,,,,,,,,
,191.85,80,191.75,3920,,,,,,,,,,,,,,,,,,,,,
,192.06,80,191.95,3930,,,,,,,,,,,,,,,,,,,,,
,192.29,80,192.17,3930,,,,,,,,,,,,,,,,,,,,,
,192.50,80,192.39,3940,,,,,,,,,,,,,,,,,,,,,
,192.72,80,192.61,3940,,,,,,,,,,,,,,,,,,,,,
,192.92,80,192.81,3940,,,,,,,,,,,,,,,,,,,,,
,193.14,80,193.04,3940,,,,,,,,,,,,,,,,,,,,,
,193.36,80,193.25,3940,,,,,,,,,,,,,,,,,,,,,
,193.56,80,193.47,3940,,,,,,,,,,,,,,,,,,,,,
,193.79,80,193.67,3940,,,,,,,,,,,,,,,,,,,,,
,194.00,80,193.89,3940,,,,,,,,,,,,,,,,,,,,,
,194.22,80,194.11,3940,,,,,,,,,,,,,,,,,,,,,
,194.44,80,194.33,3950,,,,,,,,,,,,,,,,,,,,,
,194.64,80,194.54,3940,,,,,,,,,,,,,,,,,,,,,
,194.86,80,194.75,3940,,,,,,,,,,,,,,,,,,,,,
,195.08,80,194.97,3940,,,,,,,,,,,,,,,,,,,,,
,195.30,80,195.19,3950,,,,,,,,,,,,,,,,,,,,,
,195.50,80,195.41,3950,,,,,,,,,,,,,,,,,,,,,
,195.70,80,195.61,3950,,,,,,,,,,,,,,,,,,,,,
,195.92,80,195.81,3950,,,,,,,,,,,,,,,,,,,,,
,196.14,80,196.04,3950,,,,,,,,,,,,,,,,,,,,,
,196.36,80,196.25,3950,,,,,,,,,,,,,,,,,,,,,
,196.56,80,196.45,3960,,,,,,,,,,,,,,,,,,,,,
,196.79,80,196.67,3960,,,,,,,,,,,,,,,,,,,,,
,197.00,80,196.89,3960,,,,,,,,,,,,,,,,,,,,,
,197.20,80,197.09,3950,,,,,,,,,,,,,,,,,,,,,
,197.42,80,197.31,3960,,,,,,,,,,,,,,,,,,,,,
,197.64,80,197.54,3960,,,,,,,,,,,,,,,,,,,,,
,197.86,80,197.75,3960,,,,,,,,,,,,,,,,,,,,,
,198.06,80,197.95,3960,,,,,,,,,,,,,,,,,,,,,
,198.29,80,198.17,3960,,,,,,,,,,,,,,,,,,,,,
,198.50,80,198.39,3960,,,,,,,,,,,,,,,,,,,,,
,198.72,80,198.61,3960,,,,,,,,,,,,,,,,,,,,,
,198.92,80,198.81,3970,,,,,,,,,,,,,,,,,,,,,
,199.14,80,199.04,3960,,,,,,,,,,,,,,,,,,,,,
,199.36,80,199.25,3960,,,,,,,,,,,,,,,,,,,,,
,199.58,80,199.47,3960,,,,,,,,,,,,,,,,,,,,,
,199.79,80,199.67,3970,,,,,,,,,,,,,,,,,,,,,
,200.00,80,199.89,3960,,,,,,,,,,,,,,,,,,,,,
,200.22,80,200.11,3960,,,,,,,,,,,,,,,,,,,,,
,200.42,80,200.31,3960,,,,,,,,,,,,,,,,,,,,,
,200.64,80,200.54,3960,,,,,,,,,,,,,,,,,,,,,
,200.86,80,200.75,3960,,,,,,,,,,,,,,,,,,,,,
,201.06,80,200.97,3960,,,,,,,,,,,,,,,,,,,,,
,201.29,80,201.17,3970,,,,,,,,,,,,,,,,,,,,,
,201.50,80,201.39,3970,,,,,,,,,,,,,,,,,,,,,
,201.72,80,201.61,3970,,,,,,,,,,,,,,,,,,,,,
,201.94,80,201.83,3970,,,,,,,,,,,,,,,,,,,,,
,202.14,81,202.04,3960,,,,,,,,,,,,,,,,,,,,,
,202.36,80,202.25,3970,,,,,,,,,,,,,,,,,,,,,
,202.58,80,202.47,3970,,,,,,,,,,,,,,,,,,,,,
,202.78,81,202.67,3970,,,,,,,,,,,,,,,,,,,,,
,203.00,81,202.89,3970,,,,,,,,,,,,,,,,,,,,,
,203.22,80,203.11,3970,,,,,,,,,,,,,,,,,,,,,
,203.42,80,203.33,3980,,,,,,,,,,,,,,,,,,,,,
,203.64,81,203.54,3980,,,,,,,,,,,,,,,,,,,,,
,203.86,80,203.75,3980,,,,,,,,,,,,,,,,,,,,,
,204.06,81,203.97,3980,,,,,,,,,,,,,,,,,,,,,
,204.29,81,204.17,3990,,,,,,,,,,,,,,,,,,,,,
,204.50,81,204.39,3990,,,,,,,,,,,,,,,,,,,,,
,204.72,80,204.61,3990,,,,,,,,,,,,,,,,,,,,,
,204.94,81,204.83,3980,,,,,,,,,,,,,,,,,,,,,
,205.14,81,205.04,3980,,,,,,,,,,,,,,,,,,,,,
,205.36,81,205.25,3990,,,,,,,,,,,,,,,,,,,,,
,205.58,81,205.47,3990,,,,,,,,,,,,,,,,,,,,,
,205.79,81,205.69,3990,,,,,,,,,,,,,,,,,,,,,
,206.00,81,205.89,3990,,,,,,,,,,,,,,,,,,,,,
,206.22,81,206.11,3990,,,,,,,,,,,,,,,,,,,,,
,206.44,81,206.33,3990,,,,,,,,,,,,,,,,,,,,,
,206.64,81,206.54,3990,,,,,,,,,,,,,,,,,,,,,
,206.86,81,206.75,3990,,,,,,,,,,,,,,,,,,,,,
,207.08,81,206.97,3990,,,,,,,,,,,,,,,,,,,,,
,207.30,80,207.19,3990,,,,,,,,,,,,,,,,,,,,,
,207.50,81,207.40,3990,,,,,,,,,,,,,,,,,,,,,
,207.72,81,207.61,3990,,,,,,,,,,,,,,,,,,,,,
,207.94,81,207.83,4000,,,,,,,,,,,,,,,,,,,,,
,208.14,81,208.04,4000,,,,,,,,,,,,,,,,,,,,,
,208.36,81,208.25,4000,,,,,,,,,,,,,,,,,,,,,
,208.58,81,208.47,4010,,,,,,,,,,,,,,,,,,,,,
,208.80,80,208.69,4000,,,,,,,,,,,,,,,,,,,,,
,209.00,81,208.91,4010,,,,,,,,,,,,,,,,,,,,,
,209.20,81,209.11,4000,,,,,,,,,,,,,,,,,,,,,
,209.42,81,209.31,4010,,,,,,,,,,,,,,,,,,,,,
,209.64,81,209.54,4010,,,,,,,,,,,,,,,,,,,,,
,209.86,81,209.75,4010,,,,,,,,,,,,,,,,,,,,,
,210.06,81,209.97,4010,,,,,,,,,,,,,,,,,,,,,
,210.29,81,210.17,4010,,,,,,,,,,,,,,,,,,,,,
,210.50,81,210.39,4010,,,,,,,,,,,,,,,,,,,,,
,210.70,81,210.61,4010,,,,,,,,,,,,,,,,,,,,,
,210.92,81,210.81,4020,,,,,,,,,,,,,,,,,,,,,
,211.14,81,211.04,4010,,,,,,,,,,,,,,,,,,,,,
,211.36,81,211.25,4010,,,,,,,,,,,,,,,,,,,,,
,211.58,80,211.47,4020,,,,,,,,,,,,,,,,,,,,,
,211.79,81,211.67,4010,,,,,,,,,,,,,,,,,,,,,
,212.00,81,211.89,4010,,,,,,,,,,,,,,,,,,,,,
,212.22,81,212.11,4010,,,,,,,,,,,,,,,,,,,,,
,212.44,81,212.33,4010,,,,,,,,,,,,,,,,,,,,,
,212.64,81,212.54,4030,,,,,,,,,,,,,,,,,,,,,
,212.86,81,212.75,4030,,,,,,,,,,,,,,,,,,,,,
,213.06,80,212.97,4020,,,,,,,,,,,,,,,,,,,,,
,213.29,81,213.17,4020,,,,,,,,,,,,,,,,,,,,,
,213.50,81,213.39,4030,,,,,,,,,,,,,,,,,,,,,
,213.72,81,213.61,4030,,,,,,,,,,,,,,,,,,,,,
,213.92,81,213.81,4030,,,,,,,,,,,,,,,,,,,,,
,214.14,81,214.04,4030,,,,,,,,,,,,,,,,,,,,,
,214.36,81,214.25,4030,,,,,,,,,,,,,,,,,,,,,
,214.56,80,214.47,4030,,,,,,,,,,,,,,,,,,,,,
,214.79,81,214.67,4030,,,,,,,,,,,,,,,,,,,,,
,215.00,80,214.89,4030,,,,,,,,,,,,,,,,,,,,,
,215.22,81,215.11,4040,,,,,,,,,,,,,,,,,,,,,
,215.42,80,215.33,4040,,,,,,,,,,,,,,,,,,,,,
,215.64,80,215.54,4040,,,,,,,,,,,,,,,,,,,,,
,215.86,81,215.75,4040,,,,,,,,,,,,,,,,,,,,,
,216.08,81,215.97,4040,,,,,,,,,,,,,,,,,,,,,
,216.29,80,216.17,4040,,,,,,,,,,,,,,,,,,,,,
,216.50,80,216.39,4040,,,,,,,,,,,,,,,,,,,,,
,216.72,80,216.61,4040,,,,,,,,,,,,,,,,,,,,,
,216.94,80,216.83,4040,,,,,,,,,,,,,,,,,,,,,
,217.14,80,217.04,4040,,,,,,,,,,,,,,,,,,,,,
,217.36,81,217.25,4040,,,,,,,,,,,,,,,,,,,,,
,217.58,81,217.47,4040,,,,,,,,,,,,,,,,,,,,,
,217.80,80,217.69,4040,,,,,,,,,,,,,,,,,,,,,
,218.00,80,217.91,4040,,,,,,,,,,,,,,,,,,,,,
,218.22,80,218.11,4040,,,,,,,,,,,,,,,,,,,,,
,218.44,81,218.33,4040,,,,,,,,,,,,,,,,,,,,,
,218.66,80,218.55,4040,,,,,,,,,,,,,,,,,,,,,
,218.86,80,218.75,4050,,,,,,,,,,,,,,,,,,,,,
,219.08,80,218.97,4040,,,,,,,,,,,,,,,,,,,,,
,219.29,81,219.17,4050,,,,,,,,,,,,,,,,,,,,,
,219.50,80,219.39,4060,,,,,,,,,,,,,,,,,,,,,
,219.72,80,219.61,4050,,,,,,,,,,,,,,,,,,,,,
,219.94,80,219.83,4050,,,,,,,,,,,,,,,,,,,,,
,220.14,80,220.04,4050,,,,,,,,,,,,,,,,,,,,,
,220.36,80,220.25,4060,,,,,,,,,,,,,,,,,,,,,
,220.56,80,220.47,4060,,,,,,,,,,,,,,,,,,,,,
,220.79,80,220.67,4060,,,,,,,,,,,,,,,,,,,,,
,221.00,80,220.89,4060,,,,,,,,,,,,,,,,,,,,,
,221.22,80,221.11,4060,,,,,,,,,,,,,,,,,,,,,
,221.42,80,221.33,4060,,,,,,,,,,,,,,,,,,,,,
,221.64,81,221.54,4060,,,,,,,,,,,,,,,,,,,,,
,221.86,80,221.75,4060,,,,,,,,,,,,,,,,,,,,,
,222.08,80,221.97,4060,,,,,,,,,,,,,,,,,,,,,
,222.29,80,222.19,4060,,,,,,,,,,,,,,,,,,,,,
,222.50,80,222.39,4060,,,,,,,,,,,,,,,,,,,,,
,222.72,80,222.61,4060,,,,,,,,,,,,,,,,,,,,,
,222.92,80,222.81,4060,,,,,,,,,,,,,,,,,,,,,
,223.14,80,223.04,4060,,,,,,,,,,,,,,,,,,,,,
,223.36,80,223.25,4070,,,,,,,,,,,,,,,,,,,,,
,223.56,80,223.47,4070,,,,,,,,,,,,,,,,,,,,,
,223.79,80,223.67,4070,,,,,,,,,,,,,,,,,,,,,
,224.00,80,223.89,4070,,,,,,,,,,,,,,,,,,,,,
,224.20,80,224.09,4070,,,,,,,,,,,,,,,,,,,,,
,224.42,80,224.31,4070,,,,,,,,,,,,,,,,,,,,,
,224.64,80,224.54,4080,,,,,,,,,,,,,,,,,,,,,
,224.86,80,224.75,4070,,,,,,,,,,,,,,,,,,,,,
,225.08,80,224.97,4070,,,,,,,,,,,,,,,,,,,,,
,225.29,80,225.17,4090,,,,,,,,,,,,,,,,,,,,,
,225.50,80,225.39,4080,,,,,,,,,,,,,,,,,,,,,
,225.72,80,225.61,4080,,,,,,,,,,,,,,,,,,,,,
,225.94,80,225.83,4090,,,,,,,,,,,,,,,,,,,,,
,226.14,80,226.04,4090,,,,,,,,,,,,,,,,,,,,,
,226.36,80,226.25,4090,,,,,,,,,,,,,,,,,,,,,
,226.58,80,226.47,4080,,,,,,,,,,,,,,,,,,,,,
,226.79,80,226.69,4090,,,,,,,,,,,,,,,,,,,,,
,227.00,80,226.89,4090,,,,,,,,,,,,,,,,,,,,,
,227.22,80,227.11,4090,,,,,,,,,,,,,,,,,,,,,
,227.44,80,227.33,4090,,,,,,,,,,,,,,,,,,,,,
,227.64,80,227.54,4090,,,,,,,,,,,,,,,,,,,,,
,227.86,80,227.75,4090,,,,,,,,,,,,,,,,,,,,,
,228.08,80,227.97,4090,,,,,,,,,,,,,,,,,,,,,
,228.29,81,228.19,4100,,,,,,,,,,,,,,,,,,,,,
,228.50,80,228.39,4100,,,,,,,,,,,,,,,,,,,,,
,228.72,80,228.61,4100,,,,,,,,,,,,,,,,,,,,,
,228.92,80,228.81,4100,,,,,,,,,,,,,,,,,,,,,
,229.14,80,229.04,4100,,,,,,,,,,,,,,,,,,,,,
,229.36,80,229.25,4100,,,,,,,,,,,,,,,,,,,,,
,229.58,80,229.47,4110,,,,,,,,,,,,,,,,,,,,,
,229.79,80,229.69,4110,,,,,,,,,,,,,,,,,,,,,
,230.00,80,229.89,4110,,,,,,,,,,,,,,,,,,,,,
,230.22,80,230.11,4100,,,,,,,,,,,,,,,,,,,,,
,230.44,80,230.33,4110,,,,,,,,,,,,,,,,,,,,,
,230.64,80,230.54,4110,,,,,,,,,,,,,,,,,,,,,
,230.86,80,230.75,4110,,,,,,,,,,,,,,,,,,,,,
,231.06,80,230.97,4110,,,,,,,,,,,,,,,,,,,,,
,231.29,80,231.17,4110,,,,,,,,,,,,,,,,,,,,,
,231.50,80,231.39,4110,,,,,,,,,,,,,,,,,,,,,
,231.72,80,231.61,4110,,,,,,,,,,,,,,,,,,,,,
,231.94,80,231.83,4110,,,,,,,,,,,,,,,,,,,,,
,232.14,80,232.04,4120,,,,,,,,,,,,,,,,,,,,,
,232.36,80,232.25,4110,,,,,,,,,,,,,,,,,,,,,
,232.58,80,232.47,4120,,,,,,,,,,,,,,,,,,,,,
,232.80,80,232.69,4110,,,,,,,,,,,,,,,,,,,,,
,233.00,80,232.91,4120,,,,,,,,,,,,,,,,,,,,,
,233.22,80,233.11,4110,,,,,,,,,,,,,,,,,,,,,
,233.42,80,233.33,4120,,,,,,,,,,,,,,,,,,,,,
,233.64,80,233.54,4120,,,,,,,,,,,,,,,,,,,,,
,233.86,80,233.75,4120,,,,,,,,,,,,,,,,,,,,,
,234.08,80,233.97,4120,,,,,,,,,,,,,,,,,,,,,
,234.30,80,234.19,4130,,,,,,,,,,,,,,,,,,,,,
,234.50,80,234.41,4130,,,,,,,,,,,,,,,,,,,,,
,234.72,80,234.61,4130,,,,,,,,,,,,,,,,,,,,,
,234.94,80,234.83,4130,,,,,,,,,,,,,,,,,,,,,
,235.14,80,235.04,4140,,,,,,,,,,,,,,,,,,,,,
,235.36,80,235.25,4130,,,,,,,,,,,,,,,,,,,,,
,235.58,80,235.47,4130,,,,,,,,,,,,,,,,,,,,,
,235.79,80,235.67,4140,,,,,,,,,,,,,,,,,,,,,
,236.00,80,235.89,4130,,,,,,,,,,,,,,,,,,,,,
,236.22,80,236.11,4130,,,,,,,,,,,,,,,,,,,,,
,236.44,80,236.33,4130,,,,,,,,,,,,,,,,,,,,,
,236.64,80,236.54,4140,,,,,,,,,,,,,,,,,,,,,
,236.86,80,236.75,4130,,,,,,,,,,,,,,,,,,,,,
,237.08,80,236.97,4130,,,,,,,,,,,,,,,,,,,,,
,237.29,80,237.19,4140,,,,,,,,,,,,,,,,,,,,,
,237.50,80,237.39,4140,,,,,,,,,,,,,,,,,,,,,
,237.72,80,237.61,4140,,,,,,,,,,,,,,,,,,,,,
,237.94,80,237.83,4140,,,,,,,,,,,,,,,,,,,,,
,238.14,80,238.04,4140,,,,,,,,,,,,,,,,,,,,,
,238.36,80,238.25,4140,,,,,,,,,,,,,,,,,,,,,
,238.58,80,238.47,4150,,,,,,,,,,,,,,,,,,,,,
,238.79,80,238.69,4150,,,,,,,,,,,,,,,,,,,,,
,239.00,80,238.89,4150,,,,,,,,,,,,,,,,,,,,,
,239.22,80,239.11,4150,,,,,,,,,,,,,,,,,,,,,
,239.42,80,239.33,4140,,,,,,,,,,,,,,,,,,,,,
,239.64,80,239.54,4160,,,,,,,,,,,,,,,,,,,,,
,239.86,80,239.75,4150,,,,,,,,,,,,,,,,,,,,,
,240.08,80,239.97,4160,,,,,,,,,,,,,,,,,,,,,
,240.29,80,240.17,4150,,,,,,,,,,,,,,,,,,,,,
,240.50,80,240.39,4160,,,,,,,,,,,,,,,,,,,,,
,240.72,80,240.61,4160,,,,,,,,,,,,,,,,,,,,,
,240.94,80,240.83,4160,,,,,,,,,,,,,,,,,,,,,
,241.14,80,241.04,4160,,,,,,,,,,,,,,,,,,,,,
,241.36,80,241.25,4160,,,,,,,,,,,,,,,,,,,,,
,241.58,80,241.47,4160,,,,,,,,,,,,,,,,,,,,,
,241.79,80,241.69,4160,,,,,,,,,,,,,,,,,,,,,
,242.00,80,241.89,4160,,,,,,,,,,,,,,,,,,,,,
,242.22,80,242.11,4160,,,,,,,,,,,,,,,,,,,,,
,242.42,80,242.33,4160,,,,,,,,,,,,,,,,,,,,,
,242.64,80,242.54,4160,,,,,,,,,,,,,,,,,,,,,
,242.86,80,242.75,4160,,,,,,,,,,,,,,,,,,,,,
,243.08,80,242.97,4160,,,,,,,,,,,,,,,,,,,,,
,243.29,80,243.19,4160,,,,,,,,,,,,,,,,,,,,,
,243.50,80,243.39,4160,,,,,,,,,,,,,,,,,,,,,
,243.72,80,243.61,4160,,,,,,,,,,,,,,,,,,,,,
,243.92,80,243.81,4160,,,,,,,,,,,,,,,,,,,,,
,244.14,80,244.04,4160,,,,,,,,,,,,,,,,,,,,,
,244.36,80,244.25,4160,,,,,,,,,,,,,,,,,,,,,
,244.58,80,244.47,4160,,,,,,,,,,,,,,,,,,,,,
,244.79,80,244.67,4160,,,,,,,,,,,,,,,,,,,,,
,245.00,80,244.89,4160,,,,,,,,,,,,,,,,,,,,,
,245.22,80,245.11,4170,,,,,,,,,,,,,,,,,,,,,
,245.44,80,245.33,4180,,,,,,,,,,,,,,,,,,,,,
,245.64,80,245.54,4170,,,,,,,,,,,,,,,,,,,,,
,245.86,80,245.75,4160,,,,,,,,,,,,,,,,,,,,,
,246.08,80,245.97,4170,,,,,,,,,,,,,,,,,,,,,
,246.29,80,246.17,4180,,,,,,,,,,,,,,,,,,,,,
,246.50,80,246.39,4180,,,,,,,,,,,,,,,,,,,,,
,246.72,80,246.61,4170,,,,,,,,,,,,,,,,,,,,,
,246.92,80,246.83,4180,,,,,,,,,,,,,,,,,,,,,
,247.14,80,247.04,4180,,,,,,,,,,,,,,,,,,,,,
,247.36,80,247.25,4180,,,,,,,,,,,,,,,,,,,,,
,247.58,80,247.47,4180,,,,,,,,,,,,,,,,,,,,,
,247.79,80,247.69,4180,,,,,,,,,,,,,,,,,,,,,
,248.00,80,247.89,4180,,,,,,,,,,,,,,,,,,,,,
,248.22,80,248.11,4180,,,,,,,,,,,,,,,,,,,,,
,248.44,80,248.33,4180,,,,,,,,,,,,,,,,,,,,,
,248.64,80,248.54,4180,,,,,,,,,,,,,,,,,,,,,
,248.86,80,248.75,4180,,,,,,,,,,,,,,,,,,,,,
,249.08,80,248.97,4180,,,,,,,,,,,,,,,,,,,,,
,249.29,80,249.19,4180,,,,,,,,,,,,,,,,,,,,,
,249.50,80,249.39,4180,,,,,,,,,,,,,,,,,,,,,
,249.72,80,249.61,4180,,,,,,,,,,,,,,,,,,,,,
,249.92,80,249.83,4180,,,,,,,,,,,,,,,,,,,,,
,250.14,80,250.04,4190,,,,,,,,,,,,,,,,,,,,,
,250.36,80,250.25,4190,,,,,,,,,,,,,,,,,,,,,
,250.58,80,250.47,4180,,,,,,,,,,,,,,,,,,,,,
,250.79,80,250.69,4190,,,,,,,,,,,,,,,,,,,,,
,251.00,80,250.89,4190,,,,,,,,,,,,,,,,,,,,,
,251.22,80,251.11,4180,,,,,,,,,,,,,,,,,,,,,
,251.44,80,251.33,4190,,,,,,,,,,,,,,,,,,,,,
,251.64,80,251.54,4200,,,,,,,,,,,,,,,,,,,,,
,251.86,80,251.75,4190,,,,,,,,,,,,,,,,,,,,,
,252.06,80,251.97,4190,,,,,,,,,,,,,,,,,,,,,
,252.29,80,252.17,4200,,,,,,,,,,,,,,,,,,,,,
,252.50,80,252.39,4200,,,,,,,,,,,,,,,,,,,,,
,252.72,80,252.61,4200,,,,,,,,,,,,,,,,,,,,,
,252.92,80,252.81,4200,,,,,,,,,,,,,,,,,,,,,
,253.14,80,253.04,4200,,,,,,,,,,,,,,,,,,,,,
,253.36,80,253.25,4200,,,,,,,,,,,,,,,,,,,,,
,253.58,80,253.47,4200,,,,,,,,,,,,,,,,,,,,,
,253.79,80,253.67,4200,,,,,,,,,,,,,,,,,,,,,
,254.00,80,253.89,4210,,,,,,,,,,,,,,,,,,,,,
,254.22,80,254.11,4210,,,,,,,,,,,,,,,,,,,,,
,254.44,80,254.33,4210,,,,,,,,,,,,,,,,,,,,,
,254.66,80,254.55,4210,,,,,,,,,,,,,,,,,,,,,
,254.86,80,254.75,4210,,,,,,,,,,,,,,,,,,,,,
,255.08,80,254.97,4210,,,,,,,,,,,,,,,,,,,,,
,255.29,80,255.19,4210,,,,,,,,,,,,,,,,,,,,,
,255.50,80,255.39,4210,,,,,,,,,,,,,,,,,,,,,
,255.72,80,255.61,4210,,,,,,,,,,,,,,,,,,,,,
,255.94,80,255.83,4210,,,,,,,,,,,,,,,,,,,,,
,256.14,80,256.04,4210,,,,,,,,,,,,,,,,,,,,,
,256.36,80,256.25,4210,,,,,,,,,,,,,,,,,,,,,
,256.56,80,256.47,4210,,,,,,,,,,,,,,,,,,,,,
,256.79,80,256.67,4210,,,,,,,,,,,,,,,,,,,,,
,257.00,80,256.89,4220,,,,,,,,,,,,,,,,,,,,,
,257.22,80,257.11,4220,,,,,,,,,,,,,,,,,,,,,
,257.42,80,257.33,4220,,,,,,,,,,,,,,,,,,,,,
,257.64,80,257.54,4220,,,,,,,,,,,,,,,,,,,,,
,257.86,80,257.75,4220,,,,,,,,,,,,,,,,,,,,,
,258.06,80,257.97,4220,,,,,,,,,,,,,,,,,,,,,
,258.29,80,258.17,4220,,,,,,,,,,,,,,,,,,,,,
,258.50,80,258.39,4230,,,,,,,,,,,,,,,,,,,,,
,258.72,80,258.61,4220,,,,,,,,,,,,,,,,,,,,,
,258.92,80,258.83,4220,,,,,,,,,,,,,,,,,,,,,
,259.14,80,259.04,4230,,,,,,,,,,,,,,,,,,,,,
,259.36,80,259.25,4230,,,,,,,,,,,,,,,,,,,,,
,259.58,80,259.47,4230,,,,,,,,,,,,,,,,,,,,,
,259.79,80,259.69,4230,,,,,,,,,,,,,,,,,,,,,
,260.00,80,259.89,4230,,,,,,,,,,,,,,,,,,,,,
,260.22,80,260.11,4230,,,,,,,,,,,,,,,,,,,,,
,260.42,80,260.33,4240,,,,,,,,,,,,,,,,,,,,,
,260.64,80,260.54,4230,,,,,,,,,,,,,,,,,,,,,
,260.86,80,260.75,4240,,,,,,,,,,,,,,,,,,,,,
,261.06,80,260.97,4240,,,,,,,,,,,,,,,,,,,,,
,261.29,80,261.17,4240,,,,,,,,,,,,,,,,,,,,,
,261.50,80,261.39,4240,,,,,,,,,,,,,,,,,,,,,
,261.72,80,261.61,4240,,,,,,,,,,,,,,,,,,,,,
,261.94,80,261.83,4240,,,,,,,,,,,,,,,,,,,,,
,262.14,80,262.04,4240,,,,,,,,,,,,,,,,,,,,,
,262.36,80,262.25,4240,,,,,,,,,,,,,,,,,,,,,
,262.56,80,262.47,4240,,,,,,,,,,,,,,,,,,,,,
,262.79,80,262.67,4250,,,,,,,,,,,,,,,,,,,,,
,263.00,80,262.89,4250,,,,,,,,,,,,,,,,,,,,,
,263.22,80,263.11,4250,,,,,,,,,,,,,,,,,,,,,
,263.44,80,263.33,4260,,,,,,,,,,,,,,,,,,,,,
,263.65,80,263.55,4250,,,,,,,,,,,,,,,,,,,,,
,263.86,80,263.75,4250,,,,,,,,,,,,,,,,,,,,,
,264.08,80,263.97,4250,,,,,,,,,,,,,,,,,,,,,
,264.30,80,264.19,4250,,,,,,,,,,,,,,,,,,,,,
,264.50,80,264.41,4250,,,,,,,,,,,,,,,,,,,,,
,264.72,80,264.61,4260,,,,,,,,,,,,,,,,,,,,,
,264.94,80,264.83,4260,,,,,,,,,,,,,,,,,,,,,
,265.16,80,265.05,4260,,,,,,,,,,,,,,,,,,,,,
,265.36,80,265.25,4260,,,,,,,,,,,,,,,,,,,,,
,265.58,80,265.47,4260,,,,,,,,,,,,,,,,,,,,,
,265.80,80,265.69,4260,,,,,,,,,,,,,,,,,,,,,
,266.00,80,265.91,4260,,,,,,,,,,,,,,,,,,,,,
,266.22,80,266.11,4260,,,,,,,,,,,,,,,,,,,,,
,266.44,80,266.33,4260,,,,,,,,,,,,,,,,,,,,,
,266.66,80,266.55,4260,,,,,,,,,,,,,,,,,,,,,
,266.86,80,266.75,4260,,,,,,,,,,,,,,,,,,,,,
,267.06,80,266.97,4260,,,,,,,,,,,,,,,,,,,,,
,267.29,80,267.17,4260,,,,,,,,,,,,,,,,,,,,,
,267.50,80,267.39,4260,,,,,,,,,,,,,,,,,,,,,
,267.72,80,267.61,4260,,,,,,,,,,,,,,,,,,,,,
,267.94,80,267.83,4270,,,,,,,,,,,,,,,,,,,,,
,268.16,80,268.05,4270,,,,,,,,,,,,,,,,,,,,,
,268.36,80,268.25,4270,,,,,,,,,,,,,,,,,,,,,
,268.58,80,268.47,4280,,,,,,,,,,,,,,,,,,,,,
,268.80,80,268.69,4270,,,,,,,,,,,,,,,,,,,,,
,269.00,80,268.90,4280,,,,,,,,,,,,,,,,,,,,,
,269.22,80,269.11,4280,,,,,,,,,,,,,,,,,,,,,
,269.42,80,269.31,4280,,,,,,,,,,,,,,,,,,,,,
,269.64,80,269.54,4280,,,,,,,,,,,,,,,,,,,,,
,269.86,80,269.75,4280,,,,,,,,,,,,,,,,,,,,,
,270.08,80,269.97,4280,,,,,,,,,,,,,,,,,,,,,
,270.29,80,270.17,4280,,,,,,,,,,,,,,,,,,,,,
,270.50,80,270.39,4280,,,,,,,,,,,,,,,,,,,,,
,270.72,80,270.61,4280,,,,,,,,,,,,,,,,,,,,,
,270.94,80,270.83,4280,,,,,,,,,,,,,,,,,,,,,
,271.14,80,271.04,4280,,,,,,,,,,,,,,,,,,,,,
,271.36,80,271.25,4280,,,,,,,,,,,,,,,,,,,,,
,271.58,80,271.47,4280,,,,,,,,,,,,,,,,,,,,,
,271.79,80,271.69,4280,,,,,,,,,,,,,,,,,,,,,
,272.00,80,271.89,4280,,,,,,,,,,,,,,,,,,,,,
,272.22,80,272.11,4280,,,,,,,,,,,,,,,,,,,,,
,272.42,80,272.33,4280,,,,,,,,,,,,,,,,,,,,,
,272.64,80,272.54,4280,,,,,,,,,,,,,,,,,,,,,
,272.86,80,272.75,4280,,,,,,,,,,,,,,,,,,,,,
,273.08,80,272.97,4280,,,,,,,,,,,,,,,,,,,,,
,273.29,80,273.17,4280,,,,,,,,,,,,,,,,,,,,,
,273.50,80,273.39,4280,,,,,,,,,,,,,,,,,,,,,
,273.72,80,273.61,4280,,,,,,,,,,,,,,,,,,,,,
,273.92,80,273.83,4280,,,,,,,,,,,,,,,,,,,,,
,274.14,80,274.04,4280,,,,,,,,,,,,,,,,,,,,,
,274.36,80,274.25,4280,,,,,,,,,,,,,,,,,,,,,
,274.56,80,274.47,4280,,,,,,,,,,,,,,,,,,,,,
,274.79,80,274.67,4290,,,,,,,,,,,,,,,,,,,,,
,275.00,80,274.89,4280,,,,,,,,,,,,,,,,,,,,,
,275.20,80,275.11,4280,,,,,,,,,,,,,,,,,,,,,
,275.42,80,275.31,4290,,,,,,,,,,,,,,,,,,,,,
,275.64,80,275.54,4290,,,,,,,,,,,,,,,,,,,,,
,275.86,80,275.75,4300,,,,,,,,,,,,,,,,,,,,,
,276.08,80,275.97,4280,,,,,,,,,,,,,,,,,,,,,
,276.29,80,276.17,4290,,,,,,,,,,,,,,,,,,,,,
,276.50,80,276.39,4290,,,,,,,,,,,,,,,,,,,,,
,276.72,80,276.61,4290,,,,,,,,,,,,,,,,,,,,,
,276.94,80,276.83,4300,,,,,,,,,,,,,,,,,,,,,
,277.14,80,277.04,4300,,,,,,,,,,,,,,,,,,,,,
,277.36,80,277.25,4300,,,,,,,,,,,,,,,,,,,,,
,277.58,80,277.47,4300,,,,,,,,,,,,,,,,,,,,,
,277.80,80,277.69,4310,,,,,,,,,,,,,,,,,,,,,
,278.00,80,277.91,4310,,,,,,,,,,,,,,,,,,,,,
,278.22,80,278.11,4300,,,,,,,,,,,,,,,,,,,,,
,278.44,80,278.33,4310,,,,,,,,,,,,,,,,,,,,,
,278.64,80,278.54,4300,,,,,,,,,,,,,,,,,,,,,
,278.86,80,278.75,4300,,,,,,,,,,,,,,,,,,,,,
,279.08,80,278.97,4310,,,,,,,,,,,,,,,,,,,,,
,279.29,80,279.17,4310,,,,,,,,,,,,,,,,,,,,,
,279.50,81,279.39,4310,,,,,,,,,,,,,,,,,,,,,
,279.72,80,279.61,4310,,,,,,,,,,,,,,,,,,,,,
,279.92,80,279.81,4310,,,,,,,,,,,,,,,,,,,,,
,280.14,80,280.04,4300,,,,,,,,,,,,,,,,,,,,,
,280.36,80,280.25,4310,,,,,,,,,,,,,,,,,,,,,
,280.58,80,280.47,4310,,,,,,,,,,,,,,,,,,,,,
,280.79,80,280.69,4310,,,,,,,,,,,,,,,,,,,,,
,281.00,80,280.89,4310,,,,,,,,,,,,,,,,,,,,,
,281.22,80,281.11,4310,,,,,,,,,,,,,,,,,,,,,
,281.44,80,281.33,4310,,,,,,,,,,,,,,,,,,,,,
,281.66,80,281.55,4310,,,,,,,,,,,,,,,,,,,,,
,281.86,80,281.75,4310,,,,,,,,,,,,,,,,,,,,,
,282.08,80,281.97,4320,,,,,,,,,,,,,,,,,,,,,
,282.30,80,282.19,4310,,,,,,,,,,,,,,,,,,,,,
,282.50,80,282.41,4320,,,,,,,,,,,,,,,,,,,,,
,282.72,80,282.61,4320,,,,,,,,,,,,,,,,,,,,,
,282.92,80,282.83,4310,,,,,,,,,,,,,,,,,,,,,
,283.14,80,283.04,4310,,,,,,,,,,,,,,,,,,,,,
,283.36,80,283.25,4330,,,,,,,,,,,,,,,,,,,,,
,283.58,80,283.47,4320,,,,,,,,,,,,,,,,,,,,,
,283.79,80,283.69,4330,,,,,,,,,,,,,,,,,,,,,
,284.00,80,283.89,4330,,,,,,,,,,,,,,,,,,,,,
,284.22,80,284.11,4330,,,,,,,,,,,,,,,,,,,,,
,284.44,80,284.33,4330,,,,,,,,,,,,,,,,,,,,,
,284.65,80,284.55,4330,,,,,,,,,,,,,,,,,,,,,
,284.86,80,284.75,4330,,,,,,,,,,,,,,,,,,,,,
,285.08,80,284.97,4330,,,,,,,,,,,,,,,,,,,,,
,285.29,80,285.17,4330,,,,,,,,,,,,,,,,,,,,,
,285.50,80,285.39,4330,,,,,,,,,,,,,,,,,,,,,
,285.72,80,285.61,4330,,,,,,,,,,,,,,,,,,,,,
,285.92,80,285.83,4330,,,,,,,,,,,,,,,,,,,,,
,286.14,80,286.04,4330,,,,,,,,,,,,,,,,,,,,,
,286.36,80,286.25,4330,,,,,,,,,,,,,,,,,,,,,
,286.58,80,286.47,4330,,,,,,,,,,,,,,,,,,,,,
,286.79,80,286.69,4330,,,,,,,,,,,,,,,,,,,,,
,287.00,80,286.89,4340,,,,,,,,,,,,,,,,,,,,,
,287.22,80,287.11,4330,,,,,,,,,,,,,,,,,,,,,
,287.42,80,287.33,4340,,,,,,,,,,,,,,,,,,,,,
,287.64,80,287.54,4350,,,,,,,,,,,,,,,,,,,,,
,287.86,80,287.75,4340,,,,,,,,,,,,,,,,,,,,,
,288.08,80,287.97,4350,,,,,,,,,,,,,,,,,,,,,
,288.29,80,288.17,4340,,,,,,,,,,,,,,,,,,,,,
,288.50,80,288.39,4340,,,,,,,,,,,,,,,,,,,,,
,288.72,80,288.61,4350,,,,,,,,,,,,,,,,,,,,,
,288.92,80,288.81,4340,,,,,,,,,,,,,,,,,,,,,
,289.14,80,289.04,4350,,,,,,,,,,,,,,,,,,,,,
,289.36,80,289.25,4350,,,,,,,,,,,,,,,,,,,,,
,289.58,80,289.47,4350,,,,,,,,,,,,,,,,,,,,,
,289.79,80,289.69,4350,,,,,,,,,,,,,,,,,,,,,
,290.00,80,289.89,4350,,,,,,,,,,,,,,,,,,,,,
,290.22,80,290.11,4350,,,,,,,,,,,,,,,,,,,,,
,290.44,80,290.33,4350,,,,,,,,,,,,,,,,,,,,,
,290.66,80,290.55,4350,,,,,,,,,,,,,,,,,,,,,
,290.86,80,290.75,4350,,,,,,,,,,,,,,,,,,,,,
,291.08,80,290.97,4350,,,,,,,,,,,,,,,,,,,,,
,291.29,80,291.19,4350,,,,,,,,,,,,,,,,,,,,,
,291.50,80,291.39,4350,,,,,,,,,,,,,,,,,,,,,
,291.72,80,291.61,4350,,,,,,,,,,,,,,,,,,,,,
,291.94,80,291.83,4350,,,,,,,,,,,,,,,,,,,,,
,292.16,80,292.05,4360,,,,,,,,,,,,,,,,,,,,,
,292.36,80,292.25,4350,,,,,,,,,,,,,,,,,,,,,
,292.58,80,292.47,4350,,,,,,,,,,,,,,,,,,,,,
,292.80,80,292.69,4360,,,,,,,,,,,,,,,,,,,,,
,293.00,80,292.91,4360,,,,,,,,,,,,,,,,,,,,,
,293.22,80,293.11,4350,,,,,,,,,,,,,,,,,,,,,
,293.44,80,293.33,4360,,,,,,,,,,,,,,,,,,,,,
,293.64,80,293.54,4370,,,,,,,,,,,,,,,,,,,,,
,293.86,80,293.75,4360,,,,,,,,,,,,,,,,,,,,,
,294.08,80,293.97,4360,,,,,,,,,,,,,,,,,,,,,
,294.29,80,294.19,4370,,,,,,,,,,,,,,,,,,,,,
,294.50,80,294.39,4370,,,,,,,,,,,,,,,,,,,,,
,294.72,80,294.61,4380,,,,,,,,,,,,,,,,,,,,,
,294.94,80,294.83,4370,,,,,,,,,,,,,,,,,,,,,
,295.14,80,295.04,4370,,,,,,,,,,,,,,,,,,,,,
,295.36,80,295.25,4370,,,,,,,,,,,,,,,,,,,,,
,295.56,80,295.47,4370,,,,,,,,,,,,,,,,,,,,,
,295.79,80,295.67,4370,,,,,,,,,,,,,,,,,,,,,
,296.00,80,295.89,4370,,,,,,,,,,,,,,,,,,,,,
,296.22,80,296.11,4370,,,,,,,,,,,,,,,,,,,,,
,296.42,80,296.33,4370,,,,,,,,,,,,,,,,,,,,,
,296.64,80,296.54,4380,,,,,,,,,,,,,,,,,,,,,
,296.86,80,296.75,4380,,,,,,,,,,,,,,,,,,,,,
,297.08,80,296.97,4380,,,,,,,,,,,,,,,,,,,,,
,297.29,80,297.17,4380,,,,,,,,,,,,,,,,,,,,,
,297.50,80,297.39,4380,,,,,,,,,,,,,,,,,,,,,
,297.72,80,297.61,4380,,,,,,,,,,,,,,,,,,,,,
,297.92,80,297.81,4380,,,,,,,,,,,,,,,,,,,,,
,298.14,80,298.04,4380,,,,,,,,,,,,,,,,,,,,,
,298.36,80,298.25,4380,,,,,,,,,,,,,,,,,,,,,
,298.56,80,298.47,4380,,,,,,,,,,,,,,,,,,,,,
,298.79,80,298.67,4380,,,,,,,,,,,,,,,,,,,,,
,299.00,80,298.89,4380,,,,,,,,,,,,,,,,,,,,,
,299.22,80,299.11,4380,,,,,,,,,,,,,,,,,,,,,
,299.42,80,299.31,4390,,,,,,,,,,,,,,,,,,,,,
,299.64,80,299.54,4390,,,,,,,,,,,,,,,,,,,,,
,299.86,80,299.75,4380,,,,,,,,,,,,,,,,,,,,,
,300.08,80,299.97,4390,,,,,,,,,,,,,,,,,,,,,
,300.29,80,300.19,4390,,,,,,,,,,,,,,,,,,,,,
,300.50,80,300.39,4390,,,,,,,,,,,,,,,,,,,,,
,300.72,80,300.61,4390,,,,,,,,,,,,,,,,,,,,,
,300.92,80,300.81,4400,,,,,,,,,,,,,,,,,,,,,
,301.14,80,301.04,4400,,,,,,,,,,,,,,,,,,,,,
,301.36,80,301.25,4400,,,,,,,,,,,,,,,,,,,,,
,301.58,80,301.47,4400,,,,,,,,,,,,,,,,,,,,,
,301.79,80,301.69,4400,,,,,,,,,,,,,,,,,,,,,
,302.00,80,301.89,4400,,,,,,,,,,,,,,,,,,,,,
,302.22,80,302.11,4400,,,,,,,,,,,,,,,,,,,,,
,302.44,80,302.33,4400,,,,,,,,,,,,,,,,,,,,,
,302.64,80,302.54,4400,,,,,,,,,,,,,,,,,,,,,
,302.86,80,302.75,4400,,,,,,,,,,,,,,,,,,,,,
,303.08,80,302.97,4400,,,,,,,,,,,,,,,,,,,,,
,303.29,80,303.19,4400,,,,,,,,,,,,,,,,,,,,,
,303.50,80,303.39,4400,,,,,,,,,,,,,,,,,,,,,
,303.72,80,303.61,4400,,,,,,,,,,,,,,,,,,,,,
,303.94,80,303.83,4400,,,,,,,,,,,,,,,,,,,,,
,304.16,80,304.05,4400,,,,,,,,,,,,,,,,,,,,,
,304.36,80,304.25,4400,,,,,,,,,,,,,,,,,,,,,
,304.58,80,304.47,4400,,,,,,,,,,,,,,,,,,,,,
,304.79,80,304.69,4400,,,,,,,,,,,,,,,,,,,,,
,305.00,80,304.89,4400,,,,,,,,,,,,,,,,,,,,,
,305.22,80,305.11,4400,,,,,,,,,,,,,,,,,,,,,
,305.44,80,305.33,4400,,,,,,,,,,,,,,,,,,,,,
,305.66,80,305.55,4400,,,,,,,,,,,,,,,,,,,,,
,305.86,80,305.75,4400,,,,,,,,,,,,,,,,,,,,,
,306.08,80,305.97,4400,,,,,,,,,,,,,,,,,,,,,
,306.29,80,306.19,4410,,,,,,,,,,,,,,,,,,,,,
,306.50,80,306.39,4400,,,,,,,,,,,,,,,,,,,,,
,306.72,80,306.61,4410,,,,,,,,,,,,,,,,,,,,,
,306.92,80,306.81,4400,,,,,,,,,,,,,,,,,,,,,
,307.14,80,307.04,4410,,,,,,,,,,,,,,,,,,,,,
,307.36,80,307.25,4400,,,,,,,,,,,,,,,,,,,,,
,307.56,80,307.47,4410,,,,,,,,,,,,,,,,,,,,,
,307.79,80,307.67,4400,,,,,,,,,,,,,,,,,,,,,
,308.00,80,307.89,4410,,,,,,,,,,,,,,,,,,,,,
,308.22,80,308.11,4410,,,,,,,,,,,,,,,,,,,,,
,308.44,80,308.33,4410,,,,,,,,,,,,,,,,,,,,,
,308.66,80,308.55,4420,,,,,,,,,,,,,,,,,,,,,
,308.86,80,308.75,4410,,,,,,,,,,,,,,,,,,,,,
,309.06,80,308.97,4410,,,,,,,,,,,,,,,,,,,,,
,309.29,80,309.17,4420,,,,,,,,,,,,,,,,,,,,,
,309.50,80,309.39,4410,,,,,,,,,,,,,,,,,,,,,
,309.72,80,309.61,4420,,,,,,,,,,,,,,,,,,,,,
,309.92,80,309.83,4430,,,,,,,,,,,,,,,,,,,,,
,310.14,80,310.04,4430,,,,,,,,,,,,,,,,,,,,,
5,310.36,80,310.25,4420,,,,,,,,,,,,,,,,,,,,,
,310.56,80,310.45,4420,,,,,,,,,,,,,,,,,,,,,
,310.79,80,310.67,4420,,,,,,,,,,,,,,,,,,,,,
,311.00,80,310.89,4420,,,,,,,,,,,,,,,,,,,,,
,311.22,80,311.11,4430,,,,,,,,,,,,,,,,,,,,,
,311.42,80,311.33,4430,,,,,,,,,,,,,,,,,,,,,
,311.64,80,311.54,4420,,,,,,,,,,,,,,,,,,,,,
,311.86,80,311.75,4430,,,,,,,,,,,,,,,,,,,,,
,312.08,80,311.97,4430,,,,,,,,,,,,,,,,,,,,,
,312.29,80,312.17,4430,,,,,,,,,,,,,,,,,,,,,
,312.50,80,312.39,4430,,,,,,,,,,,,,,,,,,,,,
,312.72,80,312.61,4430,,,,,,,,,,,,,,,,,,,,,
,312.92,80,312.81,4430,,,,,,,,,,,,,,,,,,,,,
,313.14,80,313.04,4440,,,,,,,,,,,,,,,,,,,,,
,313.36,80,313.25,4440,,,,,,,,,,,,,,,,,,,,,
,313.58,80,313.47,4430,,,,,,,,,,,,,,,,,,,,,
,313.79,80,313.69,4430,,,,,,,,,,,,,,,,,,,,,
,314.00,80,313.89,4440,,,,,,,,,,,,,,,,,,,,,
,314.22,80,314.11,4450,,,,,,,,,,,,,,,,,,,,,
,314.42,80,314.33,4440,,,,,,,,,,,,,,,,,,,,,
,314.64,80,314.54,4440,,,,,,,,,,,,,,,,,,,,,
,314.86,80,314.75,4440,,,,,,,,,,,,,,,,,,,,,
,315.08,80,314.97,4440,,,,,,,,,,,,,,,,,,,,,
,315.30,80,315.19,4440,,,,,,,,,,,,,,,,,,,,,
Jef
HQ
So just rounding off the numbers, it would seem the engine idles at 4000 kPa (40 BAR) of rail pressure. And if I read your post correctly, hot engine (coolant +80C) the rail pressure didn't beak 5000 kPa (50 BAR) on 2 different attempts 2 minutes after the engine was shut off. This implies the possibility of leaking fuel injectors.
Where were parts purchased from?
rickmac
C?ID=344391
Correct. The first time it did climb above 8000 kPa, the second and third time it did not break 5000 kPa.
Injectors and timing chain were done at an Audi dealer.
Sourced everything else online. OE replacement parts, but not genuine Audi.
NostraJackAss
Jef
Or the high pressure pump leaking fuel into the engine oil directly?:rolleyes:
Jef
HQ
If ALL of the injectors were just replaced at the Audi dealer, then they shouldn't be bleeding out.... with an engine up to temp, shut it off, remove oil cap and take a big phat whiff of the crank case... does it have a gassy smell about it. If so, Jack wins a box of doughnuts.
rickmac
C?ID=344391
All 4 injectors were done within the last year; I'd guess less than 5k miles on them. It definitely smells of gas. So, new pump and cam shaft follower just because I'm already in there and then retest. Assuming the fuel pressure builds as expected I'll change the oil/oil filter, clear codes and pray to the car Gods. Anything else I should consider to mitigate any damage the fuel contamination might have caused internally?
rickmac
C?ID=344391
Installed the new pump and cam follower last night. Checked the fuel pressure and it looked to build fuel pressure post-warm up. Added some Liqui Moly Pro-Line engine flush and let that idle for 10-15 minutes and then changed the oil/oil filter.
Cleared codes, let it warm up, ran a scan, took it for a test drive. Ran great! First cold start this morning, idles like a champ, stabbing the accelerator had 0 lag, 0 issues. Seems like it is good to go.
Thanks for the pointers. Much appreciated!
