7E0-819-008 J737__Standheizung Coding
mrjj
Finland
C?ID=32548
For my T5 van there is no coding for aux heater behaviour. I knpow that German VCDS have a label file for it called: 7E0-819-008.clb
That´s not included in English version (latest) I have HEX NET pro version.
I am pretty much confused about language version difference ?!
That label is pretty much needed in order to configure whether aux heater will warm up cabin, engine or both. It is getting cold up here in Finland.
I tried to copy file to my version but obviously it will not work just like that.
mrjj
Finland
C?ID=32548
Address 18: Aux. Heat Labels: None
Part No: 7E0 819 008 D
Component: J737__Standheizung 0605
Revision: 00084000 Serial number: 09019169F00000
Coding: 0001322
Shop #: WSC 02737 790 00000
VCID: 2A50848E8530BE1FD9-807E
Date: 2014.03.10
Time: 00:00:01
Temperature: 15.0°C
Voltage: 12.92 V
Temperature: 77.5°C
(fault can be ignored, due to battery removal)
_Val
Latvia
C?ID=356659
Did you try renaming 7E0-819-008.clb to 7E0-819-008-D.clb ?
Known coding for this module (hand-translated from German info):
00?xxx2: Axuiliary Functions
0 = Start-Stop not active/installed
2 = Start-Stop is active/installed
00x?xx2: Remote Control
0 = Remote Control/Telestart not installed
1 = Remote Control/Telestart is installed
00xx?x2: 2/3-Wegeventil (I have no idea what this is)
2 =
3 =
00xxx?2: HVAC Type:
0 = Just Heating
2 = A/C with Climatic type controls
3 = A/C with Climatronic type controls
mrjj
Finland
C?ID=32548
Now it is getting hotter :)
Those makes sense.
This is exactly the thing I want to sort out. It is a magnet valve controlling water flow from heater.
I have now "3" and it have to defined as cabin only. As it is 3 there might be atleast three other options left 0,1,2
Possible choices I can imagine are engine, cabin, both. Maybe I will give a try and test 0 =>1022
2 =
3 =
00xxx?2: HVAC Type:
0 = Just Heating
Those makes sense.
Well, '2' appears to be a value that has been seen, but unfortunately, neither '3' nor '2' have been documented as to their meaning.
PS: I changed the thread topic to something more specific/informative.
mrjj
Finland
C?ID=32548
Confirmed. "0" will heat both cabin and engine. Works pretty good. Is there any known way to could get this coding included in VCDS English delivery ? Personally I don´t understand why these must be language dependent.
Thinking about low level bits, using 0, 2 , 3 makes lot of sense.
VWT6
Finland
C?ID=295527
2 =
3 =
00xxx?2: HVAC Type:
0 = Just Heating
Could use any additional bits of information also for
Part No: 7E0 815 071 B
Revision: 00085000 Serial number: 09019275F00000
Coding: 0030031
Shop #: WSC 02739 790 00000
VCID: 2412E621B2D281C78DF-8070​
as in German version there seems to be a label file also for this one (7E0-815-071.clb dated Jan-06, 2013). Thanks.
Coding: 0030031
There's no coding info in the German file for that one other than:
"0000031 = Standard"
golfi_vend
Tartu, Estonia
C?ID=195131
2 =
3 =
00xxx?2: HVAC Type:
0 = Just Heating
I was dealing with this quite recently. Coding goes as follow:
00?xxxx: Auxiliary Functions
00x?xxx: Remote Control
00xx?xx: 2/3-Wegeventil (I have no idea what this is)
0 = Without 2/3 Valve and without climatronic/climatic
1 = With 2/3 Valve and without climatronic/climatic
2 = Without 2/3 Valve and with climatic/climatronic
3 = With 2/3 Valve and with climatic/climatronic
00xxx?x: HVAC Type:
0 = Just Heating
00xxxx?: Auxiliary Water Heater
1 = No Auxiliary Water Heater Installed
2 = Auxiliary Water heater installed
VWT6
Finland
C?ID=295527
Just to clarify - is this aux. heater's automatic start/stop-functionality at cold temperatures (usually set to fire up below +5C and shut down when coolant at approx. 70C)??? :confused: Not related to engine's automated start/stop?
