Audi A6 AD Hello BLUE FAULT
HOWIE
Ireland
C?ID=62065
Hello I am having a problem with a 2014 Audi A6 , engine code :CHN .There is a ad blue system fault on the dash and not a ad blue refill fault on the dash. The customer was driving the car on the motorway when the fault light came on with a limit of 600 miles left on the count down.The customer drove another 100 miles and filled the ad blue to the top . When the car came to me there are no logged faults on vag com but the light was still on the dash.
I have checked the pressure in the ad blue and it registers 5000 mbar when the reduction pump is activated .I took off the adblue injector ,and gave it a clean .I then activated it by using the SRC activation metering valve procedure and it sprayed perfectly .I have driven the car 70 miles and disconnected the battery for a half an hour but the fault light was still on.
I did the SRC metering quality test .src lock test and checked the level of the SRC and all ok. Any help would be great .it seems like a software update but when I Audi was contacted i was told there are no software up dates but they are willing to book it in and look at it.
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: Ballinlough Motors
VIN: WAUZZZ4G5EN161217   License Plate: 142 C 4948
Mileage: 166103km-103211mi   Repair Order: DAMIEN CLIFFORD
CODE Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72 AC
VIN: WAUZZZ4G5EN161217   Mileage: 166103km-103211miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FE    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8243
   Revision: 85H23---
   Coding: 0A194012242401080000
   Shop #: WSC 33529 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
   ROD: EV_ECM20TDI01104L906021FE_002.rod
   VCID: 6DDA0836BCAC59277C-8038
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A09F016005F9808B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A70F36ABD623E9FA9-806E
   Part No SW: 4H0 907 064 EG    HW: 4H0 907 064 EG
   Component: BCM2 2.0      H36 0521
   Coding: 03B83046000000000000
   VCID: 72E01B4AAD9286DFA1-8026
   Serial number: 0214000077556001
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 30041400111581
   Coding: 3421090821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 5FC662FE46003BB7FE-800A
   Part No SW: 4H0 907 063 CA    HW: 4H0 907 063 A
   Revision: 12012002    Serial number: 00000001866002
   Coding: 690000108034A7600405008000005F5F0F9D820827080201000004406000
   VCID: 69D27C268044450710-803C
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140415  H37 0080
   Serial number:         140426093358
   Coding: 0045F7
   Serial number: 22587879
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 16 04 2014  00001085
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: F2388927000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061412800321
   Coding: 08C205
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71E21446A094BDC758-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00HUU5Y
   Coding: 3032343631324E303235554A305234473053
   VCID: 3668E75A897ADAFF4D-8062
   Serial number: 3575HRB405N2M1H628UN
   Serial number: 3585HRB400Q50PASHOTT
   Serial number: 3515JRB400K510A0G9SZ
   Serial number: 3525JRB400K510A0IA3E
   Serial number: 3554VRB401G50VKQO97E
   Serial number: 3564VRB401050U86E8VM
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20140509000314
   Coding: 000014
   VCID: 3064D142631EF4CF17-8064
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658060514592019
   Coding: 33A40A0003412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3F86827EA6401BB79E-806A
   Part No SW: 4G5 907 468 C    HW: 4G5 907 468 B
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001342465
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 356AE056947CD1E744-8060
   Serial number: 6369093303
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140226000000000002C0
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA7209UMR5
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 336EDE4E9A08CFD76A-8066
   Component: TSG FA        H03 0507
   Coding: 011C16004001620002080002
   VCID: 47969A9EF690537726-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0025524597
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 3260DB4A6512C6DF61-8066
   Revision: 00002001    Serial number: 0331642391
   Coding: 011B062280B900408320080400010E470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 26
                    Reset counter: 182
                    Mileage: 151912 km
                    Date: 2019.04.24
                    Time: 14:02:06
02616 - Fuel Tank Cap; Unlock
                    Fault Frequency: 26
                    Reset counter: 182
                    Mileage: 151912 km
                    Date: 2019.04.24
                    Time: 14:10:09
   Component: TSG BF        H03 0507
   VCID: 4688979AF19A4A7FDD-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000001059547
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5AC8367C2C99273C-8078
   Part No SW: 4G0 035 192 P    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 RMC Nav Plus  H55 08180818
   Coding: 0101000001415B47082B060301010000010000
   VCID: 2F66D23E7E20EB370E-807A
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06
   Subsystem 2 - Part No: 4G0 919 603 B
   Component: DU6 Basic
   Subsystem 3 - Part No: 4G2 919 710 B
   Component: E380 BDT C7
No Faults Found
   Component: TSG HL        H03 0507
   Coding: 010814004001620002080002
   VCID: 49929CA6E084A50730-801C
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141060503
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B5EC62E4238971722-807E
End-------------------------(Elapsed Time: 04:07)--------------------------
ECU software version is 8243. There is a newer version 8286 for it.
https://vag-flashinfo.de/
If it were mine, I might try one or both of the following Basic Settings:
IDE04567 -- Resetting of SCR tank level detection
IDE04730 -- Reset SCR lock
HOWIE
Ireland
C?ID=62065
Thanks for your replies .I forgot to mention that I had also reset the SRC lock and reset the tank level detection but still no joy. Just wondering Wolfgang are you suggesting to keep driving until it regenerates and it the codes will clear them self's .or should I do a forced regeneration.
HOWIE
Ireland
C?ID=62065
Mileage: Repair Order: AUDI A6 AD
Address 01: Engine (04L 906 021 FE)
08:42:55
IDE00432 Particle filter: time since last regeneration 43509 s
IDE00435 Particle filter: soot mass measured 9.46 g
IDE00436 Particle filter: kilometers since last regeneration 224618 m
IDE01408 Charge limit for field regeneration 22.77 g
IDE01409 Charge limit for service regeneration 40.00 g
IDE03142 Remaining vehicle distance until reducing agent deficiency 547.80 km
IDE05232 Reducing agent fill level 96.61 %
IDE05630 Reducing agent tank fill level indicator: raw value 100.00 %
IDE05865 DPF statistics: soot mass measured at start of regeneration 0.00 g
IDE05867 DPF statistics: soot mass calculated at start of regen 0.00 g
IDE06839-ENG57549 Reducing agent fill level sensor: diag. status-Bits 0-7 0
These are some of the measurement blocks .It shows that the adblue tank is full .My question is the value in km since the last regeneration is off.Is this normal?
Mike@Gendan
Swansea, UK
C?ID=57030
If the reported units are to be believed the distance since regen is shown in meters, so it's only 224km?
HOWIE
Ireland
C?ID=62065
Thanks Mike , I never would have thought the measurement would be in meters.
Mike@Gendan
Swansea, UK
C?ID=57030
Being described as "kilometers since last regeneration" does confuse things somewhat :confused:
VAG does silly stuff like this on occasion. Be glad it's all in metric. Imagine the fun it would be if it were described as "mileage since last regeneration" and the actual units were yards. :D
