2009 Audi A4 2.0T Quattro B8 Misfire in Cylinder #3 and random misfire in #4 at idle
markbooker95
C?ID=383169
I bought this car a couple months ago for $2800 the vacuum line rotted off from the vacuum pump the breaks didnt work.
I replaced the whole line. it fixed the problem. But its been misfireing in cylinder #3 at idle and randomly will misfire in #4.
I pulled my intake off put 4 new injectors and wallnut shelled the carbon off the intake valves. Got better gas milage.
The person that had it before me put teflon tape on the intake bolts between 3 and 4 they are stripped out I can put a heater coil in it.
But I dont think thats the problem. There is oil coming out the camshaft bridge seal outside for the camshaft positioning magnet seal.
I think the cam bridge screen broke into peices and is stuck in the oil drain ports. Have not had the time to pull the front end apart yet.
I keep getting a bost pressure code and think my waste gate actuator rod and fasteners are the cause of it.
I need to get my car on a lift and wiggle the rod and make sure. I put a forge blow off valve on my turbo and when my car idles I can hear the air coming out of it.
witch makes me think its the waste gate actuator. The person that had the car before me put a amp in the car and took the original amp out and said it had a fault I sill have it.
its a rats nest of wires in my trunk from them splicing the amp into the speakers I have the Hormone Kardon sound system. I know there is shorts because of their rats nest of a Splice job.
I have been trying to run the camshaft positioning test to see if the solenoid's on my exhaust cam are working correctly. But cant figure out how to get it to run the test.
I have been doing the work myself but have not had the time or place to rip my front end apart and look at it. I keep getting these suspension Codes
01769- Sensor for Viechicle Leveling Front Right (G289) 010- open or Short to Plus
03262- Comfort Restrction 000.
Dose anybody know where I can find Wiring Diagrams for my 2009 Audi A4 2.0T Quattro B8 looking to find the shorts from the previous owner installing the aftermarket amp.
Wednesday,16,October,2019,16:34:06:05713
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUMF78K19N0XXXX   License Plate: BOOKER
Mileage: 347690km-216044mi   Repair Order:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37 3C
          42 46 47 52 53 55 56 62 65 67 6C 72 77
VIN: WAUMF78K19N029678   Mileage: 347690km-216044miles
0F-Digital Radio -- Status: Cannot be reached 1100
47-Sound System -- Status: Cannot be reached 1100
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 0104010A190F0160
   Shop #: WSC 02301 444 04944
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: F9BA752878CF838760-80AC
7 Faults Found:
          U1113 00 [040] - -
                    Mileage: 345999 km
                    Date: 2019.10.11
                    Time: 04:05:07
                    Engine speed: 2431.00 /min
                    Normed load value: 37.3 %
                    Vehicle speed: 120 km/h
                    Coolant temperature: 94 °C
                    Intake air temperature: 16 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 13.923 V
                    Unlearning counter according OBD: 32
          U1113 00 [040] - -
                    Mileage: 345999 km
                    Date: 2019.10.11
                    Time: 04:05:07
10434 - Catalyst System; Bank 1
          P0420 00 [237] - Efficiency Below Threshold
                    Mileage: 346786 km
                    Date: 2019.10.11
                    Time: 23:03:25
                    Engine speed: 1549.00 /min
                    Normed load value: 16.9 %
                    Vehicle speed: 59 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.041 V
5671 - Boost Pressure Regulation
          P0299 00 [237] - Control Range Not Reached
                    Fault Frequency: 9
                    Mileage: 346469 km
                    Date: 2019.10.11
                    Time: 17:31:33
                    Engine speed: 3018.50 /min
                    Normed load value: 52.2 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 30 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 14.135 V
4060 - Cylinder 3
          P0303 00 [237] - Misfire Detected
                    Fault Frequency: 9
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:50:29
                    Engine speed: 796.50 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 77 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 13.216 V
7960 - Cylinder Disabling
          P130A 00 [040] - -
                    Mileage: 346494 km
                    Date: 2019.10.11
                    Time: 18:35:44
                    Engine speed: 783.50 /min
                    Normed load value: 17.6 %
                    Vehicle speed: 3 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.159 V
                    Unlearning counter according OBD: 36
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [109] - -
                    Fault Frequency: 9
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:50:23
                    Engine speed: 950.50 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 78 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 13.334 V
Readiness: 0000 0100
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 C    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0050
   Revision: --H04---
   Coding: 001002
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: B620BE140951ACFFCD-80E2
   Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
   Component: ESP8 quattro  H04 0060
   Coding: 152500
   Shop #: WSC 02399 823 56573
   VCID: FBB66F207AF3B19772-80AE
                    Reset counter: 154
                    Mileage: 345999 km
                    Date: 2019.10.11
                    Time: 04:05:07
                    Hex Value: 0x7840
                    Hex Value: 0x4006
                    Hex Value: 0x1F07
                    Hex Value: 0x81AF
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
   Component: BCM2 1.1      H80 0143
   Coding: 0D0100
   VCID: F5A279185CD7E7E704-80A0
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000066865009
00192 - Rear Left Door Handle Touch Sensor (G417)
                    Fault Status: 00100111
                    Reset counter: 159
                    Mileage: 347624 km
                    Date: 2019.10.14
                    Time: 13:32:01
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 340IR087512547
   Coding: 0000003
   VCID: C3C6D7C0828309577A-8096
   Subsystem 1 - Part No: 8T0 919 609 D
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000151568
   Subsystem 3 - Serial number: 0115.09.080000000100010014ÿ
   Subsystem 4 - Serial number: 010014ÿ
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0140
   Revision: C1000000    Serial number: 0112.09.081189
   Coding: 64002000
   VCID: F2A842042DB9F0DF21-80A6
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 91
                    Reset counter: 122
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:42:33
                    Fault Frequency: 85
                    Reset counter: 162
                    Mileage: 345676 km
                    Date: 2019.10.10
                    Time: 13:54:19
                    Temperature: 17.0°C
                    Fault Frequency: 95
                    Reset counter: 162
                    Mileage: 345676 km
                    Date: 2019.10.10
                    Time: 13:54:21
                    Temperature: 17.0°C
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000125485
   Coding: 26001091063CAF311F00080300003D0D0F9CD24800010161000000
   VCID: B02C880CE33582CF97-80E4
   Component: WWS 160908  H06 0070
   Serial number: SWF08090165524
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10254148
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000002009080933
7 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 115
                    Mileage: 346756 km
                    Date: 2019.10.11
                    Time: 21:20:00
                    Fault Frequency: 83
                    Reset counter: 160
                    Mileage: 346818 km
                    Date: 2019.10.12
                    Time: 06:10:00
03020 - Local databus 2
                    Fault Status: 00101100
                    Fault Frequency: 175
                    Reset counter: 162
                    Mileage: 345676 km
                    Date: 2019.10.10
                    Time: 13:54:00
                    Reset counter: 159
                    Mileage: 346506 km
                    Date: 2019.10.11
                    Time: 19:09:00
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 76
                    Reset counter: 122
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:42:00
02258 - Door Opener Transmitter
                    Reset counter: 122
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:42:00
03207 - Charisma Switch Module
                    Reset counter: 158
                    Mileage: 347613 km
                    Date: 2019.10.14
                    Time: 11:23:00
   Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
   Component: MP3-Changer     H43 0390
   Revision: 00043003    Serial number: AUZ5ZBH8601924
   VCID: AA189A6405E9F81F59-80FE
Address 0F: Digital Radio
   Part No SW: 8K0 919 475 D    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0020
   Revision: 11001001    Serial number: 52940825301285
   Coding: 200103
   VCID: BA38AA243549489F29-80EE
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8K0 907 364     HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H08 0052
   Revision: 00000000    Serial number: 10090806130002
   Coding: 050181
   Shop #: WSC 02301 444 52373
   VCID: F0AC480C23B5C2CFD7-80A4
01769 - Sensor for Vehicle Leveling; Front Right (G289)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 112
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:42:33
03262 - Comfort Restriction
                    Fault Frequency: 58
                    Reset counter: 122
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:42:33
                    Error Code: 2
   Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
   Component: AirbagVW-AU10 H27 0410
   Serial number: 0039KD14801G
   Coding: 303836354230303030304A55304C384B3053
   VCID: C0CCD8CC5B95124F67-8094
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0800001QYG
   Serial number: 6334MSME40220455
   Serial number: 6344MSME3F346E1FZ
   Serial number: 6352QSME750B10247
   Serial number: 6362QSME260D220EH
   Serial number: 63732SME4E091228$
   Serial number: 63832SME230D341A-
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90319HH90007Q
   Coding: 000016
   VCID: BE30A634296164BF15-80EA
   Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
   Component: KOMBIINSTR.   H17 0224
   Revision: 00100000    Serial number: 9E1115K98
   Coding: 8B1609003300D705020000
   Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0094
   Revision: 4FB50047    Serial number: 4700F08907812C
   Coding: 000303
   VCID: CAD8FAE465A9D81FB9-809E
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 1804338A030908
02230 - Digital Radio (DAB) (R147)
                    Reset counter: 112
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:43:34
                    Reset counter: 112
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:43:34
                    Reset counter: 112
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:49:08
   Part No SW: 8K0 907 144 B    HW: 8K0 907 144 B
   Component: DYNAMIKLENK.  H05 0490
   Revision: 50000003    Serial number: --------------
   Coding: 0C0000
   VCID: AE109674F901943F85-80FA
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
   Component: SG ext.Player H15 0850
   Revision: 00000000
   Coding: 020000
   VCID: AB169F60CA13E117A2-80FE
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00000015855579
   Coding: 00581300000000000000
   Shop #: WSC 02391 823 56573
   VCID: BB36AF203A73719732-80EE
                    Reset counter: 122
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:42:33
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
   Component: MNS US          H52 1100
   Revision: 00000000    Serial number: 341IM087515520
   Shop #: WSC 02301 444 54128
   VCID: B83CB02CCB455A8FDF-80EC
   Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
   Revision: 00H01000    Serial number: 6PZ 009 014-13
   Coding: 0000001
   VCID: B620BE14C151ACFFCD-80E2
   Subsystem 1 - Part No: 8K0 907 568 B
   Subsystem 2 - Serial number: 6PZ 009 014-33
   Subsystem 3 - Serial number: 5F24.09.0800H010003CD10278ÿ
   Subsystem 4 - Serial number: D10278ÿ
02850 - Control Module 2 for Lane Change Assistance (J770)
            014 - Defective
                    Reset counter: 112
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:42:34
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000007705080
   Coding: 011C13204E00410001
   VCID: C1CADDC8589F1B4768-8094
   Revision: 00002001    Serial number: 0114589452
   Coding: 0106023A007A440500B001
   Component: GTO BF  H06 0040
   Serial number: 00000000000000072096
   Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
   Component: J245 PS034  H06 0037
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 112
                    Mileage: 345756 km
                    Date: 2019.10.10
                    Time: 14:42:00
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 112
                    Mileage: 345756 km
                    Date: 2019.10.10
                    Time: 14:44:05
Address 47: Sound System
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000007699504
   VCID: C0CCD8CC5395124F67-8094
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 10000000097666
   VCID: B12A8D08E83F8BC798-80E4
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000005
   VCID: B424841CD72DBEEFF3-80E0
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 379IS087531301
   Coding: 0000002
   VCID: B12A8D08283F8BC798-80E4
   Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
   Revision:             Serial number: 0000100279635
   Coding: 010C13204000210001
   VCID: C4C4D4DC478D0E6F43-8090
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140781805958
   Coding: 0CD154
02214 - Tire Pressure Warning
                    Reset counter: 155
                    Mileage: 346807 km
                    Date: 2019.10.12
                    Time: 00:36:48
                    Bin. Bits: 00000000 00100101
                    Voltage: 13.80 V
                    Text:  04,0°C; -0,56bar;3441675374;00h;  6°C
   Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
   Component: SDS 3501 US     H46 0630
   Revision: 00000000    Serial number: 00000809120244
   Shop #: WSC 12336 024 394758
   Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8990UX
   Coding: 1001006
   VCID: B73EB310C65B55F7D6-80E2
   Revision:             Serial number: 0000100279613
                    Fault Status: 01101000
                    Reset counter: 118
                    Mileage: 345672 km
                    Date: 2019.10.10
                    Time: 13:50:42
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H20 1130
   Revision: 00000000    Serial number: 00000005061582
   Coding: 0010900
   VCID: A81C606C1BE5CA0F4F-80FC
End----------(Elapsed Time: 02:43, VBatt start/end: 12.2V/12.0V)-----------
Nice. 216,000 miles. :thumbs:
What have you done so far to try to trouble-shoot these misfires? Plugs? Coils? How's this engine's compression? How badly are the intake valves carboned up?
DrPeter
16.4905° S, 151.7375° W
The ECM may not run the Basic Settings when there are fault codes. You can run the Output Tests to hear/feel if the N205-Camshaft Adjustment Valve clicks on/off, do this with the key on, engine off.
Also when everything is fixed and the only codes you have left are the misfire faults, try clearing the fault codes three times in a row, in 30 seconds or less to Reset Misfire Adaptions.
- See the Ross-Tech wiki page for the P0300- Random/Multiple Cylinder Misfire Detected
Have you looked here: Official Factory Repair Information
drpeter
markbooker95
C?ID=383169
I’ve changed the coils and plugs, just did a compression test 1,2,4 165 right at start 3 at start Is 100 but go’s up to 150 after a little bit. The intake valves where pretty carboned up they are clean now. I keep getting oil on top of my valve cover and I don’t know where it’s coming from. I think the cam bridges screen broke and is plugging up the ports for the oil to drain down. I just don’t understand how It can be on top of my valve cover. And when I put new oil in it turns black after a couple 100 miles. And I don’t think it’s from carbon. I bought the VVT bolt on my intake cam that holds my cam bridge in I was going to replace it and put a new Cambridge and timing chain kit and tensioner in it when I take my front end apart. Because of the high miles. I had Audi look at it they charged me $165 HR and said there is scratching and scoring on my cylinder #3 walls. Saying that the repairs going to cost $20,000 for a new block. I said all you did was pull my spark plug out and put I camera down it. And charged me $165 I could have done that. I was pissed. And if they are right I’ll just bore it out when I pull my front end apart. But I looked with a camera and didn’t see anything. Haven’t done a leak down test on It yet. I’ll run the N205 test and see if it clicks. When I shut my car off right after something clicks close to the front right side of the engine. Any body have any idea what that could be?
markbooker95
C?ID=383169
What’s LKQ? Sorry I’m new to this Forum.
Sunday,20,October,2019,12:04:13:05713
VIN: WAUMF78K19N0XXXXX   License Plate: BOOKER
Mileage: 348180km-216349mi   Repair Order:
VIN: WAUMF78K19N0XXXXX   Mileage: 348180km-216349miles
   Revision: E1H14---
                    Mileage: 347706 km
                    Date: 2019.10.17
                    Time: 06:24:37
                    Engine speed: 2949.00 /min
                    Normed load value: 72.5 %
                    Vehicle speed: 113 km/h
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 13.570 V
4060 - Cylinder 3
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:42:40
                    Engine speed: 761.50 /min
                    Normed load value: 13.3 %
                    Coolant temperature: 69 °C
                    Intake air temperature: 42 °C
          P0300 00 [109] - -
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:42:33
                    Engine speed: 940.50 /min
                    Coolant temperature: 70 °C
                    Voltage terminal 30: 13.428 V
Readiness: 0100 0101
   Revision: --H04---
   Coding: 001002
   Coding: 152500
   Coding: 0D0100
   Coding: 0000003
   Coding: 64002000
                    Fault Frequency: 41
                    Reset counter: 132
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:39:45
                    Fault Frequency: 64
                    Reset counter: 171
                    Mileage: 347729 km
                    Date: 2019.10.17
                    Time: 17:40:17
                    Temperature: 13.0°C
                    Fault Frequency: 74
                    Reset counter: 171
                    Mileage: 347729 km
                    Date: 2019.10.17
                    Time: 17:40:19
                    Temperature: 13.0°C
   Coding: 00FD11
   Coding: 025028
7 Faults Found:
                    Fault Frequency: 126
                    Reset counter: 168
                    Mileage: 347731 km
                    Date: 2019.10.17
                    Time: 19:34:00
                    Fault Frequency: 152
                    Reset counter: 171
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 20:52:00
                    Reset counter: 166
                    Mileage: 347768 km
                    Date: 2019.10.18
                    Time: 19:33:00
                    Reset counter: 167
                    Mileage: 347777 km
                    Date: 2019.10.18
                    Time: 19:52:00
            014 - Defective
                    Fault Frequency: 34
                    Reset counter: 132
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:39:00
                    Fault Frequency: 216
                    Reset counter: 132
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:39:00
                    Reset counter: 167
                    Mileage: 347803 km
                    Date: 2019.10.18
                    Time: 20:17:00
   Coding: 200103
   Coding: 050181
                    Reset counter: 122
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:39:45
                    Fault Frequency: 30
                    Reset counter: 132
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:39:45
                    Error Code: 2
   Coding: 000016
   Coding: 000303
                    Reset counter: 122
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:40:45
                    Reset counter: 122
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:40:45
                    Reset counter: 122
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:42:46
   Coding: 0C0000
   Revision: 00000000
   Coding: 020000
                    Reset counter: 132
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:39:45
   Coding: 0000001
            014 - Defective
                    Reset counter: 122
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:39:45
                    Reset counter: 122
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:51:35
                    Reset counter: 122
                    Mileage: 347696 km
                    Date: 2019.10.17
                    Time: 06:16:15
   Coding: 0000005
   Coding: 0000002
   Coding: 0CD154
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 130
                    Mileage: 348171 km
                    Date: 2019.10.20
                    Time: 10:15:11
                    Bin. Bits: 00001000 00100011
                    Voltage: 14.10 V
                    Text:  11,5°C; -0,64bar;3441675374;00h;  7°C
   Coding: 1001006
                    Reset counter: 131
                    Mileage: 347696 km
                    Date: 2019.10.16
                    Time: 18:51:35
   Coding: 0010900
End----------(Elapsed Time: 02:33, VBatt start/end: 12.3V/12.2V)-----------
