Hi
Have fitted a westfalia detachable towbar with 7pin dedicated electrics, the instructions ask the coding to be done via software version managment SVM on ODIS using code 050205. I have tried this with a local agent but wont ecept the code for some reason
Now using VCDS have manged to code the required control units except Adaptive cruise, when trying to do this there is no longcoding helper. can anyone help in giving me the correct code to sort this please.
I understand that not doing it on ODIS wont update the dealer portal but our customer just wants his car back and working.
Tuesday,22,October,2019,09:58:41:52053
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: Wagenworx LTD
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 36 3C 42 44 46 47
52 53 56 5F 62 69 6D 72 A9 AC C0
VIN: WAUZZZ8R2GA100655 Mileage: 61600km-38276miles
Address 01: Engine (J623-DEHA) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 C HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0008
Revision: 54H23---
Coding: 2A2A4032257603030000
Shop #: WSC 07475 003 104857
ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
ROD: EV_ECM30BTD0118K5907589C.rod
VCID: C1CA180350421F4768-8094
4330 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Mileage: 61600 km
Date: 2019.10.21
Time: 17:43:11
Engine speed: 0.00 /min
Coolant temperature: 91 °C
Intake air temperature: 36 °C
Voltage terminal 30: 12.000 V
ACC target acceleration: 0.007 m/s²
ACC control module received status-Bits 0-7: 7
Active brake system error status-Bits 0-7: 1
Status of ACC/CCS acceleration interface-Bits 0-7: 4
Acceleration: 0.000 m/s²
Engine status: COENG_READY
Part No SW: 8R0 927 158 BC HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1006
Revision: --H19---
VCID: FF4E5EFB6636A9B75E-80AA
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 BF HW: 8R0 907 379 BF
Component: ESP8 quattro H09 0020
Coding: 38EDCE01
Shop #: WSC 06335 000 00000
VCID: 8542CC130CEAF36714-80D0
Part No SW: 8K0 907 064 KH HW: 8K0 907 064 KH
Component: BCM2 2.0 H15 0711
Coding: 05B54040000000000000
VCID: 804CDD0713C8D64F27-80D4
Subsystem 1 - Part No SW: 8K0 959 754 BR HW: 8K0 959 754 BR
Serial number: 0816000008761015
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000208250008
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01250120161788
Coding: 3625028080
VCID: F8BCB5E74B189E8F1F-80AC
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00001265087702
Coding: 260000108074AFF2318140C300001D0D0F9DE70827090201000008004400030100000024000000
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 160109 H13 0050
Serial number: 90243015151109164301
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 61239233
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001301160374
Serial number: A1B8CD08000000000001
Address 13: Auto Dist. Reg (J428) Labels: Redir Fail!
Part No SW: 8R0 907 561 A HW: 8R0 907 561 A
Component: ACC3 H11 0110
Coding: 008172
VCID: B73E76DB068651F7D6-80E2
Reset counter: 47
Mileage: 61600 km
Date: 2019.10.21
Time: 17:35:52
Temperature: 26.0°C
Voltage: 13.06 V
Hex Value: 0x005D
Lateral Accel.: 0.00 m/s^2
Fault Status: 00101101
Reset counter: 87
Mileage: 61600 km
Date: 2019.10.21
Time: 17:35:52
Temperature: 26.0°C
Voltage: 12.93 V
Hex Value: 0x00BE
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H49 0610
Serial number: 003JPDD1EV8+
Coding: 304A3531313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: C8DC052773782E0FAF-809C
Serial number: 6334MSME563A4859N
Serial number: 6344MSME565A4E46S
Serial number: 6352QSME0E5A256EX
Serial number: 6362QSME676E3E60Y
Serial number: 63732SME48510E682
Serial number: 63832SME45515760X
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Revision: -------- Serial number: 90372PAH000QS
Coding: 00003F
VCID: C4C4111747500A6F43-8090
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 951 HW: 8R0 920 951
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 03I24JL1H
Coding: 33A72200A7012600010000
VCID: F4A481D75770FAEF33-80A0
Part No SW: 8R0 907 468 AA HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0070
Revision: 1Z130032 Serial number: 3241Z161120D45
Coding: 80CD07FF00
VCID: FEB0A3FF693CA0BF55-80AA
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 2153078903
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 16019004182021200410
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 0C0100
VCID: BA386FEF35944C9F29-80EE
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 02022064747464545425363E00
VCID: FCB4A9F77F20B2AF7B-80A8
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H15 0100
Serial number: 001301160001019
VCID: AF2E4EBBF6D699378E-80FA
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000180787195
Coding: 01781B00000000000000
VCID: C2C8170F5D44045F71-8096
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H07 0071
Serial number: 0390383126
Coding: 010312
Shop #: WSC 06334 000 00000
VCID: BFCE1EFB26B669B71E-80EA
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H07 0071
Serial number: 0391820025
Coding: 010312
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0511
Revision: Serial number: 0000182312039
Coding: 011D12215E01440004
VCID: CFEE2E3B9E16F937EE-809A
Part No SW: 8R0 909 144 Q HW: 8R0 909 144 L
Component: RCevo H53 0702
Revision: 00000003 Serial number: 0000399876
Coding: 010000010001
ASAM Dataset: EV_RCEPSAU48X 104002
ROD: EV_RCEPSAU48X_104.rod
VCID: C6C00B1F796C387F5D-8092
Revision: 00002001 Serial number: 0391591921
Coding: 013B0E22A0B9309587200536A0040047
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H04 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H04 0090
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813054879807
VCID: AD1254B3F4DAEB27BC-80F8
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H03 0511
Revision: Serial number: 0000183417637
VCID: CED0333F991CF03FE5-809A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H03 0005
Revision: -------- Serial number: 20000000725209
ROD: EV_ParkiBrake_AU48.rod
VCID: BA386FEF3D944C9F29-80EE
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109AY0G2527159
Coding: 010103010000000001
VCID: AB165AABCACEE517A2-80FE
Part No SW: 8R2 035 666 K HW: 8R2 035 666 H
Component: H-BN-EU H49 0946
Revision: -------- Serial number: 515A10GS006321
Coding: 1A0101060205A9ED75808B5E00000403E40100020000000000
VCID: C1CA180358421F4768-8094
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Component: DU7 High H42 0104
Serial number: A130AI0G3519201
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000002453524
Component: CD-Database 6890
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H02 0510
Revision: Serial number: 0000183451368
Coding: 010C12204001240004
VCID: C6C00B1F716C387F5D-8092
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: ConWys Trailer H09 0100
Revision: 1G001001 Serial number: 00000173782896
Coding: 0100000000000000
Shop #: WSC 00375 223 87350
VCID: B5227CD31C8AA3E7C4-80E0
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: BD3264F324BA7BA70C-80E8
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H02 0510
Revision: Serial number: 0000183451367
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 151214201745
VCID: F9BAB0E37812878760-80AC
Part No SW: 4G0 907 355 G HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0013
Revision: 00000000 Serial number: 153290418
ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 A HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H10 0008
Serial number: 151026200628
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: B22847CFE5E4B4DFE1-80E6
End----------(Elapsed Time: 02:21, VBatt start/end: 14.7V/14.5V)-----------
