Polo fuel trim issue
cammym3
C?ID=189514 (NRRT)
hello everyone new to the site !but hoping for some help with a reoccurring issue on a 2014 polo 3cylinder petrol ,11730 (po171) system too lean car has had a recent engine change due to a failed timing chain all parts swapped between engines apart from inlet manifold ! have smoked tested engine for any air leaks with no joy replaced front lambda due slow activity and obviously reset all adaptations .usually takes 2/3 days before fault reoccurs with no obvious loss of power thanks in advance
South Molton, UK
Pleas post a full unedited VCDS Auto-Scan so we can see how this Polo is equipped.
cammym3
C?ID=189514 (NRRT)
Friday,01,November,2019,11:08:10:61138
VCDS Version: 19.6.2.0
VIN: WVWZZZ6RZEU029305   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZEU029305   Mileage: 128760km-80007miles
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 AK    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 5151
   Revision: --H03---    Serial number:
   Coding: 00110016002400080000
   Shop #: WSC 00078 790 12345
   ASAM Dataset: EV_ECM12MPI02103E906019AK 001003
   ROD: EV_ECM12MPI.rod
   VCID: 6DD793B7BC7F2C277C-8038
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 23DD2485212500C9C4172469845600800905
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
   VCID: 0F2BE93FD6B3BE372E-805A
   Serial number: 05101304650086
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF5A4FBE119A7BFD5-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397F77E7B0B74087A0-806C
   Part No SW: 6R0 937 087 P    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0411
   Revision: BF034001    Serial number: 0581 234131674
   Coding: 25B42B3F08E12400923008002D2B0CD000C0410F60060000200020000000
   Shop #: WSC 31414 790 31414
   VCID: 4A9D382BE551DB1F39-801E
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU013091300013990
   Coding: 1000A0
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU002091300016517
   Coding: 0000A0
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU023091300017190
   Coding: 0000A0
   Subsystem 7 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU018091300018310
   Coding: 1000A0
Address 10: Park/Steer Assist (J446)       Labels:| 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47331326202427
   Coding: 108001
   ASAM Dataset: EV_VW250ParkiAssis2 S01008
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E7564FBA19967BF95-806A
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H10 0020
   Revision: --------    Serial number: 003GX01V9DP2
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9D382BED51DB1F39-801E
   Serial number: 3575HRB400A50LFC5HG8
   Serial number: 3585HRB400A50LFCF0C+
   Serial number: 3515RRB400Q50L2UMOJH
   Serial number: 3525RRB400A50MBIF0F8
   Part No SW: 6R0 920 960 M    HW: 6R0 920 960 M
   Component: KOMBI         H04 0709
   Coding: 440A01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
   VCID: 3F8B19FFA6936EB79E-806A
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0411
   Revision: BF034001
   Coding: 002300
   VCID: 70E98AC3A34DC1CF57-8024
   Component: IMMO          H04 0709
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADD98AB8D913B1F19-803E
   Revision: A1001003    Serial number: 7665324755
   Coding: 010100
   VCID: 2B535DAF4AEBE21722-807E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11250
   Shop #: WSC 31414
   VCID: 30694AC3F7CD81CF17-8064
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  004 0119
   Revision: 01000001    Serial number: VWZ1Z2N1901251
   Coding: 01000400020001
   VCID: 35677BD79CAFA4E744-8060
End-------------------------(Elapsed Time: 03:16)--------------------------
cammym3
C?ID=189514 (NRRT)
any help guys
South Molton, UK
Do you have a scan showing the fault codes (VCDS saves all the auto-scans in C:\Ross-Tech\VCDS\Scans) as that would give more clues?
cammym3
C?ID=189514 (NRRT)
Friday,08,November,2019,13:52:19:61138
VCDS Version: Release 19.6.2 Running on Windows 7 x86
                Address 01: Engine       Labels: 03E-906-019-CGP.clb
Control Module Part Number: 03E 906 019 AK    HW: 03E 906 019 B
  Component and/or Version: SIMOS11.1     H03 5151
           Software Coding: 00110016002400080000
            Work Shop Code: WSC 00078 790 12345
              ASAM Dataset: EV_ECM12MPI02103E906019AK 001003 (VW25)
11730 - Fuel Trim; Bank 1
          P0171 00 [237] - System Too Lean
                    Mileage: 128765 km
                    Date: 2067.14.15
                    Time: 00:15:56
                    Engine speed: 841.00 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.574 V
                    Mixture deviation in adapted partial load range 1-FAC_MPL_LAM_AD[1][0]: 17.999 %
                    Mixture deviation in adapted partial load range 2-FAC_MPL_LAM_AD[1][1]: 17.999 %
                    Mixture deviation in adapted partial load range 3-FAC_MPL_LAM_AD[1][2]: -3.908 %
                    Sensor control factor: output value-Lambda control value: bank 1: 2.026 %
16712 - System Voltage
          P0562 00 [032] - Too Low
                    Mileage: 128764 km
                    Date: 2067.14.15
                    Time: 12:26:50
                    Engine speed: 0.00 /min
                    Coolant temperature: 12 °C
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 8.554 V
                    Unlearning counter according OBD: 18
                    Engine speed: 0 /min
                    Engine status-Engine: operating status: ES
                    Time since engine start: 0 s
thanks in advance
cammym3
C?ID=189514 (NRRT)
hello people really struggling with any info any one I can message to help me
cammym3
C?ID=189514 (NRRT)
can you help dave
"Too lean" is either air unmetered getting into the engine somehow, or not enough fuel.
But I don't know this engine or the SIMOS management it has on it.
cammym3
C?ID=189514 (NRRT)
hi yes I realize what causes issue and ive checked for the leaks was hoping that the faults would help to give me a better area to check or anyone with previuos experience of issues
