Sunday,20,October,2019,13:39:00:25110
VIN: 9BWDE61J724020003 License Plate:
76
VIN: 9BWDE61J724020003 Mileage: 163280km-101457miles
Address 01: Engine Labels: None
Part No: 06A 906 032 S2
Component: 1.8L R4/5VT G 0001
Coding: 07500
Shop #: WSC 00066
VCID: 6099A2FFC3558267A97-5184
XXXXXXXXXXXXXXXXX XXXXXXXXXXXXXX
9 Faults Found:
18058 - Powertrain Data Bus
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
18044 - Powertrain Data Bus
P1636 - 35-10 - Missing Message from Airbag Controller - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
17881 - EVAP Leak Detection Pump
P1473 - 35-00 - Open Circuit
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
16519 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P0135 - 35-10 - Malfunction - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-10 - Performance too Low - Intermittent
16621 - Manifold Pressure / Boost Sensor (G31)
P0237 - 35-10 - Signal too Low - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 35-10 - Implausible Signal - Intermittent
Readiness: 0010 0100
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00000 785 00200
VCID: 2B0305D3FF13113F4C5-5184
013 - Check DTC Memory
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0004
Coding: 12344
VCID: 270BF9E3E6FB355FA8D-5160
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 J
Coding: 07232
VCID: 2F3B11C3CE0B6D1F60D-5160
9BWDE61J724020003 VWZ7Z0A3900683
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00001
VCID: 70B9D2BF13B532E7397-5160
Part No: 1C0 959 799 C
Component: 1J Komfortgerát HLO 0003
Coding: 00064
Shop #: WSC 00001
VCID: 372B29A3365BA5DF38D-4B1E
Component: 1J Tõrsteuer.FS KLO 0002
Component: 1J Tõrsteuer.BF KLO 0002
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: RADIO 3CP 0005
Coding: 04031
Shop #: WSC 00066
VCID: 2411EEEF97CDDE478DF-5160
End----------(Elapsed Time: 04:58, VBatt start/end: 12.2V/12.2V)-----------
is there anything in common with my codes ?
honestly I can't make sense out of the wiring diagrams. I was hoping somebody would have some short cuts. I'll be checking grounds and fuses while I wait for the magic answer.
Dave
