2012 VW Jetta Lost ABS Coding (MK60EC1)
Bloughautomotive
C?ID=122717
Car has lost its coding for abs module. Would like to know what software to use to be able to create the coding for this common issue along with the coding needed for the module. I have seen different options for a coding calculator but would like input to which one is the best for VW. Thank you for the support.
Tuesday,22,October,2019,09:09:05:59206
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: 3VWLX7AJ0CM463862   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 56 77
VIN: 3VWLX7AJ0CM463862   Mileage: 174970km-108721miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 A    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 9740
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 2C141F3B8FEC712F2B-8078
Readiness: 0110 0101
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2246
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 004C9B8B53E4454FA7-8054
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   VCID: 74A4C75BD75C69EFB3-8020
                    Reset counter: 41
                    Date: 2014.03.07
                    Time: 03:32:06
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 49920
                    Count: 56064
                    Fault Status: 01100101
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:32:04
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 279
                    Count: 50176
                    Count: 56064
                    Count: 65024
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:32:04
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 295
                    Count: 50176
                    Count: 56064
                    Count: 65024
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:32:04
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 270
                    Count: 50176
                    Count: 56064
                    Count: 65024
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0708
   Revision: 00085000    Serial number: 0000000000
   Coding: 030C0C
   ASAM Dataset: EV_KESSY_PQ35GP A01010
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 332604479AD22ED76A-8066
65826 - No Basic Setting
          B2010 00 [009] - -
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 L    HW: 5C0 820 047 L
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000031552
   Shop #: WSC 03068 444 84351
   VCID: 291AE62F801E6407D0-807C
   Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0226
   Revision: B2066001    Serial number: 03311172100206
   Coding: 73994B9A08A30B0008382000240884C500C2502E6000000030A000000000
   Shop #: WSC 25807 444 58783
   VCID: 2D12123F74F678273C-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3462
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3462
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH00005AD+
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0003142
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3462
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3462
   Coding: 800000
03440 - Activation of LED for Lock and Unlock
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 00:04:10
00975 - Heated Rear Window (Z1)
            006 - Short to Plus
                    Fault Status: 01100110
                    Fault Frequency: 18
                    Reset counter: 42
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:33:01
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   012 0805
   Serial number: 003END076N47
   Coding: 00003232
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FAEC837B67A4A374E-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1000000BFB05
   Coding: 30314A
   Serial number: 3572MSME2A3A3253ZZZV
   Serial number: 3582MSME60645352ZZZP
   Component: S.Sens.Fahr.H  H01 ----
   Serial number: 3516KSME23575708ZZZQ
   Component: S.Sens.Beif.H  H01 ----
   Serial number: 3526KSME28596208ZZZU
   Component: F.Sens.Fahr  H01 ----
   Serial number: 3556LSME5F540208ZZZX
   Serial number: 3566LSME43251915ZZZP
   Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
   Component: KOMBI         H04 0604
   Coding: 270A01
   Shop #: WSC 00066 000 00119
   VCID: 2A1819234D186F1FD9-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70ACCB4BA34455CF57-8024
   Component: IMMO          H04 0604
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A98D9238D98AF1F19-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 04:11:56
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 12000033562004
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E10153371F0033F05-807A
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668355706
   Coding: 020000
   VCID: 271EE017560A5277C6-8072
   Part No SW: 1K0 035 274     HW: 1K0 035 274
   Component: RNS315-NAR    H03 0007
   Serial number: VWZAZ2K8405348
   Coding: 040004210200000000001000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315VWNARV1UDS A01005
   ROD: EV_RNS315VWNARV1UDS.rod
   VCID: 618ABE0F70AEEC47C8-8034
1048597 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [tweeter front left open load]
                    Reset counter: 42
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
1048598 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [tweeter front right open load]
                    Reset counter: 42
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
1048632 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Reset counter: 42
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:17
          B11CF 53 [009] - Deactivated
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:16
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668271838
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3228014365C827DF61-8066
End----------(Elapsed Time: 01:27, VBatt start/end: 14.3V/14.3V)-----------
United States
Hi Joshua,
That VIN decrypted as a 2012, and I can easily tweak the forum subject line, but do verify the actual VIN is 3VWLX7AJ0CM463862 (to rule out swapped Immo components).
If 3VWLX7AJ0CM463862 is correct I believe the factory installed ABS module was 1K0 907 379 BL. The direct replacement should be 1K0 907 375 BL according to PL24 by VIN. The installed module (1K0 907 379 BC) appears to fit an entirely different VIN split. Temp screen shot link: https://media.trillian.im/media/?m=...xP92nqvWvFLhjDaNUKLFH9PD0BylAZhOJITKXtWFDZQ==
Either way, I believe the factory condition ABS coding was:
B14B400C492808FD8D1302EA921B1061A71000
That may be rejected if the installed module doesn't support HHC.
Next, although I'm not opposed to using to using online calculators for a second opinion or a cross check of my work I don’t use then for building coding that’s sent to customers. Instead, we search our database of scans for identical cars to establish a baseline (with the VIN digits removed) and use that base coding in conjunction with internal label files to fine tune things like steering type, park assist/wheel speed sensors, HHC, TPMS and similar per the PR-Codes of the car in question.
If I cannot locate at least one (5 or more are preferred) baseline scan I won't even attempt to craft up long ABS coding from scratch due to all of the variables and potential liability for Ross-Tech.
Best,
Vehicle Identification No.3VWLX7AJ0CM463862
ModelJetta
JEM
Date of production05.06.2012
Model year2012
Sales type162XS3
Engine CodeCBTA
Transmission CodePDW
[TABLE="class: vinInfoTable"]
[TR]
[TH]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PE[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]7KK[/TD]
[TD]Vehicle class differentiation -160-[/TD]
[/TR]
[TR]
[TH]drive-off assistance[/TH]
[TD="class: prCode"]UG1[/TD]
[TD]Hill hold control[/TD]
[/TR]
[TR]
[TH]Emission standard[/TH]
[TD="class: prCode"]7GJ[/TD]
[TD]Emission standard TIER 2[/TD]
[/TR]
[TR]
[TH]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH]airbag[/TH]
[TD="class: prCode"]4UM[/TD]
[TD]Driver's and front passenger air bag, NAR with front
passenger air bag deactivation (2-stage) -
SMART airbag with automatic deactivation[/TD]
[/TR]
[TR]
[TH]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E4[/TD]
[TD]Activated carbon canister (ORVR)
and siphoning device for fueling[/TD]
[/TR]
[TR]
[TH]Storage compartment[/TH]
[TD="class: prCode"]7N2[/TD]
[TD]Sunglass holder[/TD]
[/TR]
[TR]
[TH]Aerials[/TH]
[TD="class: prCode"]8L6[/TD]
[TD]"diversity" window antenna[/TD]
[/TR]
[TR]
[TH]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH]Follow-on warranty[/TH]
[TD="class: prCode"]EA0[/TD]
[TD]Without subsequent warranty[/TD]
[/TR]
[TR]
[TH]Left exterior mirror[/TH]
[TD="class: prCode"]5SH[/TD]
[TD]Left exterior mirror, flat (US)[/TD]
[/TR]
[TR]
[TH]Right exterior mirror[/TH]
[TD="class: prCode"]5RR[/TD]
[TD]Right exterior mirror, convex (US)[/TD]
[/TR]
[TR]
[TH]Alternative drive system[/TH]
[TD="class: prCode"]0K0[/TD]
[TD]Without alternative drive system[/TD]
[/TR]
[TR]
[TH]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WC[/TD]
[TD]Without "Multimedia" in vehicle[/TD]
[/TR]
[TR]
[TH]Equipment levels[/TH]
[TD="class: prCode"]A8F[/TD]
[TD]Sports equipment[/TD]
[/TR]
[TR]
[TH]Brake type in rear[/TH]
[TD="class: prCode"]1KD[/TD]
[TD]Disc brakes in rear[/TD]
[/TR]
[TR]
[TH]batteries[/TH]
[TD="class: prCode"]J1D[/TD]
[TD]Battery 380 A (72 Ah)[/TD]
[/TR]
[TR]
[TH]Brake type, front[/TH]
[TD="class: prCode"]1ZP[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH]Components with special surface[/TH]
[TD="class: prCode"]6FF[/TD]
[TD]Exterior mirror housing and various attachments
colour coded to vehicle[/TD]
[/TR]
[TR]
[TH]Beverage holders[/TH]
[TD="class: prCode"]4M2[/TD]
[TD]Beverage holder in center console in
front and in storage compartment in rear[/TD]
[/TR]
[TR]
[TH]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0D[/TD]
[TD]Assembly kit, USA corresponding vehicle
version (not California), various parts[/TD]
[/TR]
[TR]
[TH]floor covering[/TH]
[TD="class: prCode"]3MH[/TD]
[TD]Dilours floor covering without scuff
guard[/TD]
[/TR]
[TR]
[TH]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH]Owner's manuals[/TH]
[TD="class: prCode"]0VM[/TD]
[TD]Information kit in American English[/TD]
[/TR]
[TR]
[TH]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH]brake wear indicator[/TH]
[TD="class: prCode"]9U0[/TD]
[TD]Without brake pad wear indicator[/TD]
[/TR]
[TR]
[TH]Heated washer nozzles[/TH]
[TD="class: prCode"]9T1[/TD]
[TD]Heated washer nozzles in front[/TD]
[/TR]
[TR]
[TH]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH]Chrome package[/TH]
[TD="class: prCode"]QJ3[/TD]
[TD]Chrome package (version 2)[/TD]
[/TR]
[TR]
[TH]General operating permit, alterations[/TH]
[TD="class: prCode"]C09[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FE[/TD]
[TD]Tilting and sliding glass sunroof with
sunbshade[/TD]
[/TR]
[TR]
[TH]Suspension system in rear[/TH]
[TD="class: prCode"]1JA[/TD]
[TD]Rear shock absorption, basic design 1[/TD]
[/TR]
[TR]
[TH]Suspension system in front[/TH]
[TD="class: prCode"]G18[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G7[/TD]
[TD]Filler neck module 1 with insert[/TD]
[/TR]
[TR]
[TH]Installation differentiation for components[/TH]
[TD="class: prCode"]0ER[/TD]
[TD]Installation differentiation for
transmission AQ250
-- vehicle components --[/TD]
[/TR]
[TR]
[TH]Theft protection system[/TH]
[TD="class: prCode"]7AZ[/TD]
[TD]Preparation for anti-theft alarm system[/TD]
[/TR]
[TR]
[TH]Inserts[/TH]
[TD="class: prCode"]5MN[/TD]
[TD]Decorative inserts[/TD]
[/TR]
[TR]
[TH]Scuff plates[/TH]
[TD="class: prCode"]7M5[/TD]
[TD]Without impact protection film for door sill[/TD]
[/TR]
[TR]
[TH]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH]Electric interface for external use[/TH]
[TD="class: prCode"]UF8[/TD]
[TD]Electric interface for external use[/TD]
[/TR]
[TR]
[TH]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FL[/TD]
[TD]Mexico manufacturing sequence[/TD]
[/TR]
[TR]
[TH]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH]Pedestrian protection[/TH]
[TD="class: prCode"]VL0[/TD]
[TD]Standard pedestrian protection measures[/TD]
[/TR]
[TR]
[TH]Pedal cluster[/TH]
[TD="class: prCode"]VF0[/TD]
[TD]Standard pedal cluster[/TD]
[/TR]
[TR]
[TH]Headlight activation[/TH]
[TD="class: prCode"]8K4[/TD]
[TD]Separate daytime running lights
NAR[/TD]
[/TR]
[TR]
[TH]Fresh air intake for passenger
compartment (with particulate filter)[/TH]
[TD="class: prCode"]2V1[/TD]
[TD]dust-pollen filter[/TD]
[/TR]
[TR]
[TH]Antifreeze[/TH]
[TD="class: prCode"]1C2[/TD]
[TD]Antifreeze up to -35 degree celsius
tolerance up to -40 degree C[/TD]
[/TR]
[TR]
[TH]Vehicle tracing system[/TH]
[TD="class: prCode"]7G0[/TD]
[TD]Without preparation for VTS (Vehicle Tracing System)[/TD]
[/TR]
[TR]
[TH]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH]Interior noise suppression measures[/TH]
[TD="class: prCode"]3W0[/TD]
[TD]Without additional noise suppression
measures for passenger compartment[/TD]
[/TR]
[TR]
[TH]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH]Weight category rear axle[/TH]
[TD="class: prCode"]0YD[/TD]
[TD]Weight range 4
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH]Weight category front axle[/TH]
[TD="class: prCode"]L13[/TD]
[TD]Suspension range 13
[/TR]
[TR]
[TH]Base engine[/TH]
[TD="class: prCode"]T8K[/TD]
[TD]5-cylinder SI engine 2.5 l
unit 07K.1[/TD]
[/TR]
[TR]
[TH]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U7[/TD]
[TD]Luggage pocket on backrest of right seat[/TD]
[/TR]
[TR]
[TH]Tie down straps/net/pocket[/TH]
[TD="class: prCode"]6M0[/TD]
[TD]Without tie down straps/net/pocket[/TD]
[/TR]
[TR]
[TH]cruise control system[/TH]
[TD="class: prCode"]8T2[/TD]
[TD]Electronic cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH]Exterior noise suppression measures[/TH]
[TD="class: prCode"]2B0[/TD]
[TD]without additional exterior noise insulation[/TD]
[/TR]
[TR]
[TH]Luggage compartment trim[/TH]
[TD="class: prCode"]5A2[/TD]
[TD]Comfort luggage compartment trim[/TD]
[/TR]
[TR]
[TH]Transmission specifications[/TH]
[TD="class: prCode"]G1A[/TD]
[TD]6-speed automatic transmission[/TD]
[/TR]
[TR]
[TH]glove box[/TH]
[TD="class: prCode"]4Z3[/TD]
[TD]Lockable glove compartment door, with
light[/TD]
[/TR]
[TR]
[TH]Brackets[/TH]
[TD="class: prCode"]3P0[/TD]
[TD]Without bracket for first aid kit and
warning triangle[/TD]
[/TR]
[TR]
[TH]handle for hand brake lever[/TH]
[TD="class: prCode"]6PC[/TD]
[TD]handbrake lever grip (leather)[/TD]
[/TR]
[TR]
[TH]Rear spoiler[/TH]
[TD="class: prCode"]5J0[/TD]
[TD]Without rear spoiler[/TD]
[/TR]
[TR]
[TH]Rear axle[/TH]
[TD="class: prCode"]0N9[/TD]
[TD]Lightweight rear axle[/TD]
[/TR]
[TR]
[TH]Rear seats[/TH]
[TD="class: prCode"]3KB[/TD]
[TD]Unsplit rear seat bench, split folding
backrest, with center armrest[/TD]
[/TR]
[TR]
[TH]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AB[/TD]
[TD]Manually controlled air conditioning
system[/TD]
[/TR]
[TR]
[TH]Headlamps[/TH]
[TD="class: prCode"]8ES[/TD]
[TD]Twin headlamps for driving on the right,
with integrated high beam (US design)[/TD]
[/TR]
[TR]
[TH]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH]Instrument clusters[/TH]
[TD="class: prCode"]U5C[/TD]
[TD]Instrument cluster, mph speedometer
- USA -[/TD]
[/TR]
[TR]
[TH]Instrument panel[/TH]
[TD="class: prCode"]4N3[/TD]
[TD]Comfort dashboard[/TD]
[/TR]
[TR]
[TH]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L2[/TD]
[TD]Breakaway interior rearview mirror,
dimming[/TD]
[/TR]
[TR]
[TH]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH]Body style[/TH]
[TD="class: prCode"]K8B[/TD]
[TD]Notchback[/TD]
[/TR]
[TR]
[TH]Luggage compartment floor covering[/TH]
[TD="class: prCode"]6SF[/TD]
[TD]Standard trunk floor covering[/TD]
[/TR]
[TR]
[TH]coolbox[/TH]
[TD="class: prCode"]1W0[/TD]
[TD]Without refrigerator/glove compartment
cooling system[/TD]
[/TR]
[TR]
[TH]Electronic map cooling system[/TH]
[TD="class: prCode"]QS0[/TD]
[TD]Without electronic map cooling system[/TD]
[/TR]
[TR]
[TH]Climatic zones[/TH]
[TD="class: prCode"]0Y3[/TD]
[TD]Cold zones[/TD]
[/TR]
[TR]
[TH]Compass/road sign display[/TH]
[TD="class: prCode"]QR0[/TD]
[TD]Without compass/road sign display/
dynamic road sign display[/TD]
[/TR]
[TR]
[TH]headrest for seat, rear[/TH]
[TD="class: prCode"]3Q6[/TD]
[TD]Three rear head restraints[/TD]
[/TR]
[TR]
[TH]Head restraints[/TH]
[TD="class: prCode"]3J1[/TD]
[TD]Hight-adjustable head restraints for
front seats[/TD]
[/TR]
[TR]
[TH]Fuel tank treatment[/TH]
[TD="class: prCode"]2LC[/TD]
[TD]Fuel tank with special material
treatment (coextrusion)[/TD]
[/TR]
[TR]
[TH]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z0[/TD]
[TD]Initial standard fuel filling[/TD]
[/TR]
[TR]
[TH]Fuel systems[/TH]
[TD="class: prCode"]1A1[/TD]
[TD]Fuel system for fuel-injected SI engine,
injection system without fuel return[/TD]
[/TR]
[TR]
[TH]Body measures[/TH]
[TD="class: prCode"]5C1[/TD]
[TD]Body measures for increased safety
requirements[/TD]
[/TR]
[TR]
[TH]Child seat anchors in front[/TH]
[TD="class: prCode"]3G0[/TD]
[TD]Without child seat anchora in front
(ISOFIX)[/TD]
[/TR]
[TR]
[TH]Radiator grille[/TH]
[TD="class: prCode"]6KC[/TD]
[TD]Radiator grille[/TD]
[/TR]
[TR]
[TH]License plate lighting[/TH]
[TD="class: prCode"]KL0[/TD]
[TD]Standard license plate lighting[/TD]
[/TR]
[TR]
[TH]Rear license plate bracket[/TH]
[TD="class: prCode"]6P2[/TD]
[TD]License plate bracket, rear (NAR)[/TD]
[/TR]
[TR]
[TH]Front license plate bracket[/TH]
[TD="class: prCode"]6W3[/TD]
[TD]License plate bracket front (small, NAR)[/TD]
[/TR]
[TR]
[TH]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K5[/TD]
[TD]Transport protection film with
additional transport protection measures[/TD]
[/TR]
[TR]
[TH]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH]Reading lamp[/TH]
[TD="class: prCode"]8S1[/TD]
[TD]Reading light in front[/TD]
[/TR]
[TR]
[TH]steering[/TH]
[TD="class: prCode"]1N1[/TD]
[TD]Power steering[/TD]
[/TR]
[TR]
[TH]Backrest release[/TH]
[TD="class: prCode"]3H0[/TD]
[TD]Without backrest release for front seats[/TD]
[/TR]
[TR]
[TH]Light control systems[/TH]
[TD="class: prCode"]8G0[/TD]
[TD]Without Light Assist[/TD]
[/TR]
[TR]
[TH]Lumbar support[/TH]
[TD="class: prCode"]7P5[/TD]
[TD]Manually adjustable lumbar support for
left front seat[/TD]
[/TR]
[TR]
[TH]steering wheels[/TH]
[TD="class: prCode"]2ZM[/TD]
[TD]Leather-wrapped multi-function steering
wheel[/TD]
[/TR]
[TR]
[TH]Speaker installation[/TH]
[TD="class: prCode"]8RU[/TD]
[TD]Sound system with subwoofer "branded"[/TD]
[/TR]
[TR]
[TH]Steering column systems[/TH]
[TD="class: prCode"]2C5[/TD]
[TD]Steering column, adjusted axially and vertically[/TD]
[/TR]
[TR]
[TH]Headlight range control[/TH]
[TD="class: prCode"]8Q0[/TD]
[TD]without beam length regulator[/TD]
[/TR]
[TR]
[TH]Center armrest[/TH]
[TD="class: prCode"]6E4[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q1[/TD]
[TD]Multi-function display/trip computer[/TD]
[/TR]
[TR]
[TH]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH]Engine specifications[/TH]
[TD="class: prCode"]D77[/TD]
[TD]5-cylinder SI engine 2.5 l/125 kW (20V)
(R-5)
base engine is T8K[/TD]
[/TR]
[TR]
[TH]Market-specific vehicle version[/TH]
[TD="class: prCode"]AW0[/TD]
[TD]Version (low)[/TD]
[/TR]
[TR]
[TH]Left vanity mirror[/TH]
[TD="class: prCode"]4SH[/TD]
[TD]Left vanity mirror illuminated with
cover and special mirror imprint (NAR),
extractable[/TD]
[/TR]
[TR]
[TH]Right vanity mirror[/TH]
[TD="class: prCode"]4TQ[/TD]
[TD]Vanity mirror, right, illuminated, with
cover and special mirror imprint (NAR)[/TD]
[/TR]
[TR]
[TH]Navigation device[/TH]
[TD="class: prCode"]7T8[/TD]
[TD]Navigation system "RNS315" NAR[/TD]
[/TR]
[TR]
[TH]rear fog lamp[/TH]
[TD="class: prCode"]8TA[/TD]
[TD]witout rear fog lamp[/TD]
[/TR]
[TR]
[TH]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WD[/TD]
[TD]Integrated front fog light[/TD]
[/TR]
[TR]
[TH]Rear of platform module base[/TH]
[TD="class: prCode"]4P1[/TD]
[TD]Rear floor panel module, type 2[/TD]
[/TR]
[TR]
[TH]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH]Panic switch[/TH]
[TD="class: prCode"]KP3[/TD]
[TD]With additional switch[/TD]
[/TR]
[TR]
[TH]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH]Wheels[/TH]
[TD="class: prCode"]CK5[/TD]
[TD]Alloy wheels 7J x 17[/TD]
[/TR]
[TR]
[TH]Radios[/TH]
[TD="class: prCode"]8AY[/TD]
[TD]Radio navigation system[/TD]
[/TR]
[TR]
[TH]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JF[/TD]
[TD]Non-smoking package (NAR)[/TD]
[/TR]
[TR]
[TH]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K6[/TD]
[TD]Tire pressure monitoring system[/TD]
[/TR]
[TR]
[TH]tire[/TH]
[TD="class: prCode"]H7K[/TD]
[TD]All-season tires 225/45 R17 91H (NAR)[/TD]
[/TR]
[TR]
[TH]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G4[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH]Restraint systems, front[/TH]
[TD="class: prCode"]4QQ[/TD]
[TD]3-point seat belts in front with
pretensioner and height adjustment,
US label[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PL4[/TD]
[TD]SEL+ package[/TD]
[/TR]
[TR]
[TH]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q2[/TD]
[TD]Gearshift knob/handle in leather[/TD]
[/TR]
[TR]
[TH]Special labels/plates[/TH]
[TD="class: prCode"]0SC[/TD]
[TD]Labels in English[/TD]
[/TR]
[TR]
[TH]Tail lamp assemblies[/TH]
[TD="class: prCode"]8SA[/TD]
[TD]Rear combination lamp, standard design[/TD]
[/TR]
[TR]
[TH]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH]Front seat, left[/TH]
[TD="class: prCode"]3TG[/TD]
[TD]Sports comfort seat in front, left[/TD]
[/TR]
[TR]
[TH]Front seat, right[/TH]
[TD="class: prCode"]3SG[/TD]
[TD]Sports comfort seat, front, right[/TD]
[/TR]
[TR]
[TH]Nameplates for sales name[/TH]
[TD="class: prCode"]QD3[/TD]
[TD]Nameplates for sales name[/TD]
[/TR]
[TR]
[TH]Seat belt check[/TH]
[TD="class: prCode"]9P7[/TD]
[TD]Visual and acoustic seat belt reminder,
electric contact in buckle[/TD]
[/TR]
[TR]
[TH]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZD[/TD]
[TD]3-point seat belts, outer rear with US
label[/TD]
[/TR]
[TR]
[TH]Center rear seat belts[/TH]
[TD="class: prCode"]3C8[/TD]
[TD]3-point seat belt, center rear with US
label[/TD]
[/TR]
[TR]
[TH]seat covers[/TH]
[TD="class: prCode"]N2Q[/TD]
[TD]Seat trim covers in leatherette[/TD]
[/TR]
[TR]
[TH]Seat adjustment[/TH]
[TD="class: prCode"]3L3[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH]Side lights[/TH]
[TD="class: prCode"]7R7[/TD]
[TD]Side marker lights plus exterior mirror
turn signals[/TD]
[/TR]
[TR]
[TH]Start-stop system/regenerative braking[/TH]
[TD="class: prCode"]7L3[/TD]
[TD]Without start/stop system without
regenerative braking[/TD]
[/TR]
[TR]
[TH]Horns[/TH]
[TD="class: prCode"]8Y0[/TD]
[TD]Single-tone horn[/TD]
[/TR]
[TR]
[TH]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH]power outlet[/TH]
[TD="class: prCode"]7B5[/TD]
[TD]12-volt outlet(s)[/TD]
[/TR]
[TR]
[TH]Bumper[/TH]
[TD="class: prCode"]2JG[/TD]
[TD]bumper in color of vehicle[/TD]
[/TR]
[TR]
[TH]Rear stabilizer[/TH]
[TD="class: prCode"]0BG[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH]Front stabilizer bar[/TH]
[TD="class: prCode"]0AG[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH]Drawers under front seats[/TH]
[TD="class: prCode"]QN0[/TD]
[TD]Without drawers under front seats[/TD]
[/TR]
[TR]
[TH]Heavy-duty/sports version[/TH]
[TD="class: prCode"]2UA[/TD]
[TD]Standard design[/TD]
[/TR]
[TR]
[TH]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N4[/TD]
[TD]Windshield wiper intermittent control
with potentiometer (four speeds)[/TD]
[/TR]
[TR]
[TH]Nameplate set[/TH]
[TD="class: prCode"]0QP[/TD]
[TD]Nameplate set "SEL"[/TD]
[/TR]
[TR]
[TH]Door storage compartments in front[/TH]
[TD="class: prCode"]3YQ[/TD]
[TD]Door pockets without insert mats[/TD]
[/TR]
[TR]
[TH]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q0[/TD]
[TD]steering wheel without balance weight[/TD]
[/TR]
[TR]
[TH]Door and lid locking system[/TH]
[TD="class: prCode"]4F6[/TD]
[TD]Central locking system "Keyless Entry"
without deadlock (NAR)[/TD]
[/TR]
[TR]
[TH]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]BU1[/TD]
[TD]Legal requirements for USA 1
States without CARB requirement[/TD]
[/TR]
[TR]
[TH]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D2[/TD]
[TD]Carrier frequency 315 MHz[/TD]
[/TR]
[TR]
[TH]Door and side trim panels[/TH]
[TD="class: prCode"]3LJ[/TD]
[TD]Door and side trim panel in foam film,
insert in leatherette[/TD]
[/TR]
[TR]
[TH]doors[/TH]
[TD="class: prCode"]0A2[/TD]
[TD]4 doors[/TD]
[/TR]
[TR]
[TH]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QU4[/TD]
[TD]Satellite radio reception NAR
integrated in device[/TD]
[/TR]
[TR]
[TH]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH]Identification plates[/TH]
[TD="class: prCode"]1EB[/TD]
[TD]without identification plate[/TD]
[/TR]
[TR]
[TH]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH]Telephone / telematics[/TH]
[TD="class: prCode"]9ZS[/TD]
[TD]Preparation for UHV-internal telephone
with voice control[/TD]
[/TR]
[TR]
[TH]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH]LongLife Service Regime[/TH]
[TD="class: prCode"]QG0[/TD]
[TD]without service interval extension[/TD]
[/TR]
[TR]
[TH]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W0[/TD]
[TD]without washer water level indicator[/TD]
[/TR]
[TR]
[TH]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH]Decorative trims[/TH]
[TD="class: prCode"]4ZG[/TD]
[TD]Chrome-plated decorative trims[/TD]
[/TR]
[TR]
[TH]Additional child seat anchors[/TH]
[TD="class: prCode"]3B7[/TD]
[TD]Child seat anchors as per Canadian
requirements a. ISOFIX child seat system[/TD]
[/TR]
[TR]
[TH]Zündanlaß/Schloß-Sperrsystem/
Elektrische Lenksäulenverriegelung[/TH]
[TD="class: prCode"]0RB[/TD]
[TD]Ignition/starter switch locking system[/TD]
[/TR]
[TR]
[TH]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
Bloughautomotive
C?ID=122717
3VWLZ7AJ2BM307556 is the vin to the car. I apologize that I did not clarify that previous to my employment a lot of changes were done to the car. From what I have been told the car had an electrical issue that caused ecm failure. We are close to having ODIS and the equipment needed so this type of repair will not happen. The cluster, ignition,ecm and entire column electronics was taken out of a parts car owned by the company to repair this vehicle. I am the lucky one to finish the project as the tech that started the repair no longer works at the shop. Again sorry for the lack of known car history.
The coding that you provided was accepted. The only issue I am having is basic settings for the Lateral Acceleration Sensor (G200) sensor. It comes up with error. The traction control light and the tpms light is on. The key is also never found unless put up to the column
The part number of the abs module in the car is 1K0 614 517 CK
I greatly appreciate the information you provided on the long coding portion. I am able to provide many auto scans to add to you data base if you would like more information.
Here is the current auto scan.
Wednesday,23,October,2019,15:39:00:59206
VIN: 3VWLX7AJ0CM463862   Mileage: 174980km-108727miles
   Coding: 0000075
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 000 -
                    Mileage: 174981 km
                    Date: 2014.03.15
                    Time: 03:37:27
                    Temperature: 71.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 980.0 mbar
Readiness: 1110 0101
   Coding: 0000840
   Revision: 00H30001
   Coding: B14B400C492808FD8D1302EA921B1061A71000
   Shop #: WSC 00066 123 12345
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 16390
                    Count: 48640
                    Count: 256
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 212
                    Count: 48640
                    Count: 256
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 270
                    Count: 48640
                    Count: 256
03197 - Stopping Distance Reduction 2 in ADR Control Module (J428)
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 8244
                    Count: 48640
                    Count: 256
   Coding: 030C0C
          B2010 00 [009] - -
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:26:46
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:26:46
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 00:04:10
            006 - Short to Plus
                    Fault Frequency: 42
                    Reset counter: 46
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:33:01
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:31:02
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:30:03
                    Fault Status: 00100001
                    Reset counter: 86
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Reset counter: 86
   Coding: 00003232
   Coding: 30314A
13635840 - Supply voltage
          [Powersupply  lower threshold fall short of]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:09:17
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:32:37
   Coding: 270A01
          [Supply voltage too low]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:28:26
   Coding: 102200
   Coding: 000007
9456681 - Key
                    Fault Frequency: 11
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 04:11:56
          [Under voltage (continued)]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:09:40
                    ELV State: 0C
                    Information Clamps: 77 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 49
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:08:37
                    ELV State: 0C
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 4B
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
          [CAN-Bus off]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:58:38
                    ELV State: 2C
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 2E
   Coding: 020000
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:08:37
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:27:55
1048578 - Supply voltage
          [supply voltage lower limit exceeded]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:24:30
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [restriction due to undervoltage]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:08:40
          B1061 13 [008] - Open Circuit
                    Reset counter: 86
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
          B1064 13 [008] - Open Circuit
                    Reset counter: 86
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
                    Fault Frequency: 30
                    Reset counter: 46
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:17
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:16
   ROD: UHVNA.rod
9457425 - Left audio channel for speech/telephone
          B104F 11 [000] - Short to GND
9457169 - Right audio channel for speech/telephone
          B104E 11 [000] - Short to GND
          [Klemme 30: unterer Grenzwert unterschritten]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:27:02
          U1400 00 [008] - -
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:08:48
End----(Elapsed Time: 01:28, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Bloughautomotive
C?ID=122717
Update I was able to do the basic setting for the Lateral Acceleration Sensor (G200). Will post completed auto scan tmr. Thanks for your help Dana!
Bloughautomotive
C?ID=122717
Well long story short this peach of a car has had its ups and downs since the last post. The car again has had all IMMO parts replaced...again and to save the time I will not give the long story as to why it had to happen. So unfortunately I am in need of the long coding for the ABS. Thank you for the continued support and as I planned I will upload the the final scan when completed.
Wednesday,06,November,2019,09:48:56:59206
VIN: 3VWLP7AJ7CM397441   License Plate:
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 47 56 77
VIN: 3VWLP7AJ7CM397441   Mileage: 114510km-71153miles
47-Sound System -- Status: Cannot be reached 1100
77-Telephone -- Status: Not registered 0001
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CJ    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 3691
   Coding: 0000075
   VCID: 78BCF36B0B340D8F9F-802C
               P1643 - 000 -
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:32:60
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.684 V
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
               P2432 - 000 - Short to Ground
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:33:01
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Voltage: 11.684 V
Readiness: 1110 1101
   Component: AQ 250 6F           1914
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Revision: 00H30001
                    Reset counter: 36
                    Date: 2014.03.29
                    Time: 00:36:42
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 40704
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0160216723
   Coding: 030C0C
   VCID: 3424075B9FDC29EF73-8060
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371086120476
   Coding: 7B994B9A08AB0B0008382000240884C500C2502E6000000030A000000000
   VCID: 2F2E08377EFA0A370E-807A
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Coding: 800000
            006 - Short to Plus
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:44
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:47
   Coding: 00003232
   Coding: 30314A
          B1000 1B [137] - Resistance Too High
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:45
   Coding: 270A01
   Shop #: WSC 00066 000 00123
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:42
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:47
   Coding: 000007
   Revision: 00000000    Serial number: 11000264319002
   Coding: 020000
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:43
1048662 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [CAN TO sound booster]
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:48
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:42
Address 47: Sound System
   ROD: UHVNA.rod
End----(Elapsed Time: 01:36, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
South Molton, UK
Will the ABS not accept the coding suggested by Dana in post #2 of this thread which worked last time?
Bloughautomotive
C?ID=122717
The coding he made in his last post did work but that was for the first swapped IMMO parts. I may not have made it clear in the last post but the car has had the IMMO swapped twice now. The coding he created was for the first IMMO swapped parts. Long story short they have been changed a second time thus the long coding he created is not accepted. If you look at the auto scans the vin have changed.
United States
3VWLZ7AJ2BM307556
Hi,
We're running a 2-tech support team this morning but I can take a crack at that coding at some point. Just to be clear, this is the VIN to the actual vehicle correct?
3VWLZ7AJ2BM307556
[TR]
[TH]Vehicle Identification No.[/TH]
[TD="colspan: 2"]3VWLZ7AJ2BM307556[/TD]
[/TR]
[TR]
[TH]Model[/TH]
[TD="colspan: 2"]Jetta
JEM[/TD]
[/TR]
[TR]
[TH]Date of production[/TH]
[TD="colspan: 2"]16.08.2010[/TD]
[/TR]
[TR]
[TH]Model year[/TH]
[TD="colspan: 2"]2011[/TD]
[/TR]
[TR]
[TH]Sales type[/TH]
[TD="colspan: 2"]162XS3[/TD]
[/TR]
[TR]
[TH]Engine Code[/TH]
[TD="colspan: 2"]CBUA[/TD]
[/TR]
[TR]
[TH]Transmission Code[/TH]
[TD="colspan: 2"]MAN[/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
(unlockable)[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]0GT[/TD]
[TD]Emission standard SULEV[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]airbag[/TH]
[/TR]
[TR]
[TD="class: prCode"]1E7[/TD]
[TD]Activated carbon canister (ORVR), for
intensified evaporation system,
[/TR]
[TR]
[/TR]
[TR]
[TH]Aerials[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]Drive type[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]1KS[/TD]
[TD]Disc brakes in rear (Geomet D)[/TD]
[/TR]
[TR]
[TH]batteries[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
guard[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]QJ1[/TD]
[TD]Chrome package[/TD]
[/TR]
[TR]
[TD="class: prCode"]C00[/TD]
[TD]Operating permit, initial registration[/TD]
[/TR]
[TR]
sunbshade[/TD]
[/TR]
[TR]
[TD="class: prCode"]1JC[/TD]
[TD]Rear shock absorption for sports version[/TD]
[/TR]
[TR]
[/TR]
[TR]
fuel/fuel type[/TH]
[/TR]
[TR]
transmission AQ250
[/TR]
[TR]
[/TR]
[TR]
[TH]Inserts[/TH]
[TD="class: prCode"]5MJ[/TD]
[/TR]
[TR]
[TD="class: prCode"]7M4[/TD]
[TD]Scuff plates in door apertures[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]0FA[/TD]
[TD]Standard manufacturing sequence[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]VF1[/TD]
[TD]pedal cluster[/TD]
[/TR]
[TR]
NAR[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]Antifreeze[/TH]
[/TR]
[TR]
[/TR]
[TR]
equipment[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD]Weight range 4
[/TR]
[TR]
[TD="class: prCode"]L55[/TD]
[TD]Suspension range 55
[/TR]
[TR]
unit 07K.1[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]glove box[/TH]
light[/TD]
[/TR]
[TR]
[TH]Brackets[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]Rear axle[/TH]
[/TR]
[TR]
[TH]Rear seats[/TH]
[/TR]
[TR]
system[/TD]
[/TR]
[TR]
[TH]Headlamps[/TH]
[/TR]
[TR]
- USA -[/TD]
[/TR]
[TR]
[TD="class: prCode"]4N0[/TD]
[TD]Standard dashboard (Leather trimmed minor gauges
+ Ipod drawer)[/TD]
[/TR]
[TR]
dimming[/TD]
[/TR]
[TR]
[TH]Body style[/TH]
[TD]Notchback[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]coolbox[/TH]
cooling system[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]0Y2[/TD]
[TD]Tropical zones[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
front seats[/TD]
[/TR]
[TR]
[TD="class: prCode"]2LF[/TD]
treatment (coextrusion) with changed
protective layer[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
requirements[/TD]
[/TR]
[TR]
(ISOFIX)[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]5K4[/TD]
[TD]Full body cover (shape-adapted system)
with additional transport protection
measures[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]steering[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
wheel[/TD]
[/TR]
[TR]
[TD="class: prCode"]8RL[/TD]
[TD]6 speakers (passive)[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
(R-5)
[/TR]
[TR]
[/TR]
[TR]
extractable[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]Hubcaps[/TH]
[/TR]
[TR]
[TH]Wheels[/TH]
[TD="class: prCode"]CC3[/TD]
[/TR]
[TR]
[TH]Radios[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]tire[/TH]
[/TR]
[TR]
brand[/TD]
[/TR]
[TR]
[/TR]
[TR]
US label[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PL3[/TD]
[TD] SEL 3 package[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PMC[/TD]
[TD]California emission[/TD]
[/TR]
[TR]
airbag[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
rear[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD]Lettering for sales name[/TD]
[/TR]
[TR]
[/TR]
[TR]
label[/TD]
[/TR]
[TR]
label[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
turn signals[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]Horns[/TH]
[/TR]
[TR]
[TH]Control number (no PR family)[/TH]
[TD="class: prCode"]S0C[/TD]
[TD]Introductory volume[/TD]
[/TR]
[TR]
glass[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TH]Bumper[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]2UC[/TD]
[TD]Sports version[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]1Q1[/TD]
[TD]Mass damper for steering wheel, 26.5Hz[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]B38[/TD]
[TD]Legal requirements California[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]doors[/TH]
[TD]4 doors[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: prCode"]9W7[/TD]
[TD]Mobile phone interface (NAR)[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[TH]floor mats[/TH]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[HR][/HR]
Edit; Based on the VIN of 3VWLZ7AJ2BM307556, Part No SW: 1K0 907 379 BC is correct for the car. I believe the factory condition ABS coding was:
B14B400C492208018D1002E9921F1061A70000
Since the Diagnostic VIN is incorrect that won't be accepted. If I flip the VIN Bytes to match the wrong VIN (3VWLP7AJ7CM397441) I end up with:
B14B400C492B08018D0F02E8921A1061A70000
[HR][/HR]
Nerd notes. This is my base (no VIN) coding based on PR-Codes for 3VWLZ7AJ2BM307556:
B1004000490008008D00020092001061A70000
Bloughautomotive
C?ID=122717
The coding was accepted. Again greatly appreciate the support! Here is an upload of the current auto scan.
Monday,11,November,2019,14:39:19:59206
   Coding: 0000075
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:44
                    Temperature: 69.0°C
                    Temperature: 16.0°C
                    Voltage: 11.811 V
   Coding: 0000840
   Revision: 00H30001
   Coding: B14B400C492B08018D0F02E8921A1061A70000
   Coding: 030C0C
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 13 [008] - Open Circuit
                    Reset counter: 76
1057035 - Antenna for Keyless Entry System; Drivers Side
          B116F 13 [009] - Open Circuit
                    Reset counter: 36
                    Mileage: 114514 km
                    Date: 2019.11.11
                    Time: 05:21:12
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
            006 - Short to Plus
                    Reset counter: 36
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:11
   Coding: 00003232
   Coding: 30314A
   Coding: 270A01
   Revision: B2066001
   Coding: 102200
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:32
                    Reset counter: 36
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:37
   Coding: 000007
   Coding: 020000
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:43
          U1111 00 [009] - -
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:48
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:42
   ROD: UHVNA.rod
End----(Elapsed Time: 01:42, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
