BCM and GTW upgrade - problem with window heating and generator charge
Lyxx
Slovakia
C?ID=138734
hellou everyone, i retrofited my car fully, now i upgraded ambiente door color via lin...
car: skoda octavia RS 2015/05 TSI 162KW
i have problem after ugrade my BCM 5Q0937084CQ(0253SW) to DH(0312) no work correctly window heating front and rear, heating button blinking.. i see in gtw, generator charge only 12.3-13V battery is NEW(70AH 420A Varta oem EFB+)
but i read when is battery up to 75% not charging with fully 14+V... when i drain battery to about. 70% .. charging is on and window heating work... working when volts up 13.8V+
when i updatet bcm to DH version(sw flash) i upgraded my Gateway 3Q0907530G to AC(5388sw) bcm and gtw is parametrized online with odis (another VIN i use, for parametrization car who have this units)
i updated battery control module my old to 5Q0915181J , and generator old 180A to newer 180A, and still noting :(
any1 help me with this problem
i read in orginal manual skoda: 2019/07 - when is window heating blinking
here is logs: 09BCM is without faul, i have last log after online parametrization, but here is adapt log after when i edit all adaptation 09 from my old bcm...
Tuesday,30,July,2019,19:50:07:54457
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: TMBAE7NE3F0198519   License Plate:
Mileage: 56682km-35220mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 47 52 55 5F
          65 6C A5 A9
VIN: TMBAE7NE3F0198519   Mileage: 56682km-35220miles
33-Flux Capacitor -- Status: Malfunction 0010
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0C19003A2444050B1000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E04FE6A909A0EE76BB-807A
Readiness: 1110 0001
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 61508000000056
   Coding: 24076B9154291174407C060160CC2924D62A8802600694763443500040A6430000000012121212B8586C384E4484EE
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: 77AA1B0E2F400F2FF8D-8022
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0360435219
   Coding: 032C0C
   VCID: 3C20C42256E6EC77D5F-8068
   Part No SW: 5E0 907 044 AT    HW: 5E0 907 044 AT
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 0101000400410101100500410010102A
   Air quality sensor:
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0312
   Serial number: 01001813801263
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 015E75D67184419FC69-8054
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150215  041  0570
   Serial number:         150219163545
   Coding: 065DDD
   Component: RLHS  042  0105
   Serial number: S5Y16M09D20H17M40S25
   Coding: 00885D
10 Faults Found:
0531 - Footwell Illumination
          B11FF 01 [009] - Electrical Failure
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:30:07
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:33:14
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:36
529173 - Databus
          [Anhaenger_01 Datenbus fehlende Botschaft]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:39
555797 - Databus
          [Getriebe_11_alt aktiv]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:39
563221 - Databus
          [OCU Datenbus fehlende Botschaft]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:41
568086 - Databus
          [LCM links - Blinker defekt]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:33:15
568342 - Databus
          [LCM rechts - Blinker defekt]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:33:15
568836 - Databus
          [LWR AFS - Kein Signal/Kommunikation]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:39
795140 - Steering Column Control Module
          U0212 00 [009] - No Communications
          [Schaltermodul Lenksäule (SMLS)->kein Signal/ Kommunikation]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:39
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417617041
   Coding: 0271167841
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FE8596E164711F169-8004
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 2B0060C349FFC728949C810560400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E24CE2A40FAFE67FBB-806A
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:25:34
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 12.0 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4P3SKE2
   Coding: 98CCC000000000005C5400CC000800000065
   Shop #: WSC 73430 790 00126
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5AF32E0770376FB0D-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 102 15
   Serial number: 3576U00000098AD4D31Q
   Subsystem 2 - Part No SW: -----------    HW: 454 001 002 15
   Serial number: 3586U00000085138B215
   Subsystem 3 - Part No SW: -----------    HW: 454 801 802 15
   Serial number: 3516R150AD605000000$
   Subsystem 4 - Part No SW: -----------    HW: 454 802 002 15
   Serial number: 3526R6D952A060000008
   Subsystem 5 - Part No SW: -----------    HW: 454 800 402 15
   Serial number: 3556V0E67D0050000009
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20180224400810
   Coding: 6404
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 5E0 920 790 A    HW: 5E0 920 790 A
   Component: KOMBI         506 1703
   Coding: 05AD11906C8C00080088730F5001000080000000
   Shop #: WSC 26000 654 12345
   ASAM Dataset: EV_DashBoardVDDMQBA0 001031
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2614064AB86A46A793B-8072
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 K    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0080
   Coding: 9309
   Shop #: WSC 00015 115 00001
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000116932
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 01071910522070
   Coding: 030100347F085900AB1002FB980F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 70B820124A2E5817397-8024
   Component: 4-01-09-01-04
   Subsystem 2 - Part No SW: 3V0 919 719 G    HW: 3V0 919 719 G
   Serial number: 000000000B3063030518
   Serial number: 6949600205
   Revision: 00000000    Serial number: 15000049698004
   Coding: 5500000000000000
   Shop #: WSC 73430 031 00126
   ROD: EV_ELVMarquMQB.rod
   VCID: 3430EC027EB624371DF-8060
   Part No SW: 5Q0 907 686 C    HW: 5Q0 907 686 B
   Component: HRE_Master    H12 0080
   Serial number: 0412224304
   Coding: 02011103
   Shop #: WSC 00028 028 00066
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D26C9264DFCE57FE21-8068
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 B
   Component: HRE_Slave  H12 0080
   Serial number: 0412260879
   Coding: 020111
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000139084378
   Coding: 001D0020D000040000001100
   VCID: 45D6A1C6252CADBFBA1-8010
   Serial number: 00000000000005391299
   Coding: 010200
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9303
   Shop #: WSC 28502 001 104857
   VCID: 392EDD3659D4D95FCE9-806C
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1GJE00W7UU
   Coding: 0373010000AA002AAA0000000000
   Shop #: WSC 73430 790 12345
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001002
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59EE7DB6B994395FEE9-800C
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000138903607
   Coding: 001D0020DC00040000001100
   VCID: 44D0BCC22E1694B7ADF-8010
   Serial number: 00000000000005296258
   Coding: 190200
   Coding: 03DA02003F000000
   VCID: 40D8B0D23A0E8897897-8014
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 021 B    HW: 565 035 021
   Component: MU-H-LND-EU   043 1382
   Serial number: A578C0GB003321
   Coding: 037351010000000041111202008802332F0101E401200400BE
   Shop #: WSC 28502 001 1048576
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 0D4659E63DDC15FFB21-8058
   Subsystem 1 - Part No SW: 5E0 919 606 D    HW: 5E0 919 606 D
   Component: ABT_High-2  H51 9130
   Serial number: SKZ6ZHV0260611
   Subsystem 2 - Part No SW: V03 959 803 TF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0010
   Serial number: 30000000019453
   ROD: EV_RDKBERU30_006_VW48.rod
   VCID: 3634D60A68CA362723B-8062
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556
   Component: RVC Compact   H09 0231
   Coding: 047301010600201F000040
   Part No SW: 3QD 980 654 A    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1611
   Serial number: 10061841P10858
   Coding: 0203070100000401002223458150A90094000E20002000
   ROD: EV_MFKBoschMQBB_002_VW37.rod
   VCID: 49CEADF6093449DF5E9-801C
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:34
                    Outside air temperature: 13.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 336.0 s
                    mid: 00 29
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 1
1123377 - Databus
          [Timeout_Gateway_72_Anhaenger_01_alt]
                    Reset counter: 2
                    Mileage: 56682 km
                    Date: 2019.10.10
                    Time: 19:23:35
                    System run time: 337.0 s
                    mid: 02 94
                    Software_Info_4: 1
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 1
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 150204202505
   VCID: 698E4D7669F4A9DF7E9-803C
End------(Elapsed Time: 15:22, VBatt start/end: 12.1V/12.1V, Deb=2)--------
BCM09:
;SW:5Q0-937-084-DH   HW:5Q0-937-084-CG ---  Cent. Elect.
;Component:BCM MQBAB H   H36 0312, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,020001,EV_BCMBOSCH_020_VW27.rod
;Wednesday,16,October,2019,19:21:41:54457
;VCDS Version: Release 19.6.2  Data version: 20190930 DS308.0
;VCID: 015E75D67184419FC69-8054
IDE01550-Service position,166.505329 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active ,10
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,25.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,65 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,40 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe,installed ,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04928-MAS01577-Anti-theft device-Parking heater,installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,driver door contact thatcham ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,Yes ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 08 09 23 1E 00 23 14 00 64 00 00 00 04 4C 00 4C 08 0A 23 1E 00 23 14 00 64 00 00 00 01 3A 00 49 08 09 7F 1E 00 7F 14 00 7F 00 00 00 01 44 00 4B 08 0A 7F 1E 00 7F 14 00 7F 00 00 00 03 36 00 1A 0B 0F 7F 1E 00 7F 00 00 00 00 00 00 03 40 00 1B 0C 0F 7F 1E 00 7F 00 00 00 00 00 00 0A 4E 00 24 12 16 64 00 00 00 00 00 00 00 00 00 0A 4F 00 25 13 17 64 00 00 00 00 00 00 00 00 00 02 37 00 1E 0D 0F 7F 00 00 00 00 00 00 00 00 00 02 41 00 1F 0E 0F 7F 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 63 0A 78 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 06 00 0F 1D 00 85 0F 34 F7 25 23 65 42 57 9B 24 42 3F 3A 69 35 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 29 0F E3 42 87 1B 03 32 3F 3A 69 35 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 29 1E 65 42 77 1B 03 22 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 24 0C 42 20 57 1B 03 22 3F 3A 69 58 92 05 09 A3 05 64 26 06 15 0C 12 18 86 09 30 33 27 23 65 42 57 9B 24 22 0C FA 0A 34 95 2D 09 A3 21 43 34 02 02 02 02 02 02 91 40 21 28 02 ,172
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,30 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,37.50 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,37.50 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.0 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,not_active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,not_active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,not_active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active ,8
IDE07007-ENG249923-A/C heater function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,not active ,8
IDE07356-Position during interval mode,25.505469 °,2
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,coupled ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.50 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,1 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,4 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,5 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,4 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,20 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,30 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,0 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,4 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,50 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,50 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,70 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,70 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,8.505486 °,2
IDE10299-Alternating park position 2,22.505472 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.37 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000011  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00110000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00001100  ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00011001  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,0 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,0 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,40 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,37 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,0 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,0 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,0 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,0 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,0 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,40 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,37 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,0 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,40 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,37 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,0 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,40 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,37 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,1.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,235 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,57 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,5 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,55 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,40 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,240 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,222 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,255 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,255 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,221 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,172 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,108 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,116 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,76 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,102 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,192 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,204 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,217 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,182 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,255 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,253 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,242 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,252 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,132 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,1 ,30
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,not active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,71 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,6 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,2 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,106 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,182 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,254 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,153 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,4 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,231 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,132 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,200 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,73 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,9 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,134 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,140 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,110 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,245 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,120 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,57 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,255 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,173 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,255 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,255 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,106 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,29 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,58 ,30
MAS05055-lower turn position,25.505469 °,2
MAS05056-upper turn position,166.505329 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,59395 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,50 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,37905 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,225300 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,53255 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,7 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,8 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,4 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,4 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,3 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,9 ,23
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,not active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,50 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,50 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Keine_Spannungsanforderung ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,not active ,3
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,0 ms,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,83.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,67.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,50.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,33.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,17.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-0.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-0.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-0.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,44.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,38.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,33.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,28.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,24.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,17.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,10.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,10.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,10.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,10.0 %,30
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,36 - LED Kleinleistung ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,1E ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low' ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell ,16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,1F ,16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41 ,16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low' ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam ,16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,17 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,35 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,8 - allgemeine Glühlampe 12W ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,19 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,3F ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,8 - allgemeine Glühlampe 12W ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parking light right ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,127 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,32 - allgemeine LED bis 12W ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2F ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,35 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,35 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,100 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Daytime running lights ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,126 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,44 - LED Fußraum- oder -Innenleuchte ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2 ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3 ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4 ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,35 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,35 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,100 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Daytime running lights ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Daytime running lights ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Parking light right ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Daytime running lights ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,100 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,24 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,4E ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,10 - allgemeine Scheinwerfer ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Nebellicht links ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Abbiegelicht links ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,100 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,25 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,4F ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,10 - allgemeine Scheinwerfer ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Nebellicht rechts ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Abbiegelicht rechts ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 1E 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 1E 00 00 00 00 00 22 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 1E 00 7F 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 1E 00 7F 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 00 00 00 00 00 00 00 00 00 20 0C 00 2E 1A 00 7F 00 00 00 00 00 00 00 00 00 20 1C 00 2F 1A 00 7F 00 00 00 00 00 00 00 00 00 09 0B 00 31 19 00 64 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,08 35 00 17 08 09 64 00 00 00 00 00 00 00 00 00 08 3F 00 19 08 0A 64 00 00 00 00 00 00 00 00 00 2C 00 00 02 2B 00 7E 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 00 00 00 00 00 00 00 00 00 00 24 00 00 00 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR,2-Sensor LWR ,62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,2700 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,100.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,0.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,5.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,5.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,5.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,3.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,3.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,3.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,44.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.03 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,Inverted ,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.03 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,0.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,1000.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,0.0 %,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-3.71 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-2.96 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-2.04 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-1.48 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-0.37 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.20 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-0.10 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-0.05 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-0.01 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.00 ,20
ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,Skoda ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Keine_Spannungsanforderung ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,600 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,600 ms,10
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,72.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,48.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,33.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,18.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,12.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,8.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,6.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,4.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,2.0 %,22
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,0.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,0 ,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,60 %,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,20.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,installed ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,No ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Pulse control ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
Elapsed Time: 02:12
GTW19:
;SW:3Q0-907-530-AC   HW:3Q0-907-530-C ---  CAN Gateway
;Component:GW MQB High   521 5388, Coding:030100347F085900BB1002FA080F00010001070000000000000000000000
;EV_GatewNF,013026,EV_GatewNF.rod
;Wednesday,16,October,2019,19:21:08:54457
;VCDS Version: Release 19.6.2  Data version: 20190930 DS308.0
;VCID: 70B820124A2E5817397-8024
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,70 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,VAO ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,490512C1F5 ,15
IDE03903-Production process data 1,00 00 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE07838-Counter for inconsistent states,1 ,2
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,not activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,activated ,3
IDE11689-48V-System: locking,regular operation ,1
IDE13756-Diagnosis filter: activation,not active ,1
MAS16372-Security version number,3 ,2
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,0 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1
ENG137850-MVK_Warning,regular operation ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
Elapsed Time: 00:24
darkchina811
ITALY
C?ID=333184
usually we want to upgrade a MID BCM/GW to a HIGH because it will allow several retrofits. but if you upgrade to a different generation (eg the car is 2015 and you install a 2018 module), then there is no guarantee that the module will "talk the same language" with the rest of the car's network.
myounus
Northwest UK
C?ID=321059
Hi
I am currently investigating a similar issue where the rear window defogger ceases to operate with the change of a BCM. Have you paramaterised your BCM to a similar vehicle, i.e. one with PR that has an auxillary heater STG18?
darkchina811
ITALY
C?ID=333184
I don't know if it's the answer you are looking for, but when I retrofitted the Webasto I did not change the parameterization for the BCM.
myounus
Northwest UK
C?ID=321059
The issue is likely related to the gateway, testing of the BCM didn't produce any issues. Try flashing it back to AA and re-paramaterise.
