Monday,21,October,2019,15:17:22:21652
-- Windows Based VAG/VAS Emulator Running on Windows 7 x86
Version: 19.6.2.0 HEX-V2 : 0.4508.4
VIN: WVWZZZ3CZGE002584 License Plate: TMPS ERROR PASSAT B8
Mileage: 247104km-153543mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 6C
VIN: WVWZZZ3CZGE002584 Mileage: 247104km-153543miles
03- Brakes -- Status: Malfunction 0010
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2,0L H21 1343
Revision: B5H21---
Coding: 011D003203241D083000
Shop #: 05311 115 00300
Dataset: EV_ECM20TDI01104L906026ET 002001
ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
VCID: 00598701AA864A47C97-8054
Part No SW: 0D9 300 041 A HW: 02E 927 770 AQ
Component: DQ250-6F H53 4801
Revision: 05853104 Serial number: TFK01504262177
Shop #: 05311 115 00086
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1675C159D802D4F703B-8042
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 K HW: 3Q0 907 379 F
Component: ESC H42 0622
Revision: 00000000 Serial number: 61225000001213
Coding: 0EEC6A8F34200B6E077C060841C74970562CD0E0608292F13062F078C202
Shop #: 131071 1023 2097151
Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
VCID: 42DD4D09E40A98579F3-8016
16385 - Display
C1146 F2 [137] - EEPROM Malfunction
Reset counter: 37
Mileage: 247104 km
Date: 2016.01.11
Time: 04:25:15
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0709
Revision: 00026000 Serial number: 0369523318
Coding: 000F0F0703
Dataset: EV_KessyHellaMQBAB 004032
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 392F2AE589DCDB8FCE9-806C
Part No SW: 5G0 907 044 BF HW: 5G0 907 044 BF
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 11020104202100011015500000101802
Shop #: 00015 115 00001
Dataset: EV_ACClimaBHBVW37X 005137
VCID: 6C81C3B1B60EBE2705F-8038
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AH HW: 5Q0 937 086 AH
Component: PQ37BOSCH 028 0162
Revision: -------- Serial number: 86583004152335
Coding: 00011842C2C102FF43E04004000007081880000000000000000000000000
Shop #: 05311 115 00105
Dataset: EV_BodyContrModul1UDSBosc 015002
ROD: EV_BCMBOSCH_015.rod
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150427 042 0607
Serial number: 150430072614
Component: 037 0059
Serial number: S5Y15M05D20H09M46S48
Coding: 90A8DD
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - H01 0032
Serial number: 07 04 2015 00000345
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: ˙˙˙305183615132
Coding: 0271161051
Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000.rod
VCID: 0D47AE35EDD4172FB21-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: BOSCH H04 0192
Coding: 3200600151FFC428949C804D
Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34311BD1AEBE26E71DF-8060
Part No SW: 3Q0 959 655 AF HW: 3Q0 959 655 AF
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R2P9ARYKS
Coding: 88CCC000000000005C5400CC000800000065
Shop #: 05314 000 00001
Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 025D8D09A48A5857DF3-8056
Subsystem 1 - Part No SW: ----------- HW: 454 003 004 15
Serial number: 3576U0000000B3C80414
Subsystem 2 - Part No SW: ----------- HW: 454 003 004 15
Serial number: 3586U0000005A3C80419
Subsystem 3 - Part No SW: ----------- HW: 454 802 204 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RD98772060000008
Subsystem 4 - Part No SW: ----------- HW: 454 800 405 15
Component: SideSensor_Pr 111 0148
Serial number: 3526R1CF494060000008
Subsystem 5 - Part No SW: ----------- HW: 454 800 905 15
Component: FrontSensor_D 114 0149
Serial number: 3556V2B605B060000005
Part No SW: 3Q0 953 521 HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150510400013
Coding: 0010
Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 6D87CEB58D14B72F121-8038
Part No SW: 3G0 920 741 HW: 3G0 920 741
Component: KOMBI 209 4300
Coding: 07A401182380000800886B011001000000000000
Shop #: 00015 115 08193
Dataset: EV_DashBoardVDDMQBAB 009042
VCID: 619FA28541CCE34FA69-8034
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW High 212 2227
Revision: -------- Serial number: 14051510800335
Coding: 0B0300045F087300FB0002481C0F00010001070000000000000000000000
Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 75B7E6D5E5447FEFEA1-8020
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0038
Serial number: 29150000824360025175
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 1690236603
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H54 0033
Serial number: 0062493
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000084229018
Coding: 0800000000000000
Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD2C5912C53CF369-8024
Component: FS 020 0041
Serial number: 280415BDR16596
Coding: 00350B20D000020000001000
Dataset: EV_DCUDriveSideEWMAXKLO 006003
VCID: 43D3480DFB10915F945-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000001403404
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2033
Revision: 00000000 Serial number: 0000214627
Coding: 01010010005000
Shop #: 00015 115 00300
Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
VCID: 3B2330ED83E0E99FDC5-806E
Component: BFS 020 0041
Serial number: 300415BDT06127
Coding: 00350120D000020000001000
Dataset: EV_DCUPasseSideEWMAXKLO 006003
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000001406395
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035--STD2.clb
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0624
Coding: 02840101FF00000051110001000808001F01008401200100CF
Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 6E85C9B980124C372BB-803A
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R1410329
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 0184010162002017000040
Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
VCID: 77ABECDDFF480DFFF8D-8022
End----------(Elapsed Time: 01:49, VBatt start/end: 12.1V/12.0V)-----------
