Audi Q3 F3 Rear sensor graphic on MMI
mdk11
Italy
C?ID=368097
Hi all,
Hope you can help me, I have stock rear distance sensor and I would like to code the graphic visualization on MMI.
Actually I'm trying the old code for 8U and even I can now see the graphics on MMI (when I chose reverse gear), I dont' see the typical "Waves" for distance detection.
This is what I did:
5F-Infotainment and go to coding.
Go to Byte 6 and enable Bit 1,
Change adaptation change on 10-Park assist to OPS DISPLAY: This is the point!, I have found similar option using long coding and I know see (as stated before) the graphic but still non "waves".
Any idea about?
Many thanks for your help
ib97
Croatia
C?ID=375363
There should be curve option display on byte 0 or 1 on 10 park assist module
hadez16
C?ID=289891
From what I know, since Audi MY16 this is not possible anymore.
It could be the case that is works again for this new MIB3 unit..
mdk11
Italy
C?ID=368097
I can't see any option like that, I will post some screenshot if you want
ib97
Croatia
C?ID=375363
