Hi, I did post before but nobody could help so I thought I’d try a new post with different question. I think to get security access to allow adaptions in the C7 MMI I need a custom label file or something to decode the security access code? As VCDS doesn’t suggest the code like most modules. Can anyone help? Auto scan below:
Monday,30,September,2019,13:55:59:64533
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ4G7HN021528 License Plate: L21NCS
Mileage: 95100km-59092mi Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 5F 62 6D
72 AC
VIN: WAUZZZ4G7HN021528 Mileage: 95100km-59092miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FQ HW: 04L 907 309
Component: R4 2,0L EDC H23 1649
Revision: 85H23---
Coding: 12254012242401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
ROD: EV_ECM20TDI01104L906021FQ_002.rod
VCID: 79F90A16F8254787DE-802C
11913 - Start/Stop System; Maximum Time for Restart Exceeded
P167E 00 [096] - -
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G1 927 153 B HW: 0CK 927 156 AA
Component: 0CK 20TDI RdW H04 0002
Revision: --H04--- Serial number: 0000000003
Coding: 100001
ASAM Dataset: EV_TCMDL382021 002020
ROD: EV_TCMDL382021_AU57.rod
VCID: 29591A5648053707EE-807C
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 K
Component: V553 MTFP 002 0572
Serial number: 75117071160173000661
22307 - Oil Pressure Reservoir
P187E 00 [032] - No Pressure
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 06A29E41604579829B00
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 4189A2F6D075DF47D6-8014
Part No SW: 4H0 907 064 HN HW: 4H0 907 064 HN
Component: BCM2 2.0 H61 0824
Coding: 01B9704E000000000000
VCID: 7CF71302FF1772AFC5-8028
Serial number: 3216000128529004
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0113
Serial number: 28061600041957
Coding: 34A209B8210000
VCID: 63C5487E6AA9AD57E4-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 15020001 Serial number: 00001405641901
Coding: 2600001400349FE00181408300001D0C0F9DC60827090201000008206100140200400024030000
VCID: 74E73B22D7473AEF8D-8020
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 160515 H38 0080
Serial number: 160527174034
Coding: 0045F7
Component: G397_RLFS H06 0004
Serial number: 61987694
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 23 06 2016 00000744
Subsystem 4 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: E209473800PAG0MUFU03
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P100AE6N$
Coding: 30333130313630323639554A305234473053
VCID: 3B75D01EB299B5978C-806E
Serial number: 3575HRB406344QFU4HR0
Serial number: 3585HRB400C55CG050SY
Serial number: 3515JRB4012571N6G9U3
Serial number: 3525JRB400S570QGMHH%
Serial number: 3554VRB401A55B78M1QE
Serial number: 3564VRB401I55B7891VF
Revision: -------- Serial number: 90372PFO00094
Coding: 000435
VCID: 387FCF128BAF9E8F61-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 15 04 2016 F0051854
Part No SW: 4G8 920 951 E HW: 4G8 920 951 E
Component: MDieGb H43 0604
Revision: 30450307 Serial number: 658300616592005
Coding: 33A715000B412600010000
ASAM Dataset: EV_RBC7KMID 004050
ROD: EV_RBC7KMID.rod
VCID: 326BFD3A65D374DF5F-8066
Part No SW: 4G5 907 468 G HW: 4G5 907 468 C
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002293271
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 002000
VCID: 3979CA16B8A587879E-806C
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Serial number: 8104520504
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663 D
Component: J532_DCDCStab H23 0022
Serial number: 16041600000000000272
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 29061600040572
Coding: 22
VCID: 3E73D90AA18BA0BFAB-806A
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720S0WJ$
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3365F83E9AC97DD754-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0511
Coding: 011C16015C01620002080002
VCID: 479DBCEEF651E17718-8012
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000002 Serial number: 0000050439
Coding: 101000010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A7BD51ABDA38C9F97-806E
Revision: 00002001 Serial number: 0410098456
Coding: 013B0620A0B930808320098400010F470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00022690267
Component: TSG BF H03 0511
Coding: 011C16015E01620002080002
VCID: 4683B1EAF15BF87FE3-8012
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001900463
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_VW51.rod
VCID: 3169F23660D54FC726-8064
Address 5F: Information Electr. (J794) Labels: Redir Fail!
Part No SW: 4G1 035 192 C HW: 4G1 035 192 A
Component: RMC Nav Plus H62 0170
Coding: 0101010001415B47080B060301010000000000
VCID: 2345087E2229ED57A4-8076
Subsystem 1 - Part No: 8X0 919 884 J
Component: P32-50-15.03 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464E00G2762781
Subsystem 3 - Part No SW: 4G2 919 610 E HW: 4G2 919 610 E
Component: E380 BDT C7 H20 0250
Serial number: 90349PFO00036
Component: TSG HL H03 0511
Coding: 010814004001620002080002
VCID: 4999BAD6E04517070E-801C
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 165601097
Coding: 093205C010
ROD: EV_HDSGAu571.rod
VCID: 3663C12A89BB68FF73-8062
Component: TSG HR H03 0511
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 161530640
ROD: EV_RDCMA00100_008.rod
VCID: 2F6DF44E76E1593730-807A
End-------------------------(Elapsed Time: 04:22)--------------------------
