audi a4 b6 steering angle sensor fault
raf0468
C?ID=120244
Hi have above vehicle can someone tell me if its the angle sensor at fault or the supply to the sensor.
in abs measuring block i see 0 degrees and does not increase or decrease as i rotatate steering ,
if the supply is at fault please can someone indicate the fuse, or where the fault may lie thanks...
Saturday,10,January,2015,16:33:39:29062
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUZZZ8E04A114448   License Plate: BUCKTYAR 2
Mileage: 161320km-100239mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E04A114448   Mileage: 161320km-100239miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 LJ
   Component: 1,9l R4 EDC 0000SG  4910
   Coding: 00002
   Shop #: WSC 63251
   VCID: 6ADE4E0B160E6F71D1F-4AE6
   WAUZZZ8E04A114448     AUZ6Z0C0273854
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04255
   Shop #: WSC 06435
   VCID: 65C43D37FF104009FCD-5120
            35-00 -  -
            37-00 - Faulty
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1319
   Coding: 00000
   Shop #: WSC 63251
   VCID: 60CA2C23E03225210FB-5120
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  RDW 0517
   Coding: 01001
   Shop #: WSC 63251
   VCID: 3564AD770F30F0898CD-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        3002
   Coding: 0011602
   Shop #: WSC 63251 000 00000
   VCID: 3666AA7B4236FB91857-5120
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 01012
   Shop #: WSC 63251
   VCID: 4380C3AF51E45E39329-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 J
   Component: KOMBI+WEGFAHRS. RB4 D37
   Coding: 00400
   Shop #: WSC 00001
   VCID: 306A9C63F052D5A1DFB-5120
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0704
   Coding: 00001
   VCID: 6BD04B0F19F47679AA9-5120
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BC
   Component: Komfortgerát T3B    1311
   Coding: 07115
   Shop #: WSC 63251
   VCID: 73E0536F41C4AEB9629-4B00
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0004
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0004
   Part No: 8E0 035 186 L
   Component: concert II  GRO    0001
   Coding: 01201
   Shop #: WSC 63251
   VCID: 306A9C63F052D5A1DFB-4B00
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283 A
   Component: Parkingsyst. A4 RDW D09
   Coding: 00114
   Shop #: WSC 63251
   VCID: 4380C3AF51E45E39329-513C
End-------------------------(Elapsed Time: 06:10)--------------------------
You expect us to deduce that how? Yes, I have a volt meter, but I don't have access to the car. ;)
Jef
HQ
We've seen were the 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 gets flagged, but nothing is wrong, it clears out with a simple test drive doing some lock to lock turns. However, the bigger problem as I see it is this:
37-00 - Faulty
If the wiring harness and the rest of the electrical paths are to factory design, I'd suspect the G85 is in fact... faulty. As noted by Uwe, we don't have access to the vehicle in question, so my question to you would be, is the wiring harness and electrical paths (fuses/ground points) to factory design?
raf0468
C?ID=120244
update used angle sensor fitted, a little drive and cleared codes, all fine..
thanks
