SEAT Leon Mk2 - Setting the Service Reminder Interval back to Flexible Schedule
   #21
GaryM
Oxford, UK
C?ID=226919
That is normal, until you drive some time (normal 500 km).
By doing the manual service reset, using the menu option, you have reset again and system is changed to "Fixed service".
Yes, but what I'm not sure about is where the following adaptation values came from (i.e. what set them):-
  • ESI: oil quality-> poor oil quality
  • (6)-ESI: Coding of Service Interval Extension (SIE)-Oil quality -> poor oil quality
  • maximum value of distance to service -> 15000 km
  • maximum value of time to service -> 372 d
I haven't changed any of those values myself through VCDS. When a manual service reset is done via the MFD/MFA, does it also reset those 4 values to the values shown above? So could those 4 values have been something different before I actually did a manual service reset via the MFD/MFA?
   #22
Yep. Historically, using the buttons on the cluster to reset the service reminder puts the cluster into fixed interval mode.
Keithuk
Stoke on Trent, England
C?ID=122432
When I've had mine dealer serviced from new it always shows poor oil quality. When I serviced mine last year it still show poor oil quality even though I using the recommended oil from my dealer.
   #24
GaryM
Oxford, UK
C?ID=226919
OK, to confirm that I fully understand things correctly, those 4 adaptation parameter values aren't just static reference values stored in the instrument control map, but are actually dynamic values that get changed to some default fixed schedule values (poor oil quality, 15,000 km and 372 days) whenever a service reset is done via the MFD/MFA? Yes or no?
So, to get my car from a fixed service schedule back to its original flexible service schedule, exactly which instrument control map adaptation parameters do I need to set, to what values, and in what order (if that matters)?
   #25
My understanding is, Yes. Caveat: NAR model cars are all on fixed intervals, VW/Audi has never used flexible intervals over here, so I don't have any hands-on experience with this.
I don't have a definitive answer to that. What I would try first is to change (6)-ESI: Coding of Service Interval Extension (SIE)-Oil quality -> good oil quality, then run another map and look to see if that changed anything else.
GaryM
Oxford, UK
C?ID=226919
OK, maybe one of the European members knows for sure and can chip in to clarify this.
It's dark here now so it will probably be at least tomorrow before I try that. I'll take a new copy of the map setting before I change anything so in the worst case I can just set values back to what they were again. I'll report back once I've tried your suggestion.
Thanks.
   #27
GaryM
Oxford, UK
C?ID=226919
Hi Keith,
When this has happened, was your car put on a flexible service schedule by the dealer?
You don't happen to have a log of all your instrument control map parameter values after a dealer service do you? I would very much like to know what values are actually present for the following adaptation parameters immediately after a dealer has set a car to a flexible service schedule:-
It looks like a manual service reset via the MFD/MFA either changes these parameter values dynamically and sets them back to 372 days / 15,000 km (assuming they were previously set to some larger values when the car was in a flexible service schedule), or those parameter values always just remain static at 372 days / 15,000 km and are only ever referenced and used if the car is in set to a fixed service schedule (i.e. so in a flexible service schedule mode those values may just be ignored and the data from the TOG sensor used to determine the days / km values to the next service schedule instead).
If someone has a log of those values immediately after a service reset has been done for a flexible service schedule with a dealer VAS machine then we would know for sure.
   #28
GaryM
Oxford, UK
C?ID=226919
Uwe - You were correct :D
I changed the "(6)-ESI: Coding of Service Interval Extension (SIE)-Oil quality" adaptation parameter value to "good oil quality" and I now have the dashes / hyphen status of "Service in --- mi or --- days." in my MFD/MFA service interval display so it looks like I am back to a flexible long life service schedule again. I guess the TOG sensor will now start to do its work by analysing the oil and I should then see some real values displayed in ~300 miles or so.
Following that single parameter change, this is what my instrument cluster adaptation parameter values are now:-
;SW:1P0-920-950-K   HW:1P0-920-950-K ---  Instruments
;Component:KOMBI         H05 0607, Coding:410F01
;EV_Kombi_UDS_VDD_RM09,A04114,EV_Kombi_UDS_VDD_RM09_SE25.rod
;Sunday,18,January,2015,13:00:47:55895
;VCDS Version: Release 14.10.0 (x64)  Data version: 20141022
;VCID: 3561048F949B21898CD-8060
Activating and deactivating all development messages,not active
(1)-Additional coding-Speed source,via CAN
(2)-Additional coding-Coolant temperature source,via CAN
(3)-Additional coding-Tank characteristic curve,1
(4)-Additional coding-Number of fuel level sensors,1
(5)-Additional coding-Locking bit,locked
Automatic door locking,Yes
Cruise control display,not active
Display correction of consumptions and operating range,100 %
Display correction of fuel gauge,0.0
Display depiction,Not available
Distance,27880 km
(1)-Emergency telephone number-Telephone number,
(2)-Emergency telephone number-Status,not active
(3)-Emergency telephone number-Preselection,
(1)-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SID on
(2)-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI)
(3)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation
(4)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure
(5)-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver
(6)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality
(7)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster
ESI: distance driven from inspection,0 km
ESI: maximum value km-driving distance/inspection,30000 km
ESI: maximum value of time between inspections,744 d
ESI: minimum value km-driving distance/inspection,15000 km
ESI: minimum value of time between inspections,744 d
ESI: oil quality,good oil quality
ESI: Resetting ESI,Reset
ESI: soot entry,0 km
ESI: thermal load,0 km
ESI: time from inspection,5 d
Hour,13 H
Indicator light for start-stop operation,active
Language version,English
Minute,3 min
Pause recommendation,Yes
Seat belt warning,Version 4
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,OFF
(6)-Service-key settings-p_main_switch_basis,OFF
Speed threshold of dynamic oil pressure warning,kein Offset
Staging,active
(1)-Units adjusted-Temperature,°C
(2)-Units adjusted-Distance,miles
(3)-Units adjusted-Speed,Miles per hour
(4)-Units adjusted-Pressure,bar
(5)-Units adjusted-Volume,gallons (UK)
(6)-Units adjusted-Time,24h
(7)-Units adjusted-Date,dd_mm_yy
(8)-Units adjusted-Consumption,Miles per gallon (UK)
Volume to be replenished,No
Service_Key_Clear_All_Counters,Yes
Twindrive,not active
So by changing just that one parameter value, all of the adaptation parameter changes below have automatically occurred...
The following 2 parameters are now showing "good oil" for their values:-
  • (6)-ESI: Coding of Service Interval Extension (SIE)-Oil quality -> good oil quality
  • ESI: oil quality -> good oil quality
The following 2 parameters/values have disappeared completely:-
  • SIA: maximum value of distance to service -> 15000 km
  • SIA: maximum value of time to service -> 372 d
The following 4 parameters/values are new ones that have appeared:-
  • ESI: maximum value km-driving distance/inspection -> 30000 km
  • ESI: maximum value of time between inspections -> 744 d
  • ESI: minimum value km-driving distance/inspection -> 15000 km
  • ESI: minimum value of time between inspections -> 744 d
Many thanks to the contributors of this thread for helping me to get this sorted out :thumbs:
   #29
GaryM
Oxford, UK
C?ID=226919
Just to conclude this, I've now put up a step-by-step screenshot guide in the following post which shows how to use VCDS to switch to a flexible long life service schedule. Hopefully this will be of some use to anyone else who ends up in the same situation as I did...
   #30
Thanks Gary! I was looking at those SIA values in my Tiggy map compared to your ESI values but I wasn't real sure about the oil quality. I added this to the Special Notes on that Golf based cluster page.
GaryM
Oxford, UK
C?ID=226919
Just reporting back to say that this issue is now fully concluded.
Today the service status in my MFD started displaying real longlife service schedule figures again which is roughly ~350 miles since the dealer did the original service reset (before I screwed the service interval up). So I'm now happy that the longlife service reset fix done with VCDS has proved to have worked successfully :)
   #32
m_bolc
San José, Costa Rica
C?ID=230356
I have a doubt to clear on this topic.
My car has the appropriate QG1 code on the build sheet, but the dealer set it to a fixed 8000km/9 month interval for service.
When I change the "Oil quality" adaptation channel I can verify in the MMI that the oil change interval changes to 30000km (minus covered distance). The inspection interval is not updated. Is that because the "FIX" maximum distance is at 8000km? How long are the oil service intervals on these things? 30 thousand km is too much for my peace of mind.
Auto scan for reference:
Thursday,24,March,2016,20:28:01:29892
VCDS Version: 16.3.0.0 (x64)
Data version: 20160216
VIN: WAUZZZ8V7H1000288   License Plate: TRS456
Mileage: 552km-342mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V7H1000288   Mileage: 552km-342miles
Address 01: Engine (J623-CYVB)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 GR    HW: 04E 907 309 BL
   Component: R4 1.2l TFS   H23 2394
   Revision: R4H23---
   Coding: 02250012230400082000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
   ROD: EV_ECM12TFS01104E906027GR.rod
   VCID: 7AFBDCC3FDAB9DECE1-802E
   Part No SW: 0CW 300 048 K    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0614
   Revision: 00005005    Serial number: CU501512106812
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021.rod
   VCID: 4487623BCFEF1B1CCB-8010
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63625000001935
   Coding: 13F16AA22420126C0179060841CB25C8562448806082A4B2002100348208
   VCID: 79F9C3CFF8AD96F4E8-802C
Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000187281
   Coding: 03000004100000000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 377D05F78E3940845E-8062
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [008] -  -
                    Reset counter: 63
                    Mileage: 436 km
                    Date: 2016.03.22
                    Time: 19:28:12
                    Voltage terminal 30: 12.0 V
                    Compressor shut-off requirement: Shut-off from Engine Control Module (ECM) via CAN
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061533701281
   Coding: 04041A42C041227D03A04004B10807000000000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 0919B30FA84D8674F8-805C
   Slave 1:
   Component: WWS371 151118  043 0585
   Serial number:         151126161111
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0004
   Serial number: 50030281
   Coding: 06885D
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
   Serial number: 17 10 2015  00000327
   Serial number: 000000000ZY153154N42
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064431957
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39291534203226
   Coding: 0000050011
   ROD: EV_EPHVA14AU3700000_AU37.rod
   VCID: 3C771ADBB71F63DCB3-8068
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    015 0388
   Serial number: 003MMR1BC5J-
   Coding: 98CCC000000000005C540000004800000065
   VCID: 000FAE2B9B77C73CAF-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 001 812 15
   Serial number: 357670000001F741381P
   Subsystem 2 - Part No SW: -----------    HW: 480 001 812 15
   Serial number: 358670000007A741381R
   Subsystem 3 - Part No SW: -----------    HW: 480 402 811 15
   Serial number: 3516502B11E34435E21%
   Subsystem 4 - Part No SW: -----------    HW: 480 403 011 15
   Serial number: 3526502C91E2431261B3
   Subsystem 5 - Part No SW: -----------    HW: 480 401 509 15
   Serial number: 3556502C71CF2D82920N
   Part No SW: 8V0 953 521 EM    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 10121504221033
   Coding: 8018
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_AU37.rod
   Part No SW: 8V0 920 860 N    HW: 8V0 920 860 N
   Component: KOMBI         H03 6423
   Coding: 07841A082B8000080500BA001000000000000000
   VCID: 45817F3FC4D52214DC-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 10121510800534
   Coding: 01010008300864005B000208100B00000001010000000000000000000000
   ROD: EV_GatewConti.rod
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 11 12 2015  A0038721
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 181015BJH00562
   Coding: 00100A204100040000001002
   VCID: 41896B2FD0FD0E34E0-8014
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811
   Serial number: 00000000000008171337
   Coding: 110000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0502
   ROD: EV_SteerAssisMQB_VW37.rod
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 111015BJA06371
   Coding: 001002204D00040000001002
   VCID: 408F6E2BDBF7073CEF-8014
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812
   Serial number: 00000000000008176200
   Coding: 090000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 010A000001000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   VCID: 75E1CFFFD4B5F2948C-8020
   Part No SW: 8V0 035 840 C    HW: 8V0 035 840 B
   Component: MU-S--ER      042 0461
   Serial number: A3E01212150142
   Coding: 01730100FF0A000021220001001A00002F0001040100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 35610FFF9435B2944C-8060
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30F2K3
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: ALJAL111111500010126
End-------------------------(Elapsed Time: 03:37)--------------------------
Address 09:5Q0 937 084 AS recoded (ADP-(8)-Leuchte27NSL RC6-Lichtfunktion C 27) from Bremslicht  to nicht aktiv
Address 09:5Q0 937 084 AS recoded (ADP-(10)-Leuchte27NSL RC6-Dimmwert CD 27) from 100  to 0
Address 09:5Q0 937 084 AS recoded (ADP-(8)-Leuchte26NSL LA72-Lichtfunktion C 26) from Bremslicht  to nicht aktiv
Address 09:5Q0 937 084 AS recoded (ADP-(10)-Leuchte26NSL LA72-Dimmwert CD 26) from 100  to 0
Address 09:5Q0 937 084 AS recoded (ADP-(16)-Leuchte2SL VLB10-Lichtfunktion G 2) from Blinken links aktiv (beide Phasen)  to Blinken links Hellphase
Address 09:5Q0 937 084 AS recoded (ADP-(16)-Leuchte3SL VRB21-Lichtfunktion G 3) from Blinken rechts aktiv (beide Phasen)  to Blinken rechts Hellphase
Address 09:5Q0 937 084 AS recoded (ADP-(16)-Leuchte3SL VRB21-Lichtfunktion G 3) from Blinken rechts Hellphase  to Blinken rechts aktiv (beide Phasen)
Address 09:5Q0 937 084 AS recoded (ADP-(16)-Leuchte2SL VLB10-Lichtfunktion G 2) from Blinken links Hellphase  to Blinken links aktiv (beide Phasen)
Address 09:5Q0 937 084 AS recoded (Long Coding) from 04041A42C041227D03A04004B10807000000000000000000000000000000 to 04041A42C041227D07A04004B10807000000000000000000000000000000  (06385/790/00016)
Address 44:5Q0 909 144 S recoded (ADP-Characteristic curve of steering assistance) from Dynamic  to Driving profile selection button
Address 44:5Q0 909 144 S recoded (Long Coding) from 0502 to 8502  (06385/790/00016)
Address 5F:8V0 035 840 C recoded (ADP-(86)-Vehicle menu operation-menu_display_charisma) from not activated  to activated
Address 5F:8V0 035 840 C recoded (ADP-(89)-Vehicle menu operation-menu_display_charisma_standstill) from not activated  to activated
Address 5F:8V0 035 840 C recoded (ADP-(45)-Vehicle function list BAP-charisma_0x17) from not activated  to activated
   #33
GaryM
Oxford, UK
C?ID=226919
It would be useful if you posted a complete log of the adaptation map for your instrument cluster so we can see what all the current settings are for your car.
Ironically, since I went through all this a year ago I've had a change of mind. Coincidentally my car is in for its service today and I've asked them to switch the car onto a fixed service interval.
m_bolc
C?ID=230356
Sorry to bring this back from the dead.
After my last fixed service at 16000km I set my car to "Good oil quality" and a maximum of 15000km of service life. Right now the car is only subtracting the covered distance from the time remaining to inspection.
Is this because I set too short of a service interval on my car? Or am I somehow still running a fixed interval?
Here's my controller channel map:
;SW:8V0-920-860-N   HW:8V0-920-860-N ---  Instruments
;Component:KOMBI         H03 6423, Coding:07941A082B8000080500A8001000000000000000
;EV_DashBoardVDDMQBAB,009051,EV_DashBoardVDDMQBAB_009_AU37.rod
;Sunday,26,February,2017,18:40:13:29892
;VCDS Version: Release 17.1.3 (x64)  Data version: 20170203 DS267.2
;VCID: 45817F3FC4D522699A-8010
IDE00301-Distance,22259 km
IDE00342-ESI: Resetting ESI,Warning active
IDE00343-Language version,Spanish (US)
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,18 H
IDE00501-Minute,45 min
IDE00502-Year,2017 yr
IDE00503-Month,2 mon
IDE00504-Day,26 d
IDE00510-ESI: distance driven from inspection,6810 km
IDE00511-ESI: time from inspection,98 d
IDE00512-ESI: minimum value km-driving distance/inspection,8000 km
IDE00513-ESI: maximum value km-driving distance/inspection,15000 km
IDE00514-ESI: maximum value of time between inspections,270 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,0 km
IDE00518-ESI: thermal load,9500 km
IDE00819-Day counter,405 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,180 d
IDE01153-SIA: maximum value of distance to service,15000 km
IDE01154-SIA: maximum value of time to service,270 d
IDE02489-Display depiction,Not available
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
IDE03329-Driving profiled for range remaining,7.4 l/100km
IDE03346-IDE00301-Units adjusted-Distance,Kilometers
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM
IDE03346-MAS03032-Units adjusted-Volume,Liter
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km
IDE03346-MAS13665-Units adjusted-Anhänge-/Stützlast Masse,Kilogramm (kg)
IDE03348-MAS01456-Speed warning-Speed,20
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour
IDE03348-IDE03348-Speed warning-,not active
IDE03349-FIX: Max. distance until next mileage-related inspection,15000 km
IDE03350-FIX: Maximum time until next time-dependent inspection,270 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,6800 km
IDE03352-FIX: Time since last time-dependent inspection,98 d
IDE03372-Source for synchronization of time,internal clock
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE04169-Display correction of consumption and operating range: gas,100 %
IDE05930-Service notification in days,232 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,8000 km
IDE05932-FIX: Reset value for next time-dependent inspections,270 d
IDE05971-Vehicle Positioning System Interface Control Module,not installed
IDE06425-Roller test bench mode: functional,not activated
IDE06588-Ignition active message: actuator,Driver door
IDE06922-No-voltage display,No display
IDE07221-Cylinder shut-off,Display
IDE08140-Driving profiled for range remaining CNG,6.0 kg/100 km
IDE08247-Driving profile for range remaining LPG,10.0 l/100km
IDE11086-Service notification,30 d
MAS03685-Digital speedometer,Display
ENG117917-BAP_Debug_Mode_Release,not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
ENG119875-defuel_threshold,45 l
ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC
ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,03
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,03
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C
ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,6E
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,82
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,AA
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,05
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,14
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,50
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,04
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,04
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,40
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,52
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5F
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,64
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,96
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,08
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,08
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,64
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,64
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,64
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,64
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,96
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0A
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0A
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,32
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,5F
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,64
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,03
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,03
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,19
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,28
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
ENG119874-Gas_functionality,not active
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds
ENG119882-init_fuel_algorithm,No
ENG130585-Leaving_warning_delay,1.6 s
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 km/h
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 s
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 s
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0
ENG119825-Picture_Upload_Download,not active
ENG119876-Service_Key_Clear_All_Counter,Yes
ENG130584-Statistic_phev_mileage,5 km
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 ms
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,0 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,0 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.5
ENG109442-ENG103975-time_parameter_display-tDD15_on,1.0
ENG109442-ENG100026-time_parameter_display-tDDWUP,1.0
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN
ENG112418-ENG99298-total_range_gas-State,not active
   #35
"Inspection" intervals are not flexible. Only "Service" intervals are. "Inspection" and "Service" are not the same thing.
m_bolc
C?ID=230356
Duly noted - it still is just subtracting the covered distance from 15000 km for both indicators.
How do I get a flexible oil change service programmed in there then? is 15000km too short of a distance? Should I try with a longer service interval?
