A7 2012 ACC&Brake Guard malfunction
Aleksandernils1
Norway
Hey. Just picked up an A7 3.0 TDi 2012 last night and drove it home(a few hours of driving) and I've been driving it to and from work with no issues at all.
Then, when I'm looking for an open parking spot, going around 10 km/h, I get these errors: Start/Stop, ACC&Brake Guard unavailable.
I went to my garage and did an Auto Scan with VCDS, but I'm not sure what the problem is.
Any help at all would be very welcome!
Aleksander
Thursday,17,October,2019,17:58:51:63589
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
Dealer/Shop Name: AutoGo
VIN: WAUZZZ4G5CN122690   License Plate: ALEKSANDER A7
Mileage: 136553km-84850mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 3B 42 44 46 52 53
          55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WAUZZZ4G5CN122690   Mileage: 136553km-84850miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
85-On Board Cam. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0005
   Revision: 53H37---
   Coding: 1A254012057601020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001005
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 2616FC3268688B67C41-8072
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Fault Frequency: 37
                    Mileage: 135612 km
                    Date: 2019.09.18
                    Time: 14:43:16
                    Engine speed: 1468.00 /min
                    Normed load value: 56.5 %
                    Vehicle speed: 45 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 14.620 V
                    Cruise Control System (CCS): status-Bits 0-7: 55
                    selected gear-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [032] - -
                    Mileage: 134769 km
                    Date: 2019.06.27
                    Time: 12:04:36
                    Engine speed: 745.50 /min
                    Coolant temperature: 62 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 11.660 V
                    Unlearning counter according OBD: 5
                    Immobilizer snapshot A-Sia Error Snap A: 42 36 21
                    Immobilizer snapshot B-Sia Error Snap B: 1A 00 00
   Part No SW: 4G2 927 156 M    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H06 0004
   Revision: --H06---    Serial number: 0000000681
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501021 001026
   ROD: EV_TCMDL501021.rod
   VCID: 382A224AB2DC0D9766D-806C
7971 - Transmission Control Unit
          P1701 00 [040] - Locked
                    Reset counter: 2
                    Mileage: 134769 km
                    Date: 2019.06.27
                    Time: 12:04:36
                    Engine speed: 753 /min
                    Transmission input speed: 753 /min
                    Engine torque: 0 Nm
                    Transmission fluid temperature: 38 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 27A6C703E465E3C0FB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
0040 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_ACC_05_Timeout]
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:37
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 9E
                    Uz: 8D
0042 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_ACC_10_Timeout]
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:37
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: A4
                    Uz: 8D
0484 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [SCL_ACC_Status_ACC_Invalid]
                    Reset counter: 22
                    Mileage: 135597 km
                    Date: 2019.09.18
                    Time: 14:00:31
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: A1
                    Uz: 87
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 BP
   Component: BCM2 2.0      H31 0560
   Coding: 05AA2F06000000000000
   Shop #: WSC 12676 003 1048576
   VCID: 7CA2FE5AC6E4E1B7C25-8028
                    Fault Status: 00100001
                    Reset counter: 55
                    Mileage: 135777 km
                    Date: 2019.09.20
                    Time: 08:44:30
                    Fault Status: 00101101
                    Reset counter: 48
                    Mileage: 135777 km
                    Date: 2019.09.20
                    Time: 08:45:29
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0064
   Serial number: 28011200040100
   Coding: 3603007824
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 2708F1366F62926FFF7-8072
0378 - Coolant Circulation Pump
          B10D0 04 [008] - Internal System Fault
                    Reset counter: 30
                    Mileage: 134833 km
                    Date: 2019.07.01
                    Time: 21:39:13
                    Voltage terminal 30: 14.17 V
                    Outside air temperature: 20.0 °C
                    Interior temperature: 25.07 °C
   Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0111
   Revision: 20012002    Serial number: 00000001204381
   Coding: 0200E01050B49FE2C981008300001908CF9CE3082E080101000008402101
   VCID: 75B4EB7EE5CEB0FFBDB-8020
   Component: WWS57X 111218  H35 0051
   Serial number:         120109174547
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20040763
   Coding: 02562B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 23 01 2012  00000072
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 54080B06000000000001
01319 - Control Module for Distance Control (J428)
                    Reset counter: 22
                    Mileage: 135612 km
                    Date: 2019.09.18
                    Time: 14:43:00
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901202300621
   Coding: 290B03
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3B203D4683EA268F8BF-806E
Address 13: Auto Dist. Reg
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG006FASB
   Coding: 30314530323130303038554A304C34473853
   VCID: 36362C72B8C8FBE7741-8062
   Serial number: 3575HRB4063124B28G25
   Serial number: 3585HRB404T11PNAGP65
   Serial number: 3515JRB405N0VIFMKGEO
   Serial number: 3525JRB405T0TGJKB8CA
   Serial number: 3554VRB40590V8BOA96V
   Serial number: 3564VRB404V0V8BOEHM
1050368 - Databus
          [CAN: 0x323 PCF_01 Timeout]
                    Fault Frequency: 18
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:42
   Revision: --------    Serial number: 90372LAN000HN
   Coding: 00001C
   VCID: 37282176BF4202EF6F7-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
   Serial number: 23 11 2011  11194184
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 931 R    HW: 4G8 920 931 R
   Component: TDieRdwAcc    H79 0416
   Revision: 28460177    Serial number: 658190112596029
   Coding: 138600021F030008010100
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K.rod
   VCID: 3D24335E9DFE28BFB5B-8068
16776960 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_02_FR keine Kommunikation]
                    Fault Frequency: 57
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:41
16776961 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_04_FR keine Kommunikation]
                    Fault Frequency: 40
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:41
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000370747
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 3432167AAEB4E9F74A5-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790741752
   Voltage stabilizer:
   Serial number: 12018001354021200181
4365 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Fault Frequency: 37
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:37
                    Voltage terminal 30: 10.9 V
                    Voltage terminal 15: 10.9 V
                    Control Module temperature: 11 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: On
                    Datenfeld: 0
6654 - Automatic distance regulation 2
          U1071 00 [009] - No communication
                    Fault Frequency: 17
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:39
                    Voltage terminal 30: 11.3 V
                    Voltage terminal 15: 11.3 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 41
                    Mileage: 135517 km
                    Date: 2019.07.28
                    Time: 19:55:39
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 27 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 22011200041318
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 2F3819164792CA2F377-807A
   Part No SW: 4G0 907 553 E    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0781
   Coding: 008003
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2D04031E4D9EB83F05B-8078
0002 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 29
                    Reset counter: 22
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA4203J33S0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F56224000628002080403
   VCID: 41DC4FAEE1864C5FD13-8014
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0012308831
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323E106254A0E7C7589-8066
   Revision: 00002001    Serial number: 0168571944
   Coding: 013A0E2020B9B40183200A042C0302000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H09 0028
   Serial number: WA102902000000869062
   Subsystem 4 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84198711
                    Fault Frequency: 24
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:41
                    Fault Frequency: 28
                    Reset counter: 62
                    Mileage: 135596 km
                    Date: 2019.09.18
                    Time: 13:58:52
                    Reset counter: 62
                    Mileage: 135777 km
                    Date: 2019.09.20
                    Time: 08:45:29
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F56224000628002080402
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000238714
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0E08027C70AF07E09-807E
327936 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FC_ACC_05_MESSAGE_TIMEOUT]
                    Fault Frequency: 37
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:37
                    Voltage terminal 30: 11.0 V
                    Internal Fault ID: 86
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0012
   Serial number: 120124-0004-049
   Coding: 11236F33F91AEB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 303A1A6A5AACD5D72ED-8064
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
   Part No SW: 4G0 035 061 E    HW: 4G0 035 061
   Component: Radio U DAB   H60 0099
   Revision: AB001007    Serial number: 109AP0C7546013
   Coding: 010103020100000001
   VCID: 1F18E9D637B25AAF877-804A
   Part No SW: 4G0 035 666 G    HW: 4G0 035 666 A
   Component: H-BN-EU       H48 0484
   Revision: --------    Serial number: 426AM0C7634011
   Coding: 090100040003F9EF2510AB3E00000003E00001020000000000
   VCID: 2C020E1A7604B137125-8078
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB9400JVVL
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LAP000JK
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
02067 - Optical Databus; Unpermitted Wake-Up Request
            000 -  -  - Intermittent
                    Reset counter: 41
                    Mileage: 135517 km
                    Date: 2019.07.28
                    Time: 19:48:55
                    Voltage: 11.90 V
            000 -  -
                    Reset counter: 22
                    Mileage: 136540 km
                    Date: 2019.10.17
                    Time: 17:26:07
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14224000628002080002
   VCID: 44D246BAFE945977FA5-8010
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000168815195
   Coding: 0109080000000000
   VCID: 71BCDF6E91A69CDF613-8024
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0111
   Revision: 11001001    Serial number: 82330JF0026587
   Coding: 0205000001010100010102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
   ROD: EV_CamerSysteTopViewAUDI_005_AU57.rod
   VCID: 2B000D06738AB60F1BF-807E
   Part No SW: 4G8 959 107 N    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0039
   Revision: 11013001    Serial number: 014200785
   Coding: 0A3305C003
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 40DA4AAAEA0C4557DED-8014
   Component: TSG HR        H04 0212
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: EE040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6594BB3E55EE407F0DB-8030
0724 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Fault Frequency: 37
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:40
                    Outside air temperature: -43.5 °C
                    Voltage terminal 15: 11.0 V
                    Control Module temperature: 13.0 °C
Address 8B: Adaptive Cruise 2
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000052401127
   Coding: 0380AA1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0046 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Fault Frequency: 41
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:37
                    Outside air temperature: 14.0 °C
                    Control Module temperature: 0.0 °C
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 00660600031F037E000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313C1F6E51A6DCDF213-8064
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 35
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:42
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Frequency: 48
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:42
12583937 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 41
                    Reset counter: 62
                    Mileage: 135590 km
                    Date: 2019.09.17
                    Time: 16:38:58
12583970 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 62
                    Mileage: 135733 km
                    Date: 2019.09.19
                    Time: 15:44:06
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
          U1111 00 [009] - -
                    Fault Frequency: 35
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:42
          U1111 00 [009] - -
                    Fault Frequency: 48
                    Reset counter: 22
                    Mileage: 135590 km
                    Date: 2019.09.18
                    Time: 13:45:42
          U1112 00 [008] - -
                    Fault Frequency: 41
                    Reset counter: 62
                    Mileage: 135590 km
                    Date: 2019.09.17
                    Time: 16:38:58
          U1112 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 62
                    Mileage: 135733 km
                    Date: 2019.09.19
                    Time: 15:44:06
End----(Elapsed Time: 02:21, VBatt start/end: 11.7V/11.8V. VIgn 11.7V)-----
Yep, both radar sensors are completely off-line. Chances are it's something common to the two.
VadimBaldin
Finland
C?ID=383542
I think it's a communication problem, control unit for front left belt tensioner -J854- /control unit for front right belt tensioner -J855-
Pay attention to the time and fault priority:
U1112 00 [008] - -
Fault Frequency: 41
Reset counter: 62
Mileage: 135590 km
Date: 2019.09.17
Time: 16:38:58
U1112 00 [008] - -
Fault Frequency: 41
Reset counter: 62
Mileage: 135590 km
Date: 2019.09.17
Time: 16:38:58
Fault Frequency: 28
Reset counter: 62
Mileage: 135596 km
Date: 2019.09.18
Time: 13:58:52
