trying to see if a few things are possible to check/change on VCDS.
(1) on MY2015 scheduled charging is only accessible via the CarNet App. (2016+ this is accessible on the headunit) My CarNet subscription expired so i can no longer change the scheduled charging. Can this be changed on VCDS?
(2) can you check battery life/degradation? When my car was new i could easily get 100+ miles of range with conservative driving. Now its down about 80. Would like to see if i can check the battery life.
Sunday,20,October,2019,12:00:08:29944
VCDS Version: 19.6.2.0 (x64)
VIN: WVWPP7AU2FW9 License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75 8C
BD C0 C5 C6
VIN: WVWPP7AU2FW9 Mileage: 81801km-50828miles
BD-Hi Volt. Batt. Charg. -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
Address 01: Engine (J623-EAGA) Labels:. 0EA-907-309-V1.clb
Part No SW: 0EA 906 016 C HW: 0EA 907 309 A
Component: E-Vehicle H23 8073
Revision: WMH23---
Coding: 000D0016002400007000
ASAM Dataset: EV_VCU00XXX0110EA906016C 002005
ROD: EV_VCU00XXX0110EA906016C_002.rod
VCID: 2F6DACB77669B4370E-807A
17154 - Acceleration Monitoring
P150B 00 [032] - Value Above Upper Control Limit
23599 - Active Radiator Shutter 1
P05A0 00 [032] - Stuck Open
25439 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [032] - -
18939 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AE HW: 5Q0 907 379 H
Component: ESC H31 0808
Revision: 00000000 Serial number: 61155000000246
Coding: 01FA40A12C21316D017F020081C3298002348C80408194B202810058C242
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001_VW37.rod
VCID: 7F0DBCF7E68984B7DE-802A
16401 - Tire Pressure Warning
C102D 00 [032] - -
32832 - Switch for Electric Parking Brake
C100C 07 [032] - Mechanical Failure
Revision: 00021000 Serial number: 0366775678
Coding: 030C0C
VCID: 3A7B8DE3BD2B619FA9-806E
Part No SW: 5GE 907 044 AD HW: 5GE 907 044 AD
Component: Climatronic H02 1105
Revision: 00001K07
Coding: 00022200200100000005000200111801
ASAM Dataset: EV_ACClimaBHBVW37X 005132
VCID: 7EF341F3E1838DBFD5-802A
Air quality sensor:
328196 - Motor for Right Temperature Flap
B108D 71 [008] - Actuator stuck
Reset counter: 1
Mileage: 81108 km
Date: 2019.10.10
Time: 18:55:16
Voltage terminal 30: 14.4 V
Outside air temperature: 16.0 °C
Interior temperature: 20.8 °C
Right temperature flap: actual value: 78
Right temperature flap: actual value: 25.0 %
Right temperature flap: specified value: 22
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [008] - Open or Short to Plus
Reset counter: 25
Mileage: 80739 km
Date: 2019.10.04
Time: 10:25:41
Voltage terminal 30: 14.9 V
Outside air temperature: 19.0 °C
Interior temperature: 25.7 °C
Right temperature flap: actual value: 237
Right temperature flap: actual value: 100.0 %
Right temperature flap: specified value: 236
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0137
Serial number: 01011511000308
Coding: 00011A66434182E169E44000001407201C00000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 79F952EFF8ADAA87E0-802C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150413 043 0551
Serial number: 150416135942
Component: RLHS 037 0059
Serial number: S2Y15M04D28H09M35S15
Coding: 90A8DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391511800713
Coding: 2031151011
VCID: 3D7186FFAC0556A78C-8068
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR01RSG1
Coding: 8CCCFC00002000005000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 479DE417FED90C7726-8012
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002O9JJ0F
Coding: 303139
Subsystem 2 - Part No SW: ----------- HW: 480 002 704 15
Serial number: 35700000000279BC031H
Subsystem 3 - Part No SW: ----------- HW: 480 002 704 15
Serial number: 358000000005C26D231H
Subsystem 4 - Part No SW: ----------- HW: 480 401 704 15
Serial number: 3510002B51A91E76112-
Subsystem 5 - Part No SW: ----------- HW: 480 401 704 15
Serial number: 3520002B51A91E7532C6
Subsystem 6 - Part No SW: ----------- HW: 480 401 704 15
Serial number: 3550002C51A91E71F39G
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 704 15
Component: FrontSensor_P 001 6149
Serial number: 3560002C11A91E715270
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 16041504221261
Coding: 0410
ROD: EV_SMLSKLOMQB_010_VW37.rod
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 5GE 920 855 HW: 5GE 920 855
Component: KOMBI 301 4311
Coding: 0B35181A2B80CF05020868001700030000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 C HW: 5QE 907 530 A
Component: GW MQB EV 312 3203
Revision: -------- Serial number: 21041510800756
Coding: 0201001746F81000EF001200081E00000001050100030000000000000000
ASAM Dataset: EV_GatewEVConti 011020
ROD: EV_GatewEVConti_011.rod
VCID: 4683E913F9D3157FDD-8012
Subsystem 1 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29150000669780035164
Coding: 30FFFF
Subsystem 2 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9915866403
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 A HW: 5QE 909 059 A
Component: EBKV H12 0160
Serial number: 085430010693
Coding: 01720100321A02030002000500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
VCID: 4C97DB3BE7BFEF2F0B-8018
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 A HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0140
Serial number: 05802861150415233159
194560 - Indicator Lamp for Brake System
C121A 00 [032] - Defective
239616 - Implausible Data Received from Engine Control Module
U0401 00 [040] - -
Fault Frequency: 73
Mileage: 64746 km
Date: 2018.11.13
Time: 07:35:01
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000101935002
Coding: 7900000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3467A3DB9F4F97EF73-8060
Part No SW: 5Q0 959 393 D HW: 5Q0 959 393 B
Component: TSG FS 020 0028
Serial number: 130415BDC02558
Coding: 003013208000040000000000
VCID: 408FFF0BDBF73B4FE7-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005967303
Coding: 111000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: C102
VCID: 4385F007CAE12057FA-8016
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5QE 907 080 C HW: 5QE 907 080 C
Component: VW370E2615010 H06 2461
Revision: 00H06000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM09550115QE907080C 001020
ROD: EV_DMCM09550115QE907080C.rod
25304 - Inverter Idle Mode not possible
P32B5 00 [096] - -
Part No SW: 5Q0 959 392 D HW: 5Q0 959 392 B
Component: TSG BFS 020 0028
Serial number: 030415BD21389A
Coding: 003013208C00040000000000
VCID: 3F8DFCF7A60944B79E-806A
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005992801
Coding: 091000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 051A000101000000
VCID: 75E15EDFD4B5CEE784-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 R025
Serial number: V7B00904151860
Coding: 02737002FF00000021220001001800001F0100140100010544
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 69D902AF880D1A0710-803C
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9RS600P8X
Subsystem 2 - Part No SW: 5G0 919 866 S HW: -----------
Component: NAR 2015 --- 0022
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02737002C2829A017FFE06000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 5QE 915 227 M HW: 5QE 915 227 H
Component: K8C H13 0722
Serial number: VWADFDU01L
ASAM Dataset: EV_BECM08820215QE915227M 003016
ROD: EV_BECM08820215QE915227H.rod
VCID: 52ABC543059BB9DF41-8006
Address BD: Hi Volt. Batt. Charg. (J966) Labels:| 5QE-915-022.clb
Part No SW: 5QE 915 022 G HW: 12E 915 022 C
Component: LMSG H08 1075
Serial number: 00920051320496
Coding: 4A4904
ASAM Dataset: EV_HVChargManagVWMQB 001001
ROD: EV_HVChargManagVWMQB_001.rod
VCID: 4581EE1FC4D51E67D4-8010
2098176 - DC Quick-Charge; Charging Station Initialization Error
P33E5 00 [008] - -
Reset counter: 35
Mileage: 81760 km
Date: 2019.10.20
Time: 17:28:38
Chademo version-Vehicle: 0
Chademo version-Chg. statn.: 0
DC charging PLC-Malfunction status: 0
DC charging PLC-Current: actual value: 0.0 A
DC charging PLC-Connection status: Not Present
DC charging PLC-Minimum voltage: 0.0 V
DC charging PLC-Maximum voltage: 0.0 V
DC charging PLC-Minimum current: 0.0 A
DC charging PLC-Maximum current: 0.0 A
DC charging PLC-Actual Voltage: 0.0 V
Status of actuator test: not active
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 H HW: 5QE 035 335 H
Component: E_SOUND_SG H07 0198
Serial number: EN151602840000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 005012
ROD: EV_ENoiseS1NNVW3707_005.rod
Address C5: Therm. mgt. (J1024) Labels: None
Part No SW: 5GE 907 458 HW: 5GE 907 458
Component: TME-Min H03 0108
Serial number: 0006384
ASAM Dataset: EV_ThermContrVISAU49X 001009
ROD: EV_ThermContrVISAU49X_VW37.rod
VCID: 020B3503957BE95FB1-8056
Subsystem 1 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G395 pT-Sens1 H61 0006
Subsystem 2 - Part No SW: 12E 963 231 F HW: 12E 963 231 F
Component: J848 HV-PTC H09 0206
Serial number: T151143003807000140
Air Conditioning Compressor Sub:
Subsystem 3 - Part No SW: 5QE 820 803 A HW: 5QE 820 803 A
Component: J842 eKK H03 0007
Geber für Kältemitteldruck/Kältemitteltemperatur 2:
Subsystem 4 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G826 pT-Sens2 H61 0006
Geber für Kältemitteldruck/Kältemitteltemperatur 3:
Subsystem 5 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G827 pT-Sens3 H61 0006
Geber für Kältemitteldruck/Kältemitteltemperatur 4:
Subsystem 6 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G828 pT-Sens4 H61 0006
Geber für Kältemitteldruck/Kältemitteltemperatur 5:
Subsystem 7 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G829 pT-Sens5 H61 0006
Refrigerant Expansion Valve 1:
Subsystem 8 - Part No SW: 4M0 816 682 HW: 4M0 816 682
Component: N636 EV1_KaMi H09 0102
Serial number: 00000000000020042355
Refrigerant Expansion Valve 2:
Subsystem 9 - Part No SW: 4M0 816 682 HW: 4M0 816 682
Component: N637 EV2_KaMi H09 0102
Serial number: 00000000000020042351
Refrigerant Expansion Valve 3:
Subsystem 10 - Part No SW: 4M0 816 682 HW: 4M0 816 682
Component: N638 EV3_KaMi H09 0102
Serial number: 00000000000020044484
Refrigerant Shut Off Valve 1:
Subsystem 11 - Part No SW: 4M0 816 703 HW: 4M0 816 703
Component: V424 AV1_KaMi H09 0102
Serial number: 00000000000040045127
Refrigerant Shut Off Valve 4:
Subsystem 12 - Part No SW: 4M0 816 703 HW: 4M0 816 703
Component: N642 AV4_KaMi H09 0102
Serial number: 00000000000040044403
Refrigerant Shut Off Valve 5:
Subsystem 13 - Part No SW: 4M0 816 703 HW: 4M0 816 703
Component: N643 AV5_KaMi H09 0102
Serial number: 00000000000040036796
8 Faults Found:
32837 - HV Electronics Coolant Pump Control
P0CEB 00 [040] - Short to GND
Mileage: 8878 km
Date: 2016.03.23
Time: 16:11:44
37000 - Implausible Data Received From Electric A/C Compressor
U046C 00 [032] - -
37016 - Refrigerant Pressure/Temperature Sensor 2
P1C5D 00 [032] - No Signal
37025 - Refrigerant Pressure/Temperature Sensor 3
P1C60 00 [032] - No Signal
37033 - Implausible Data Received From Electric A/C Compressor
U046C 00 [032] - -
37096 - Automatic addressing Sub Bus 1
B1484 21 [032] - Signal Amplitude Too Low
37126 - Automatic addressing Sub Bus 2
B1485 21 [032] - Signal Amplitude Too Low
59002 - A/C Compressor; High Voltage Power Suppy
B1453 F0 [032] - Malfunction
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 5QE 915 681 B HW: 5QE 915 681 B
Component: OBC Delta-ES H52 1550
ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
ROD: EV_OBCTwoPhaseDT2VW3707.rod
VCID: 4B95D827E2B1E81702-801E
End-------------------------(Elapsed Time: 05:35)--------------------------
