I have this errors on CLIMATRONIC but I don't find anything on ross-tech fault codes list !!!
Is possible to explain me what SERVOMOTOR is broken because on the RIGHT SIDE I have no heat .
In fact I do not have heat on the ventilation grille from the door, but instead gives little heat on the middle one on the right side of the clock on board !!!
I understood from the ETKA program that Passat B8 have following SERVOMOTORS :
Pos. No.17 in ETKA
5Q0898141B or C = Adjuster unit
Pos. No.18 in ETKA
5Q0907511A = Servomotor
Pos. No.21 in ETKA
3Q0898141 = Adjuster unit
Pos. No.23 in ETKA
5Q0898511 = Control motor for temperature regulating flap
Pos. No.24 in ETKA
Pos. No.25 in ETKA
5Q0898511A = Control motor for temperature regulating flap
Pos. No.26 in ETKA
Pos. No.30 in ETKA
3Q0898141A = Adjuster unit
Pos. No.32 in ETKA
3Q189814 and 3Q2898141 = Adjuster unit
Pos. No.46 in ETKA
As you can see the code 5Q0907511A is identical to positions 18/24/26/46.
Now, which of these codes are on the left and which on the right I can only guess after the ETKA call.
But I don't know which piece is the defective one !!!
I be very grateful if, somebody tell me to which of them the three SERVOMOTORS refers to these two errors !!!
Thanks .
Pos. No.17 in ETKA
Pos. No.18 in ETKA
Pos. No.21 in ETKA
Pos. No.23 in ETKA
Pos. No.24 in ETKA
Pos. No.25 in ETKA
Pos. No.26 in ETKA
Pos. No.30 in ETKA
Pos. No.32 in ETKA
Pos. No.46 in ETKA
Part No SW: 5G1 907 044 B HW: 5G1 907 044 B
Component: Climatronic H03 1001
Revision: 00001K10
Coding: 11020114202100012115504E00101102
Shop #: WSC 00015 115 08193
ROD: EV_ACClimaBHBVW37X_003_VW48.rod
VCID: 2708F3519F625D7FAB3-8072
Air quality sensor:
328198 - Position Sensor for Right Temperature Flap Motor
B1095 11 [008] - Short to Ground
Reset counter: 106
Mileage: 62384 km
Date: 2019.03.19
Time: 11:20:22
Voltage terminal 30: 14.4 V
Outside air temperature: 18.0 °C
Interior temperature: 26.7 °C
Right temperature flap: actual value: 0.0 %
Right temperature flap: actual value: 109
Right temperature flap: specified value: 109
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [008] - Open or Short to Plus
Reset counter: 106
Mileage: 62378 km
Date: 2019.03.19
Time: 10:33:35
Voltage terminal 30: 14.6 V
Outside air temperature: 13.5 °C
Interior temperature: 21.2 °C
Right temperature flap: actual value: 221
Right temperature flap: specified value: 221
Thanks .
