2013 jetta 2.5L AJ readiness codes missing
RayJuod
C?ID=127865
CT Emissions testing station detected several readiness codes as NOT READY while I could not tell this from my VCDS scan. My CT test result told me
Catalyst: NOT READY , Evaporative System: NOT READY, Fuel System: NOT READY Oxygen Sensor: NOT READY.
As a result I failed my initial emissions test. I had tested the readiness earlier and found all the emissions items green and passed with code Readiness: 0000 0000 . Should Readiness be 1 ?
Presumably all I have to do is drive the car for a period of time for them to set as i don't believe there is anything wrong. But I would like to verify them before going for my retest.
Monday,14,October,2019,08:19:59:31041
VIN: 3VWDP7AJ7DM447079   License Plate:
Mileage: 49530km-30776mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDP7AJ7DM447079   Mileage: 49530km-30776miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CP    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 4725
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 7EA5FFE4BCF0E1E7BBB-802A
Readiness: 0010 0101
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2246
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 0059811CC6049717C97-8054
                    Fault Status: 00101101
                    Reset counter: 195
                    Mileage: 42620 km
                    Date: 2018.11.11
                    Time: 16:30:09
   Revision: 00H31001
   Coding: B14B400C492608018D0B02EB92221061A71000
   VCID: 7DA7F8E8BDF6FAFFA21-8028
                    Reset counter: 15
                    Mileage: 49521 km
                    Date: 2014.03.05
                    Time: 16:48:48
                    Count: 12
                    Count: 12544
                    Count: 8193
                    Count: 42752
                    Count: 65533
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BA    HW: 5C0 820 047 BA
   Component: J301  Klimaanlage   0204
   Revision: 2001012S    Serial number: 00000001585129
   VCID: 6099A19C26443717A97-8034
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371140130905
   Coding: 7B994B1808AB0B0000382000240884C500C2502E60000000300000000000
   VCID: 2F3B12A0271AD86F60D-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 3465
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3465
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Serial number: 0233217 FLE 20130424
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
   Component: J388__TSG_HL  004 3464
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
   Part No SW: 5C0 959 655 Q    HW: 5C0 959 655 Q
   Component: AirbagVW10G   013 0851
   Serial number: 003LKM04PF1P
   Coding: 00004A33
   Shop #: WSC 00066 000 00201
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 40D9411C8A045717897-8014
   Serial number: 6940000Y130000UAHZ0K
   Coding: 303036
   Serial number: 3572MSME3E585578ZZZ5
   Serial number: 3582MSME35133478ZZZS
   Serial number: 3516KSME09376E23ZZZX
   Serial number: 3526KSME3A7B2623ZZZY
   Serial number: 3556LSME0E0E6C21ZZZ0
   Serial number: 3566LSME22645B21ZZZS
   Part No SW: 5C6 920 952 B    HW: 5C6 920 952 B
   Component: KOMBI         H06 0705
   Coding: 270A01
   VCID: 2B0306B01382A44F4C5-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70B9D1DCFAA48797397-8024
   Component: IMMO          H06 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC3B4DCF87D47773-803E
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664534554
   Coding: 010100
   VCID: 2A0D03B41CF8BD47B73-807E
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H03 0005
   Revision: -----07S    Serial number: VWZ4Z6N3570344
   Coding: 01000400020006
   VCID: 2517F08875E6923F9A1-8070
                    Reset counter: 230
                    Mileage: 49521 km
                    Date: 2014.03.05
                    Time: 16:48:47
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664544708
   Coding: 0A10040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2D33F4ECD80DC7C73-806E
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
NostraJackAss
Thanks​
Sure you can see in red above?
0 PASSED IN PRIOR DCY
1 INCOMPLETE OR FAILED
You can also go to OBD2 MODE 0x33 & observe MODES for readiness test screens.
Readiness should be all zeros.
If all tested systems are functioning correctly, driving the car for a few days should indeed set all the readiness bits to 0.
There should be a "Set Readiness" script for your engine that you can use to hurry the process along.
[Select]
[01-Engine]
[Readiness-15]
See here.
Also, before going for your next emissions test, use the generic OBD-II function to check readiness. It uses the same query that the emissions inspection facility will.
RayJuod
C?ID=127865
Ok thanks both, i'll do some testing later and see how it goes.
RayJuod
C?ID=127865
Emissions passed, all good, thanks
