Engine Light '09 Golf 1K engine code CAY
dnb9170
Norway
C?ID=288196 (NRRT)
Hi, can someone help?
Tuesday,22,October,2019,11:09:48:58635
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ9W555024   License Plate: SU74419
Mileage: 87870km-54599mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W555024   Mileage: 87870km-54599miles
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 A    HW: 03L 906 023 A
   Component: R4 1.6l TDI   H23 9978
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00114016030400080000
   ASAM Dataset: EV_ECM16TDI02103L906023A 003013
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 2404EF182F3EF46FE3-8070
6395 - Oxygen (Lambda) Sensor B1 S1
          P2237 00 [101] - Pump Current Open Circuit
                    Mileage: 87663 km
                    Date: 2019.09.07
                    Time: 16:37:31
                    Engine speed: 2270.75 /min
                    Normed load value: 28.2 %
                    Vehicle speed: 62 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.005 V
                    Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1]: 108
                    Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor): 0.502 Lambda / 0.000 V
                    Oxygen sensor enhancement adaptation factor-FAC_LSL_GAIN_AD[1]: 1.00815
                    Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1]: 975.0000 °C
                    Time too low oxygen sensor voltage-T_VLS_UP_MIN_DIAG_OC_LSL_UP[1]: 0.0 s
                    Oxygen value calculated-LAMB_EXT_CLC_FIL: 2.4277
                    Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP: 1105.71 hPa
14355 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [175] - Malfunction
                    Fault Frequency: 13
                    Mileage: 87587 km
                    Date: 2019.09.06
                    Time: 15:11:42
                    Engine speed: 0.00 /min
                    Coolant temperature: 63 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 11.746 V
Readiness: 1 1 0 0 0
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 113B200D092700FF880B04E6901D00403000
   Shop #: WSC 30333 002 1048576
   VCID: 76A0E550C12236FF8D-8022
   Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
   Component: Climatronic   130 0305
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 74A4DF58DF5E24EFB3-8020
          B10AB F0 [009] - Too Low
                    Reset counter: 55
                    Mileage: 72803 km
                    Date: 2017.10.03
                    Time: 10:39:20
   Part No SW: 1K0 937 084     HW: 1K0 937 084
   Component: BCM PQ35  B   020 0358
   Revision: 00020000
   Coding: 40180A3A90251AC040000080500000E445010088724D8D60648000000000
   VCID: 6B96C4248A60FB1762-803E
   Component: Wischer 07040  21  0501
   Coding: 009795
01598 - Drive Battery Voltage
                    Reset counter: 86
                    Mileage: 87587 km
                    Date: 2014.01.27
                    Time: 15:08:21
                    Voltage: 13.80 V
                        Term 50 Off
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2R56633O
   Coding: 00003139
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77BEE854CE284FF796-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 222B3647ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 59661147ZZZZZZZZZZZZ
   Serial number: 22182909ZZZZZZZZZZZZ
   Serial number: 2022223FZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 03468C8442F01357BA-8056
   Part No SW: 5K0 920 860 E    HW: 5K0 920 860 E
   Component: KOMBI         H21 0030
   Coding: 170F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 2E100D3071F24E3F05-807A
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 010409F2000014
   Coding: E9807F06000202000002
   VCID: 373E285446A88FF756-8062
   Component: IMMO          H21 0030
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
   Component: Tuer-SG         008 2041
   Coding: 0000180
   VCID: 79BAEE6C303C5987E0-802C
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 69     2501
   Revision: 00H15000
   VCID: 2C1407388FEE3C2F2B-8078
   Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
   Coding: 0000180
   VCID: 7AB8F160353A529FE9-802E
   Part No SW: 1K0 035 186 AB    HW: 1K0 035 186 AB
   Component: Radio RCD310  013 0036
   Revision: 00000000    Serial number: VWZ1Z2I6490037
   Coding: 0500040004
   VCID: 6680B5109182C67F3D-8032
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
   VCID: 7BB6F4643A006B97F2-802E
End----------(Elapsed Time: 00:58, VBatt start/end: 13.9V/14.2V)-----------
I would start by inspecting the EGT and Lambda sensors, and the wiring to them.
dnb9170
Norway
C?ID=288196 (NRRT)
script>
Can anyone tell me which sensor this is?
