Audi A6 C7 custom label file for security MMI access
endacy
England
C?ID=125876
Hi, I did post before but nobody could help so I thought I’d try a new post with different question. I think to get security access to allow adaptions in the C7 MMI I need a custom label file or something to decode the security access code? As VCDS doesn’t suggest the code like most modules. Can anyone help? Auto scan below:
Monday,30,September,2019,13:55:59:64533
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ4G7HN021528   License Plate: L21NCS
Mileage: 95100km-59092mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 42 44 46 52 53 5F 62 6D
          72 AC
VIN: WAUZZZ4G7HN021528   Mileage: 95100km-59092miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1649
   Revision: 85H23---
   Coding: 12254012242401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79F90A16F8254787DE-802C
11913 - Start/Stop System; Maximum Time for Restart Exceeded
          P167E 00 [096] - -
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
   Part No SW: 4G1 927 153 B    HW: 0CK 927 156 AA
   Component: 0CK 20TDI RdW H04 0002
   Revision: --H04---    Serial number: 0000000003
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002020
   ROD: EV_TCMDL382021_AU57.rod
   VCID: 29591A5648053707EE-807C
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  002 0572
   Serial number: 75117071160173000661
22307 - Oil Pressure Reservoir
          P187E 00 [032] - No Pressure
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 4189A2F6D075DF47D6-8014
   Part No SW: 4H0 907 064 HN    HW: 4H0 907 064 HN
   Component: BCM2 2.0      H61 0824
   Coding: 01B9704E000000000000
   VCID: 7CF71302FF1772AFC5-8028
   Serial number: 3216000128529004
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 28061600041957
   Coding: 34A209B8210000
   VCID: 63C5487E6AA9AD57E4-8036
   Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0368
   Revision: 15020001    Serial number: 00001405641901
   Coding: 2600001400349FE00181408300001D0C0F9DC60827090201000008206100140200400024030000
   VCID: 74E73B22D7473AEF8D-8020
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 160515  H38 0080
   Serial number:         160527174034
   Coding: 0045F7
   Serial number: 61987694
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 23 06 2016  00000744
   Subsystem 4 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: E209473800PAG0MUFU03
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P100AE6N$
   Coding: 30333130313630323639554A305234473053
   VCID: 3B75D01EB299B5978C-806E
   Serial number: 3575HRB406344QFU4HR0
   Serial number: 3585HRB400C55CG050SY
   Serial number: 3515JRB4012571N6G9U3
   Serial number: 3525JRB400S570QGMHH%
   Serial number: 3554VRB401A55B78M1QE
   Serial number: 3564VRB401I55B7891VF
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372PFO00094
   Coding: 000435
   VCID: 387FCF128BAF9E8F61-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 15 04 2016  F0051854
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 30450307    Serial number: 658300616592005
   Coding: 33A715000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 326BFD3A65D374DF5F-8066
   Part No SW: 4G5 907 468 G    HW: 4G5 907 468 C
   Revision: --------    Serial number: 00000002293271
   Coding: C0CD074418
   VCID: 3979CA16B8A587879E-806C
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 8104520504
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 16041600000000000272
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0113
   Serial number: 29061600040572
   Coding: 22
   VCID: 3E73D90AA18BA0BFAB-806A
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720S0WJ$
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3365F83E9AC97DD754-8066
   Component: TSG FA        H03 0511
   Coding: 011C16015C01620002080002
   VCID: 479DBCEEF651E17718-8012
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000050439
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A7BD51ABDA38C9F97-806E
   Revision: 00002001    Serial number: 0410098456
   Coding: 013B0620A0B930808320098400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00022690267
   Component: TSG BF        H03 0511
   Coding: 011C16015E01620002080002
   VCID: 4683B1EAF15BF87FE3-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000001900463
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 3169F23660D54FC726-8064
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 192 C    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H62 0170
   Coding: 0101010001415B47080B060301010000000000
   VCID: 2345087E2229ED57A4-8076
   Subsystem 1 - Part No: 8X0 919 884 J
   Component: P32-50-15.03  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464E00G2762781
   Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
   Serial number: 90349PFO00036
   Component: TSG HL        H03 0511
   Coding: 010814004001620002080002
   VCID: 4999BAD6E04517070E-801C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 165601097
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 3663C12A89BB68FF73-8062
   Component: TSG HR        H03 0511
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 161530640
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F6DF44E76E1593730-807A
End-------------------------(Elapsed Time: 04:22)--------------------------
TBAx
C?ID=287144
The redirect fails. Possibly, because the label file is non-existant or the like.
Maybe this will help you in the mean time:
https://ufile.io/imjfqo22
Content:
REDIRECT,4G1-035-MIB-HGH2.CLB,4G1-035-192-???
Place it in your C:\Ross-Tech\VCDS\Labels\User directory (assuming default installation).
This will redirect your unit to the 4G1-035-MIB-HGH2.CLB, which by now should offer the S12345 login code. I however am not sure, this login works. You can as well try the common 20103.
Deo
Cracow, Poland
C?ID=377181
Hi, TBAx
Can you re-upload this label?
TBAx
C?ID=287144
@Deo - which module do you have? Is it an 4G1 035 192 as well?
Deo
Cracow, Poland
C?ID=377181
@TBAx - no, I have the following 5F module
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
  Part No SW: 4G1 035 043 M    HW: 4G1 035 043
  Component: MU-H-N-EU     042 1425
  Serial number: A591J0F7545122
  Coding: 017501010000000013110002000A00032F0006E5F17001009F
  VCID: 285F4DA753F3120FCF-807C
  Subsystem 1 - Part No SW: V03 959 802 TL    HW: -----------
  Component: ECE 2020/2021  --- 0187
  Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
  Component: DU8 C7 SV  H63 0007
  Serial number: AUZ8Z9FY80338R
  Multimedia Operating Unit:
  Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
  Serial number: 90349OJ8000X7
  Compact Disc Database:
  Component: Gracenote  --- 1010
TBAx
C?ID=287144
Hi. As of now you can simply update your VCDS to 20.12 and the login should be available.
