2017 GTI ACC Screwed Up
invernesspl
C?ID=345478
Just found this thread whilst trying to resolve a problem with the distance sensor on a 2017 golf GTi.
Error message on dashboard says front assist unavailable. Here is the coding I found:
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_ACCBOSCHVW416 002005 (VW37)
VCID: 3C21379876E1AAE7D5F-8068
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MISALIGNMENT_VERTICAL]
Reset counter: 46
Mileage: 2699 km
Date: 2019.10.19
Time: 11:15:20
Control Module temperature: 23 °C
Voltage terminal 15: 11.7 V
The front of the car has been apart but no accident damage, when it was put back together it was fine, but then a few days later this error occurred.
So is this a dealer only re calibration?
Thanks.
invernesspl
C?ID=345478
Here is the full Autoscan... (distance sensor was unplugged)
Saturday,19,October,2019,11:36:44:41168
VIN: WVWZZZAUZHW382157   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6 D7
VIN: WVWZZZAUZHW382157   Mileage: 2699km-1677miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091900122444050B2000
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E050DD0B09D48776BB-807A
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:37
                    Engine speed: 745.75 /min
                    Normed load value: 10.2 %
                    Coolant temperature: 36 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 13.066 V
                    Engine: operating status: IS
                    ECU_STATE: SYN_ENG_IGK_ON
                    Engine oil temperature: 12.0 °C
                    Time since engine start: 70.5 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 51107000001206
   Coding: 01FA93A13428216E47780605C0CAA980C92C84E26003957734405078C009430000000012121212B835351919323200
   VCID: 76B5E5B0084D30B7E3B-8022
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 46
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:36
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012000420011001100500000010102A
   VCID: 6D87CADC7D1BF36F121-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001711104482
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5FD90207D78F7BBB-802A
   Component: WWS    170328  042 0551
   Serial number:         170419121454
   Component: RLHS  042 0105
   Serial number: S8Y17M05D03H10M23S41
   Coding: 00A8DD
   Serial number: 000000000ZY171021408
   Serial number: 00000000000068946239
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617123
   Coding: 0471051001
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4ACD61402C350457573-801E
Address 13: Auto Dist. Reg
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0318
   Serial number: 003TDR2XA8B7
   Coding: 98CCC000000000005C0000CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B3280AE97E87597-8044
   Belt Pretensioner left:
   Serial number: 34169677E04051751477
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E28041751083
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 205 17
   Serial number: 35700000000228F0C32G
   Subsystem 4 - Part No SW: -----------    HW: 480 000 205 17
   Serial number: 35800000000C7C15A32P
   Subsystem 5 - Part No SW: -----------    HW: 480 402 404 17
   Serial number: 3510001B1254CB1446C/
   Subsystem 6 - Part No SW: -----------    HW: 480 402 404 17
   Serial number: 3520001BB24E983154C9
   Subsystem 7 - Part No SW: -----------    HW: 480 400 305 17
   Serial number: 3550001C325A69A4262%
   Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
   Revision: --------    Serial number: 25041704220178
   Coding: 0400
   VCID: 0D47AA5C1DDB536FB21-8058
   Part No SW: 5G1 920 791     HW: 5G1 920 791
   Component: KOMBI         409 2180
   Coding: 27AD11002F80060001886B011400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 698FBECC49F3EF4F7E9-803C
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 46
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:39
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 46
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:35
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 46
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:35
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0006250262
   Coding: 030100047F085900FB00027E080F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F3B10D4B797417F60D-807A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170000806220087165
   Coding: 2CFFFF
   Serial number: 3567433804
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 46
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:35
                    Supply voltage: Terminal 30: 12.7 V
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   VCID: 47CB58743F27F93F48D-8012
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 180417EDI13664
   Coding: 003F0220D001048000001000
   VCID: 43D34C640B1FD51F945-8016
   Serial number: 00000000000014436723
   Coding: 0D0000
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D31807CD594D7C73-806E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Component: FCM MQB Low   001 0285
   Serial number: 21041710803211
   Coding: 000000050100164E01100F01020000000000000000000000000000000000
   VCID: 72BDD9A064252C97CF3-8026
   Serial number: 110217EBA13347
   Coding: 003F0020DE01048000801000
   VCID: 42DD49601405DC179F3-8016
   Serial number: 00000000000014407222
   Coding: 150000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0753
   Coding: 02731001FF00000051110101008808001F0503E601200000CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313F16ACA1A3578F769-8064
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H41 8084
   Serial number: VWZ6ZHT1170850
   Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
   Component: ECE1 2017/18  --- 0820
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 46
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:38
                    Voltage terminal 30: 13.2 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 46
                    Mileage: 2699 km
                    Date: 2019.10.19
                    Time: 11:34:39
   Component: SAS-GEN 2     H06 0014
   Serial number: 170330200177
   VCID: 6B83C4C4430FFD5F0C5-803E
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2E8C79D39FCFCE9-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:41, VBatt start/end: 13.4V/13.6V)-----------
downtime
Finland
C?ID=280813
Check that the sensor is firmly seated to it’s holder, then try reset misalignment angle basic setting and go for a drive.
invernesspl
C?ID=345478
I have removed the grille and checked everything is located correctly, if I try to erase the fault code it just comes back straight away. Is there a separate setting to reset the misalignment?
downtime
Finland
C?ID=280813
In basic settings.
What exactly did you remove? Front bumber? Did you need to remove the crash bar where the radar is attached? If you’ve only removed the sensor, check again that it’s firmly in place. The legs need to be in their sockets completely. Otherwise you’ll have this error again even you do the reset.
invernesspl
C?ID=345478
This is a later model golf, the sensor is behind the VW badge on the front grille, it's definitely located correctly.
Right, but a 2017 GTI is nothing like a 2015 Touareg, so I've split this into its own thread. :)
downtime
Finland
C?ID=280813
Ah yes :) newer models also don’t have the reset misalignment basic setting. Search the forum, there was quite nice guide how to make basic settings for these newer radars.
invernesspl
C?ID=345478
Sorry Uwe, arrived at the thread via Google search and didn't realise it was Toureg specific
