MQB Blind spot monitor and VCDS
JSWTDI09
Las Vegas, Nevada
C?ID=96924
I have an MQB Tiguan (2018 SE) and my blind spot monitor system went nuts and then died, however VCDS shows no fault codes of any kind (autoscan below).
First the little light in the rear view mirror started blinking on and off for no reason (nothing in blind spot) and then now it never comes on.
My real question is there any way to look at this function with VCDS. I am just surprised that it is apparently quite dead but there are no DTCs stored. It is going into the dealership next week for a "calibration", but this apparently requires special equipment and VW's computer system. Can VCDS see anything about this system? I assume it is controlled in some way by the CECM (09).
Saturday,24,August,2019,10:32:46:29381
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
VIN: 3VV3B7AX0JM03xxxx  License Plate: xxxxx
Mileage: 25484km-15835mi   Repair Order:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 3C 42 44 52 5F 6C 75
VIN: 3VV3B7AX0JM035049   Mileage: 25484km-15835miles
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000
   Coding: 012A00122424010F34000000000000000000000000000000
   Shop #: WSC 00066 790 00451
   ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
   ROD: EV_ECM20TFS0115NA907115A.rod
   VCID: 3C34F33DB71962AF85-8068
   Part No SW: 09G 927 158 B    HW: 09G 927 158
   Component: AISIN AQ8     206 3380
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00443
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 3228DD05655DA4DF5F-8066
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 52037000001741
   Coding: 0BFA6BA454231B71C5770204A2CC49D0D62AD8A34045927010415058C2824200002764121A1C230A35351919323200
   Shop #: WSC 01383 790 50316
   VCID: 76A02115C9B5F8FFB3-8022
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0447390592
   Coding: 132C0C0723
   VCID: 3E30F935A10570BFAB-806A
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000D00033377
   Coding: 00020004200118001005000012111406
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4AD8A5E5EDCDCC1F07-801E
   Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 034 0243
   Revision: --------    Serial number: C86427071701A4
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0B5660E1A2379517FC-805E
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170703  034 0373
   Serial number: 17063021013450
   Component: ACCCONTIMQB   H02 0233
   Coding: 3200000110FF8728749C8145004097
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM060HKZ
   Coding: 8CCCFC00000000005000001AC20800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 054256D98453E367AA-8050
   Occupant Detection:
   Serial number: IBH000000000007J7GCL
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 001 106 17
   Serial number: 3570000000097410C42B
   Subsystem 3 - Part No SW: -----------    HW: 480 001 806 17
   Serial number: 3580000000009B55252C
   Subsystem 4 - Part No SW: -----------    HW: 480 402 906 17
   Serial number: 3510001C725E6142B2B1
   Subsystem 5 - Part No SW: -----------    HW: 480 402 806 17
   Serial number: 3520001A7264428183D-
   Subsystem 6 - Part No SW: -----------    HW: 480 400 507 17
   Serial number: 3550001B32610AE6345-
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 507 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001B12610AE3B7E9
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 03071708491275
   Coding: 0410
   VCID: 075E5CD1BE5FF177D8-8052
   Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
   Component: KOMBI         370 0310
   Coding: 0BA5091A2388CF0502882B0954000000A0000000
   Shop #: WSC 00066 790 00274
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 10071700841250
   Coding: 030100347F085900FA0002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3326D8019A47ADD754-8066
   Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
   Serial number: 1701703390500348BH2B
   Coding: 280000
   Serial number: 1114343504
   Serial number: 17000172077013
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA1209A0DBDFC766-8024
   Component: HRE_Master    H12 0080
   Serial number: 0446829195
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D32FE39AC036BA7B2-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0445410148
   Coding: 010111
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 7038721402262
   Coding: 003013200000028000000000
   VCID: 45C296D9C4D32367EA-8010
   Serial number: 00000000000006981153
   Coding: 011000
   Revision: 00000000    Serial number: 0001810381
   Coding: 01000010004000
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 40CC87CDDBF1064FD9-8014
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 8038722500295
   VCID: 44C48BDDCFE91A6FFD-8010
   Serial number: 00000000000006922623
   Coding: 091000
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     721 0842
   Coding: 02730600BE00000051220001001808001F0500C40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E10C9757165803F3B-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT2085716
   Coding: 0123060120002017300040
   VCID: 393AEA29B82B57879E-806C
   Coding: 02230602C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 43C688C1CAE71D57C4-8016
End----(Elapsed Time: 01:37, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Have Fun!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Are you sure you haven't configured it off using the infotainment or instrument cluster menus? Find the checkbox and make sure it's turned on, likewise for Rear Cross Traffic Assist. I dimly recall it does a little flash dance when it's enabled or disabled. I believe it can also be enabled or disabled on a per-driver-profile basis. I'll also note, for others that might come across this thread, it will auto-disable if a trailer is detected, but I can see you're not equipped with a trailer detection module.
JSWTDI09
Las Vegas, Nevada
C?ID=96924
Thanks guys. Now I have something to check and some reading to do. My car is still going to the dealer next week for a recall about the coolant bottle. We shall see what happens.
JSWTDI09
Las Vegas, Nevada
C?ID=96924
Boy, do I feel stupid. Some idiot (me) accidentally turned off blind spot monitoring while looking for (or playing with) something else. However, thanks to you I don't feel nearly as stupid as I would have if I had asked the dealership service department to fix it and then they just turned it back on.
Have Fun!
P.S. I grew up in Cincinnati, but I like what they call winter here.
