After replacement of OEM shocks with KW shocks, the suspension fault display now comes on maybe after 10 miles. When the car is restarted, the code is off only to reappear after another couple of miles. The car has been slightly lowered with the shock install. I have posted the autoscan. Yes, we havehe DCC resistors installed and have been in contact with KW.
Sunday,06,October,2019,12:15:43:54023
VCDS Version: 19.6.2.0 (x64)
VIN: WAUF1GFF9G1030501 License Plate: RC 66R8
Mileage: 107970km-67089mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
55 5F 6C A5 A9 BB BC
VIN: WAUF1GFF9G1030501 Mileage: 107970km-67089miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00122466000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H.rod
VCID: 45AFA4C0C472E167D4-8010
17178 - Databus
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4903
Revision: 06253104 Serial number: TFK01507151448
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 538B8A983A264FD74A-8006
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61885000001108
Coding: 31FF6B9254230A6C017C030041C4698CD62A5080C08296B6184150D48208
ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
VCID: 7AD5073CFD0C5E9FE9-802E
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 165
Mileage: 106969 km
Date: 2019.08.05
Time: 10:47:42
Revision: 00021000 Serial number: 0374834977
Coding: 030C0C
VCID: 3A55C73CBD8C9E9FA9-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000707976
Coding: 03000014010000000000000000001400
VCID: 334BEA189AE66FD76A-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: D4394FB7000000000001
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061520400821
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 012770D090DA0D47A8-8054
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150717 042 0585
Serial number: 150725015637
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 24114778
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 29 05 2015 00000019
Serial number: 00000000000033149633
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000FW78Q00000
Coding: 101F00
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Reset counter: 227
Mileage: 107696 km
Date: 2019.09.15
Time: 17:44:34
204293 - Remote key 1
B1479 54 [008] - Missing Calibration / Basic Setting
Reset counter: 227
Mileage: 107889 km
Date: 2019.10.05
Time: 10:44:32
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331521007490
Coding: 0070150011
VCID: 43ABBAD8CA46DF57FA-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 N HW: 5Q0 907 567 N
Component: ACC3 H10 0400
Serial number: 13091703070475
Coding: 01261701FE0309
Shop #: WSC 27775 002 1048576
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 46ADA3CCF974EA7FDD-8012
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 280715004
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
3149829 - Valve for Damping Adjustment Front Left
C1040 1D [008] - Current Implausible
Reset counter: 228
Mileage: 107895 km
Date: 2019.10.05
Time: 10:49:31
COM: 00 33 09 33 00 0D 01 00 13 00
Voltage terminal 30: 14.4 V
Terminal 15 status via CAN: Terminal 15 on
Vehicle_level_sender_PWM-Left front: Not available
Vehicle_level_sender_PWM-Right front: Not available
Vehicle_level_sender_PWM-Left rear: 90.8 %
Vehicle_level_sender_PWM-Right rear: 61.6 %
AMR state: 6
Damping adjustment indicator lamp: On
Dampening adjustment: current Highside-Left front: -19 mA
Dampening adjustment: current Highside-Right front: -16 mA
Dampening adjustment: current Highside-Left rear: 0 mA
Dampening adjustment: current Highside-Right rear: 5 mA
Dampening adjustment valve: current Lowside-Left front: -8 mA
Dampening adjustment valve: current Lowside-Right front: -3 mA
Dampening adjustment valve: current Lowside-Left rear: -14 mA
Dampening adjustment valve: current Lowside-Right rear: 3 mA
ESP automatic engagement: activated
Fall-back level: 00 00 06 42
3153925 - Valve for Damping Adjustment Front Right
C1041 1D [008] - Current Implausible
Reset counter: 228
Mileage: 107894 km
Date: 2019.10.05
Time: 10:48:38
COM: 02 33 09 33 00 0D 01 00 0D 00
Voltage terminal 30: 14.3 V
Vehicle_level_sender_PWM-Left front: 35.2 %
Vehicle_level_sender_PWM-Left rear: 15.6 %
Vehicle_level_sender_PWM-Right rear: 15.2 %
AMR state: 0
Damping adjustment indicator lamp: OFF
Dampening adjustment: current Highside-Left front: 2459 mA
Dampening adjustment: current Highside-Right front: -8 mA
Dampening adjustment: current Highside-Left rear: 1135 mA
Dampening adjustment: current Highside-Right rear: 1073 mA
Dampening adjustment valve: current Lowside-Left front: 2442 mA
Dampening adjustment valve: current Lowside-Right front: 3 mA
Dampening adjustment valve: current Lowside-Left rear: 1127 mA
Dampening adjustment valve: current Lowside-Right rear: 1077 mA
ESP automatic engagement: not activated
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR02ZJZK
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47B3AEC8FE7EF37726-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A04081570148
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A04081570353
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001DH35F
Coding: 303337
Subsystem 4 - Part No SW: ----------- HW: 480 002 707 15
Serial number: 357000000006000DB518
Subsystem 5 - Part No SW: ----------- HW: 480 002 707 15
Serial number: 35800000000FF00DB51X
Subsystem 6 - Part No SW: ----------- HW: 480 402 207 15
Serial number: 35100029F1B7E8E1023A
Subsystem 7 - Part No SW: ----------- HW: 480 402 207 15
Serial number: 35200029F1B7E8E4C27U
Subsystem 8 - Part No SW: ----------- HW: 480 400 805 15
Serial number: 35500029F1A91E7261AE
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 805 15
Component: FrontSensor_P 001 6149
Serial number: 3560002A11A91E71A341
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 GR HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 02081508490053
Coding: E818
ROD: EV_SMLSKLOMQB_010_AU37.rod
VCID: 10014594CBB074CF37-8044
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Part No SW: 8V0 920 972 B HW: 8V0 920 972 B
Component: KOMBI H03 6420
Coding: 0BCD181B7F88D7050281E8001800000000000000
VCID: 3D5FCC20ACA2A9A78C-8068
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 21071510801799
Coding: 0101000830085A005B00023C980B00000001010000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 75CF1400D41231E784-8020
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 14 07 2015 F0049179
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00008.06.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000176510003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3449E9049FE868EF73-8060
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0080
Serial number: 0374187880
Coding: 030211
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3851DD3483808C8F5F-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0080
Serial number: 0372243119
Coding: 030211
Component: TSG FS 020 0041
Serial number: 070715BG703316
Coding: 005D1B205C00048000000003
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9102
VCID: 3753DE088E9E83F756-8062
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAFN90196DW
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: 3957D830B88A9587A0-806C
Component: TSG BFS 020 0041
Serial number: 100715BG919537
Coding: 005D13205E00048000000003
VCID: 42A5BFDCD55CD65FF1-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 0122000123200400
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FA3B628A6AEBBB79E-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 038 B HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302H0FB017550
Coding: 017301020000000021220002041A00102F000225010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY203QUA
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000004061500030111
Compact Disc Database:
Component: Gracenote --- 3006
6667 - Optical Data Bus for Information Electronics 1
U10CA 00 [008] - Intermittent Disruption
Reset counter: 228
Mileage: 104874 km
Date: 2019.06.08
Time: 14:43:20
Voltage terminal 30: 13.7 V
Temperature of MOST transceiver-max.value: -50 °C
Temperature of MOST transceiver-min.value: -19 °C
Temperature of MOST transceiver-Current: 31 °C
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 3041E5146BF054CF17-8064
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000399125
Coding: 0100000000010303000500010100000100
ROD: EV_MFKBoschAU370.rod
VCID: 3C59C124B7B8A0AFBB-8068
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 150701200993
VCID: 7DDF0C20EC2269A7CC-8028
0006 - Actuator for Structural Accoustics
P193A 00 [009] - Open Circuit
Fault Frequency: 27
Reset counter: 188
Mileage: 104695 km
Date: 2019.06.04
Time: 15:03:51
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 240715BGG1795B
Coding: 004D13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 240715BGN16786
