Retrofit in Golf GTD 2014 discover media MIB1 at MIB 2 HECK. Problem data SERVICE!
djthema
Italy
C?ID=382547
Retrofit in Golf GTD 2014 discover media MIB1 at MIB 2 HACK. Problem data SERVICE!
i have a golf GTD 2014year with discover media navigation MIB1,
i have installed discover media MIB2 3Q0035874C, i have remove component protection after i contact online a company and hack the fecs online.
All work but i don't see the service data:
this problem is for the hack?
djthema
Italy
C?ID=382547
Friday,18,October,2019,19:28:28:36623
VIN: WVWZZZAUZEW16   License Plate:
Mileage: 30341km-18853mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZE..   Mileage: 30341km-18853miles
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
   Component: R4 2,0L EDC   H22 6284
   Revision: 81H22---
   Coding: 011D0032032405082000
   ASAM Dataset: EV_ECM20TDI01104L906021EQ 002006
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 78A81321825BBB37F17-802C
   Part No SW: 0D9 300 040 J    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4027
   Revision: 05652104    Serial number: TFK01309271755
   ROD: EV_TCMDQ250021.rod
   VCID: 1E6425B9403F2507DBB-804A
          P1734 00 [002] - -
   Revision: 00000000    Serial number: 628330000010CC
   Coding: 01FA62A1342609750379060041CC2980462C90C0608294F50062507AC109
   VCID: 7BA20C2DB36D902F9C5-802E
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00020114202100011005000000101000
   VCID: 66944D59D8EF3DC753B-8032
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011329104429
   Coding: 00141A46C24122FB4BE44000001C0728100A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77AA101D8F45B44FF8D-8022
   Component: WWS    131012  042 0551
   Serial number:         131014133932
   Component: RLFS  024 0042
   Serial number: Y13M10D09H11M38S49S1
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO24736938
   Coding: 181801
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131328801038
   Coding: 0031251051
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 3D26C235EDF95E1FE21-8068
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R01TFR.
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41DEBEC591013AFF869-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 210 13
   Serial number: 3576700000050379DD0Z
   Subsystem 2 - Part No SW: -----------    HW: 480 000 210 13
   Serial number: 3586700000010379DD0W
   Subsystem 3 - Part No SW: -----------    HW: 480 401 710 13
   Serial number: 3516502A71230BB4F077
   Subsystem 4 - Part No SW: -----------    HW: 480 401 710 13
   Serial number: 3526502AF11FBEA2213M
   Subsystem 5 - Part No SW: -----------    HW: 480 401 510 13
   Serial number: 3556502991142C85E106
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0085
   Revision: FF026026    Serial number: 20131011400219
   Coding: 0400
   ASAM Dataset: EV_SMLSVALEOMQB 001011
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDAB83DE7F54C0FF0D-806A
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3195
   Coding: 03AD41082B90000800086A000400000000000000
   Shop #: WSC 00046 123 12345
   VCID: 2A0CF9690C77D9A7B73-807E
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0001165062
   Coding: 030100040B087300FF00066A1C0F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B22CC2DF3ED502FDC5-806E
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27130001506960073376
   Coding: 29FFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 5199551503
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 08101301101316
   Coding: 003F0320D000040000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003086053
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 8301
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 3332E40DDBBD986F045-8066
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 12101301101476
   Coding: 003F0120DE00040000801000
   VCID: 3E24C539E0FF4507FBB-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000003102712
   Coding: 090000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A01000B000200
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
   Component: MU-S-N-ER     851 0842
   Coding: 02731001FF00000011510000000A00001F0602F4012000004E
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313EEE0521A1AA7F769-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV0750013
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Component: SAS-GEN 2     H06 0011
   Serial number: 130918201213
   VCID: 6B823C6DC30D00AF0C5-803E
End----------(Elapsed Time: 01:10, VBatt start/end: 12.9V/12.6V)-----------
 Quick reply to this message Reply   Reply With Quote Reply With Quote   Multi-Quote This Message          .
10-19-2019, 01:48 PM
MasterTommy
Amsterdam
C?ID=295586
Im not really sure what the problem is, but when someone ‘hacks’ this unit, id say there is pretty good chance firmware is changed, which is where stuff like this is stored. In other words youre better of asking this to whoever changed the firmware.
