Need HELP with Traffic Sign recognition on Skoda Superb 3FL
georgexs
Unverified
Moldova
Hi all, I activated Lane Assist on new Skoda Superb 3 FL, it work ok, when I activated Traffic Sign Asist on dash board is error, in block 5F is this error: U111100 ($1C21 / 7201) Function limitation due to missing message
DTC text: Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful
Everything is coded corectly. ECU: 005F - Information Control Unit 1
Coding 03 84 01 01 00 00 00 00 41 11 00 02 00 10 2A 00 2F 01 03 E4 01 20 84 00 DF
georgexs
Unverified
Moldova
VIN: TMBCJ6NP7L702xxxx  License Plate:
Mileage: 850km-528 mileage
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 23 2B 36 3C 42 44 47
          4B 52 5F 6C 6D A5 BB BC
VIN: TMBCJ6NP7L702xxxx   Mileage: 850km-528mileage
02-Transmission Control Module -- Status: OK 0000
17-Instruments -- Status: contains malfunctions 0010
19-CAN Gateway -- Status: Status: OK 0000
22-Four-wheel drive electronics -- Status: OK 0000
47-Acoustic system -- Status: OK 0000
5F-Information Electr. -- Status:  contains malfunctions 0010
A5-Frt Sens. Drv. Assist -- Status: OK 000
Address 01: Engine  (J623-DFHA)      Labels: None
   Part No SW: 04L 906 027 P    АО: 04L 907 309 P
   Component: R4 2.0l TDI   H26 9497
   Revision: B4H26---
   Coding: 01250512036605083000
   Shop  #: WSC 00033 790 00177
   ASAM Dataset: EV_ECM20TDI01104L906027P 005003
   ROD: EV_ECM20TDI01104L906027P_SK48.rod
Address 02: Transmission Control Module (J743)            Labels:. 0BH-927-711.clb
   Part No SW: 0GC 300 013 K    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2405
   Revision: 00H06V09
   Rod: EV_TCMDQ381061_VW37.rod
   Part No SW:  5Q0 614 517 FA    HW: 5Q0 614 517 BR
   Component: ESC           H82 0190
   Revision: 00000000    Serial number: 62439000003082
   Coding: 1D077A9C31223B6C477B070360CA49B85E8CDCE2E0069275386150B8D2894A0B0003000012121212B835351919323200
   ROD EV_Brake1UDSContiMK100IPB_038.rod
Address 05: Acc/Start Auth. (J518)      Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0526918593
   Coding: 0F20000723
   ROD: EV_KessyHellaMQBAB_VW48.rod
   Subsystem 1 - Part No Sw: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial Number: 84620022
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 FG    HW: 3V0 907 044 FG
   Component: AC Automat    H34 4803
   Revision: 20K10000    Serial number: 00000B01450150
   Coding: 11010104002400011005100D0010512A
   ASAM Dataset: EV_ACClimaPrehVW37X 002027
   ROD: EV_ACClimaPrehVW37X.rod
   Air quality sensor:
   Subsystem 1 -Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 91013828
   Subsystem 2 - Part No Sw: 3V0 907 049 E   HW: 3V0 907 049 E
   Component: E265KlimaHeck  H02 0101
   Serial Number:       06051501850797
   Part No SW: 5Q0 937 086 CF    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F22081900IB
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   Subsystem 1 - Part No Sw: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 190723  032  0121
   Serial number: 00000001907190303621
   Coding: 165DDD
   Subsystem 2 - Part no SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Файл QML: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: S4Y19M09D04H08M21S33
   Coding: 0088DF
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 DF    HW: 5Q1 953 569 C
   Component: Lenks.Modul  H33  0170
   Serial number: 0100030820190C301403
   Seat Backrest Fan 1 Front Left:
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014  0101
   Serial number: ESE0939654
   Seat Cushion Fan 1 Front Left:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0941323
   Seat Backrest Fan 1 Front Right:
   Subsystem 7 -  Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0541443
   Seat Cushion Fan 1 Front Right:
   Subsystem 8 -Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0658015
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Componentт: PDC 8 Kanal   H08 0061
   Serial number: 000150058319255
   Coding: 0471155851
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Coding: 320467D259FFC428949C812480300600000000000000000046
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003.rod
   Serial number: 28071941350222
   ROD: EV_DRCONTITEMIC_VW37.rod
   Part No SW: 5Q0 959 655 BR    HW: 5Q0 959 655 BR
   Component: AirbagVW21    007 0403
   Serial number: 003FLR5G69L.
   Coding: 88CCC000000000005C5400CF000800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: -----------    HW: 480 000 709 19
   Serial number 35700000000C5780DF3Z
   Subsystem 2 - Part No SW: -----------    HW: 480 000 709 19
   Serial number: 35800000000ED780DF33
   Subsystem 3 - Part No SW: -----------    HW: 480 400 609 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100012A2C9EFD6B4BX
   Subsystem 4 - Part No SW: -----------    HW: 480 400 609 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001BCF271E74DB2O
   Subsystem 5 - Part No SW: -----------    HW: 480 400 609 19
   Subsystem: FrontSensor_D  005 6149
   Serial number: 3550001C4F27DCC288D-
   Part No SW: 3V0 920 790 D    HW: 3V0 920 790 D
   Component: KOMBI         502 4191
   Coding: 05A5001AFF8C00080188630B5001000080000000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
1 fault code:
U111000 ($FFFF34 / 16777012) Function restriction due to communication interruption
DTC text: BAP_VZA_0x21 keine Kommunikation
     DTC ambient conditions
         Date 12:52:04 - 31.10.2019
         Odometer reading 837 km
         Priority 6
         Malfunction frequency counter 1
         Unlearning counter 25
   Part No SW: 3Q0 907 530 AC    HW 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 08091911601327
   Coding: 0B0100045F087300A90002DA9C0F00010001070000000000000000000000
   Shop #: WSC 00033 790 00138
   ROD: EV_GatewNF.rod
   Component: 4-01-09-01-04
   Subsystem 2 - Part No SW: 3V0 919 719 G    HW: 3V0 919 719 G
   Component: E221__MFL-PR6  H03 0180
   Serial number 000000000D0266280819
   Serial number: 1056912405
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H27 0810
   Serial number: 2153696
Аdress 22: Four-wheel drive electronics (J492)       Labels:* 0CQ-907-554.clb
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00029.07.19
   Coding: 0301
Adress 23: Brake Booster (J539)       Labels: None
   Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0069
   Serial number: BPA085070819013
   Coding: 0102C500340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
   Serial number: 19000232040015
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 C    HW: 3Q0 959 760 C
   Component: Sitzmemory    H06 0026
   Serial number: Y0007SH221374
   Coding: 0010000000000500818280808080000000008181000000D400
   ASAM dataset: EV_SeatMemorDriveSide 002022
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0149
   Serial number: 00000524685562
   Coding: 52954640
   ASAM Dtataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000388435933
   Coding: 001D8920DE00020000001100
Аdress 44:  Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 956032 00
   Coding: 0100001100400110
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
Аdress 47:  Acoustic system (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1KJE08AJ79
   Coding: 0384010000AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 03071910801912
   Coding: 00000007090008F206003D13010000000000000000000000000000000000
   Shop #: WSC 00033 790 00120
   ROD: EV_MultiModulContiVW48X_003.rod
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Componet: TSG BFS       007 0485
   Serial number: 0000388209181
   Coding: 001D8120DE00020000001100
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   Part No SW: 565 035 020 E    HW: 565 035 020
   Componnet: MU-H-ND-EU    H55 1440
   Serial number: A855F0KB027938
   Coding: 03840101000000004111000200102A002F0103E401208400DF
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   Subsystem 1 - Part No SW: 3V0 919 606 D    HW: 3V0 919 606 D
   Component: ABT_High-2  H52 9130
   Serial number: SKZ6ZHW2520418
   subsystem 2 - Part No SW: V03 959 803 TF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Compact Disc Database:
   Component: Gracenote2  --- 1017
1 fault code:
         Priority 6
   Coding: 04840101A2002017000040
   Part Noo SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number : A2-C737-6291-8
   Coding: 1008
   ROD: EV_DeckLidCONTIAU736_AU73.rod
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1027
   Serial number: E33417008192560
   Coding: 0002088821684028B0DF10001030008000210000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_AU37.rod
   Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
   Component: TSG HFS       010 0384
   Serial number: 0000388696285
   Coding: 001C81208000020000001100
ddress BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      010 0384
   Serial number: 0000388691588
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
End---------------------(Elapsed Time: 05:54)-----------------------
