Immobilizer adaptation VW Caddy 2006, PIN is known
sttr
Norway
C?ID=368861
Hi Everyone.
So while I wait for my verified status to come through I can ask here if anyone has experienced the same and can give me some pointers.
I have a 2006 model VW Caddy which basically is a mk5 golf with a big butt.
I bought my car second hand and it only came with one key with a remote control and one valet key.
I have since used my key insurance and have received a new keyfob from VW.
So here the fun begins.
Because I am either not able to follow the instructions or my car does not allow me to store a new value when adding (or removing) a immobilizer paired key.
I have used this guide: http://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_Key_Matching
I start VCDS and got to immobilizer
There I first use measuring blocks to verify my new key is ok.
It appears to be.
The value in field 3 is "Yes" while the value in the first field is "No" for the new key.
Both fields are "Yes" on the original keys.
Then I exit this menu and enter my PIN in the security menu. It is accepted.
I can now access the adaptation menu and look at address 01.
Here it states that I have 2 keys paired to my immobilizer system.
I can add one to a total of 3 and click 'save'.
"3" is now displayed in the new value field.
Instructions on this site then states I should use one key after another and turn the ignition on until the immobilizer icon in the instrument cluster goes out.
This happens with my two original keys, but my new key only make this icon blink.
As it should if the key was not programmed correctly.
So that didnt work.
I go back into adaptation menu to check and the total number of keys is still 2.
ok... I try to alter this to 1 and progam just one of my original keys.
Immo icon goes out and I can start my car with this key. But also with the other original key.
So I appearantly have not changed the immo adaptation at all.
I tried again but this time I exited the adaptation menu before trying to cycle the keys.
Same result.
Can anyone see something obvious I am doing wrong here?
Is VCDS not able to program my new key to my car this way?
I have since I bought it replaced the SWCM to a CH version (it used to be a 1K0 953 549 AE) and replaced the stalks while waiting for a upgraded cluster to arrive.
This shouldnt prevent the immobilizer system to be programmed should it?
I drive my car daily and now have cruisecontrol so those new parts seems to work as they should.
Attached autoscan:
Monday,21,October,2019,21:59:03:42173
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: WV1ZZZ2KZ6X075733   License Plate:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52
VIN: WV1ZZZ2KZ6X075733   Mileage: 181420km-112729miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 FF    HW: 028 101 315 7
   Component: R4 1,9L EDC G000SG  8183
   Revision: --H01---    Serial number: VWZ7Z0E3202718
   Coding: 0000031
   Shop #: WSC 35110 377 00176
   VCID: 6889B919DE799097617-803C
   Part No: 1K0 907 379 P
   Coding: 0017106
   Shop #: WSC 35110 377 00156
   VCID: 3FDB4245EB77F72FF0D-806A
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000005292553
   Coding: 09004E030004100032000032320000000009FF075C
   Shop #: WSC 35110 377 08192
   VCID: 2B0306150F0F7B8F4C5-807E
   Subsystem 1 - Part No: 2K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
   Shop #: WSC 35110
00156 - Control Circuit for Windshield Washer Pump
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 121
                    Mileage: 181425 km
                    Voltage: 12.00 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD08ZL8
   Coding: 0012345
   VCID: 7DA7F84DA1FB253FA21-8028
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0000033
   VCID: 7AADF351B0D51207873-802E
   Part No: 2K0 920 842 C
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0017101
   Shop #: WSC 78411 128 139648
   VCID: 290FFC1D05F3699FBE9-807C
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105C310134
   Coding: 3D0F0100079002
   VCID: 2A0D031100F56287B73-807E
   Component: IMMO            VDD 1012
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2315
   Coding: 0000048
   VCID: 36352761C44D366723B-8062
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 33331E75D73F234F045-8066
   Part No: 1K0 959 433 AK
   Coding: 008B0C087F2D8405484A016010C0
   VCID: 79AFEC5DB5D3191F8E9-802C
   Part No: 1T0 959 702 B
   Coding: 0000048
   VCID: 372B2A65C347CF6F38D-8062
End----(Elapsed Time: 00:45, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
grant@gendan
Battery voltage is a little low, might be worth charging the battery and trying again:
Battery voltage at least 12.0 V
sttr
Norway
C?ID=368861
Hey thanks for the suggestion.
I tried this exercise again today with a charger connected to the battery.
Unfortunately the result is the same.
Please post Advanced ID data from 01-Engine and 25-Immo.
Ok so advanced ID
01-Engine
Tuesday,22,October,2019,21:23:43:42173
VCDS Version: Release 19.6.2
                Address 01: Engine
Control Module Part Number: 03G 906 021 FF
  Component and/or Version: R4 1,9L EDC G000SG  8183
           Software Coding: 0000031
            Work Shop Code: WSC 35110
Advanced Identification
     Identification: BPG-810
     Revision: --H01---
     Date: 13.11.05
     Test stand number: 1479
     Manufacturer number: 1225
Flash Status
     Programming Attempts: 0
     Successful Attempts: 0
     Programming Status: 00000000
     Required Conditions: 00000001
     Flash Tool Code: 00000 000 00000
     Flash Date: 00.00.00
Software
     P0101
     HAS8
Misc.
     Hardware number: 028 101 315 7
Car Info
     Chassis Number: WV1ZZZ2KZ6X075733
VCDS Info:
       Readiness: No script available
and
25-immobilizer
Tuesday,22,October,2019,21:24:37:42173
Control Module Part Number: 2K0 920 842 C
  Component and/or Version: IMMO            VDD 1012
           Software Coding:
            Work Shop Code: WSC 00000
Misc.
VCDS Info:
Hopefully this will mean something to a trained eye...
golfi_vend
Tartu, Estonia
C?ID=195131
If new key isn't learning and old ones are, then I see no ither issue than the key itself.
sttr
Norway
C?ID=368861
I would normally agree with you on this, but I was not able to program a single key either.
I tried to do so while troubleshooting.
Just for giggles and testing, but my other original key (the one *not* programmed) still worked after my first key was programmed in as the single key.
Leading me to think that I did something wrong in the process and have canceled the adaptation somehow.
NZDubNurd
New Zealand
C?ID=230482
DO NOT try this, unless some one confirms it is for keys... I seem to recall having to "delete" all keys or remotes before I could match mine... is that a KEY thing, or a REMOTE thing???
sttr
Norway
C?ID=368861
Hi Allan. Fancy seeing you here 👍😊
The problem is for the key and the immobilizer.
The remote part is programmed and working.
golfi_vend
Tartu, Estonia
C?ID=195131
I see now, what You wrote.
I'm not native English speaker and as I understand it quite well, sometimes I miss stuff...again my bad.
What happens when You try to start with new key?
After trying to match only 1 key what does key count say in MVB.
Is Your known PIN code also accepted when You try to enter it in Engine Security Access?
NZDubNurd
New Zealand
C?ID=230482
Hi Allan. Fancy seeing you here ����
I just clicked it was you :-)
For EITHER my Remotes or Keys, I had to delete them all first, which I think was an adaptation. I Just don't recall what it was for... someone will know though :-D
sttr
Norway
C?ID=368861
You and me both friend.
I am not a native english speaker either.
Using new key I get immo icon blinking and the car starts for about 1 second before the motor stops again.
The MVB still states 2 programmed keys even though I have saved "1" in the adaptation menu.
Yes my PIN is also accepted in 01-engine.
Glenlivet ftw! :)
I think I had to delete my original remote before I was able to program 2 new ones.
This was covered in some guide I followed, but I cannot recall the details atm.
But I believe I had to use 00 to reset all remotes and then 01 to program new ones.... Could it have been Cent.conv and adaptation..
NZDubNurd
New Zealand
C?ID=230482
Glenlivet ftw! :)
I was on the Lagavulin last weekend ;-)
That is probably what I was confused with. I remember making 3 keys for my car, but one isn't cut - the immo and remote works though.
Turns out I'm no help to you :-D
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I said this so many times , 2006 and up VCDS can not program keys in Mk5 platform . I tried this 100 times and never worked.
Not even to delete old keys and program just one original key like OP trying to do .
golfi_vend
Tartu, Estonia
C?ID=195131
I hear You.
So it is not only WVX immobiliser, also later VWZ also?
sttr
Norway
C?ID=368861
It was my understanding that 2006 was a year where you have both immo4 and immo4c immobilizer. 4c is a no go with vcds but the older immo 4 should be programmable.
and that the way you distinguish between the two is the first letters in immo ID wvx/wvz.
My car being a wvz should be programmable.
Is this understanding false?
That is my understanding as well.
DGMotors
C?ID=57532
What part number is the Key? (I also need the colour code part EG. INB/INF)
NZDubNurd
New Zealand
C?ID=230482
Could this be related to having no WSC number in VCDS???
The other modules in the original autoscan all have WSC number in them.
This setup is very similar to my 2x 2006 Tourans - one early-ish, one late; and I can match keys to them, but I have WSC's in mine.
I doubt it, but it couldn't hurt to put some random WSC, Importer, and Equipment Number values in on the Options screen in VCDS (User Interface & Identification tab), save them, and restart VCDS.
wojciech300
Poland
C?ID=147841
I hear You.
I did many time mk5 after 2006.6, ofcourse i read Security Block, put Component Security to TP, then program with vcds.
Maybe i never came across WVX.
