2015 A6 C7 TDI | resync key fob after dead fob battery
jd_ca
C?ID=381721
One of my two fob keys was missing and had a fully drained battery. The car has the KESSY start system so I was hoping to resync the fob with a fresh battery following this procedure
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_Key_Matching_(Kessy)
Am I understanding correctly only dealers can resync the fob because the PIN is NOT made available to owners?
For reference below is the latest auto scan.
Tuesday,22,October,2019,20:13:26:24895
VIN: WAUHMAFC9FN036342   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
          53 55 56 5F 62 6C 72 82 8F 90 AC
VIN: WAUHMAFC9FN036342   Mileage: 100465km-62426miles
Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0004
   Revision: 58H14---
   Coding: 0A2A4012052601050000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401N 001005
   ROD: EV_ECM30TDI0114G0907401N_001.rod
   VCID: 2E050E4F509156876BB-807A
   Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
   Component: 0BK 30 TDIUSA H19 1005
   Revision: --H19---
   VCID: 3C21340796EDB417D5F-8068
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 27A79701E4E5E9804B00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2D321F9CD98A27C73-806E
   Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0560
   Coding: 0DA82046000000000000
   VCID: 7EA5FE0FC0F16607BBB-802A
   Serial number: 3214000112360008
   Part No SW: 4G0 820 043 AN    HW: 4G0 820 043 AN
   Component: KLIMA 4 ZONEN H14 0096
   Serial number: 05111400040747
   Coding: 368120BA59
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6B83C75BA303E3AF0C5-803E
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001820689
   Coding: 09072091073C9FE081000884A0003800CF9CD208A60802258001085C7B00
   VCID: 6FBBD34B979B1F8F20D-803A
   Component: WWS57X 141024  H37 0080
   Serial number:         141027100034
   Coding: 0045F7
   Serial number: 23403610
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
   Component: E1 - LDS  H07 0044
   Serial number: 03 11 2014  00000400
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01CE5A54
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0123371102
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000031101400010438
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000003111400010128
   Coding: 110000
   Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA109325000009945973
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: E3888757000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061430500263
   Coding: A8C306
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD533812F097F369-8024
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0001KZD2
   Coding: 303331343131303134354A55304C34473053
   VCID: 34311C27BEBD7C571DF-8060
   Serial number: 6940000Y1400018UBD0Z
   Serial number: 3575HRB405F2R8PA70BH
   Serial number: 3585HRB40672RDNSBHTS
   Serial number: 3515JRB404R31R1Q59OU
   Serial number: 3525JRB406332020GGJE
   Serial number: 3554VRB405332IIG2H24
   Serial number: 3564VRB405332IIG7H6E
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372NK70000I
   Coding: 000434
   VCID: 38292817A2559837317-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 16 10 2014  10046379
   Part No SW: 4G8 920 984     HW: 4G8 920 984
   Component: TDieUsa   Nv  H58 0622
   Revision: 29460237    Serial number: 658301014596006
   Coding: 0BE60A040B41D705020000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 73B3DF3BFB333B6FC45-8026
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001620789
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDDA3F84293267CF3-8026
   Serial number: 4120824803
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140830000000000004DF
   Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
   Component: KLIMA FOND    H08 0096
   Serial number: 03111400040635
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Revision: AA000000    Serial number: 00000122554235
   Coding: C0581B008F006001000001010101102030303232203232
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720DDLEL
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331F3BBBB37B6F045-8066
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH05 0060
   Revision: 00H05000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 3039103746254077797-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H05 0060
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F02.11.1400H05000AMS14243ÿ
   Subsystem 4 - Serial number: S14243ÿ
   Component: TSG FA        H03 0507
   Coding: 011F17005E00628002000012
   VCID: 47CB5BEBDFABE7CF48D-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0022124827
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0351681250
   Coding: 0106023A00FA418580A0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000254360
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO33782377
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00010086144
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93369213
   Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
   Component: BO G3 C7      H09 0160
   Revision: 11000000    Serial number: 0020767
   VCID: 2517F16305E715DF9A1-8070
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
   Serial number: 02207140028422
   Component: TSG BF        H03 0507
   Coding: 011F17005E00628002000002
   VCID: 46D556EFD8A1FEC7B3B-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001259358
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0709435D972D9F521-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 141106-0001-061
   Coding: 1221A6601002A500
   ROD: EV_HeadlRegulBasic.rod
   Revision: AB001007    Serial number: 156K60E8091558
   Coding: 020007010000000001
   VCID: 2411EC670EDDECD78DF-8070
   Part No SW: 4G0 035 746 H    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0902
   Revision: --------    Serial number: 194K%0EB011392
   Coding: 050200000003E5EF55128B1E00000003100001000000000000
   VCID: 2C010447660D249745F-8078
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED005VRQW
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NJV000DF
   Component: CD-Database  5950
   Component: TSG HL        H03 0507
   Coding: 010F17004000628002000002
   VCID: 49CF5DD3C9BF11BF5E9-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H08---    Serial number: 525 PA8J4XG7AA
   Coding: 1080004
   VCID: 2615F66F74E11EC793B-8072
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
   Component: HeadUpDisplay 007 0203
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F153341AF497F769-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323D1A3F44A972670F3-8066
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 142940718
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B03075B638323AF4C5-807E
End----(Elapsed Time: 02:46, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
An earlier scan had this error
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 100
                    Mileage: 89469 km
                    Date: 2018.09.23
                    Time: 10:29:41
You're looking at Immo-3 instructions; this car is way beyond Immo-3.
Even if the PIN were available, it wouldn't be sufficient to match a key to one of these cars. It's a challenge/response mechanism now. The challenge (from the car) changes every time the ignition is cycled, and the only place the algorithm exists to generate the response from the challenge is on the factory's servers.
That said, I would think that a key that previously worked and only stopped working due to disuse and a dead battery should work again once it has a good battery. If it doesn't, my guess is the key is defective.
jd_ca
C?ID=381721
Thank you for your education Uwe. I'm new to the audi/vw world and couldn't find resync instructions for my model.
The fob was laying in the car between the seat and center console for 3+ months and was working fine before. I tried 2 new batteries today but the key isn't recognized. When I hit the start button, the LED in the bad FOB lights up briefly.
I'll give it a shot a the dealer. Reprogramming is $110 and I hope to avoid the $350 replacement key.
Thank you.
I can't say I blame you for that.
Make sure you take all your keys to the dealer. If any key gets programmed, they all need to be programmed. If one missed, it will no longer work. I do not know if your car came with a separate valet key, but it's one people often miss.
Oh, and when they give you the car back, make sure to test all the keys individually. That means leave all but one a goodly distance away and make sure the one you're testing unlocks, starts, and locks the car. At least that's what I do. "Trust, but verify!" :)
jd_ca
C?ID=381721
Just closing the loop on this. The dealer was able to reprogram the dead fob. Lesson learned: don't loose your key between the seat and the transmission tunnel. :(
