VW sharan 7N, tweak advice needed
istenica
Slovenia
C?ID=81583
Hello
I would like to to some configuration changes in my sahran:
- is it possible to have active Auto hold, but disabled Electrical Parking Brake engaging when leaving the car and gear selector is in P position. I want the car to be hold still when stopped, but when it is parked I do not want to engage parking brake automatically (in garage etc.),
- is it possible to have disabbled EPB auto engage at running engine and opened door with gear selector NOT in position P,
- is it possible to enable that climate, seat heating settings etc. beeing shown in 5F-Information Electronic as it is possible in sharan MY2015 with component 56-Radio installed.
Thanks for your support
Saturday,26,October,2019,12:35:44:38184
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZ7NZHV239484   License Plate:
Mileage: 33490km-20809mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 25 2B 36 3C 42 44
          46 4C 52 53 55 5F 61 62 69 6C 6D 72 BE BF
VIN: WVWZZZ7NZHV239484   Mileage: 33490km-20809miles
18-Aux. Heat -- Status: Sporadic communication error 1000
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DFMA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 JD    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 1999
   Revision: 8AH20---
   Coding: 0125003A047619083000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01104L906016JD 004002
   ROD: EV_ECM20TDI01104L906016HD_004_VW36.rod
   VCID: 74EC3508DF2E07EFB3-8020
   Part No SW: 0BH 300 013 D    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5301
   Revision: 00H11V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 254A184C24742E67F4-8070
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CM    HW: 5N0 614 109 CM
   Component: ESC-EBC460iV1 H14 0014
   Serial number: A01PPV8
   Coding: 12F0449A4923C275087B480822C7924310394FF8500B4995
   Shop #: WSC 22368 002 1048576
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 78F40138C346638F9F-802C
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1308
   Revision: 00093000    Serial number: 0438516612
   Coding: 03300C
   Shop #: WSC 00020 999 39850
   VCID: 3A70DB30BDCAB19FA9-806E
   Part No SW: 7N0 907 044 BC    HW: 7N0 907 044 BC
   Component: Clima-Sharan  H04 0606
   Revision: 00001K06
   Coding: 0210004449
   Shop #: WSC 00020 999 12345
   VCID: 72E03310A53A09DFA1-8026
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0184
   Revision: BC122001
   Coding: 40590A3FCD33E1C0508804C0B10009FC03FD0008672D2FB2E4848720A2C1
   VCID: 458AB8CCCC34CE67D4-8010
   Subsystem 1 - Part No SW: 7N1 955 119 B    HW: 7N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 220317  024 0644
   Serial number: 17031703019651
   Coding: 004DBD
   Component: RLHS  042 0105
   Serial number: S6Y17M04D12H10M21S09
   Coding: 0228BB
Address 10: Park/Steer Assist (J791)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475 E    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0005
   Serial number: 000305183617096
   Coding: 0071167251
   ASAM Dataset: EV_EPHVA3CVW428GP00 001005
   ROD: EV_EPHVA2CVW428GP00.rod
   VCID: 3D7AD02CACE486A78C-8068
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 06041704403485
   Coding: 00001900FE0739
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3668CF0089D255FF4D-8062
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag11M H15 0016
   Serial number: 003PWP6Q7JKY
   Coding: 00314D
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 4084A9D8DB16EB4FE7-8014
   Serial number: 3493ETS60ABC45D1D9DF
   Serial number: 3503ETS602EDD601DDD4
   Serial number: 3513ETS600781601D9DI
   Serial number: 3523ETS60A76C5D1DDDB
   Serial number: 35540TS606AA0541D9DM
   Part No SW: 5K0 953 501 EL    HW: 5K0 953 569 AN
   Revision: FF010042    Serial number: 20170404200405
   Coding: 1112C40008
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 0811707095100700AE1B
   Coding: 2D0000
   Part No SW: 7N0 920 880 L    HW: 7N0 920 880 L
   Component: KOMBI         H04 1109
   Coding: 110F010800
   VCID: 3C7CDD28B7FE8FAFBB-8068
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   Shop #: WSC 00020 790 00000
   VCID: 3874C1384BC6A38F5F-806C
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 060417F1000274
   Coding: 468032
   VCID: 7BFE1E34FA704897F2-802E
                    Fault Status: 00110100
                    Reset counter: 120
                    Mileage: 33266 km
                    Date: 2019.10.19
                    Time: 08:15:01
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00007.03.17
   Coding: 0401
   VCID: 52A09390057A69DF41-8006
   Component: IMMO          H04 1109
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD02B708DEAC11F19-803E
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 17000096980001
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3162FC1C60BC72C718-8064
   Part No SW: 3C8 959 760 F    HW: 3C8 959 760 F
   Component: Sitzmemory    H03 1301
   Revision: 00H03000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 3874C1388BC6A38F5F-806C
01902 - Lumbar Support Fore / Aft Adjustment Motor (V230)
                    Fault Status: 00101011
                    Reset counter: 43
                    Mileage: 25418 km
                    Date: 2019.07.09
                    Time: 18:00:24
   Serial number: 0436784372
   Coding: 02012102
   ROD: EV_HREntryHella_VW32.rod
   Lane Change Assistant 2:
   Serial number: 0436177911
   Coding: 020121
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000250008183
   Coding: 01152E20DE00411001
   VCID: 4992B4FCE02C2A0730-801C
   Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
   Component: J500__APA-BS KL.326 1501
   Revision: 1BH04741    Serial number: 00170730193101
   Coding: 0000258
   VCID: 4280A3D01D1AF95FF1-8016
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000250046240
   Coding: 01152C20DE00411001
   VCID: 4894B1F8FB26D30F2F-801C
   Component: AFS-ECU       H05 0111
   Coding: 058A00000B000200
   VCID: 3776C2048ED8ACF756-8062
   Subsystem 1 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
   Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
   Component: MU-S-ND-ER    H31 0363
   Serial number: VWZAZ2T5165726
   Coding: 02240801FF0000001111110100880A001F01008400200100CF
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 234E06542A40D0579A-8076
   Subsystem 1 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
   Component: Batt.regelung H56 1682
   Coding: 330F7873
   VCID: 71E23C1CA83C32C758-8024
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 34088H15285831216223
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H03 0561
   Revision:             Serial number: 0000245909235
   Coding: 01006C200000411001
   VCID: 4C9C8DE8EF5E3F2F0B-8018
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383 A    HW: 7N0 907 383
   Component: Anhaenger     H12 0130
   Revision: 3I001001    Serial number: 00000435992700
   Coding: 410C040003000000
   VCID: 346CF50897AE47EF73-8060
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012301000700
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 3064F9186BB67BCF17-8064
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H12 0250
   Revision: 41012001    Serial number: 081701523
   Coding: 0733334003
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B7EDE34B2F08897B2-806E
   Component: TSG HR        H03 0561
   Revision:             Serial number: 0000245908246
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 17112824
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 3874C13883C6A38F5F-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 17112951
   ROD: EV_AST.rod
siLc
Tallinn, Estonia
C?ID=330192
With address 5F radio, climate display is no longer available. With older address 56 radios it still should be available. Though I wouldn't go downgrading my radio for this :)
istenica
Slovenia
C?ID=81583
Thanks for answer. Do you maybe have answers on other questions, regarding auto hold/EPB?
Another question is, is it possible to show traffic signs from navigation system on MFD? Car does not have traffic sign assist/front camera.
