Can anyone help with transmission coding for an audi all road
aaron carter
C?ID=231404
Currently the transmission control module is under water and has no communication. Can we fit a second hand unit ? and can someone assist us with the coding required? Please see below:
Tuesday,29,October,2019,15:05:49:63423
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4B55N026517   License Plate: KS05CUA
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
Address 01: Engine        Labels: 059-907-401-AKE.clb
   Part No: 8E0 907 401 J
   Component:  2.5l/4VTEDC G200AG  0006
   Coding: 06006
   Shop #: WSC 01242
   VCID: 2C14D881DEFC882F2B-4B1E
   WAUZZZ4B55N026517     AUZ7Z0E2716863
00534 - Engine Oil Temperature Sensor (G8)
18034 - Powertrain Data Bus
            P1626 - 35-10 - Missing Message from TCU - Intermittent
01318 - Control Module for Injection Pump (J399)
00546 - Data wiring faulty
            35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
Readiness: 1 2 X 0 X
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D66
   Coding: 06457
   Shop #: WSC 02335
   VCID: 4AD8BE197448B61F39-5160
18256 - Please check DTC Memory of Engine Controller
            P1848 - 35-10 -  - Intermittent
18265 - Load Signal
            P1857 - 35-10 - Error Message from ECU - Intermittent
18031 - Powertrain Data Bus
            P1623 - 35-10 - No Communication - Intermittent
01310 - Level Control System Control Module (J197)
            P1626 - 35-00 - Missing Message from TCU
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AP
   Component: A6-Klimavollautomat 0208
   Coding: 00104
   Shop #: WSC 02335
   VCID: 689C64910984640F0F-2586
            57-00 - Electric Circuit Failure
01312 - Powertrain Data Bus
            37-10 - Faulty - Intermittent
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 M
   Component: Airbag 8.4EP        1000
   Coding: 0001106
   Shop #: WSC 02334 785 00200
   VCID: 59FA515591EECD8780-5184
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 H
   Component: Lenkradelektronik   D01
   Coding: 01012
   Shop #: WSC 02334
   VCID: 312AC9F5FADEE5C718-5184
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 J
   Component: KOMBI+WEGFAHRS. VDO D17
   Coding: 04460
   Shop #: WSC 00222
   VCID: 2D12D585E5E681273C-5160
            49-00 - No Communications
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 F
   Component:  - 2C1A1          X060
   Coding: 25500
   Shop #: WSC 02335
   VCID: 48DC84116A44440F2F-513C
7 Faults Found:
            79-00 - Please Check Fault Codes
01400 - Suspension Level Control
            11-00 - Control Limit Not Reached
            79-10 - Please Check Fault Codes - Intermittent
02538 - Function Restriction due to Overload
01577 - Turn-Off due to Over-Temp
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 N
   Component: Zentralverrieg.,DWA D38
   Coding: 06863
   Shop #: WSC 02335
   VCID: 3424C0E105CCD0EF73-4F0C
8 Faults Found:
01366 - Opened Due to Crash Signal
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 - -
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0204
   Coding: 00001
   VCID: 2C14D881DDFC882F2B-4B1E
            07-00 - Signal too Low
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00102
   Shop #: WSC 02334
   VCID: 26002AA9C310B27FFD-50F4
01349 - Alarm via Theft Warning System; Front
            35-00 - -
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00030
   Shop #: WSC 02334
   VCID: 0444502115ECA06F83-4B1E
Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
   Part No: 4B0 035 186 P
   Component: concert II  GRO    0004
   Coding: 02005
   Shop #: WSC 02334
   VCID: 2D12D585E6E681273C-4B00
End----------(Elapsed Time: 04:53, VBatt start/end: 14.3V/14.2V)-----------
NostraJackAss
Coding is not the problem here you need a module.
Vehicle Identification No.WAUZZZ4B55N026517
ModelAudi A6 Av.qu.2,5 TDI
allroad
A6AR
Date of production11.04.2005
Model year2005
Sales type4BH0FZ
Engine CodeBAU
Transmission CodeEYJ
You need this 4Z7-927-156N
https://www.ebay.com/itm/331907104827
Send me old Unit I will hook you up with additional forum discount & unit will be plug and play pre coded and set.
iichel
Eindhoven, NB, NL
C?ID=284912
Usually it's not a problem to fit a second-hand unit, but as you mention, coding it could be tricky.
I'd suggest to get a unit. Then have a look at the label file or use the RT forum/Google to guesstimate a good coding.
Or, even better, leave it all up to the Jack to fix it for you.
