09 Passat CC 2.0TSI Running Issues
ahiggins_1
C?ID=380340
Hello all,
This is my first post and I'm a complete beginner when it comes to VCDS so I'm hoping for some help/guidance to solve the issue with my car.
I'll try to keep the post short but it might go on a bit.
I only had the car a week and one evening I was driving it to see family then all of a sudden I felt a small loss of power then by the time I got to my end destination the car was really low on power, misfiring and a lot of smoke coming out of the exhaust, I assumed fuel as it was a really pungent smell. The roadside assistance company came and plugged their diagnostics into the car it is showed the following codes:
P0300 - Random/multiple cylinder misfire
P0302 - Cylinder 2 misfire
P0303 - Cylinder 3 misfire
P120A - Cylinder deactivation
P2293 - Fuel pressure regulator 2 performance
Cut a long story short, I got the car recovered to my local garage who were adamant it was a turbo failure and said it was too much for them to take on and would need to go to a specialist.
I wasn't so sure so rather than scrap the car I wanted to buy VCDS to see what I could find to possibly salvage the car.
So...the garage cleared the codes, I drove the car home and this is what I got on and auto-scan. No misfires but a MAF sensor issue.
Tuesday,22,October,2019,18:56:00:45158
VIN: WVWZZZ3CZ9E560101   License Plate:
Mileage: 153250km-95225mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 14 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3CZ9E560101   Mileage: 153250km-95225miles
Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
   Part No SW: 06J 906 026 D    HW: 06J 906 026 D
   Component: MED17.5             2424
   Revision: A7H06---    Serial number: VWZCZ000000000
   Coding: 0404000318070060
   Shop #: WSC 05314 000 00000
   VCID: 2B03077A9F0E363F4C5-807E
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal
                    Mileage: 153242 km
                    Date: 2014.03.02
                    Time: 12:04:59
                    RPM: 1265 /min
                    Load: 28.2 %
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.478 V
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage - Intermittent
                    Mileage: 153245 km
                    Date: 2014.03.13
                    Time: 18:38:55
                    RPM: 818 /min
                    Load: 24.7 %
                    Temperature: 21.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.351 V
Readiness: 0000 0101
   Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
   Component: J104    C4 440 V2   0013
   Revision: --025---    Serial number: 00000795091653
   Coding: 0003436
   Shop #: WSC 05311 000 00000
   VCID: 2F3B136AAB164A1F60D-807A
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 24
                    Reset counter: 254
                    Mileage: 153242 km
                    Date: 2014.03.02
                    Time: 12:04:59
                    Hex Value: 0x0000
                    Voltage: 14.50 V
                    Bin. Bits: 00011111
                    Count: 217
                    Hex Value: 0x0000
                    Reset counter: 2
                    Mileage: 152233 km
                    Date: 2014.02.10
                    Time: 15:40:20
                    Hex Value: 0x00C9
                    Voltage: 13.75 V
                    Bin. Bits: 00011111
                    Count: 220
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 AJ    HW: 5K0 907 044 AJ
   Component: Climatronic   130 0305
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 73B3DF1A0B3E2EFFC45-8026
   Revision: 00H54000    Serial number: 00000009414872
   Coding: E1840F8B00041A0047970F00170000000008FF475C40017C170000000000
   Shop #: WSC 05124 000 00000
   VCID: 33331F1A473E6EFF045-8066
   Subsystem 1 - Part No: 3C8 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 111108 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     220913 054  0403
   Coding: 00209069
   Shop #: WSC 05124
02236 - Stationary Right Cornering Lamp (Right) (M52)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 3
                    Mileage: 149939 km
                    Voltage: 14.50 V
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 24020902250001
   Coding: 010180
   VCID: 6695B64E486CCB5753B-8032
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__301 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P4SLJXK
   Coding: 0012337
   VCID: 44D14CC61290D947ADF-8010
   Subsystem 1 - Serial number: 6332MTS640500559
   Subsystem 2 - Serial number: 6342MTS611090569
   Subsystem 3 - Serial number: 6351HTS647EDV5KJ
   Subsystem 4 - Serial number: 6361HTS6O4OTV5KR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0030
   Revision: 00032000    Serial number: 3C5953507BN
   Coding: 0000501
   VCID: 74B1DC0602B029C7DDF-8020
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 3C8 920 970 D    HW: 3C8 920 970 D
   Component: KOMBI         H05 0110
   Coding: 440F00
   Shop #: WSC 05314 115 00000
   VCID: 2D070962AD9A380F521-8078
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P0931006BA
   Coding: F9887F06000202009003
   VCID: 2A0D027E90F42F37B73-807E
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 7AADF23E20D45FB7873-802E
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1532
   Revision: 71009005    Serial number: 00000768888615
   Coding: 0000693
   Shop #: WSC 00354 210 83959
   VCID: 40D940D60688C567897-8014
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 205    2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C0104669A00310745F-8078
   Component:    KSG PQ46 ELV 043 0612
   Coding: 01910A0001860E763604941570085FCE107C01
   Component: LIN BACKUP HORN H08 9001
   Component: Neigungssensor  004 0611
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1534
   Revision: 71009005    Serial number: 00000756098114
   Coding: 0000692
   VCID: 41DF45D20D82CC6F869-8014
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 B
   Component: J540 EPB3  VW-10498 0003
   Revision:   010       Serial number: 00000000016842
   Coding: 0000057
   VCID: 2809F8768EF81D27A17-807C
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4225753
   Coding: 0500040004
   VCID: 6597B142B56AC04F5A1-8030
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000832333
   Coding: 0000144
   VCID: 313F1512BD225CEF769-8064
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000827240
   Coding: 0000144
   VCID: 323D1A1EB82467F70F3-8066
End----(Elapsed Time: 01:20, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
I wanted to see how it drove tonight so I cleared the codes before I took the car out with the intention to see what an auto-scan showed following the car being driven. Shortly before I was due to finish my test drive it started to misfire again. The code following the drive is below...
Tuesday,22,October,2019,19:21:26:45158
Mileage: 153260km-95231mi   Repair Order:
VIN: WVWZZZ3CZ9E560101   Mileage: 153260km-95231miles
               P0300 - 000 -
                    Mileage: 153268 km
                    Date: 2014.03.14
                    Time: 19:15:31
                    RPM: 1198 /min
                    Load: 14.9 %
                    Speed: 17.0 km/h
                    Temperature: 94.0°C
                    Temperature: 21.0°C
                    Voltage: 14.097 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected
                    Mileage: 153268 km
                    Date: 2014.03.14
                    Time: 19:15:31
                    RPM: 1198 /min
                    Load: 14.9 %
                    Speed: 17.0 km/h
                    Temperature: 94.0°C
                    Temperature: 21.0°C
                    Voltage: 14.097 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected
                    Mileage: 153268 km
                    Date: 2014.03.14
                    Time: 19:15:38
                    RPM: 1492 /min
                    Load: 11.8 %
                    Speed: 21.0 km/h
                    Temperature: 94.0°C
                    Temperature: 21.0°C
                    Voltage: 14.224 V
   Coding: 0003436
   Coding: 0000000000
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 00209069
   Shop #: WSC 05124
                    Reset counter: 4
                    Mileage: 153254 km
                    Voltage: 14.60 V
   Coding: 010180
03264 - Functionalty Shut Off
                    Reset counter: 43
                    Error Code: 9
                    Bin. Bits: 00000000
   Coding: 0012337
   Coding: 0000501
   Coding: 00000226
   Coding: 440F00
   Coding: 0000693
   Revision: 00H15000
   Coding: 0000692
   Coding: 0000057
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:17, VBatt start/end: 12.6V/12.5V)-----------
I've being going round in circles thinking I need a low pressure fuel pump, a high pressure fuel pump, a MAF sensor or even just coils.
Are these fault codes something that's a definite issue, easily diagnosed or something that is going to need checking one by one? Obviously, that'll take me some time as I can do the checks, it's just trying to understand what the information means or what I need to look out for.
If anyone can help that'd be great as I'm currently having to borrow a car until I can get this one fixed, I just didn't think it was the turbo and think I should try and salvage the car.
I see nothing here that indicates it's the turbo.
I wonder if you have a loose/bad connection to the MAF?
ahiggins_1
C?ID=380340
Is this something I check for with a multimeter or just a visual inspection.
