VW Passat 3C central locking strange behavior
FandaTDI
Czech Republic
C?ID=204559
Hi,
this car came to me with problem that sometimes the remote control doesn´t work, but when I tried it, it works perfectly. The problem/strange thing is the driver door/key lock - it locks the car, but not unlocks (just switch the interior light on and when I stay in unlock position, windows go down, but all doors are still safe), respectivelly not unlocks just from safe (when the ignition is switched on, it locks by the key just to locked/not safe position and the key also unlocks all doors). I´ve tried to find something in coding/adaptation (found just things like confirmation methods or if the windows works by key or remote, etc.), but have no clue what causes this strange behavior (all microswitches seems to be ok).
:banghead:
Any ideas, please?
Wednesday,23,October,2019,19:44:26:00335
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ3CZ8E197770   License Plate:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 55 56 62 72
VIN: WVWZZZ3CZ8E197770   Mileage: 250330km-155547miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  2650
   Revision: --H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 80093 222 71269
   VCID: 70E9B4ED63A25CCF69-8024
   Part No SW: 3C0 614 109 C    HW: 3C0 614 109 C
   Component: J104    C4 440 V1   0003
   Revision: --020---    Serial number: 00000785197723
   Coding: 0000267
   Shop #: WSC 05311 000 00000
   VCID: 1E35BA55C9B69ABF8B-804A
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DA    HW: 3C0 907 044 DA
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 63C3CBA1A254F757E4-8036
                    Reset counter: 63
                    Mileage: 250330 km
                    Date: 2019.10.19
                    Time: 19:05:03
   Revision: 00H54000    Serial number: 01000008026982
   Coding: EA8A8F0700041A00470A00000F000000000B59435C000100000000000000
   Shop #: WSC 05124 000 00000
   VCID: 71EFB1E968A855C766-8024
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 220108 003  0205
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     210909 054  0402
   Coding: 00209069
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 B    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0006
   Revision: --------    Serial number: 22030804806442
   Coding: 000006
   Shop #: WSC 05314 000 00000
   VCID: 3A7D56C5B55ED69F97-806E
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DP39GDV-
   Coding: 0012341
   VCID: 3B7353C17A64EF978C-806E
   Subsystem 1 - Serial number: 6333FTS635670268
   Subsystem 2 - Serial number: 6343FTS692140268
   Subsystem 3 - Serial number: 6353ETS69NKGSVNP
   Subsystem 4 - Serial number: 6363ETS6FJ0HSVNP
   Part No SW: 3C0 953 549 AD    HW: 3C0 953 549 AD
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507BA
   Coding: 0000014
   VCID: 6ED5AA9579964A3F7B-803A
   Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Component: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0005105
   Shop #: WSC 73430 031 00063
   VCID: 264592B591E6427FC3-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P082190683
   Coding: F9A17F060002022002
   VCID: 23438BA1E2D4B757A4-8076
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   VCID: 397F49C97058DD879E-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Component: J386  TUER-SG FT    1131
   Revision: 32008001    Serial number: 00000659688218
   Coding: 0000181
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.135 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 356745F95C4039E77A-8060
03075 - Parallel Parking Assistance Control Module (J791)
                    Mileage: 250320 km
                    Temperature: 25.0°C
                    Voltage: 13.50 V
                    Voltage: 13.30 V
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0091020051030C7F3004951570084F0B607C01
   Component: J387  TUER-SG BT    1131
   Revision: 32008001    Serial number: 00000597388211
   Coding: 0000180
   VCID: 3C7150DD7F6AE8AF85-8068
   Part No SW: 3C0 907 801 J    HW: 3C0 907 801 J
   Component: J540 EPB3  VW-09393 0009
   Revision:   008       Serial number: 00000000358085
   Coding: 0000056
   VCID: 295F998980F86D07EE-807C
   Part No SW: 5M0 907 357 B    HW: 5M0 907 357 B
   Component: AFS-Steuergeraet    X024
   Revision: 00H01000    Serial number:
   Coding: 2311169
   VCID: 33637BE1523427D754-8066
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No: 1K0 035 186 AD
   Component: Radio GR0       034 0033
   Revision: 0003404S    Serial number: VWZ2Z2H5938605
   Coding: 0040400
   VCID: 68D9DC8D5B72940F31-803C
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000229572
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000224276
   Coding: 0000144
End-------------------------(Elapsed Time: 02:16)--------------------------
dieseldub
Bay Area, CA
C?ID=28764
Strange, the key in the door lock should mechanically unlock, as well as send the disarm signal on the comfort data bus. And since you stated the windows roll down when the key is turned to unlock, you can assume that the microswitch in the lock module is infact working correctly and the rest of the system is responding by at least rolling the windows down.
When you turn the key to unlock twice, do all the doors unlock, or none?
FandaTDI
Czech Republic
C?ID=204559
Even twice doesn´t unlock (from safe). Yes, it is strange, I am thinking about some terminal logic or some "safety" functions, but found nothing yet...
^^^^ hmm..... agree with deiseldub - very odd indeed. I wonder whether the parallel parking DTC in your auto-scan might be implicated -perhaps?
Yes, T15 voltage should not be present when the unlock function is activated in your example, but perhaps the CAN network thinks that there is a problem with the way that it parked the car and therefore it doesn't want to open the driver's door. If you clear this DTC -is there any correlation between the next occurrence of the error and using parallel park at the previous ignition cycle and subsequent strange lock behavior?
Long-shot I agree, but in the absence of a better suggestion - perhaps worthy of consideration?
